View Full Version : Acura Integra
- stock radiator fans
- Mad Catz zeta?
- Integra Immune to Laser Detection?
- Venom 400 fuel management??
- synchro's???
- Got my GSR yesterday!!
- Help !!
- CAI diameters???????
- stock type r exhaust
- Mugen Revealed - The secrets of the OBD I computer chip.
- LS exhaust question...
- To those with the Apex N1...
- RSX-S H1 4300K HID vs. 95 Integra GSR's 6000K HID
- exhaust question
- new (?) inexpensive lightweight cast wheel for us to play with????
- type-r springs
- godspeed web site home page
- i am sure this has been asked, but i am just looking for infor on engine block codes and swap
- Which headers??
- valve adjustment -> DIY???
- Time to drop tranny and install clutch/flywheel?
- when is tint illegal?
- Got ripped off by TurboDC2?
- injen or aem cai
- My RPM's when rev'd when it comes down it settles at 1,000 rpms, then goes up a little then drops, n
- 3rd Gear grinds when shifting over 6,000rpm.
- Fluidyne Radiator fitting?
- 94-95 gsr P72 OBD1 ecu
- my sway bar bolts got loose
- Rods
- ?? about LS IM
- Do I need more fuel?!
- Does this make sense
- h22a into a integra
- which spring type would you prefer? Eibach prokit or comptech.
- AC smells burning on my 94GSR. help?
- time to build my baby please help me pros
- ****Godspeed test-pipe****
- Effect of lighter flywheel on feul economy?
- does b18c5 internals fit in b16 block ?
- This had been asked before, but please help
- Where to get Hawk brake pads?
- anybody know any good body shops in south jersey/philly?
- interior painting help??
- Accord V6 brakes on Integra?
- 4door GSR Questions
- Are AEM brake pads better than stock?
- Mudflap removal?
- Which of these two LSD's fit in my B18B?
- Place to find the cheapest NGK's
- 2001 Integra Battery woes..
- LS TURBO
- B18 stock fpr vs. B16 fpr
- Do the integra LS/GS have their own emblems?
- High flow fuel pump
- ITR LCA's on LS
- Dumb A$$ Car Theives!!!!!!!! Found my car!!!!!!!!!!!!
- camber kits
- Have K&N Filter, should I go with AEM CAI instead?
- HELP...steering wheel is cracking!
- is there a way to modify our bumper lens?
- May remove the tar/sound deadening material. Just a quick question.
- *****Pics of Philips 6000K HID install**** Update
- Annoying rattling close to my AEM CAI...wtf
- AEM CAI
- radar dectectors, which one do you use?
- 2000 GSRs with spunk2 IM?
- What ATF for 90' Integra Auto??
- Does anyone have the ES oval muffler from JHP.com?
- Any aftermarket exhaust with not to big of a rear muffler/tip for 94+Integras?
- What is the Hp created by Greddy turbo and JRSC
- JDM ITR wheels
- Possible LS CR
- What Model Engine?
- aem
- koni reds Q
- aem intake
- Automatic Integra owners: What mods do you have?
- short shifter
- aem or akimoto
- next step
- Shift Knob: Would you use this?
- HELP!!!!!!
- gsr timing
- Has anybody seen or heard of the new autolites 8000k HID's??
- Knoxville H-T meet
- Is the suspension on LS same as GSR?
- finally got the dounut gasket in there......can this be?????
- skunk2 front camber kit for GSR
- koni yellow/ground control install
- Purolator PureONE??? + WHy is my Oil Leaking!!! WAHHH!!
- Best Cams?
- CHEAPEST Ground Control Coilovers?
- What gauge wire for engine grounding?
- is there any disadvantage to a light-weight flywheel?
- JDM Honda Aftermarket Products Oil Filter or Mobil 1 Oil filter??
- LS crank pulley the same as a GS-R???
- tailgating ticket....
- a 96-98 Hatch w/ 3rd gen Integra GSR engine..ECU question
- is it true that the hub assemble of an ACURA VIGOR will be a direct bol on to the integra
- Rattling at 3k RPM for 94 GSR
- DC/MD/VA meet/cruise
- Need your guys help!!!!!!!!
- Pic of C's Short Shifter
- QUESTION
- Will a Type R muffler fit a 97 GSR? Any extra parts need?
- What is GSR spare tire sz?
- to those with del sol seats and teg rails
- So. Cali. 2-10-2002 Meet: Fudruckers in Pasadena @ 12:00 PM, Dromo 1 afterwards, Details Inside...
- Guages, who has them and do they really work?
- plug for rear wiper - TODA RACING plz help
- 94 GSR's with leather??
- whats a good price for used Red recardo seats with seat rails?
- 94 GSR Timing Belt...
- intake questions
- fuddruckers meet
- anyone with konig rims?
- Installing AEM underdrive pullies TIPS please for 94 LS
- Is it a good idea for me to get the AEM FPR and B&M fuel gauge?
- rough ride....
- Heatshield
- Possible scammer: TURBODC2
- What would be the best bolt on for a stock 94 GSR???
- OT: question about posting pics in sig
- quickest bolt on gsr?
