- how to remove ABS?
- 4 door seats in a 2 door? anyone try before?
- 5Zigen fireball technology(???)
- Is it troo..
- Pics and a Video of the Spoon N1!
- Pics and a Video of the Spoon N1 on my Integra GSR!
- stock timing question
- Window Molding Mold
- 98 ls cr
- just finished rotor/pad install and brake bleed.
- I think I ruined my ECU Harness!!! Help Please!!!
- removal of ac
- Fuel system
- GSR intake manifold wires.
- quick radio question
- cv boot damage
- which wheel comes wit?
- A question for all you 90-93 integra fans !!!!!!
- Average Air Fuel Mixtures
- Any Advise???
- HELP!! uhh.. my motor's runnin.. but my $hit aint goin newhere!! why?
- B&M Fuel Pressure Regulator
- Rattle near intake manifold
- DC 4-1 or Comptech 4-2-1
- Honda Junk yards NJ/NYC
- skunk2 short shifter aint so short..
- Carsound Cat pics...
- 94-97 LS suspension Vs. 97-01 type R suspension
- leaking clutch fluid?
- gsr's LSD?
- ACT clutch/flyhweel and Tokico 5 way adjustables installation.
- gsr tranny is makin winding noise
- suspension question
- Wiring Diagram for 95 GSR NEEDED!!! Help PLEASE!!
- slight camber changes in the last 6 months (stock suspension)??
- which flywheel
- suspension confuses me but heres a question thanks....
- noise from tranny
- will the 92-93 GSR tranny fit on to 90-91 LS
- Boost Gauge help!!!
- Stock clutch break-in period?
- ls head gasket
- Pillar Pod Install
- doing my tune up tomorrow ?'s
- H&R Sport/KYB AGX vs. H&R Sport/Neuspeed Koni Yellows - My story
- need help with apexi worldsport exhaust
- do they make 4 dr integra spoon replica mirrors?
- It's About Time!
- OBD2-OBD1 conversion harness GB!!!
- 'oo gsr w/obdII testpipe
- is the bomz high flow cat off ebay any good?
- which camber kit?
- tire size
- Honda Camp!
- ITR rear sway bar on 4dr?
- How much brake fluid do I need?
- Do the silver dots on the wires coming from the ECU mean anything?
- how many users
- Whats the best LSD for a GSR?
- noobie question
- redline for 94b18c
- tanabe hyper exhaust
- People with H&R sports??
- Powerstop cross drilled rotors and why they suck...
- Price of JDM ITR Front end
- Baer Big Brake conversion?
- auto torque converter
- Alignment Done Today.. Before and After Settings.
- just plain white gauge face covers
- taking out bypass valve, what to use
- jdm gsr advise???
- stock ls static fuel pressure...
- JDM front, or 98+ conversion with new paint?
- rods and Piston question
- Js racing intake?
- got quoted $250 for brakes
- usdm motor racing shop in so cali? who does work good n good price
- HKS Dragger system for my GSR
- Do you understand why these Honda mechanics believe this?
- How do I change my icon( this little smily face)?
- When is the next honda or integra meet in chicago area?
- JDM folding mirrors
- Anyone get a check engine light #91..Fuel Pressure Sensor?
- For those with skunk2 intake manifolds
- JDM v.s. DC
- Install DSM Injectors
- fields sfc-vtec
- Need advice on aftermarket rear
- anyone swap 94+ seats?
- LS motor top dead center
- Will AGX's withstand lowering?
- Thinking of spray painting parts of my car
- DC Sports 4-2-1 vs. Comptech 4-2-1 for LS?
- How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!!
- My Strut Bar?
- neuspeed race ?????
- Good deal?
- springs that work well with stock shocks on a 92 gsr?
- motor swap opinions needed
- marks on ITR cams (yes i searched)
- Coilover ?
- Tweak goes on a diet...
- TYPE-R stereo
- Tire Poll
- Air/Fuel Gauge Install
- sleeper exhaust for DA's?
- My big loss and Future plans (lots of pics)
- might have blown something on my ls
- Wind deflector clips, where can I get them?
- 98 ls bill gude
- AEM Big Rotor OE Caliper kit
- any supercharged gsr's out there?
- scattershield required 11.99 or quicker?
- Whistling Sound Coming From A/C
- brake fluid for my integra? where is bleeder screw.
- any one know anything bout rsr header?
- Greddy Exhaust Setup On LS
- brake and clutch master cylinders
- Physics 101
- Could 3rd gear popping out be related to a bent intermediate shaft?
- Am I paying too much??
- radiator problem?
- problems with my left front tire
- How Can I Tell If I Got A Real JDM type R Tranny W/ LSD
- lost vtec?
- which pedals should i get?????
- will 94+ oem cd player fit in 90-93?
