View Full Version : Acura Integra
- think I screwed up my gas light..
- Reputable shops in Clearwater/Tampa Fl area for rebuild
- Link: F/S: Spoon Strut Tower Bar (Rear) For ITR
- rs into itr
- check out this clutch
- Where are the bottlenecks in a full ITR exhaust system?
- putting some extra nuts making the camber more straight??
- H.I.D
- jdm armrest removal thingy install how to?
- What do you think?
- Whats the going price on a used Apexi W/S exaust
- O2 sensors and OBD1 conversion...
- installing jdm b16a in 91 rs please help
- G2 JDM headlights
- Header problem
- TEG FOR SALE ! ! ! ( Chicagoland)
- fuel rail/line
- What Kinda Wheels are on this Integra ?
- hit rev limiter @ 7100 (??)
- changing my tranny fluid.
- Maintenance required light blinking when starting car
- paint jobs
- Quick Question
- I caved in and bought the car!
- Is there a gasket between the 2 parts of a header?
- what to do with $8000.00?
- what weight of oil?
- Its a Greek Tragedy!!!! not for the faint of heart!!
- anybody know any rim fixing shop in san jose or nearby cali?
- alternator power???
- cap and rotor ?
- AUTOLOCK saves the GSR!!!! (This time it did....)
- Almost became a part of the integra family.. Now im kicking my self in the ass!
- my setup for next year!
- is a skunk2 exhaust loud on a 99 LS
- car keeps popping 100 AMP fuses!
- oil 90 integra ls (how much) ??????
- Help on Specs of a 3rd gen LS
- dyno question
- Taking out Center console
- What do you think of this grounding kit? HKS style...
- Difference in 94-99 LS and GSR exhaust.
- DA pics... post pics of DA's only.
- will the complete jdm itr center console fit in a usdm gsr
- coolant hoses?
- Professional Integra tuning in the Midwest (Missouri)
- water pump bolts....PLEASE HELP
- Integra Transmission LSD
- 95 gsr, will a 99 si axelback work with no modifications? Quick
- What would i need.....
- jdm kit queries
- Easiest way to pull the axle out of the transmission?
- Type One vs T1R
- People in New Jersey who have had their tegs stolen..
- oem repair manual
- what's wrong when it does this?
- one more question about coilovers
- valve adjustment tool
- Ball & Seat and Disc Type Injectors. WHAT?
- ITR parts on RS?
- Look At my SWEET pictures
- WTB: CTR intake cam or JDM ITR intake cam
- Whats the differnece of peak and hold and saturated??
- Look at this
- Tool shopping list for head removal?
- 8.9 flywheel too light
- Winding noise in first gear at slow engagement...
- BURNED 5 QUARTS IN 1500 MILES... TIME FOR REBUILD????
- head bolts wtf?
- thinking of itr springs on the wifey's 4dr
- getting good deal on JDM front.. what to look for? help
- Whats your favorite color integra
- Integra question for friend.
- What exhaust for turbo setup?
- b16a pistons or b18c5 pistons which is better?
- Painting side moldings...
- tranny swap
- exhaust system
- san diego shops that do good work on integras?
- NEED HELP: Anyone ever got a 4-8 ABS DTC code? and how to fix?
- infamous stock header...again
- NEED HELP: What psi I should get when doing compression and leak test on stock 94 ls
- Help I smell an oil burning smell, but I don't see any leaks.
- Welp, the Tokico's are on, Greddy Evo is tomorrow!
- GSR AEM CAI IN LS TEG!
- can anybody verify this?
- voltage are reading low!
- need help from gsr owners
- $Gearset$??
- Mechanic in Delaware or Chester County, PA?
- Looking for Integra Parts
- b16a2 head on my b18c1?
- g2 suspension tips
- placement of the o2 sensor on stock 97 gsr header
- my integra DA..check it out
- MSD 6al install question..
- GM synchromesh W/ friction modifier or W/out
- Ebay HID kits
- civic si 99 ecu fit in a 99 civic hx?
- 98-01 rear bumpers 2door 4door the same??
- Coolant Temp Sensor
- b20 in 2nd gen teg????
- need help
- Question about raising coilovers
- Ignorance...ClubSI
- Really bad shaking when i step on the gas!
- Benefits to powershifting (flat-shifting???)
- OT:98 integra headlight
- keyless entry remote
- spark plug wires
- Flywheel cover..NEEDED 1988 LS Integra PLEASE HELP
- arp head bolts for ls vtec
- Oil Drain Plug Gasket
- DA integra swap
- stripped bolts
- is my header supposed to have a o2 bung?
- Who makes the Quietest Aftermarket exhaust?
- roll cage in DC-2
- for all you b18c1 people
- Need to buy! Charcoal Canister, Purge Control Solonoid ect...
- To those of you w/the Power Steering removal kit and have had it a while...???
- gm synchromesh.. where to buy?
- $80 a good deal for used AEM CAI?
- any local (So Cali) people willing to let me test your P28? or u test my p28?
