View Full Version : Acura Integra
- Short shifter Q's
- Looking for a pic...
- LS Vtec VS GSR which car have more power??
- ARC Intake on GSR?
- da vs dc
- problem with tach
- greddy header question
- shift linkage
- Help me build my Integra.
- Install Cusco Supension PICS!
- replacing stock exhaust
- Prelude 5 lug hubs
- Need Help Air-Fuel Gauge Install
- What type of oils do you use in your GS-R...
- how to take hatch of 90-93 integra
- itr intake manifold vs skunk 2 intake manifold
- 5spd swap
- Ugh, Here we go again,
- What is the difference between the 3 integra models??
- How hard is it to install the ITR front Strut on my non-Vtec integra??
- 91 da overheating??
- FIPK or COLD AIR INTAKE
- quick auto tranny fluid change questions.
- 94 rs needs clutch. which kind?
- relocating battery
- B16 AEM fuel rail fit b18b?
- Intake Manifold Question?
- any difference between left and right tires?
- Auto trans. shifting too early!
- Modded '92 DA Cluster w/ Greddy gauges.
- My car was STOLEN!
- should i get a ecu next
- the ground wire going to the engine
- what next?
- O2 sensor question??
- WHAT IS THIS PART CALLED
- Where to buy aftermarket calipers (OEM Spec) ??
- are JDM lights DOT approved
- Windshield Wiper Delay?
- help -- went over a parking stop and it pulled my bumper off at the sides
- gs-r rims
- quarter mile times
- 2001 gsr...need some help...please
- does anyone make a lsd for my tranny?
- ABS Light
- Honda-Techians, Verify is this is a JDM or USDM foglight switch. PIC Included.
- bogging issues...
- Surging idle (searched found want more info)
- 93 Timing Settings
- help please!!!
- Skunk 2 slowed my car down!
- 95 LSVTEC NOSTART
- CEL Help
- New TOYS!!!
- Question About Putting on a Type R Header onto a B18B Motor!
- gsr head?
- Should I go out and buy a stock spoiler?
- exhaust flow problem
- High Rev Performance-NYC
- How to make engine bay cleaner?
- Need 2 find a Dyno in SoCal!
- Apexi N1 dampers
- what type of light bulb are the turn signals?
- cf hood help
- how to tell between trims?
- vafc initial settings on stock gsr.......
- spring spacers or something to lift my car for a trailer
- valve springs interchangable?
- B18C5 type R or H22
- Noob obd0 to obd1 question
- 89 Civic shocks on 94 Integra?
- Victor X manifold on GSR-throttle cable rubs hood
- Using SeaFoam!!!! help GSR!!
- ls wit b16 tranny or gsr? faster? gas mileage?
- NGK Double Plat vs NGK GP Plat?? Whats the difference?
- Apexi Ws2
- brake difference help...
- Installing OEM Optional Rear Valences HELP
- Apex WS or Greddy SP/SP2
- auto ls
- Where can i buy JDM 92 - 93 integra fenders?
- Does LS stock intake arm fit on gsr w/ skunk2 IM?
- Do i need a camber kit?
- What the hell is wrong with my suspension?
- what intake will fit for ls/vtec w/ skunk2 IM
- Cable Conversion on a '92 DA...NEED HELP
- Gauge cluster for you DA guys....
- part number, wires, cap, rotor for price of wires?
- Stupid Q...gsr/ls b pipe length???
- STR tb on skunk2
- SMOG Help... !!!
- Is Skunk2 all around a good setup??
- fuel pump relay
- re-powder coating my rimz. gun metal or keep it white?
- Broke a sensor on B18C. Dont know what it is? Does anyone know?
- Off subject retarded HT question
- PISTON RING QUESTION?????
- replace badge
- What is the best header????????????
- e-brake light problem
- 2000 P72 ecu question
- Suspension
- people who has Spoon N1 what kind carsound u guys use??
- How long can u ride on a bad axle?
- Trans or clutch?
- Abs Codes
- ls rims?
- Strut Bar Install Question??
- need a tranny 4 91 teg... whats better ls or gs to put a lsd in....
- Skunk2
- ACT Clutch & Flywheel okay to rev while break in?
- HELP FAST!!`
- Fuse? Or something else
- Pics on removing cluster on 93 Teg?
- need to find out if this ecu is an obd1 need help
- SpeedTrialUSA HPDE @ GingerMan Raceway September 25
- sprint springs
- Question on wheel horsepower.
- ls/vtec distributor
- Difference in Spoon radiator cap types?
- whats the best 1000$ mod??
- Who here is interested in a front and/or rear diffuser for their DC Integras??
