View Full Version : Acura Integra
- help for abs removel
- Threw a CEL code 3 MAP and car running in Limp Mode and won't stay running...
- FLASHING OIL LIGHT QUESTION
- Transmission Fluid
- jdm headlight fog light bulbs?
- REQ PIC: DA w/Skunk2 catback
- need help posting up pics
- H.O.P Radio block off plate question
- WHY IS MY LS TEG IDLEING FUNNY..
- RADIO HARNESS wiring
- exhaust systems????
- '98 GS-R; Anyone ever changed the antenna mast?
- problem with suspension
- popping thok thok noise upon acceleration and braking
- Help! Battery light doesn't come on. batt. not charged
- CARFAX
- JDM non-srs quick release
- hello from israel + integra ques
- searched: tranny question
- My 1/4 mile slips from this weekend!!
- h22 swap
- headers
- HelP:: Walbro 255 hp fuel pump question..
- B17A1
- Victor X manifold VS Skunk2 Pro...
- b series motor question
- ls.transmission????????/
- PAINT JOB COST
- bb6 prelude vs. dc integra Gsr? (Need your knowledge!)
- HELP!! Squeaking noise and car shaking.. problem??
- top mount turbo
- main relay
- axel problem!?!
- gsr questions
- just changed wheels on the old teg tell me what u think
- Does a 90-91 front bumper support fit on a 92-93 car?
- Brakes. Calipers. Pistons.
- DIY rust repair
- What do you think of this integra engine build LSvtec?
- best leather cleaner???
- need help. aftermarket crank pully
- spongy clutch problem
- dome light and maplights fail to come on!
- Brake Lights Out
- gawd so confused about cable trannys
- LS/Vtec or not
- My AWD Rally DC2
- axles
- wiring tail lights
- Need Help Auto 2 standard conversion on my DC2, Trany mount issues.
- control arm replacement
- reasons for vtec not engaging?
- Which car transport company should I use?
- Gen1 brake booster checkvalve master cylinder (long)
- main relay
- What are the warning signs that you're water pump is going?
- a/c and the summer heat!
- powder coating
- k20 swap???
- where can i find ecu codes...???
- CEL
- itr sway
- front lca joint problem
- driver side window motor help
- gsr leather seats, adjustable?
- bought a gsr
- will this fit? searched...
- difference between obd2 and obd1 distributor
- Need Help Finding a da8 x-si half cut for rhd
- 93 INTEGRA FS IN MD
- Misfire Problem
- Does anyone have the vacuum diagram for a 1995 gsr?
- H22 Swap???
- Moving to Pennsylvania What the tuning base up there?
- Adding A/C into H22 swaped integra. Need Help
- A Question about my head
- ls block gaurd or not ?????
- piston slapping Q = OIL Grade to use for TEMP driving.
- Diff between LS side skirts & Type R side skirts
- Ls Vtec Questions
- integra crash , i need help...
- New calipers/pads/rotors and STILL NOISE!!!!
- alright
- Does anyone know where to get the cheapest O2 sensor bungs for a 98 GS-R?
- What are the differences between OBD2 ecus?
- mount for speed sensor broken. ok to drive with temporarily?
- Timing belt tension problems
- gsr head on b16a2?
- engine wiring harness - auto manual difference?
- suggested settings
- cooling problem please help
- Oil Filter
- Where does vacuum hose #21 go?
- Fan relay????????????
- Which OBD has a round plug for the alternator?
- installing 450cc injectors????
- carsponsership.com? anyone ever tried?
- Help clutch/pressure plate issues during replacement!
- Wiring Knock Sensor On LS/VTEC
- fixing rust; question
- will 14" del sol wheels fit on 97 ls?
- VSS Wiring
- starter probs
- IDOL PROBLEMS!! PLEASE HELP
- clutch hose removal
- scratchs front main seal mating surface
- intake manifold question
- anyone want to help with my project
- how often do integras get stolen?
- OEM oil filter 95 ls
- Fitment question
- MPH gauge is sticking
- engine rebuild kit
- clunking when turning in and out of parking spots
- Motor Mounts *I've searched*
- 1996 Integra Gs-r horsepower
- ecu question
- INTEGRA HALO PROJECTORS
- NOISES
- POINTERS FOR PAINT JOB!
- Car wont start please help!
- rebuild axles?
- post your 1/8 mile integra times
- "OEM" Genuine Integra Antenna Rubber Plug Clip Bung Delete DC2
- Removal of srs legal?
- ECU Warning Code 80
- JDM Headlight Question
- Difference between automatic and 5 speed p75 ecu's?