- B16a2 with ls Tranny
- HELP: i need some answers quick
- 93 for 91 teg?
- are rods for a b17 in great demand??
- Where to buy a JDM Type-R or Edelbrock header for cheap !?!
- b18c1 bogging heavily, but only after i shut down the engine and turn it back on.
- Header selection choice 4 gsr - Specific tho - BEEN SEARCHED :P
- Check engine light code 22, VTEC System Malfunction
- Leak in my Header gasket!!!!!!What do i do???!!
- Projector is "glazed" over need help!
- Rear camber problem...
- Does Apex-i Make a 3" Exhaust?
- mods to JDM front???
- New product For those building their motor.
- budjet DA
- which HID fits the Jdm type r headlights?
- b18c into a 1992 integra. question with tranny
- Horsepower and Headers question???
- Comptech RACE Header??
- Rotex Brake Pads
- 94 teg clutch on 92 Teg motor fitment??
- anyway ill get lucky and my 15" kosei k1's will clear an AEM brake kit???
- My quest continues...
- come on!!!!, thanks for all the help
- Maintance REQ light and beeps PLEASE Help
- Radio Double Din Block Plate
- How To Remove My Power Steering W/ Out Any Problems??????????
- what kind of exhaust on da integ
- Did all green integras come with only tan interior??
- aftermarket timing belts?
- gsr valve adjustment specs?
- Rear Defroster
- What kind of turbo?
- B18c1 Compression ratio needed for turbo?
- CEL after VAFC install
- H22 in a teg
- Can bad compression cause bad gas mileage?
- Suspension plan
- engine noise or exhaust leak?
- RS R exhaust
- Hi there new H-T
- portflow products
- for all u 5-speed swap gurus
- how long did it take you guys to break in your clutch?
- hesitates to start when cold outside
- quick noob question.. .
- Ignition Problem! Help! 96 GSRcoupe..
- Leaky CV Boot - Front Left
- GREDDY exhaust
- Need opinions on a swap...
- Noobish question, sorry =)
- BIG PROBLEMS WITH LS ENGINE??!!! It keeps bogging down and rattling really hard...
- ITR Rear sway bar - Anyone install one on their DC2?
- camber kit
- setting number 1 at tdc with a broken timing belt
- Will a turbo, Fluidyne radiator, and FAL fans fit?
- stock engines
- Battery dying?
- Bah, Teg Gets Leaky on Moving Day.....
- Loud Tick
- CEL with no code?? wtf is goin on?
- Civic SI/Integra strut bar
- Swaping Tein SS front/rear springs
- Just purchase my new suspension
- car wont turn over!
- OBDII and carsound cat...?
- Will a 99 hub and bearing fit on a 94?
- Free Valvoline MaxLife Motor Oil
- integra axle question...reboot kit??
- What air intake to buy
- Main Relay Clicking....???
- Turbo.. Worth the money?
- I went to track yesterday here is my results
- voltage blue pearl?
- Where is the Service Connector at?
- jdm steering wheel fittment?
- cv joint or axle
- sunroof
- Shaving Emblems
- rims were jacked and lookin for a new set
- Engine Overheating... and... heater stops working?
- What's the difference between Gen.1 and 2 for the mugen front upper strut bar?
- Aren't there any turbo kits for a 2001 GSR??? Why are there turbo kits for 94-99 and 99-00 but not 0
- Help me with my suspension setup...
- Spring Help! Eibach Pro's vs. Comptech Sport vs. Type R Stock
- Abs trouble???
- jdm front end install in bay area?
- where is the Pvc valve located
- question about air box
- exhaust rattle strikes, GOD NO! lol
- Will an engine harness from a 90 LS work on a 95 LS motor?
- Is this an easy fix?
- neeed help now
- Cheap online site for brakes?
- Code 13 solved: 2 Versions of OBD-0 PR4
- Might buy this block, how bad is this conditon?
- re-valving Tein SS
- Going turbo...
- which cars came with oil coolers
- Black JDM Teg Pics, please post.
- How far up to headlights adjust?
- Will getting an intake mess up a car?
- o2 sim for '94 GSR
- Stock Valvetrain GS-R rev limit?
- It finally happened to me, the teg is gone.
- Integra's with MSD's, show me the light!!
- wired up IAB on GSR swap, and...
- help fast
- Skunk 2 ball joints
- Need to overnight some items...Who is the best?
- Best clutch for an LS teg (soon to be turbo)
- Jdm Headlights Plug for Fog lights
- Integra HUB removel because of rust...
- maintaince question
- will a 92-93 bumper fit on my 91
- question about oil pan
- i stripped the stud, know the size?
- how are the stock speakers on the teg
- cant adjust my headlights?
- Does Acura Sell a hub with bearing already pressed?
- Where to mount HID ballasts in 94 GSR???
- will civic alternator work on integras?
- Tranny Questions !!
- need help plz...
- whats the spark plug gap for 94+ GSR?
- last three characters on ECU?
