Check Engine Light How To check With Paper Clip?????
Old Oct 24, 2002 | 02:23 PM
integraautox's Avatar
Default Check Engine Light How To check With Paper Clip?????
Ok i read up on checking your codes with a paper clip. I toke off the ecu cover and located the green thing and pulled the 2 thing out there is one with 3 spots to stick it in and one with 2 spots. Which ones do I stick the paper clip into to check the codes I tried numerous combination but not one has worked. does any one have good directions and which one to stick the paper clip into my car is a 94 integra ls thnaks
Old Oct 24, 2002 | 02:36 PM
GSRaCeRbOI's Avatar
Default Re: Check Engine Light How To check With Paper Clip????? (integraautox)
http://www.bseries.net/html/garage/engcode.php
http://www.c-speedracing.com/faq/06.html
and after you retrieve the code..heres what the codes mean:
http://www.c-speedracing.com/faq/05.html
Old Oct 24, 2002 | 02:48 PM
Default Re: Check Engine Light How To check With Paper Clip????? (GSRaCeRbOI)
i have reasd that but what two things do i plug it into there are 5 slots
Old Oct 24, 2002 | 03:19 PM
GSRaCeRbOI's Avatar
did you look at the pictures? look where the wires go/corresponds w/ the pins and jump that on the light blue connector.... your basically connecting/bridging the 2 wires/thru the pins w/ something conductive (paper clip, wire, spade connector, etc..)..
Old Oct 24, 2002 | 09:07 PM
is it the the one with 2 inlets or 3 inlets
Old Oct 24, 2002 | 09:21 PM
Paste's Avatar
Loved
If you have a helms, look in it. If not its the blue thing that is plugged into the green thing. you stick a paper clip in the two holes and turn the key to on. Not too hard...
EDIT-pic
[Modified by paste, 11:23 PM 10/24/2002]
91civicmaine
Mar 16, 2006 09:37 AM
iwubmybb4
Dec 1, 2005 01:59 PM
CDN Yellow ITR
Nov 4, 2005 01:12 AM
Dohc99tegLS
Dec 18, 2003 10:20 AM
Slow
Nov 16, 2002 03:53 PM