- Can anyone tell me where to get the The Plastic peice that surounds the guage cluster with the spots
- Seat belt latch with Coreau seats?
- My dyno charts...
- exedy clutch problem
- toda c or jun 3
- Pretty cool eh???
- prelude seats...
- i just changed the rails on my teg passenger seat... one side moves forward when i lift the right ha
- what's the thought on Crower 62403 and JG 1001 cams for a G3 LS teg?
- Can 94 up integras use 90-93 integra front shocks?
- Just installed my KYB's, I only have one complaint....
- Buying 16's, need tire suggestions.
- Help, car almost stalls out when at idle and rev and has weak take off
- Rear window windshield squirter..
- GSR rims center caps..
- what can it be?help needed...
- rear taillight fitment between pre 97 and 98-up?
- Just installed ITR rear sway on GSR....
- OT:Well guys it looks like i will finally have VTEC.....
- 3rd gear problem
- Integra Shootout @ California Speedway 2/17
- how much does gsr tranny weights?
- Lets start a meet for supersonic gsr's only
- Installing OEM fogs
- update: got my Philips 9006 D2S 6000K's working now....
- mugen bar on LS
- Greddy Turbo kit for Integ GSR
- Tansmission Issues. HELP!
- Engine Compression?
- 94-01 Integra factory spoiler
- SARD FPR
- dyno chart for comptech 4-2-1 header
- Link for push button starter? Did search
- Radio housing?
- Tokico Shocks
- sensor question
- gsr exhaust manifold
- Rota Slipstreams
- 9006 6000K D2S Philips HID arrived....dont know how to install it...HELP !
- Suspension on a budget....
- Thread size on shifter....
- RS Auto to RS Manual, anyone Recommend anyone that can have this done? =)
- sunday meet
- air hole in their signals for the cai?
- Good cams for turbo???
- USDM ITR Header and cat on a 94 GSR?
- Car pulls to the left but alignment is good - what do i do?
- Part Number for a ITR throttle cable bracket
- What size is the stock exhaust
- s-afc installation?
- ITR brakes...
- Will 1999 Civic SI Header fit a 96 Integra LS?
- Anyone using the specialty Adj Ball Joint Camber Kit?
- test pipe loud??????????
- horn replacement?
- What other Honda/Acura motors have the same fuel rail & FPR as a B series?
- Skunk2 chipped p28 w/ v-afc
- GSR intake mani vs. LS mani??
- 2-door Integra leather seats onto a 4-door Integra, possible?
- GSR timing belt last 107,000 miles+???
- Downsides to Z10 Radius Arms?
- my car vandalized...once again
- adjusting GC coilovers
- Why do things keep breaking or falling apart in my car??? I HAVE only the extremities of HEAT or COL
- Removing my spoiler(Part 2)
- Attn Rota wheel owners: Did you need hubcentric rings??
- just got header installed,.....not the color change trick already!!!!!
- Type R swaybar - what parts do I need?
- Need help with fittings
- Time to get new tires
- Where to drill through firewall?
- Would OBD1 worth it?
- hood question
- Clutch pedal too soft!
- 4 door handles in coupe
- Removing my rear spoiler..
- Suggested mods for Integra GS
- fastest all motor GSR...
- tires
- Just finished installing KYB AGXes!!! :-)
- Which wire to tap for Air/Fuel gauge?
- whats the best exhaust system for GSR sedans?
- Overbored Throttle Body? B18C1
- Best high flow cat
- CD Player doesn't work when it is cold
- Vin #'s
- How much are 96' GSR wheels worth???
- ok where is it?
- Apexi RS cat back?
- Anyone with the AEM 4 POT caliper kit running 16" rims?
- Koni Sports
- Sound or video clips with comptech exhaust?
- Can the Projector lamp be tightened?
- online acura parts store like majestic honda???
- Integra Rear Sway Bar Question
- Carfax report please? Thank you!
- Highest CR on 93 octane.
- Has anyone else broken the valve cover studs ??
- will my AC unit fit in a 94 gsr????
- Can anyone suggest ways to protect your car from being stolen, alrams, etc....?
- changed tranny oil
- ? ABOUT LS SWAP
- Exedy Clutches
- Motor Oil
- my gsr is totaled !!!!! all good parts 1998, black
- 94 TEG LS
- Clutch shudders when being engaged... normal?
- Stock Specs of a 99 GSR?
- First gear lag for gsr?
- $10,000 for a 96 Integra gsr. Good or bad?
- help! i need help.. my clock doesn't work... or my radio.. i think my friend wired incorectly????
- Is this genuine Mugen Strut Bar (link inside)
- Opinions.....please???
- LS owners with chips??
- Anyone have bad door hinges?
- Z10 Groupbuy on All Products
- OT: Whats that Acura parts web address? A & H or somthing?
- ECU chipping on a Auto LS?
- please help me asap teg is smoking!
- Skunk2 Intake Manifold Question
- ASAP: Need a GSR or Type R fuel pump in the Vancouver area!
- How mcuh HP does a throttle body give?
- OT: (but for a school project)....I need to know who started the import scene (if this is even know
- Would a 60mm catback exhaust from any JDM maker support 200-215 WHP?
- detonation questions
