View Full Version : Acura Integra
- fastest gsr?
- SAFC II, Is this what i need???
- Electric and fuse problems...car wont start
- draining the block of water
- hey looking for any opinions on future body work....
- can any 1 tell me what cel this is, can't figure out the #...video
- Warning!!!!! Stupid question
- Integra GSR, Integra Type R, RSX Type S
- ABS? How many of you guys use it/gotten rid of it?
- Importing a teg
- 5 speed conversion
- not going into gear?
- what do automatice integras w/exhaust sound like?
- new clutch/flywheel = funny sound
- Anyone have the Toyo T1R tires on their Teg
- Mounting Half Sized Radiators
- Im new to the family...
- automatic aluminum radiator ?
- Check engine Light HELP
- GSR turbo Intercooler questions
- What head?
- greddy evo 2
- need help with 97 GSR..
- Rebleeding brakes
- JDM TYPE-R CLUSTER INTO 95 GSR
- ls/vtec questions
- newbie
- What to do with shell?
- Car stinks of GAS. where's it come n from...
- Tein Hood damper???
- Cheap by Effective Motor Upgrades
- very bad compression test results!
- what color to go with on the gsr
- Need Help with Blox Intake Mani*********
- speed sensor for a 91 honda accord
- aem fuel rail
- taking front bumper off HELP!!!!
- My first time at the track!
- need a question answered about integra's
- underdrive pully?
- turbo setup for my 00 gsr and future plans
- type R doors wires harness help
- i got a question for all of you what would you take a 2000 GSR or a 2000 prelude sh
- tune up
- Upon searching..........
- ECU question
- front end integras
- quick n00b ignitor question
- Help Wanted!!!
- Best Bang for my Buck?
- halo projectors
- p72 ecu.. what years are the same?
- JDM ITR radiator fits GSR! almost didn't think so!
- Oil Pressure is WAY too HIGH
- Are all Gen 3's have the same alternator?
- why wont it run right?
- clucth engagement sound.....has it happened to u ? how u get rid of it
- rear "extra" seat belt eliminated
- What is Cats size????
- Oem or Aftermaket Gsr Head?
- vacum problem on b18c.. please help.. pics of engine inside
- i need advice on buying a motor...ASAP
- Question about timing belt change
- stamped number on front wheel bearing
- head gasket or rings?
- gromet plugs
- insurance question
- converting a 95 gsr
- DC2 DC3 DC4???
- 1157 and wedge bulbs
- If your battery is dead, will your alarm still work?
- Question regarding 97 and up Integra front bumper...
- Apex'i World Sport knock-off
- Damn CLutch PLease Help!!
- valve cover gasket
- need better brakes with stock 15 inch wheels
- EMERGENCY, I broke something, I need help
- fule rail and pressure regulator.
- Integra sedan or coupe?
- How do I do this???
- CHECK ENGINE LIGHT
- I can not for the life of me find B17 cam specs.
- gsr greddy turbo
- NRG quick release with MOMO HUB question
- Ebay Corner Lights
- ls vtec questions
- *94 LS dizzy problems! How to test coil or ignitor?*
- 96 gsr integra(turboed) vacuum lines
- Window Problem
- Tiburon or GSR?
- 94-01 healight housing too thick?
- about to purchase a 94 gsr
- when should i start worrying about rust?
- 95 LS idle question
- Will an RS*R muffler work for a 00 GSR? (Yea I already searched with no answer.)
- Car and Driver Integra articles
- How do you check trailing arm bushings?
- OBX cams good or garbage?
- Little Big Problem
- stock gsr tranny or gsr w/phantom grip lsd?which is better?
- Brake Kits
- SKUNK 2 INTAKE MANIFOLD
- STOLEN INTEGRA COUPE IN RICHMOND!!!
- differnce in lma's
- Compression test - how and what to expect
- sunroof make loud thump sound when it closes ?
- look @ my bra
- finding the fan swich
- trunk(rear end) "hops" over speed bumps
- Buddy Club Racing Spec Condenser
- 91 integra vs 2000? Ford Escort ZX2
- Anybody have any experience with jdmwarehouze.com?
- RADIATOR PROBLEM PLEASE HELP
- how hard is it to rebuild the DA calipers?
- 2000 SI springs on 91 DA? will it fit?
- Cut Bumpstops with Stock Springs
- gsr tranny vin#?
- wtb: integra type r lip 98
- Better Upgrade on my GS-R
- Im I going to be scammed? Check this out selling my car..
- hey guys i got a problem with my spark plugs i think
- HID retrofit Problem!!
- hiding amplifiers
- Tricking your Odometer
- Stolen Teg Colorado
- Where to find a oem gsr crank or cut my old one????
- questions about secondary butterflies???
- Is there any way to adjust the speedometer?
