View Full Version : Acura Integra
- Teg wont start..back to square one, need input!!
- integra shifter hard to move
- looking for a 93 integra front bumper
- 1995 Acura Integra SE progress thread.
- HUGE oil leak ! on tranny side after head was off. 94 gsr
- Oil, coolant burning? Thoughts? Help
- b18a1 and b18b1 head studs
- harness diagram
- trouble finding OBD1 connector HELP!
- Help [Values and Block] B18A1
- Flywheel
- Blower Motor won't work
- Cruise Control not Working
- Timing belt install questions B18C1.
- 92 DA no start no fuel no power to fuse 18
- GSR Black box purge solenoid question
- 1991 integra da9 ecu decode
- 99 gsr quick question.
- SIMPLE KWIK QUETION..octane booster for 91 octan
- rear visor
- Tick Tick sound. Please help!!
- tire size help needed
- 99 integra gsr
- DA DASH HARNESS 90-91 vs 92-93
- Smog/bar help, 95 gsr in crx
- Burnt valves ? with pics B18C1
- Noob alert, have a couple questions
- Rounded exhaust manifold bolt. B18C1
- dc4 kyb?
- Replacing O-rings of fuel injectors. First time, need help
- Function Form vs Ground Control setup, Which goes lower?
- need some info
- 1996 Integra GSR Distributor Plug Pinout
- Thoughts on GSR parts list....
- what to do?
- Injector pulse test came back good but still running rich. 94 GS-R
- 94 Integra Coolant system issue
- Obd2a to Obd1
- 95 b18b1 idle surge, not fitv or iacv
- power steering delete da9
- HELP FINDING WEBSITE THAT CARRIES THESE TAILIGHTS 98-01 SEDAN
- jdm tranny distributor?
- DA Integra with a EG/DC ASR Subframe?
- custom piping/mandrel bend
- 2.5" cold air intake too skinny?
- Solid CEL and ecu only likes to show certain codes OBD1 GS-R
- harness problem
- Oil squirting problem..
- cant get any of the spark plugs out...
- timing belt woe's
- Brake Issue DA Integra
- interior harness Convertion
- QUICK Question:JDM B20B Knock sensor 9/8
- engine takes awhile to warm up. how do i know what thermo i have or if i have one?
- GSR stalls idle bouncing
- LS injectors(obd1) ok to use on GSR ?
- Running rich narrowed down. 94 GS-R
- Ebay Turbo Kit.. I know there not great but...
- Just bought Integra, turbo questions.
- 90 DA Integra suspension problems.
- Need to Replace Clutch -- Advice?
- 90-93 4dr exhaust question.
- RSX TYPE S muffler on Integra DA? Can it be done???
- GSR Oil Cooler o-ring
- Floor Mats
- Plugs dripping with fuel after 3-4 cranks @ 3 sec's each
- Need help.. 90 integra
- parts wtb
- Video: Am I burning oil or fuel?
- Back up lights won't come on anymore. 94 GSR
- Pinout for auto OBD1 Integra - P75-A51
- b18c1 oil question
- 285.00 kms to tank good,ok,bad ? 94 GSR
- OBD0 b18a1 code 9, wont go away!
- i know its my integra but i need some opinions
- gsr cam holders
- Starter problems
- my Da keeps stalling!! Help
- Just got my first integra
- 91 ls map sensor issues! please help!
- A wrecked turbo civic breathes new life into an Integra - Re-Build Thread -
- Mystery Oil Leak Squriting Out Hood
- 91 integra battery light on??
- exhaust help
- Need help with injectors!
- distributer
- problem with suspension
- Upper rad hose for integra with half rad?
- Can you identify these side skirts?
- if you have a slammed or lowered teg, or rolled fenders on teg please check this
- Inexpensive muffler for a 1990 Acura Integra?
- Dead spots in Throttle ? how can i tell 94 GS-R
- Running Light Issue 2000 LS
- new honda owner! ( integra)
- c5 head swap on b18c1... tuning ?
- oil leak problem
- Oil pressure Light blinking (Help)
- Help with TPS calibration.
- Transmission Fail :/
- shift boot bracket?
- Stolen!! ITR FRONT END INTEGRA HELP PLEASE (Socal)
- Steering wheel jerking
- godspeed fuel rail?
- Interior Lighting
- Which Springs?
- Heater Problems
- Ecu question. 2000 gsr
- Need front blinker harness
- Integra Help MEEE if you can
- Idle and timing
- b16a been sitting for 1.5 years
- No Crank but dashboard lights turn on still
- Help! No spark and no injector pulse
- custom ride
- What are these Injectors?
- if you know anything about laws please help and look!
- question about gsr to ls
- Auto to manual parts
- Suspension Refresh (95 RS Integra)
- Car wont shift nor start in gear
- 2002 USDM Integra!?
- Leaking Coolant and Overheating!
- Help retarded gsr acting up
- Hardrace Front Lower Control Arm quality?