- Want to put OEM badges back on (emblems)
- Distributor Question?
- sypmtoms of bad fuel pump?
- catback exaust
- Pics of APC metal fenders - 1000251M
- Apex n1 rear section for 94+integra
- Specs..?
- ACL B18A bearings on a B18B?
- anyone with a 3" exhaust they dont need?
- Got a ??? Engine harness
- used mugen front bumper
- 1/4 mile times for GSRs
- Need your opinion for an Integra T Shirt design
- How often do you clean your intake filter?
- Another tein question
- sensor locations on 94 b18c1
- My doors don't line up correctly
- Just upgraded my brakes
- 90-93 cluster will the gsr cluster work?
- spark plug wires?
- Suspension bushings?
- Attn: HIDS user i need pics of were u guys mounted ur ballast.
- Scrapped up my left front side(pic inside)
- kyb agx: look at this price quote...
- ITR valves and retainers???
- New Integra Parts Website
- what kind of power???
- www.raxles.com any good?
- best exhaust and clutch/flywheel out there for the price.
- question to anyone on a 96 integra if u could put a 97 throttle body type R on a skunk2 intake manaf
- Question about ECU's for a 2000 GSR
- whats the total price for all parts needed to put in type r rear sway bar?
- 2000 GS-R for $13,300
- dyno tuning and or tracks in south eastern MICHIGAN ???
- OBD2 to OBD1 Conversion - Secondary O2
- Oil on sparkplugs #2 and #3. is it the sparkplug gasket?
- I need a weight loss plan...
- Are these worth 60 bucks?
- Dyno tuning in so cal ,whos good ?dynamic ? importbuilders ?r&d ?
- i am in love with my itr rear swaybar.
- Tach Problem after OBD2 to OBD1 Change!!!
- how hard is it to do brakes?
- 215/45/17 tires too big?
- Tire recommendation please?
- Axle back !!
- AEM Fuel Rail & Fuel Pressure Regulator
- '91 Integra exhaust
- Will a '99 stock exhaust fit one my '96?
- NO i hate thieves!!!!!!!!!
- Which muffler?! Es or ITR?
- front and read lower tie bars
- Which clutch?
- Condensation on front headlights.
- Help plz I need a radiator overflow bottle(WTB)
- dc2 tail light question
- Indeglow glue
- buying a new motor....what should I be looking for?
- d series alternator
- Club Owners and Autolock Owners watch out!!!
- just bought a gsr...is there a way to tell if the odometer and motor go together???
- Comptech ecu
- Type R axle back vs RSR axle back
- DSM 450cc without V-AFC?
- Apexi N1 exhaust
- exhaust for 4dr
- HELP with a ticking noise!
- Outboard CV Joint removal?
- Q for those with AGX/Comptech springs or AGX/Eibach prokit combo
- Crazy stuff just went on with my car...
- Very STRANGE SOUND coming from my parked teg...
- is my auto tranny going?
- PLEASE HELP!!!! Cat install went bad
- skunk2 exhaust
- Need serious help. Major Problem.
- Buy one or the other: Factory Service Manual or Helms Manual
- how much are stock shocks and springs worth?
- crack in windshield
- Help!! got flatbedded home
- LS oil pan same as B18C oil pan?
- requesting diagram of wiring behind gauge cluster
- how to find abs code?
- replace rotors?
- mugen strut bar install.. difficult?
- my brakes shot?
- lean or rich?
- Weather/Rain affecting my transmission/clutch???
- Having a litle problem with idle?
- New Springs
- Turbo kit for 90-91 Integra?
- B18B Cam Seal Change
- I need my car tuned on a Dyno
- 98 acura integra LS
- type r clutch flywheel in b18b1 tranny?
- Aerogear vs. ViS
- idle at low rpms
- how to get more torque
- downshift-accelerate-BOOM!!!
- Part number for NGK-R
- weight question
- weird question about VTEC head
- the best overall honda B block
- 9005 headlight question
- Smoke from the engine bay?
- 95 Moonroof Problemz
- Quick, which wire is the primary o2 sensor wire needed for an A/F gauge?
- 92 ls rear brakes??
- Beeping when turning the key to ON
- ECU help!!!
- 96 integra sway bar sizes?
- Compression Test Numbers For my 98 LS
- Will this setup work? What else will I need? Help!
- front Teg Forks?
- B18A okay to put in 94 LS in CA??
- diameter of apexi dunk mid-pipe???
- protecting the Apexi N1
- Ridiculous Mileage!
- 'need to resurface rotor?
- will a fluidyne radiator from a 95 integra fit a 92???
- need help asap please: type r distributor in a gsr...
- please help me right-hand ITR front clip
- do GSR's come stock with LSD
- Do not buy from www.tracracingparts.com
- need help guys...fpr related
