View Full Version : Acura Integra
- JDM Type R FENDERS NEEDED!~
- confused about this guys swap
- Help Converting 9005 to low beam
- Exedy organic racing clutch...
- Need Some help!
- KYB AGX's / Tanabe Precedo's
- Benefits of ITR flywheel in gs-r tranny?
- 94 LS Firing order?!
- Anyone with 98 LS or RS....
- First time racing at 1/4 mile track what should i do when i get there to prep?
- Action clutch?
- Sticky tires and rocks on the road
- Dyno results from mid-March.....
- lude vs. teg
- R-Bar is in!
- Bolting on a JDM DC 4-1 Header..
- anybody running an LS turbo? if so, what all do you have done?
- any body heard of or are using a Ractive cat
- my GSR almost STOLEN
- Anyone here have the Comptech rear sway/tie combo?
- Intake/Hearder really increase hp?
- Rusted cat bolts, need info on installing catback.
- times for a 4dr ls/vtec?????
- Need new tire..any suggestion
- How much can I expect from this setup
- B18A1?????help
- Tips for taking off stuck oil filter
- 88mph = 15.9 78mph = 15.6??
- opinions on which route to take next with my teg?
- DC4??
- JDM integra
- Acura sticker/emblem/thingie?
- Weight of my 00 GSR rims w/tire (pic)
- I Need...........
- Hollowing your cat
- funny noise coming from the blower or heater?
- 96-97 vs. 98-up JDM ITR engines
- RS-R/invidia
- What exhaut sounds like a bike exhaust???
- What would win.
- probably covered many times but...... Spoon N1 or Apexi N1??
- How far can I go with ITR cams?
- skunk 2 IM w/itr aem cai vs gsr intake mani w/gsr aem cai
- radar
- Anyone need? Type R swaybar on Integra/Civic
- For those of you wondering about the Apex N1
- headlight mods????????????????
- loud clunking
- Dangit! what's the brake bleed order again?
- short ram vs CAI
- short shifter?
- Possibly going FI?
- What types of exhausts sound good?
- GSR Secondaries
- Skunk2 cams
- 10w-30, 10w-40 or Honda MTF for my 94gsr tranny?
- My stolen car was recovered. Pics inside!
- Does anyone have pics of that teg with the widebody kit that was posted here?
- New/Used Interior pieces?
- Anyone have the Mugen thermostat and switch installed?
- 95 gsr and 00 si flywheel=same?
- Help! with lights?
- Shocks, springs: My set up sucks
- Will a 4DR LS Exhaust fit my 4DR GSR? Both '95's. Need to convert back to stock!
- FS: Non-Running Integra
- Driving with out a cross member
- How much stiffer is the neuspeed strut bar then stock gsr strut bar?
- Built LS head
- Acura engine swap question.
- high flow cat
- OT: Anyone dealt with Torn Active???????
- Need help
- Removing Harmonic Balancer
- Rear brakes from the RSX will fit the Integra...
- well..
- Turbo Si VS Stock C5
- Straightpipe a GS-R?
- squeeky hatch??
- Could i get 200 at the wheels??
- valve adjustment
- Tranny Bolt
- how can you tell type r cams?
- comptech header question
- How many have Eibach Pro-kit? Comments....
- Street racing laws in Oregon
- Brakes: Diferences in master cylinder
- My car was stolen =(
- 2000 sivic si tranny vs. gsr tranny
- Noise coming from front drivers wheel??? Help please.
- To anyone with a helms manual
- Power drop at 3k???
- Skunk2 Stage 1 cams
- skunk2 stage2 cams vs. ctr cams
- Tire pressure for 205/50/15s??
- 2000 Header on a 2001 GSR?
- redline trans oil
- Anyone going to NE dragway Friday?
- Just got my honda, new to board
- Does anyone have a diagram of the stock shock assembly?
- Engine build up....most power
- Swapped distributor, car still will not start up. No sparks!
- slow down by subs
- Light Condensation...How do i get rid of it???
- Gurgling/Sputtering Sound from Engine
- valve adjustment??
- putting on skunk2 IM on gsr tomorrow, any tips?
- 90 teg help ??????
- GSR icebox fit in LS?
- Need Help: Wirings for PIVOT A/F Monitor
- M3 Carbon Fiber Mirror or JDM ITR for a 4door: anyone knowwhere to fine one?
- whats the difference?
- test pipe?
- 5zigen or Apexi N1 Exhaust?
- using an H22 TB on a ITR / skunk2 mani?
- anyone Have a build NA b18b??
- gsr cpu question
- Timing belt on GSR
- Does anyone in the Bay Area have an Exhaust Box?
- spoon thrmostat and fan switch
- questions about adjustable shocks
- I dont get it!! Someone explain!