- silly question, but some help would be apreciated
- whats the difference between a B16 and a GSR ECU
- clanking/ratling sound around the distributer cap?
- Evasive Motorsports??
- engine turns off when full throttle open.. please help
- b16b block
- Fujitsubo Power Getter fitment
- where can i get this part cheap???
- help im only running on 3 holes
- integra tranny possibly
- Clutch cable replacement
- where to buy recaro brackets and sliders
- trade or not trade
- whats the best time to launch my car...at the track...
- tach not working on conversion!!?
- Wrecked Teg - what to do
- good deal or not and what should i do
- HELP!...with install for 94-97 front lip.....Type RS lip
- Gas Smell coming from the engine bay area?????? Please Help????
- Intake manifold ?
- Smogged and failed!!! help!!!
- wings west big mouth extreme flare kit
- WTB: Wings West RS2 kit for 94-97 teg
- Transmission Part Numbers
- Suspension quesiton, eibach with tokico illumniaz
- Hood Question
- Need suggestions on a turbo build
- Need help shaving emblems ***PLEASE HELP***
- (FTP) Sensor Circuit High Voltage ????? please help
- Cooling Problem
- Questions about my DC teg: o2 sensor with test pipe
- exhaust questions
- gsr engine swap
- Header install?
- Ebay Wheels?
- quicky clutch question
- Crower 63413-2 Cams in GSR.
- Is the GSR dizzy the same as 00 civic SI??
- jdm side markers
- AEM cam gear installation
- Cargo Cover Question
- Thunk sound as I come to a stop
- Brake upgrade for stock GSR Blades
- AEM big brakes (front and rear) and 95 GSR fat fives...is it possible with major grindage?
- Ripping apart the IACV... possible?
- Installing Skunk2 intake manifold on a 2001 GSR
- I need someone who has a GS-R head Handy Help Quick Q
- what exhaust for 97 turbo gsr?
- How much would you pay for:
- Brake Calipers.
- Thinking about a 94 GSR... Please give me your advice and opinions
- blox intake manifold
- any WS2 exhaust sound clips?
- What is that part behind the steering wheel called? The black piece.
- Dumba$$ fs up my car
- skunk2 manifold on a gsr
- racing seats?
- need help wiring lights... JDM FRONT
- 100% rebuild now running, now what? - Inputs please!
- can you integra folks help me out
- can act pro-lite flywheels be resurfaced?
- Need a clutch, please help!!!!!!!
- Need help with check engine code
- p30 pistons in b18a, which piston ring?
- CLutch Problem
- What ECU for my 94 LS OBD1??
- difference between B18C1 and B16A cams
- pics of red calipers on red tegs
- b16 head problems
- gas guzzler
- Acumen HID Kit
- >>> Need Help Buying My Teg <<<
- stripped out starter bolts! HELP
- skunk2 cam gear
- Squeeking suspension....
- em racing c-pillarbar question
- clutch problems?..
- 98 ls dizzy on a 91 b18a head
- 6g's enough
- Timing belt change
- anyone have a T1R or Jracing in there DA (91 integra LS)
- Tuning Choices, VAFC Questions
- Auto DA ran at track
- DNX 2.375" Midpipe
- Code 8 &13
- what can cause lost of alot of horsepower????
- burning oil!!!!SEARCHED
- I think I fried the dizzy somehow? help please.
- 97 GS-R 5sp sedan for $2900.... is this a good deal?
- Need a link to something specific.
- Gsr crank and rods
- Power steering pump question (im not a teg guy)
- experiences with clutchnet clutches
- will a jdm starter from a 90 sir crx fit a '90 da teg?
- Dc2 Ls turbo question!!
- hardware bolts vs bolts from honda/acura? same or different?
- Where to get 15inch steelies for my 97 Teg?
- car died on freeway=battery light
- 01 GSR running horribly
- Question on DA6 corner bulb
- Stripped lug nut, how to fix?
- Codes 1, 6 & 10 when driving hard.
- Floormat ?
- What do you guys think of this?
- Need advice for boring and stroking...
- S2000 Calipers w/11" brake setup on DA
- cracked oem type r lip.. fixable?
- Squeaking
- how do i check pms
- ECU diagrams for a 96' LS non-VTEC for a B18c5 swap
- need vtec wiring diagram for 99 gs-r
- Wire Diagram for a 97 Acura Integra 4 door
- Doing Auto-to-Manual conversion need help !!!
- CARPET COLOR NOT SURE
- greddy turbo on 94 gsr
- DA9 into a type are look alike
- Air Conditioner tab tight
- Need help with new Exhaust/Muffler
- Fellow 4door Integra Drivers.
- need help my integra burns oil too fast.....
- Suspension Combinations
- K20 with b serious exhaust?
