View Full Version : Acura Integra
- Lights come on when braking
- jdm teg wheels
- sell it or keep it
- Tranny CRISIS pls respond ASAP
- pre-mods???
- Lighting problem
- idle problem, what you all think?
- OBD2 motor in OBD1 Car
- ***How-To*** Check & Clean Your Front ABS Wheel Sensor
- Timing belt tension question help?
- Steering
- 90 Integra Suspension >>help<<
- LS clutch in a GSR
- throttle body upgrade.. worth it?
- How to fix squeeky clutch pedal ???
- ctr vs itr
- Scratching 5th gear
- alternator plug conversion
- new seats for my DB8
- B18C1 - high steady idle?
- WTB DC 2 carbon fiber hood and trunk
- ac with turbo
- Looking at a potential Integra to purchase but Ignition/Key problem?How to swap lock Cyl?
- Valve Train Advice
- need help were is the pcv located
- Ls alternator amps obd1
- ***Stolen 93 GSR socal***
- break-in for ITR Cams?
- Intake manifolds for non vtec's?
- hey h-t
- hey everybody
- head gasket help
- where to get cheap JDM motors?!?!
- launching question
- skunk2 testpipe and apexi n1 combo
- Is it common for Integra steering racks to raddle?
- DA ground locations.
- how long do i have with my axle?
- a/c and pwrstrng
- question bout piston rings.
- Is more oil needed?
- B18 Headgasket install, Engine Gurus i need your help!
- rattling noise
- blox intake manifold
- Im not having a good week...
- strut tower
- Where to Buy RS*R ExMag? DA
- Water pump & Timming belt!
- GROUND CONTROL
- b18b rebuild parts
- 93 integra into an ef
- Help needed with Rims and Tires
- 3rd gear grind...
- ASDF HELP!!! ^_^
- shocks
- Apex VAFC question
- intake install question
- m2 race ported head
- ECU suggestion
- itr front sway bar install help
- Evap purge flow problem
- need help with my v-tec wiring GSR (pics inside)
- boost spike
- i need a O2 sensor
- pic request
- turbo LS coupe not starting
- getting out of limp mode
- WTF? Need Help
- disapointed
- need help with b16 pistons
- cant find a clean, stock, low mileage 94-97 GSR
- Question About my Integra NEWBIE
- How much would you pay for this car?
- Driver's side Autobelt not working on my DA.
- d-series in an Integra
- code 13. Baro Sensor. 91 LS. Internal ECU, or external?
- cap and rotor
- cant read abs codes
- timing belt help
- Headlights
- Civic 92-95 Air Bag in 2000 DC2
- Which FITV for Blox IM on a GS-R?
- jdmcarboy.com/rear lip?
- Need help finding airfilter
- F22B in a integra???
- clutch question
- this might seem dumb but wanna make sure
- Project GSR IN 90 gs Need help
- test pipe
- integra colors
- 94 GSr: Headgasket question: How will it effect the JRSC and a few other performance ?'s.
- Questions about brake pads
- b18 parts for sale
- Spark Racing Header Leak
- Fastest integra
- test pipe
- 2000 Civic Si Cat on 2000 Integra GS-R?
- extended warranty informatin
- TRANNY suggestions!!
- WILL LS TRANNY CASE FIT ITR TRANNY???
- kakimoto R or HKS super dragger exhaust system??
- clutch going bad?
- kakimoto R or hks super dragger exhaust??
- Clutch wont disengage..
- 88 Integra
- ys1 tranny, never got a straight answer
- lash valves for skunk2 s2 cams in gsr
- self port and polish b18b head
- old school b20
- taffeta white and championship white?
- it's good to see someone building a ls motor
- need a place in san diego to get wire tucking done
- good paces to put my gauges
- wat set is best for turbo
- turbo questions need help
- strange vibrations
- mysterious slow coolant leak?
- Best plug wires
- window visors for DA
- Damaged Rad/Core Support
- rear brake bolt
- Carbon interior
- 1997 Integra GS-R???
- dumb question about fuel filter
- > New Axles = shaking during acceleration
- Will an RSX Type S muffler fit in a GSR?
- stock brackets with racing seats
- Idle surge?
- What it takes?
- Adding 3 Wires for Vtec and 1 for o2 sensor, B16A Swap DA9
- 92 GSR: CEL and no vtec?
- Exhaust question
- will this exhaust system fit? (searched)
- How to get an extra 30hp on a stock GS-R?
