- Is there a date on the timing belt??
- help with rpm's
- intake manifold
- knock sensor
- Stage 2 Cams with Retainers
- Bouncy/High idle around 750 to 1000(maybe 1100 on a shitty day)
- window jet just ozzes!
- 87 integra Auto Tranny question
- downsides to getting an ls and dropping a b18c1 in it - or just get a gsr
- why does my car feel soo slow?!?!
- HELP! gsr engine vaccum lines...
- need help with exhaust (not which one to get though)
- DC5 Brake Upgrade?
- WTB 2000 GSR ECU
- blew my motor!!!
- hi there i am new here
- rear rotor removal
- WHat harnest to get?
- Pre-buy questions (burning oil)
- coolant leak?
- brake light turns on when i shift????
- CAR STILL GETS HOT?
- question on axles
- question! Manual driving
- hub!?!?!? help
- EXCLUSIVE CUSTOM COLOR BRONZE ANODIZED MOUNTS from INNOVATIVE MOUNTS
- wireing diagram for a cd player
- apexi ws2 saggg
- Alarm Wiring
- INTEGRA transmission swap
- ECU issues!!
- Super Sonic Blue Pearl!
- Rotor write up
- 94-97 taillight on 98-01 integra
- no spark in one cylinder
- rattle @ shifter
- are the worth $160?
- Help me get my 99 GS started
- 97 GSR WIRING HARNESS
- PVC
- jack points
- Any problems with an inaccurate fuel gauge?
- whats wrong with my clutch???
- RPM AND MILEAGE OFF
- B18C problem
- my muffler i just bought
- help. OBD2 LS and GSR injectors both the same right?
- Question about my head:B16,B18c,B18c1
- brake master cylinder help plz
- Just put in tranny, stiff shifting now?
- Megan Racing M-OE Muffler
- Hondata ECU Question
- Want better gas mileage??
- Hole in the radiator (help)
- h22 injectors
- where is rpm signal?
- A/C compressor?
- looking around for dc2 oem fitment fog lights
- Car dies when given WOT or throttle too fast.
- Will these fit???
- --should i or shouldnt i?----
- How much???
- Unpluged ecu repluged it back in now Cel
- what sensor is this
- GSR Cams
- jdm b18c swap need help
- how to bleed abs brakes
- Will 98 and up tail lights fit 94 to 97?
- GSR Tranny problems.
- Averege drop..
- Quick Question
- turbo
- GC with shocks , Tein SS or D2?
- broken cluster lens
- built b18b head vs gsr head
- Common Problems
- Car broken into
- wat gas should i run???
- WTB gsr - b18c1 specific questions
- ECU connectors contacts part number needed
- knock sensor question
- wipers
- chipped ecu
- Question on 96 GSR
- installing sunroof
- Hatch fitament.
- DAs: What exhaust are you running?
- K20A2 In a DA Integra?
- heat shields are rattling?
- gsr rpm sputter problem
- chicago area....
- JDM obd2a GSR distributor cap/rotor identical to USDM obd2a units?
- Gsr Problem
- GSR REVVING PROBLEMS
- e manage help...
- About to buy a used transmission
- Excedy Stage 2 (3 puck)
- Factory Foglights?
- quick question.......
- How do I tighten timing belt? Pics?
- Maybe some of you can clear this up
- IDELING PROBLEM B18C
- Gsr Cam holder bolts
- does skunk2 lower rear control arm fit 92 integra's ?
- cam profiles
- USDM engines
- 90-93 integra with 91-95 acura legend lip??
- climate control swap
- tranny problems?
- LSD QUESTION FAST
- Car bogs on start up
- Knock sensor .. wiring on a b18a
- Exhaust Flange Gasket !! Imposible to find ?
- How much is it worth? v. center console
- Motor build for boost questions...
- Jerry Built vs. Prostreetimports.com
- Electrical problem '01 GSR
- upgrading my suspension. help me with bolts to replace.
- Second Gen Integra Light Question
- How to Change a Distributor?
- Wheel Stud Replacement
- ------changing cluster gauge color-----
- Canadian Integra
- hydrolocked
- Heres Updated Pics Of My Teggy
- did i get ripped
- Ball Joint dust cover HELP
- rust problem
- ecu is throwing a code 7 and 12
- idle issue
- changing out the cam plug on a b18c1?