- WTF is going on? I need some serious help! Pics inside!
- Carbon Fiber Hood Help!!!!!!!
- Will this run rich/lean? Safe to break-in motor?
- My New Mods Coming Soon - TARGA TOP!!!
- Newbie with head questions. Please help!!
- xsi tranny??
- ls/vtec for dummies
- B16a motor questions (searched)
- ECU help!!?? What will work?
- notchy 1st, 2nd, 4th and 5th gears
- shaking at startup
- Dashboard disassembly: need help!
- new exhaust
- torque specifications
- Do Tenzo R Make Brackets for a DA?
- vtec !! check it out !!!
- Problem with B18B Block
- 2000 Type-R 5 lug conversion and sway bar fitment -----> 92 integra
- Yokohama Racing Tires
- Swap is done and on the road...
- Integ Almost died on the freeway.. some suggestions?
- COLD air intake fitment question
- Header question
- Whats the weak spot?
- Whining Noise?
- Hondata Intake Manifold gasket install
- question about my V.C. Gasket... needs answering
- Trunk Floor Brace
- my 00 si
- this a troublesome car?
- springs question
- jdm itr header question
- Header question
- What suspension and brake parts differ from the LS to GSR?
- LS/Vtec compression ratio?
- Airbag question - need some advice - 2000 airbag in a 1997 Gsr
- Hood Latch For JDM Conversion
- stock exhaust question
- skunk2 shifter question
- shocks
- D.I.Y. Coolant reservoir bottle
- Tsudo exhaust
- tranny or clutch problem? 5th gear slips
- Cluster bulbs
- rattling Apex-i world sport
- Integra cluster?
- anyone work for Acura parts department? I need a little bit of info on a GASKET
- automatic gsr
- Gas Tank
- coilovers
- fuckin stupid thieves!!
- my DA dies on a hot day
- Intake (Keep it or replace it)
- Price of fender and paint
- 96+ Accord Engine Swap
- Stock gsr w/ comptech icebox dyno +19whp???
- Info on Using a 5 lug conversion a DA
- b16a2 in 92 ls
- Feeling generous: Anyone need technical info from Helms? Post here, I will answer
- engine puttering
- 94 integra carbon fiber hood
- 1994-2001 Integra and 1996-2000 Civic Suspension
- tranny? what are the dfiference? gsr...ls...type r...
- radio shorting out?
- 5 lug conversion question
- Cold Air Intake ?'s
- I need some qucik info before i order please let me know asap!!!!
- What Would Give Me More HP???????
- Anybody have a valve cover F/S?
- Crashed my teg, JDM or USDM.
- Bogging at idle problem, 92 DA... Uberdata? Main relay?
- GSR for under $1.00 (anybody)?
- Question regarding Hondata Intake Manifold Gasket...
- b16 tranny on my b18a1...wow...big difference...
- motor swap questions
- which offset for 16x7 wheels?
- Want to find a part!?! help me out
- Anyone have problems fouling o2 sensors?
- lowering spring problems...
- DA owners need your help
- 92-93 GSR tranny reverse switch connector - what style?
- help please new user would like to post pictures of my new car
- clicking sound on take off....
- CEL code 80
- Help on header for teg
- BRAKE PISTON HELP!! 911 emergency!! (searched.. nothing..)
- symptoms of burnt valves??
- changing rear disc brakes
- Just used sea foam and now CEL is on
- Key wont eject...
- cheapest place to get a direct fit high flow cat
- I want to know some opinions on the ESPELIR EXHAUST SYSTEM
- 4 door Integra
- Help: Tenzo R Sliders
- Stock GSR V's Skunk2 inlet manifold
- VIN Number Breakdown
- headlight problem...... help!!
- h22 integra weight
- need some help with mirrors on ...
- Opinion On Muffler?
- My RPM Cluster????
- Turbo or Supercharger?
- DA Digital Climate Control
- jdm front end (grille question)
- '95 GSR I/H/E running VERY rich... HELP!
- Window Tint Scratches
- Exhaust flame
- How a Turbocharged System Works
- rota rims help! how come there's a gap? spacer?
- Brake Pads
- anyone have pics of RS limited concept pro rims
- hood locks/pins
- interior question..searched
- AXLE PROBLEM
- Buying a turbo off eBay, is this a good setup or no? Im new
- i have codes 12 and 48
- scat rods
- alternator Install
- 2000 Integra- Tons of questions
- Why do people?
- What does JDM stand for?
- Cat back recommend
- Help HElp Integra pulls to the right when braking
- snap the bolt to hold down ignition rotor.. now what?
- question about cat back fitment
- interior question
- So I just won this air filter on ebay
- should i keep my integra??
