View Full Version : Acura Integra
- tranny problem??
- question about power window switch.
- ITB's
- ant get axle out of the transaxle
- integra websites?
- Need honest answer: is T1R exhaust REALLY loud?
- need help, have ??? about a jdm itr front end on usdm teg
- question??? answers intake manifold
- installing my header, o2 sensor question
- Is this a good deal for a GSR sedan
- Do ITR suspensions work on GSR's???
- Looking for DA window moulding, Door panel
- Bad ass DC2 from south florida
- Will the Acura TL HIDs work in a 98+ headlight?
- Fluid Leak (power steering)
- strut bar ?
- Milano Red in a rattle can?
- OT: Would there be LESS integras STOLEN if...
- JDM Front End HID/Non-HID
- who makes front tension batrs for dc2
- ls-vtec oil leaks
- In-Line Fuel Pressure Gauge - What Size Fittings?
- vtec and turbo ?
- 98-01 Front end parts list for 95 Integra?
- shifting problems HELP!!!!!!!!!!
- shifting problems, maybe the transmission
- whats roung with my gsr
- people with helms....torque specs on LS cam caps.
- broken stud off of motor mount
- jdm lip kit for da?
- 1/4 mile times with b16a da
- SMOG Help
- Omnipower Coilovers
- Cheap Big Backs "legend" For DA owners
- oem head light connector question/problem
- Thinking about getting a chipped P28. Problems with GSR turbo and no knock sensor??
- Integra Air Bag Question... Interchangable?
- what ever happened to.......
- hit a pothole now i got noises.........
- Circuit 8 valve stem!
- 99 gsr muffler on ls
- Traction Bar Noise?
- VIN stickers on 94-97 Integras, what year was it first placed on this model year?
- supercharge any car for 69.95...
- Will any DOHC headers fit any DOHC
- Air/Fuel Ratio Gauge Wiring?
- Need Injectors
- LS 98-99 - Suspension Difference?
- Anyone ever heard of Vision chipped ecu's? I'm stumped
- will this fit on my set up
- Gsr clutch in a b16 will it work
- Nalley Acura Sucks!
- recommended alignment shops?
- best type of wheel locks
- Weight of a four-door
- how do i take off cam gears?
- Want a CF ITR wing??? Link inside
- Trim Level?
- help me decide yo!
- New car time! Help an integra n00b out.
- questions on racing ecu
- 4TH ANNUAL CENTRAL FLORIDA HONDA-TECH MEET.
- cost to replace timing belt, valve adjustment, and tune up?
- carbon out my exhaust
- new project.. need input on motor
- DA integra projectors and HID help
- bushings for my B&M short shifter....
- first time at the strip
- hey kinda new, kinda not got some questions
- Amber climate control
- 92 Civic DX Fuel Maps Vs 95 Integra LS Fuel Maps
- Need help on how to install HID into 92 DA
- even the smartest mechanic cant figure this out.
- need help with tuning!!!
- Pic Request: DC2s with either 16" or 17" gram light 57Cs
- why does my clock reset to 1:00??
- Wrong purchase
- ITR LCA vs. GSR LCA
- shifting
- Fan Problem, it stays on after car is off
- type r spoiler
- Will this header fit?
- Turbo my Rs Or supercharge?
- Quick Question LS/b18b oil pan washer and filter..can I get at honda dealer?
- Piston Install Direction?
- Sprint Hart CP-R's
- How far will a chipped ecu take me?
- Newb: hondata and p28
- cdn gauge cluster conversion
- is something wrong with my car?
- Reconstruction title, anyone ever register one, or buy a car with one? let me know!!!
- Sleeving Block
- b16a1 help
- What to do with my car?
- 93 LS Distributor Question
- 2nd gen vs 3rd gen - ** Shift Linkage & Stablizer** same thing?
- NGK Iridium IX for DA
- viper 791xv in a manual integra. possible?
- Strange radiator fluid leak
- APEXI GT SPEC exhaust come with a badge?
- GS vs. LS, whats the difference
- Shifter suddenly feels very stiff and rubbery wtf??
- Fuel Pump Making loud noise~~~!!
- questions for ls
- apexi super ground...only 3 grounding locations available? need help with install
- all motor DA owners
- gsr 1/4 mile times with ecu headers and exaust
- jdm front end hood latch question?
- B20Vtec Question
- Need Buying Advice ASAP, Thanks
- i cant believe it works..............
- has anyone coverted a 94 teg from abs to non abs?
- Any aftermarket DC rear lips that fit?
- What all comes with a skunk2 IM for a gsr(in the box, i got one NIB)
- ls/vtec ecu question
- Part identification help...
- OEM HID? USDM HID? need help.
- what type of tranny?? ::searched::
- the surging idle thread
- buy brand new screws from acura?
- Work Nezart Wheels
- my new gsr!!!
