View Full Version : Acura Integra
- G2 Daily Drivin' Integras
- Engine Part Question
- obd2 b18c engine harness to 94-96 integra ?
- JDM front what headlight covers ?
- need help..engine problems!
- HELP! Depinning ABS Plugs...
- Where do you buy your acura OEM parts?
- ITR dif In JDM YS1 LSD Cable... fits???
- only #1 cylinder sparks
- Steering/Wobbling Issue...????...plz Help!
- Fuel tank
- RSX-S axle back on 2door DC4?
- b18b1 Idle problem HELP!!!
- PCV line pinching?
- Ground short?
- good butt bad gas
- opinion, seat options
- first gear jerks
- HELP! Fadeing paint Trying to save.
- Car shuts off while driving
- *Wiring Diagram for Side markers with JDM Front End*
- cxracing radiator + slim fans!!!!!!?
- GSR Rebuild need help!
- Any good motor swap shops around OC/Southern california?
- 2000 Si Cluster in a 95 GSR
- autogage tach for a 97 integra
- GS-R sway bar in RS
- gunk in my brakelines
- any1 have a Diagram of how to remove the motor?
- B18B smoke
- HELP:::JDM B18C no VTEC no Speedo, tach dies at 4500rpm
- How can you tell if a flywheel is still good?
- auto to manual need help
- 1994 integra dash bulbs
- engine knock
- Help please
- Engine light coming on???
- dc cluster in da?
- 91 integra idle problem???
- rpm tach stop working today on my gsr cluster
- newer slanted muffler tip fit older mufflers?
- best upper control arm opinions
- Integra red tail lights
- Passenger side water leak
- stage 2.9 axle keeps failing
- Thermostat help
- 98 GSR Flickering check engine light
- I need help with car stalling
- DC2 Recaros
- Maint. Rqrd. Light Blinking
- Just picked up a 4dr GSR
- dash help? on 96 teg! please please please!
- Timing belt age?
- brake lights dont work help !!!!!!!!!!!
- how many 92-93 gsr made
- how much does a rhd conversion cost?
- GSR OEM Intake Dual Valve Springs used on Exhaust side?
- Throttle Body Sizes... what's too big?
- Valve cover problem? help!?
- Exhaust just got super-loud...!
- 4-2-1 vs 4-1 header for Drag Racing
- difference between 96-97 and 98+ JDM R motors?
- Need help
- Need help with used transmission purchase
- 98 gsr sputtering low RPM ( on heavy foot)HELP!
- Waterpump problem? Bottom hose no get hot.
- d2 racing rs coilover..
- Recaro Speed.....Help!!
- my gsr is is doing something weird?..
- Need help ASAP:gsr motor oil pan tq. specs???
- Question regarding my Suspension (Advice appreciated).
- Front Upper Strut Bar Install - Project
- G2 Integras NEED HELP putting on integraXSI decal on my 1990 integra LS
- Bubbles in motor oil (Dipstick)
- Quick Question About Integra Side Moldings
- DA Amber Cluster Bulbs??
- bumpy ride
- Grateful integra is still safe.. pissed that is was VIOLATED!!!
- Opinions on this GSR?
- Grid Gears..
- Will G3 Auto tran fit in G2 integra?
- Help plz Rebuilt B17A Big problem
- How to Reeplace Fog Lights on a 92 Integra?
- 95LS exhaust question
- integra cant start.
- obd0 to obd1 distributor swap
- installin a ls head
- thermal 3 inch question??
- JDM p72 Questions
- integra rear visor!
- b16 problem
- need help with da heater
- RSX Seats
- '90-'91 and '92-'93 Interior Color Type D Graphite Black
- 90 integra build
- Help with Dashboard Control Panel Lights
- Smog Certificate Question 97 Teg GSR
- accord and integra both having engine temp issue?HELP!
- what grinds my gears!
- DA problem & DC problem
- main caps interchangable
- HT Guru's: GS-R + B16 =9k?
- ECU for 99 gsr?
- b-series throttle bodies interchangable?
- GSR long block swap
- gsr tranny ?
- p28 on a gsr?
- interchangeable suspensions?
- wiring diagram for fog lights with ITR headlights?
- price for a ls vtec
- Wheel Bearing
- Alright i dont know what to do?!?!
- pissed off, bumper scratched up again
- OBD1 motor in OBD2 car help please!!
- fuse #24 IGnition ! keeps blowing 96 integra
- HELP! - stereo system burning
- 94 lsvtec dies at idle (yes i searched)
- head gasket?
- Rebuilding 96 LS bottom end QUESTION!!!
- RSX TYPE S LEATHER BUCKET SEAT on a DC4?
- Motor Mount Inserts?
