View Full Version : Acura Integra
- tranmissions
- Exhaust question.. ITR/aftermarket - looking into getting exhaust
- Intake manifold question....
- Red suspension sport Lowering shocks anyone heard of these?
- 99 integra V-TEC b18c1
- Which would you get on a budget? ACT HDSS or Exedy Organic?
- H&R Sports and Cut Bumpstops!!!!
- coil-overs on 95 RS?
- nooB
- 2nd gen linkage in a 3rd gen?
- funny idle
- 170k miles check up.
- Quick Question!?!
- OBD1 P72 and Apexi Vafc2
- HELP - HELP - HELP - BAD Oil Consumption
- stock oil cooler??
- High flow cat....suggestions
- ? about rota c-8's and stock lugnuts
- Will the 99-00 si aem cai intake fit a gen2 ls?
- for those of you who have who have switched from OBD-II to OBD-I...short
- unorthodox pulley
- B18B1 Head Polishing and porting
- Whoo guess what i got
- aftermarket steering wheel?
- gsr cams
- which power steering bracket to use??
- what's wrong w/ my brakes?
- need help suspension opinions
- koni yellow install question
- What are some good spark plugs?
- Do the 90-93 2dr tailights fit the 90-93 4dr tegs
- b16 oil pan same as b18c?
- Is their a difference between a GS and GSR rear bumper??
- Cutting valve cover
- Best turbo kit for a 93 gs-r for $3 K
- need help
- dc sports header rust...
- n/a whith whit nos or turbo?
- type r aem cold air on gsr ????
- JDM Apexi Gt spec Header, what's the length of the cat???
- how hard is it to pull apart a teg TRANSMISSION an fix it?
- post why Kutsuju_SLeePER is a scammer
- Axel problem...need help ASAP
- Charcoal canister/purge solenoid question
- GSR Transmission Fluid?
- Running lean WTF???
- quick question about intake manifolds on GSR
- obd 2 vtec wiring
- tuning help
- Fastest DA's?
- limited-slip
- Engine swap or rebuild? b18a
- another Stolen teg in nyc
- Hey Guys
- Girlfriend's 90 LS hesitates, then revs irratically, then hesitates w/ no throttle input - What coul
- timing belt question?
- WTB Type R rear Sway Bar
- remote/keyless and factory alarm CONFUSION
- Gasket for used header GSR
- PIC REQUEST: Wanna see 14" HX's on Integras (did search but no pics found)
- questions about power steering
- cf spoon mirrors wiring question
- Anybody w/a switch panel where the DIN pocket it? Post Pix
- prostreet timing belt kits
- Thermostat question....
- Help me ASAP please
- clutch squeal ?
- cheap ass integra parts
- GSR intake secondaries work SOMETIMES???
- please post pics of your COILOVERS. I think im missing something...
- have anyone used the rotors that cobalt make??
- hks vs apexi
- LS-GSR???
- how to tell vtec?
- shocks
- New Theme Song for Honda!
- Links for swaybar install?
- axle cup stuck on inter. shaft
- itr jdm conversion question
- p75 auto manual difference
- which valve springs?
- Bolt hanging....
- Just got the teg back from the shop, FINNALLY!!!!!!!!!!pics
- NEED HELP!!!
- Fluidyne
- Speedometer problem in my Integra. HELP!!!
- just degreased engine...now it sputters and hesitates under 3k rpm WTF!
- Size of shift linkage bolt....
- how much is stock exhaust worth?
- too much slack in gsr throttle cable...
- DC2 OEM Optional skirts?
- Heater not working, what to check?
- bolts for rear shocks
- can not get the key cylinder out of the door handle (doing rear to front swap on my da)
- Acura wanted $560 + tax for stock GSR valves and seals!
- Leak Detected In EVAP Control System ?
- CEL P0505 Idle Control System Fault... Need Help!
- 94-99 GSR header decisive problems
- OEM 94-97 Amber Fog Question
- Cold morning no start..............Need help!!!!
- Tires & Rims Fitment
- Problem, any one know?
- My teg some pic
- Gasket?
- Distributer problem??
- window travel time
- Car decelerating by itself
- header ?
- Interior Trim Kit
- header comparision...
- GSR & LS - Map sensors the same?
- Gsr Bolt-Pattern
- Integra sitting for 3 month problem
- Help AGX's Squeaking?!?!?! Fake Ground Controls????
- Where are those DANG OEM LIPS?!
- where can i get an o2 similator?
- RSX seats??
- type r rear strut bar
- teg stolen in EAGAN MINNESOTA
- Sucked water into CAI
- NEED HELP!!
- integra RS vs LS?!?!?
- my new pistons (worth 100$??)
- Resting ECU on an OBD1??
- stock gsr swaybar with itr lcas???
- how to get steering wheel off?