- Weapon R throttle rotor
- Just help to confirm my decition
- Turbo
- Update ... today i shaved side moldings off
- acura wheel lock question.
- carbon out of my exhaust
- help on what parts for install
- 94 integra problem?
- Wanted: Integra Body.
- LOW GAS MILEAGE!
- Help Dont know what to decide....
- painted my header
- quick exhaust fitting question
- ANZO USA PROJECTOR 1 PIECE CHROME CLEAR BULB SIZE
- rear view mirror
- 93 Integra 1600SOHC / B16a V-tech motor swap
- Help w/ Fixing Thrown Codes in 90 Integra
- 3 inch pipes
- Xenon HID
- Acura Integra, No Power, Knocking, Wont stay on, help!
- Slipping clutch
- Need help with a sleeper exhaust
- My Girl's Whip is back!!
- Exedy Clutch help
- What ECU to use with Skunk2 intake manifold on 99 GSR?
- I Want to put some HID's in my Acura Integra 91
- CTR lsd into 96 GSR
- Work Nezart wheels?
- grounding kits
- Burnig rich
- LSvtec/B20vtec setups. Any decent links?
- Anyone know
- Ok Guys, whats your 1/4 mile times with I/H/E
- whats a good aftermarket body kit
- front bumper removal
- are these Gsr wheels any good compared with OEM?
- Good Wire and Plug combo?
- ideas to get car to warm up faster?
- Best head to use for b18a vtec conversion?
- Pulled motor/trans-what can i clean inside of trans with?
- H4H Bulbs - Help
- Have a Question On Shift Linkages???
- integra seat interchangeable (driver vs. passenger?)
- B16 Civic SI Head and B16 Del Sol Head?
- Stock Shocks
- please post a pic!
- ls to gsr exhaust
- integra dash?
- [0 to 60mph] / [0 to 100kph] what is your time ?
- Will a '94 gsr powersteering hose fit a '98 civic hx?
- 198,000 miles.. when to start worrying?
- mugen replica spoiler
- Power door locks with viper alarm
- My doors wont open because its COLDDDDDD
- Falken Hanabi Bronze on Gen3 integra?
- parts help pls
- ITR cluster in DA teg
- DC, DC2!?!?!?
- meteor silver
- Will a F20C motor fit into a DC??? Plug and play or what??
- hatch gsr trade for coupe gsr condition of each is in side
- integra 1/4 mile times
- Suspension Upgrade for my GSR
- exhaust too short what do I do?
- need help on reprograming key
- Getting car vibrations when hitting the throttle, axles? tranny?
- Selling JDM ITR Pistons
- Alignment problem?
- 4-lug config ITR size rotors?
- .alarm wiring harness for integra?
- Changed wheels from 17" to 14"...MPH thrown off?
- no wheel well guards = easily stolen parts poll
- 95 special edition question!
- gsr head gasket on b16 block
- shit!shit!shit! I think i just blew my engine
- b18c botom end in a b16
- OEM brake pads vs. aftermarket
- Chasis Codes
- vtec integras
- Help Installing Power Mirror
- any risks involve with dynoing your car?
- chocolate milk like oil... n e chance head gasket can still be good?
- Timing Belt Q
- Online OEM discount parts
- looking for gsr or ls integra
- Ok, I have ABS on my 90 DA.... keep? yea or no?
- WHAT DO I NEED
- DA Wiper Delete
- help on my setup
- Acrylic Enamel paint any good??
- trying to learn
- Who wants parts straight from Japan?
- Skunk2 Manifold Assistance(OMG, YEA another one...... :hammer: :me: )
- car wont start and im out of ideas!!!!!
- Should i trade my GSR for this EK hatch?
- del sol shifter fit my teg?
- 15" aftermarket wheels
- HONDA emblem
- Bad O2?
- 98 Teg RS stalling on cold start
- Question on Skunk 2 manifold?
- What is everyones best 1/4 mile times?
- stupid 175k-mile tranny
- frequent stalling when car is warm ('90 integra)
- How much is a Master cylinder
- Nucks DA.....a work in progress
- squealing noise when starting car!
- Cylinder #1 not firing.... No spark no fuel?
- Thinking of gettinc a 94 teg.. need help!
- Brackets On engine driving my NUTS!
- Looking for a teg b/g
- Many Questions About LS Engines in various years:
- Dynamic Auto Design DAD racings seats
- b20b block Ls head
- WTB: GSR Blades!!!
- Cam seal
- Strange noise
- white sludge coming in catch can
- evap system on a 99 gsr
- i need help check engine light is on
- emissions on 99 gsr help needed
- NEED HELP WITH LIP KIT INSTALL
- omnipower full coilovers now out for DAs
- Question about clutch and Flywheel....need your help
- MPG on LS
- dash measurements
- car has gone haywire after o2 simulator install! need help!
