View Full Version : Acura Integra
- Clutch issues...
- Stupid question, but interesting...
- need help on tranny parts
- how does a gsr hold to boost
- Newbie Racer
- timing belt tension...
- gsr with type r cams
- da turbo
- arp head bolts
- Reverse Lights...
- GSR with ITR steering wheel install
- 225/45/15 hoosier, 15x8 45mm on Integra
- ACG (IG) Fuse 96 Teg
- (searched) stock b18b compression ratio?
- Replaced Raidiator now OVERHEATING?
- what tha different
- convert 94 integra headlight to 98 integra headlight?
- trouble W/ dc2
- question about my rhd dc2
- Difference between obd1 b18b and obd2
- type r camshaft
- Removing cams, slide timing belt off?
- Suspension question, brands and such.
- brake fluid ??
- A bit new to the game, need an answer...
- valve tickin
- Engine Code on block and head. Quick question
- no rear sway bar
- Paint problems
- B18C1 BLOCK SERIAL NUMBER
- Circuit 8's on a DA Integra!!!
- Corbeau seat rails
- ASR Brace And ST Sway Bar
- Amber climate controls question
- good deal or not?
- auto to manual bolts
- INTEGRA Catalytic Converter (Interchangeable)
- Is a DC GSR and LS axleback the same exact part?
- 96 JDM ITR 4x114 suspension conversion into 96 GSR. ABS Problem. HELP!
- Need to know how to cancel a DA pawer steering...??????????????????
- what intake to use with gsr with aftermarket intake manifold????
- what is a good website to find headlight and tail light for my car???
- car wont start...
- check engine light codes
- how much does it go for
- idle air control i gotta ?
- do wheel bearings make noise???
- b20 harness
- Black thing by engine bay where all wires go in firewall wont go back in?
- starter rebuild question
- b18 h-beam rod question?
- Radiator Support Question
- quik question
- heat
- gsr . rpm dropped and died
- project 4 dooR begins
- HELP!! Cut wrong pipe!!
- CAR WANT START SOMTIMES
- 1st time at drag w/ stock gsr
- Just got results of CEL from dealer
- My GSr and Compression Test Results
- Squeaky clutch noise when engine is warmed up!!
- GSR Help Please!
- engine fan cfm
- I NEED HELP!!!
- A/C help please
- b18a/b upper t belt covers interchange?
- hi im new to ht
- what kinda kit is this?
- Black smoke from exhaust?
- nub here.
- eng fan problem
- Fuel Pump
- nood question i know...
- Did my clutch go out !?
- 91 teg seat help
- 94 to 98 integra conversion
- Post pics of your JDM tegs!
- Painting SIR-G Chrome Housing to Black Housing Question
- possibly over-revved
- skunk2 manifold bore size & throttle body
- Gas needle off
- lets see those lips DAs!
- need help with my 92 gsr!!!
- 2000 Fuel pump wire
- 97 GSR Sedan susp prob
- failed NY state inspection today
- 15x8 0 offset on integra?
- Is this 96 LS going to last much longer?
- Here we go! Sedan build
- Idle drops to 1000 when clutch is engaged while driving... Any ideas?
- blown headgasket????
- How much for a used ls
- how much boost on stock b18b?
- ta all the 94 ls owners out there
- OPEN MY HEAD AND IT WAS BRONZE
- Type R Crank Pulley
- How much should I offer for these seats?
- P72-1 and P72-2 Heads.
- any other sites like majestic honda parts for acura?
- Anybody know the owner of that integra? or someone have more pics of the car????
- Most non-destructive way of taking apart my Headlights on a DC?
- Lock out of tranny, squeeking from tranny*searched*
- NEED INTEGRA REAR BUMPER MANUAL DIAGRAM
- Your GSR MPG. Mine might be way off.
- Da gauge custer bulb size?
- Clutch is squeaking
- gsr/type r transmission cases??
- HELP WITH CAMBER KIT
- 92 Acura integra for sale 2,000
- How to tell GSR OEM Intake and Header.
- ITR calipers
- How to store car for a long time
- Maintenance Light
- trade my db7 for ef hatch???
- motor set up help
- Amber Gauge Cluster
- Pinched Coolant Line
- DA integra Bride seat rails. no brackets?
- eng running hot
- Da dash
- Can to much oil mess up your motor?
- cam gears/pulleys
- why doesn't my car pull in vtec
- 92 integra knockin
- run 20w-50 to help with oil consumption?