- Need help ASAP!!!!!
- itr conversion dc2 headlight wiring diagram?
- 240cc Peak and Hold Injectors for 95 Integra gsr?
- 95 b18c1
- Transmission or axle ??
- master cylinder resavoir
- what do you think...need immediate answer
- Windshield wipers
- CLUTCH SAFETY SWITCH????????
- valve cover help
- tein srings???
- how to tell the difference between JDM and USDM ECU's
- rsx muffler (especially 05-06) on DC2 pics
- Drove through puddle! HELP!
- to pump or not to pump...
- Intake Butterflies on stock 01 GSR manifold
- cylinder 4 misifire (code: P0304) HELP!!!
- Weird ABS problem
- 01 ITR intake cam and CTR cam make comparable gains ?
- skunk2 chip
- ecu, which to get?
- help asap
- how do you do a 94 abs conversion to 98 up abs?
- windsheild wiper
- jdmshit lips
- aem big brake kit
- exaust rattling on idle
- Front Wheel bearing replacement write-up?
- spoilers
- how i got out of a fix it ticket
- Dc2 Dash Board differance....
- Linear pedal feeling after Stainless Steel lines...
- CAR shaking?
- No engine check light
- how do i increase my horsepower
- battery keeps dying
- Picture request: American Racing Wheels
- axle question
- best exhaust
- 4 door -> 2 door front seats?
- dc5 cluster in a dc chassis
- Can I use LS spark plug in a GSR?
- water in the carpet.
- 1995 teggy shell w/ full RHD conversion
- questions about boosting an LS engine
- Check engine oil light
- just did a swap and turbo please help
- revlimit on a 91 ls integra
- Radiator Fan ???
- Timeing belt question...plz help
- Is type R spoiler wrong to put on LS?
- Help with window visors
- Ground Control on Stock struts
- Skunk2 Coilovers w/ shocks
- will honda fit HFR rims fit on a gsr integra?
- vibrant muffler not quiet
- How do install a windshield
- wanted a obd2 integra ls valve cover,
- losing the wing on my GSR
- turbo coolant lines
- integra type r front end conversion
- pic reuqest 1.3-1.5 inc drop
- DA integra shock options...other than the obvious choices?
- Dash questions
- Car boggs at 4500 Pulls hard at 6000
- transmission went out neeeed help please!!!
- b20 into 91da
- shocks - aligning brake bracket + upper mounts
- O2 Emulator
- Need help with CEL 5 Map Sensor, im boggled!
- What kind of lip is this?
- what should i do left over body parts?
- pilot bearing
- Painting LS wheels
- HELP... Alot of smoke (oil steam) coming out of the valve cover
- DA's:What header are you running?
- car dies help!!!
- 98 integra CEL on and blinking -even after tune up
- Camshafts XS POWER - Stage II - Info Needed
- Yellow Film > fog lights
- Hi I'm NEW and and some HELP!!
- skunk2 cam shafts good?
- ls/vtec....stock gsr w/ greddy kit....neither......
- smoke
- port and polish job
- b seires swap parts
- Tie rod end question ?
- Burning tons of oil!!!! HELP!
- Mobil 1 VS. AMSoil
- Right Hand Drive?
- Stock Integra Injectors w/ resistor box?
- So, my DA got a little fugged up tonight.
- Does my car have to do emissions??????
- Skunk 2 coilover spring rate ???????
- Will I have problems swaping a obd1 LS block into obd2 teg with ob2 v-tec head?
- I JUST DONT KNOW!!!
- Rebuilt engine now smoking / something in the cylinder
- DA Aluminum Radiators
- Megan Racing Drift Spec exhaust...
- Now What?...Advice Needed
- Noob up in here !
- How do I take off my head lights? 1991 integra (NOOB I know)
- Brand New ITR muffler for sale
- 2dr ITR door panel on 4dr ?
- Car will shutoff sporadicly... NEED REAL FEED BACK~!
- Help: Where can I find a DC header downpipe gasket?
- interior compatibility
- Oil Pressure Build Up
- Speedo jumping when I start my car
- rs times
- harness Question
- wtb gsr blades
- Just did timing belt...now whinning noise??
- Drilling a Hole In My Firewall For Power Cable
- Slow clutch disengage
- gauge lights are out and dash lights....
- Fun with Paint
- Confused on setting timing.