- stock tach error
- Clutch for my setup?
- Exhaust help
- APEXi WS sound clips?
- I'm just one big idiot!
- Wheel Recomendations.
- How to pass CARB with a skunk2 itm?
- b18b1 redline...
- R the Drag and Greddy Turbo kits legal?
- imoto.com
- Question about Koni Yellow perch and alignment...
- Newbie Question: Door locks
- 94 LS ecu wiring
- Best Prices for Pro-kit and Koni yellows, who has 'em?
- How can u tell the difference between a b18c5 head and a b16a head???
- mini speedring meet 4-4-02
- :::HONDA-TECH BBQ IN VA:::
- Whats faster?
- Does Mobil 1 brand motor oil still have the same formula as it did 2 years ago?
- Port & Polish?
- Koni Yellows with sportlines
- How to Rev and LS to 8000....look inside
- need help with engine swap
- Camber kit
- INTEGRA MEET IN NORTHERN JERSEY
- Lets Discuss Centerforce Clutches
- crower cams?
- Flywheel
- lowering springs
- sorry miss jackson
- Stock CD player (already posted in the audio/security forum really slow)
- I WANT CAMS?????
- How close to a 1.0G cornering force will I be able to obtain with my new setup?
- Best Way to Sell My GSR?
- My Teg on the Prelude thread...
- New Member, just checking in...
- Re: Honda Motors Online
- Check engine light
- Once again, my intake cam will not move.
- need a CARFAX report
- Bridgestone SO-3 pole position ownz joooo
- Engine noise in a GSR
- who the hell is the red GS-R in DC, lowered on Spoons
- weird noise after Apexi WS install
- would honda/acura brakes fit on a neon??????????
- where to start
- ITR 5 lug conversion?
- itr aem cai on gsr
- Buying Camber kit...Ingalls or Progress??
- Gettin a teggy
- integra gsr rims
- k&n filter cleaning
- Skunk2 Coilovers.... now which shocks?
- Car won't start. Car stalls out while driving. HELP!!!
- IMPORTANT *** does the 2 door 98-01 Bumper fits the 4 door?
- Header for my set up?
- Removing 94-97 "Grill Bar"
- What kind of gains to expect from spoon gears?
- valves good after something stupid like this?
- Anyone using the Phantom grip LSD?
- Whats the best Spark plugs to use in my GSR
- engine weight?
- Acura weight
- Is this a decent price??
- ITR suspension
- 15" SSR 265 Black face with a polished lip...extremely clean
- Whose 2000 GSR did I testdrive in Albany, NY?
- Turbo Gauges
- b20vtec w/12:1 comp
- help me decide with suspension!
- Cold Air Intakes....
- Thinking of Selling GSR..Testing the Waters
- dyno service
- Which header r u GSR drivers useing??
- Dropzone Coilovers?
- Maybe you guys can help me out...
- Oversized Valves........
- Engine Gurus! Give me your advice and opinions on my planned B18A build-up!
- Sound System
- Which springs are better for ride, cornering, etc?
- LS/Vtec Reliability?
- STop my breaks from squeaking.....
- need help !
- In your opinion, the best performing tires for daily driving and the track!
- itr tranny = 99-00 civic si tranny with itr lsd?
- question about Tein damper adjustability
- Apexi SAFC???
- What is the going price for a stock GSR motor with Transmission?
- how good are toyo proxes??
- Safe amount of nos?
- Question about civic si and gen2 teg
- other parts needed
- Best Brake pads for daily driving??
- First ever track day.
- Maintenance
- overboring TB
- Sportline/Konis? Tein ha's?
- how to check the authenticity of an itr tranny?
- jdm vs usdm itr tranny
- Fuel pressure for LS?
- New World Record for fastest front wheel drive all motor
- Is the radiator support needed for JDM conversion?
- Brake Balance: Front & Rear...Which Does The Most Work?
- if I buy a carsound cat....
- taffetta white or frost white for repaint?
- o2 sensor and ecu problems
- Crap!! (Oil in heater system?)
- radiator removel
- Help!!where can i find a type r or GSR rear lower arm? the one on my car is a wrong one
- anyone have instructions for auto shift knobs?
- GSRs and pinstripes
- Whats the best bolt on high flow cat
- falken azenis??
- What next?
- links?!?!
- how much hp can prelude injectors handle?
- lug nuts
- lowering questions
- swaybar on a damaged car?
- CatBacK that is quiet
- Installing Guages
- question abuot 'conversion'
- Spark Plug Wires and Plugs
- JDM Type R Conversion
- gsr vs itr flywheel
- jdm itr tranny im my gsr for $550...
- how hard to rebiuld tranny?
- Tokico Shocks?
- Powder Coating in NJ?