- Is this head salvage-able? Pics Inside
- Crank No Start 96 Integra HELP! No fuel.
- crx and integra shocks same?
- (GSR) skunk2 or Blox IM swap??
- whats a really good setup for a 96 acura gsr
- Will a USDM TypeR lip cover this up?
- exhaust gaskets question?
- Skunk2 Springs and Shocks
- will ZC transmission fit b18a1?
- Replace Rings? or Swap out short block on my 98 GS-R?
- Can I put a Type R body kit on a gsr?
- Type r strut bar question
- anybody ever dye tan leather black
- What is it and where does it go? pics inside...
- 94-97 Integra fog light install
- Code 43 on B18a1
- WS2 Catback fitment question
- Best exhaust size for 1992 Integra Gsr
- Car is not starting! Fuel Pump Related
- Fuel Pressure regulator question??
- Apparently santa felt like blowing my engine O_o
- 97 gsr swap into my 98 coupe cel is on need help!!!!!!!!
- Test Pipe with 1 oxygen sensor!
- valve covers?
- Oil Pan
- are all oem DA hoods the same?
- Think Im burnin oil not sure
- HELP--Can't shift gears
- 94 integra with terrible idle
- gearbox
- Wheels, Tires, Spring Combo HELP =)
- DA side skirt advice??
- Oil pickup and baffle
- 94 integra b18b...help diagnose
- GSR/Type R Endlinks *HELP PLZ*
- Code 43
- 95' Integra GSR w/mods |totalled|How much is it worth?
- padawan power to manual steering rack loop
- da with b20 on auto tranny no spark?
- What is the length of the intermediate shaft?
- 99 front conversion quick question
- 2000 db8 tuned with video!
- grey/white smoke and overheating problem
- B18A1 transmisison bolt size...
- Service/Repair Manual
- 91' Integra Ls for $900
- Strut and Tie Bar Questiosn
- aebs in and tb 65mm
- torque damper help.
- Fuel Injector Plug Order?
- STOLEN Integra Tranny???!!! Help me please
- turbo kit selection???
- gsr cams and intake mani question
- Clutch Problem. Need advice.
- whats the part called??
- Rear Suspension help. DC4
- Header
- Are LS and GS rear calipers the same?
- cams?
- Wheel size ???? 15/16 stay 4x100 ?
- PCV System, Help/Suggestions?
- ok i bought some lca's now what?
- lost keys
- roll cage id help
- g2 integra heater problem
- PCV Valve Location?
- Ys1 Mainshaft Stopper Ring
- What Are Some Good Lower Control Arms For A DC2??
- 94 LS/Vtec Back From The Dead
- 94 integra Ls - STOLEN
- blow by or/and valve cover gasket problem??
- power steering pump
- 91...or 92 gsr question
- All I want for christmas is HEAT!!!
- Need to find a shop to install turbo on integra
- 1991 integra idle problem HELP!
- difficult? Putting cams in the b18b
- Help whats this bushing/seal called!!!!!!
- No electrical power
- How much would you pay???
- Integra Gurus... read ;) Have a bushing question
- What Power Steering Brackets Do I Need?
- whats kind of tranny do i have???
- axle problems!!
- HX on a DA
- 13" Steelies on da integra?
- what plugs are these?
- What spring rate?
- exhaust help
- Where can i clay my motor (SoCal)?
- Sea Foam Anyone?
- 91 DA axel problem, stumped.
- Problem with my DD
- wire harness question
- need help with clutch
- trunk leak fix question regarding about sealing the taillights
- rusting hood WTF?????
- gsr ecu with type r motor
- 98 ITR Diff Bearings in a 94 GSR
- Code 43 94 LS
- 4dr leathers in 2dr SAY WHATT!
- Integra suspension question
- Speedo Question... new to posting
- cali exhaust question
- Looking for dash deletes!!
- Gt28rs
- 440cc injectors enough??
- Smog Certification
- master cylander serous problems help!
- tires moving while driving...
- What Flywheel is this?
- b18a block with b18b head?
- Tires?
- Question on Type R Cams
- Headgasket problem
- roll cage and 4'' aluminum exhaust help!!!
- Why are my wheels spinning?
- 88 Integra not going into 5th gear HELP!!
- Tranny Teardown, Rattle Hunt, ISB?
- Integra Dies while driving... getting worse... help!!
- DA Front Cap question....
- 91 Integra Manual Car Starts, Shift into Gears, but doesn't move!?
- need your opinion..suspension
- 90 integra ls w/b20 w/automatic trans no start
- Sidemarker measurements help????
- 2 questions: (fuel/timing)
- Cylinder sleeving ????
- code 16 after soldering new injector plugs