- Need adive on possible Integra buy...may have water damage
- 91 Integra Running Rich
- ecu.question?
- Need Suggestions for changing O-ring from OIL COOLER
- Cant Get Car To Start, I Read And Tried Everything
- 1993 Integra getting hot!
- Loud screeching noise coming from passerner side. timing/other belt ?
- best machine/build shop in orlando???
- few issues with integra plz help
- Fuel Leaking..
- RUST REPAIR
- Tire tread question
- Please Help me
- 92 LS motor swap
- GSR Valve cover PCV valve ?
- washed out piston rings! how long can i drive her?
- About distributor issue messing up every 2-3 months
- low idle at stop/shutting off
- 95 ls with b20 swap cuts out when full throttle
- 01 gsr passenger rear caliper stuck. Help.
- 94 Integra overflow tank steaming/hissing
- WTB p75 obd2b ecu
- Need help(2001 Acura Integra GS-R B18c1)
- Electrical issue
- 2k idle when clutch pedel pushed in untill stoped. 94 GS-R
- Whats the difference?
- Db1 exhaust
- intersection lights placement on my dc2
- motor wont start
- Clogged Cat, now car not starting..
- Can somebody help me...94 integra oil leak
- b20 swap into Integra
- Something Squeaky-ish, Detectives anyone?
- planning a b18c1 build...any suggestions?
- 99 integra spark issue
- 2000 Integra Project
- super charger?
- B16a2 1999 si trans into 1999 LS integra help
- Tranny & ecu question
- No spark issue need some info!!!!!
- SOcal jdm motor importer...
- b18b build
- PLEASE HELP GROUND ISSUE 91 acura Integra!!!
- 2000 GSR Darkvioletpearl
- Interior
- 94 4door integra b18b precision turbo
- Cam gear, is it worth it?
- Automatic Shut down
- issues finding out what b series my head is.
- B18C1 Crank swap question
- 91 LS No Start No Spark with some crazy Gremlins - Help Please!
- alternator???91 tegg please help
- 94 integra cluster parking tail lights won't turn off
- Info on a YS1 into a 1999 auto to manual integra.
- Forced induction
- IACV on my gsr throttle body help
- 92 gsr , b17a to b16b
- HELP need help with engine swap for 99 gs integra
- axle tranny fluid leak! PLEASE HELP!
- 95 ls, pinging noise from the engine
- Advice Needed - 01 LS w/ "bad" cylinder
- 91 Teggy Problems
- How can I tell if I have an LSD tranny.
- 98 Integra mudflaps
- rhd question with clean and salvage title
- Sunroof sticks really badly. have to hit it to open 94 gsr
- rough idle while trying to start up/tick tick noise coming from manifold side motor
- STRANDED! Please help coolant issue!!!!
- AEBS intake manifold install
- ls vtec build
- 99 Integra For sale
- LMA's for S2Pro1's?
- Cold start issues/idle setting 94 GSR w/s2 IM&TB.
- Best Head Gasket for the Bucks!?
- Stock shock question
- Gsr obd1 p72
- parking pole and rear fog switches with armrest delete???
- Will civic sunroof motor work in an integra?
- Selling Acura Integra Super Cheap!
- the worst thing that can happen to your Integra (accident thread)
- What type of cams for all motor lsv
- Will 94-97 Rear Mud Flaps Work on 98-01 Rear Bumper?
- My DA9 is bogging over 3k
- Civic eg steering rack onto a integra gs help asap.
- GSR Skunk2 Intake manifold and throttle body)
- Car idle
- Cable to hydro (hush22)
- ITR trans into DA
- oil turns black almost immediately after oil+filter change 94 gsr.
- Cold start problem
- brake problems 1996 LS Auto
- B18a1
- Noob questions for 1 piece oem headlights
- How much of a drop?
- fan wiring issue please help!
- Usdm fog light wiring. Looked in faqs, They're jdm
- Suspension Related Problems
- 95 gsr no power to injectors.
- Buyin my 1st Integra
- Trans rebuild
- 5 speed ecu in auto integra helpp
- jdm p30 reving weird in 0bd1 gsr
- 94 integra rhd conversion question..
- 98 integra obd-2 with codes help me! plz
- Bride seats....are these real or replica?
- LS to GSR cluster
- 5th Gear - GSR
- looking for exhaust
- WTB da9 parts
- Video/Photos of our Turbo Integras
- New Here with my DB7
- Ordered Megan Racing Headers 2000 LS - Reviews?
- engine bay harness's
- Little help on Headlight Rewiring
- JDM Front: Yay or Nay?
- New to Hondatech.
- Idle surge and hesitation problem please help!
- New bought gsr with problems
- front wheel hub size
- help identify these oem integra seats
- Burning lots of oil!
- Help with gsr block
- Transmission oil seals. How do you do?
- Fuel pressure/Injector problems
- New to honda-tech
- Trying to make my b20 non vtec all motor