- did any itr rear shocks come with a fork lower mount?
- GSR.....Good deal or no?? Input please!!!
- Lowered car...Passenger rear higher?
- ecu code 9
- GSR-t Sizes
- LS/V Questions
- can you buy championship white at paint supply shop
- B18B trans, whats it worth?
- about to paint my da, so im looking for pics of clean da's for painting options.....
- head build GSR-t
- dam brakes
- anyone got pics of their GSR's with the red/clear tails from ebay? or even ukdm
- polyurethane bushings
- Semi Rebuilt my GSR motor
- SRS, No Horn or Cruse. 96 Teggie Sedan.
- i love KYB agxs
- question about helicoil...
- Dual bend quick question.
- are heat shields a MUST HAVE for ITR headers?
- alarm constantly going off
- GSR sway bar + Aftermarket LCAs...?
- Gauge Cluster keeps blowing
- stumped... scratched my rim
- WTB 94-98 Integra.
- cold air intake
- GS-R PROBLEM
- has anyone bought from member Addicted2Racing?
- can i interchange JDM and OEM ITR parts for headers, catback, cat converter, etc.?
- Compression?! Please help...
- Right side front and rear outside lights...
- tranny swap kit
- [B]WTB:[/B] 94 to 01 teg What to look out for
- AC Turns on out of no where while driving?
- Gen 2 Integra rewire
- Valve Cover Gasket
- front calipers in rear??
- B18B Running Rich, not good.
- Power Steering on a B18B DA, HELP!
- lowering car
- How do you remove the radio?!
- people in back with pillar bar
- got some head-shake...
- has anyone put a twin loop style muffler on a DA ??
- jdm front install in western MA/NY/CT area??
- Help on deciding. Oem clutch or performance clutch?
- half sized radiator will it fit???
- 6 light JDM Integra front bumper?
- custom exhaust question
- foglamp/interior/maplight failure Integra JDM
- Question about steering "stiffness"
- 94-01 rear lca's, swappable from left to right?
- Humming Noise? Wheel Bearing????
- Color Change
- helpppppp!! oil leak
- 14s on a gsr
- GSR/ITR rod size?
- how do i take rear wiper off DA
- 00 front on a 95
- K&N Air Filter Q's
- welcome.
- 94 95 b18c1 gsr fixs 01 integra?
- Front Bumper Amber Lens?
- wiring rsx cluster
- help: hose under car leaking?
- GSR or not?
- help!!!!!!!!!!
- need 94-01 4 door integra power window switch module
- GS-R MOTOR
- Female GSR Newbie....Please say Hi
- HELP: does anybody know if 00 si keys lock and ignition would fit a 94-01 dc2?
- LoCustom
- Need help on ABS and check engine light please!!
- Integra Parts NEEDED!
- Power loss/shut off with a p72
- Not new to the site, but new to the Integra.
- clutch pedal sticks
- need to find help in MIAMI FL
- what pistons should i get
- Hondata for GSR?
- good springs for Tokiko blues?
- new clutch is in
- ecu question, which would you use?? 94 gs-r
- msd and stock ditributr prob
- Is this safe....
- itr 23mm rear sway endlink and d bracket...
- maintence light
- g2 integra owners where r ur usdm headlights??
- car bogging after cleaning vtec solenoid...
- 13.2 gallon tank ???
- chipped ecu???
- Will 14" del sol wheels fit on DA
- another one falls prey
- Quarter Panels
- head shake
- B20Z - Where to buy and installation, located in Socal
- CEL 71 - 74, Random Misfire all 4 cylinders. Need help
- apexi neo
- How long do Noobs stay noobs
- Quick Question
- RS or LS
- OEM 3 spoke steering wheel?
- Cat. Converter
- Sun Roof blowing fuse right away!! *SEARCHED*
- Royal purple... need some reassurance
- is this a good trade?
- Paint
- same problem but can't figure out the cause???please help
- Manual conversion
- Black Smoke coming out of the exhaust
- PEOPLE POLL "WHAT COLOR"
- THE BEST HEADER?
- Awesome engine?
- which ls block???
- timing belt removal
- RC 550cc Injector Install OBD1 B18B1
- will a B20 valve cover fit on a LS head?
- What tire pressure do you like to run at the track? Remove muffler?
- My JDM DA Fogllights just quit working??? WTF??
- 98-01 front bumper
- Leak Down Test on my fully built b20 turbo motor.. what now..help please
- running rich?
- im plus sizing my tires, help me out