- help with 98+ rear bumper on a db8 94
- compression check on cold engine bad ?
- NEED HELP ASAP (oil problems)
- ABS problem???
- shipping ???
- 92 DA, gauge cluster swap, b16a swap
- What do you guys think? HP guesses?
- Anyone running HIDs in their tegs?????
- quick fuel pressure ? DA GUYS
- Integra lip kits?
- I have a problem with my 92 gsr
- B18B1 Auto Tranny into B18A1 possible??
- Help for a beginner
- in heated debate with friends and stuck
- LCA bolts on a 92 hatch
- CHeck out my 01 ls
- s300 tuning
- OBD1 jdm p72 = usdu p72?
- itr suspension into gsr
- valve job?
- B16 flywheel on my B20?
- cel system to rich bank one??????????????????
- How much would a total cost for a 5spd tranny swap for a 91 integra
- 90 DA black auto trans for sale
- cams
- motor price
- Pads and rotors.
- ok ive got dsm injectors from when i bought the car
- 92 gs-r got some money...lookin for best parts
- make amber tails red?
- looking to get cheap sportmax rims
- ITR REPLICA HEADERS
- Steering wheel coulmn
- mud guard question
- Aiming DA headlights... Help! (Searched)
- code 22? tried the common fixes
- Invidia Test Pipe ?
- used arp head studs yay or nay?
- da owners, tie bars and strut bars?
- Hi all, im new to honda-tech!
- ways to tighten shifter
- Paint Rims????
- WTB: 4dr integra gsr rear black/grey cloth seats.
- Is this a good Integra lip?
- car still bogs after tune up
- Another Noobie
- STOLEN PURPLE INTEGRA IN DFW
- leaking oil.
- suspension problem due to curbage. help me?
- help posting pics
- altenator question. help....
- first tb port job.....tips advice? critics welcome :)
- Phone no. for Beaks Products
- Check Engine Light Problem
- Check Engine Code 41 HELP
- Radiator Dying?
- integra P/S help
- DIY: Purchasing LED's for a Integra gauge cluster... UBER detailed DIY
- b18a1 b18b1 distributor
- DC2 Love
- aaronisthrowed vs APR JETTA
- RHD Integra Legal ????
- Installed 172 Deg thermostat in my DA, anyone running these? Thoughts? fuel economy?
- I need to know where i can find freeze plugs for a B18A1
- how bad ????? HELP!
- Distrubutor or Alternator?
- Thrust Washers
- 01 integra type r miss FIRING!! NEED HELP!!!
- I'm rich BICHHHH! ;]
- 5000 rpm bog
- Where can i find Honda Emblems ?
- When I had my car emissioned last, it seemed as although...
- quick question
- temperature gauge increases randomly
- Problems with my 92 GSR
- Distributor Rotor All The Same 92-01 ??
- tie rods?
- Are the Synchros bad in my Integra?
- Deck keeps poping out everytime hit WOT.. how to fix?
- car wont start after rebuild ...
- Piecing together a head for turbo
- dizzy
- A question about removing the filler beneath the Tail Lights
- best place to get a itr lip, painted!
- Apexi World Sport 2
- torque specs?!
- JDM RHD front clip
- ? about my oil
- Sparking/Ticking noise from ECU???!!! Boggy/Jerky ride at 3500+
- defrost switch question
- Just did A compression Test. Engine Geeks help me out.
- plug for 94 ls dist.
- need help with a superchared integra : problem car dies sometimes
- ls/vtec problems
- !!!!!!!PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
- Please Help, Engine Misfire!
- does anyone know
- msd 6al n 2 step help
- just got mono non srs itr wheel how to wire up horn?
- Yay or Nay to cluster mod
- getting rid of scratches
- sum1 broke in and ....
- intake manifold swap a 92ls for 96ls ?? is there a problem ???
- a/c condensor
- integra trannsmission fluid question..please help me out.
- QUICK HEADLIGHT QUESTION
- problem with fuses
- 91 Integra GSR Turbo For Sale $4700
- *****free mods?*****
- type r wing
- Oil leaking by headgasket?
- b18a1
- gsr secondary intake solenoid
- does the p72 look for the evap?
- need some help check engine light p0171
- skunk2 exhaust
- Valve clearance spec
- Air/heat not working
- OBD2 GSR HEAD AND OBD1 CAR?!?
- i need some help? on what to do
- Door Hinges make a creekin sound? grease?
- altenator question?