- WTB B-SERIES TRANS ASAP
- volk racing rims? ? ?
- Whew! :O:O:O
- Question regarding rear subframe reinforcement brace
- bought an integra tranny need help
- rad drain plug on a 94???
- SRS removal for new steering wheel HELP
- NEED HELP!
- engine RPMs get wayyyyy low when CLUTCH is depressed??? problem
- Replacement Bulbs for Gauge Cluster?
- Shart Shifter. lame
- problem with the DA
- Valve Adjustment QU's
- back seats
- bogging problem on my DA
- hollow my cat ? pro's and cons
- gsr clutch is messed up?
- my gsr is messed up
- Just Finished Another LS build, Ready for Dyno in a few weeks!!!
- Wierd problem with my 95 DC2
- Anyone in Springfield area...engine swap and 5sp conversion
- CLUTCH NOISE!!!
- is an ITR flywheel lighter than a B16 flywheel?
- need help for my ls block
- Oil Burning -- PCV Valve?
- 94 GSr burping water out of the radiator and overflow...
- V-TECH head
- JDM HID Front Install....With ABS ???
- WTB STRUTS/EXHAUST/INTAKE 90-93 integra
- LOL GAYNESS, i want to burn this car
- test pipe for a db7
- low idle in neutral n first
- clutch break-in?
- just bought a 92 integra
- check engine light is on and speedometer not working
- post pics of fat fives on your integra
- GSR with Type R Badges??? LOCATION
- exhaust comming in where from?
- Wireing Help Needed asap! (please look)
- C-pillar Bar for DA fitment
- EG9 rear seats in DB8
- EK type R optional Spolier on DB8
- 95 ls teg tranny question..
- Thin Sidemoldings, which one?!
- pr3 pistons?
- MY '99 SSBP
- new teg
- my 95 GSR got SLAMMED.... RIP 4-2-06
- 1600 bucks, what path do i take?
- my 95 gsr turbo build :)
- Aem short ram intake or cold air intake?
- short shifter question
- putting nos on b18
- Use clutch break-in?
- What size rims look the best on the Integra?
- Opinions on D2's
- RHD with LHD firewall?
- 1.8 l dohc sputters when i step on the gas
- tuning help / advise..
- dc sports exhaust
- NEED help with JDM corner lights! JDM FRONT OWNERS!
- radiator size
- Stupid steering wheel noise
- 1990 LS block need tips
- lug nut bolt stripped
- weird problem after tstat change
- Tranny fluid?
- how the fu*k do you learn how to do distributor/ ignition timing?? possible or what??
- VAFC on stock p72 computer?
- Quick question Bout Omni Coilovers
- painting block?
- LS Vtec Question
- DA headlights (searched)
- 97 teg tranny problem help.. help
- CAI in the rain with no bypass valve
- gsr vs. itr tranny
- Wiring Vtec Questions????
- Wheres the drain plug for the water on the b18c?
- manual steering rack.
- chrome valve cover
- I NEED TORQUE SPECS ASAP (I DID THE SERCH ALREADY)
- oil cooler?
- wheel studs replace . need to take the hub out ?
- 94 INTEGRA SR5 LIGHT FLASHING!!
- Chging MTF
- Please HELP! A\C Tech Question!
- b18a1 1990 clutch/fw question
- Torque
- Gsr swap,Iab prblem
- need help with side skirts!!!!!!!!
- whats missing
- Those of you with GC upper mounts.
- Obd2 dizzy colors?
- H22 OR TYPE R SWAP???
- Long term exhaust solution- Anyone owned their aftermarket exhaust 3+ years?
- car runs lean???
- hasport motor mounts?
- Stock resonator length on 00 LS Coupe??
- jdm b16 trans
- CLUTCH WORK.......diagnosis/ how long will it take??
- what ecu to use? P61 or PR3 in my 92 Integra GSR
- DC2 Making Funny Noise Need A Diagnosis
- B16 vs B18 tranny
- Speed sensor problem with auto to manual swap
- some pics of my car.
- Check Engine Light Question!
- Apexi V-AFC, your thoughts?
- Need help on identifying cams.
- Radio Install help
- Hey I'm new to the forums
- post directions on how to take off spoiler on a dc2.
- I'm going to sell my TEG, give me advice.
- Intake Manifold help!!!!!!
- what is the deal with JDM engines not being smog legal?
- Problem after the intstall of valvetrain and cams................
- anyone know site that sells front lips for different kind of honda's?