- Question about California Ticket...
- Anyone heard of a Y59 Tranny
- dc sports header DC onto DA
- Can you guess which member this is?
- PLEASE HELP!!!
- b16 swap - gauge reads engine is cold when engine is warm?
- hondata on obd0 cars..
- Noise coming from passenger side wheel
- VAOS Suspension / Coilovers - Questions...
- lowering springs question
- '00 gs-r problems.. someone please help
- RS catback fit LS?
- GO FAST = loud clunking noise
- Poor Gas Mileage
- Buying Used We NOS Kit, What to look for?
- JDM ITR catback???
- grounding kit instalation
- Here are some pics of REAL 01 ITR cams
- cheapest place to get an altenator?
- Which Lowering Spring Manufacturer do you prefer?
- Aftermarket ITR LCA's?
- something broke.
- 96 GSR-no fuel pump with obd2-obd1 harness adapter- help!
- What would you get 4 door gsr or hatch ls?
- AGX and Nuespeed
- How do you pull an integra door apart?
- Doors are completely frozen shut....
- Fuel Filter question??
- Timing belt replacement
- fake ITR cams??!?
- Help with a lost lug key!
- Found 2 plastic peices in driver side window...
- code 43 help???
- No heat in car
- My door lock doesn't work !! Haynes people please come in......
- Mugen chip for a '96 LS integra???
- My auto lock stutters. Any idea why?
- Stock GSR spoiler hole. Does the typeR spoiler has the same hole?
- Where is your VAFC located
- Will SRS light come on if my battery was dead for awhile?
- How Much Nitrous can a Stock B18a Hold?
- quick advance / retard timing question
- GSR transmission
- Aftermarket Front Motor mount company?
- 5lug conversion
- AMSoil, anybody use it?
- Dc2
- Im pretty sure I got fake set of '01 ITR Cams, Check out my comparison to OEM 98spec ITR Intake cam
- Air Conditioning Recycle Air ?
- gettin bad gas mileage help!
- pctx pistons?
- what coilover set do u thinks good for the money? (poll)
- Will a J's Racing intake fit on 99 Integra Ls
- Something worng please help!!
- jdm conversion
- Removing/installing 2000 Integra drivers side door with power everything
- anyone has the link that tells you if the CTR cams r real?
- test pipe question?
- toda c's with 55shot w/zex dry
- swapping gears from LS to YS1
- Which exhaust will fit after Type R swap?....................
- What kind of ems for rh kit
- got a question
- HELP WITH INTEGRA
- buying a tranny
- supplies for prepping jdm type r front end
- Dyno Day...Its Official.....Free Dyno Run....Feb 21,2004
- P28 ECU's In GSR
- too cold?
- TEIN Type FLEX on a DA
- ECU gains
- Coilover springs noise from rear
- i have a good question...
- vibration under acceleration
- 94-95 GSR Cat
- problems with automatic door locks, please help!!
- ls/vtec headstuds
- Electrical Problem
- Experience with Tababae Exhaust?
- guages
- Putting stock springs in...!!
- wtf? my vtec comes in at 6200 and all my boys come on around 5k Wtf is going on?
- would a stock 92 bumper fit directly on my 91 integra without any mods?
- Pics of an AEM CAI on a DA
- SCAMMER ALLERT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
- sway bar
- What would be the best or a good clutch for GS-R?
- Sparkplug?
- Will a Type R spoiler swap directly in place of a stock spoiler?
- problem with buying a 95 gsr.
- where to get good aftermarket floormats ?
- What motor is in the 1991 integra rs
- DA seat alternatives
- Questions about turboing the teg???
- SoCal: Clutch Install ...
- mystery holes on tranny
- 4 dr and 2 dr mirrors
- vibrating noise coming from engine bay
- what do you think of this deal???
- OT: anyone ever heard of six autoworks?
- Tein SS and camber kit?
- Throw out bearing question..
- Can't tell if my timing is off or if it's my idle control valve
- OBD1 vs. OBD2
- skunk2 stage 2 whith nos??
- Getting a "Random Technology" high flow cat from optauto.com, is there a better place to get it from
- Headlight Alinment for 98-01 integra??? how is it done!!
- Who knows how to run a compression test?
- the difference between 2nd gen. 2door and 4door transmission
- 2 or 4 core?????
- TIRES
- What would make more power?
- help!!!
- takeoff
- b18c wont rev past 7000 rpm
- 98+ Headlights - Tips to clean the exterior ? Advice and help needed.
- Headlight Bulb Question.
- My car just died Please Help!!!!! Teg 99 GSR
- ls/vtec ?? n weight ??'s
- Decent brake pads
- clutch masters stage 1 or ITR
- Manifold bolt tightening pattern.
- Nitrous + Cams?
- b16a2 type r tranny???
