View Full Version : Acura Integra
- What to Do 91' GS Integra
- vtec point for skunk2 stage 2
- SRR cup kit on integra reviews??
- good price?
- How do you turn OFF the check engine light?
- 90 integra tranny and clutch HELP?
- 1994 power side mirror same as 1998?
- HELP ME PLEASEE......!!!!!!
- idle problem: 2000 integra LS
- Well it happened.........AEM + Water.
- Modification steps: Anyone know where I can find a chart for modifications steps & HP increases for
- Type r OPtional body kit (not conversion)
- Hose Techniques
- how do i add my pic????
- any one want a strut bar for a 90-93 teg?
- I need Short Throw advice.
- shocks or springs, which one of these makes a squeaky noise when you push the car up and down?
- How effetive are hood locks and autolocks?
- everyone with kyb shocks please take a look!!
- gasket removal
- Integra's rear traction
- Short shifter question
- 94' integra tie rod (drivers side) HELP
- Finally, My GSR is back in action. Lookiee here--
- How much could I get for my teg?
- !!!!!!!!!!!! come on let me in ...what do i have to do?????
- car starts...then bogs down...wtf
- Engine Codes
- Engine knocking / over heat.....
- 2dr carbon fiber hatch ???
- looking to buy a roll cage, what do you have?
- rear strut bolt wont come off
- alignment q's
- Best springs or Coil Overs for Kyb Agx's?
- LCA removal?
- Help! Turn signals don't work.
- skunk2 coilovers
- how to remove the trans?
- camber kits??!!
- fuel filter bracket hose?
- No start after Distributer Cap and Rotor instal
- Major ignition issues, need help bad...
- Dipstick question from the noob
- Headers don't clear my oil pan
- Advanced or Autozone for a new master cylinder?
- oil change?
- 91 teg. stumbles and no power at low RPMs. any ideas?
- >>>>>> true sleeper <<<<<
- what seats will fit?
- skunk2 cat-backs
- cam seal part number
- VINS: Where? ***HELP PLZ***
- Alternator Question.....
- Want to go All Motor... Suggestions?
- What Causes Brake Pads to Wear Unevenly? Help me correct this problem
- skunk 2 question
- Can I borrow someone's 94-99 GSR catalytic converter (PA/NJ)?
- How to remove ECT sensor on DOHC VTEC head?
- Auto to Manual tranny swap 90-93 Integra's
- ABS light coming on after Legend brake install...anybody else have this problem?
- Steering Wheel Shaky
- HELP!!! CAR WONT START
- people from chicago i need your help
- skunk2 tie bar q??
- 90 integra seatbelts
- bronze te 37 copys?
- Good engine ECU combo?
- More horse power?
- clutch clip
- RPM launch
- I know I am a newbie but I need help fast PLEASE!
- what is the size for 14 inch integra ls steelies?
- gonna swap need a quick answer
- help check engine light
- How much do clutch master and slave cylinders run for?
- coilover suspension
- Anyones car follow grooves in the road?
- Want to know a estimated 1/4 time on this setup...
- anyone running tein s.tech springs with blues/illumina's?
- Electrical Problem... Please Help...
- Recirculation port from valve cover to intake??
- Motor Oil Grading....what should I use on a gsr with 86k. 10/30 or ???
- How to replace studs on front brakes?
- Minor shop problem, any suggestions?
- Manual tranny fluid....what do you guys recommend?
- Can overfilling your oil cause the engine light to come on?
- Water Leak from my teg
- How to tell between OBD1 and OBD2 ecu's?
- H22 swap 1/4 time?
- Gsr puttin tranny in need help.
- Integra axle nut size? (searced already)
- H22 swap shop in san francisco?
- Need Some Help
- Help me with my integra please
- Sway bar pics?
- Will 95 gsr oil pan fit on B18A (DA Tegs) with no probs?
- Ebay ITR Wing? Would you trust it on your car?
- i copified my head, YARR!?!
- no spark :(
- HELP!! What kit is this?
- tranny type????
- No muffler ..Will I Die?
- CV Boot weirdness
- repairing a jack
- air/fuel gauge
- ES oval muffler is loud and sounds like sh*t **video**
- Which spark plug wire set would be the best?
- Help, I’m having hot start problems…………………
- Front seat recline repair question
- really quick question
- 90-93 Main Fuel Relay? or other ignition problems?
- Broke spark plug, need IMMEDIATE help PLEASE!!!
- cam seals???
- Ls-vtec
- Passenger Door window and lock is fucked up
- -Tokico's Illumnas w/Neuspeed Race?
- Zenki Lug nuts
- 91' Teg engine b ay pics?
- 95 teg strut bars and sway bars
- Snapped A/C line (?)... WHAT TO DO...
- head gasket
- Wilwood Big Brake Kit
- NGK BKR6E-11 the same as NGK V-Power plugs?
- running hot
- instrument panel light replacement
- Spark plug problems
- Is there any difference between the 2002 Tein SS and the 2004 Tein SS for 94 teg
- Using MSD window switch with ZEX
- Just wanted to know if ne one else is noticing this!
- HELP im retarded
- having a problem with DC headers on '93 GSR
- SuperCharger Question
- VAFC
- what does fuse23 correspond to?
- which year gsr sedan is best?
- what should i be paying for a 94-97 integra shell?
- Integra 4 Door Visor Kit??
- What cams are these, ITR, GSR, B17, CTR etc. etc.
- My valve cover is missin' a screw!!!
- Searching to see what a apexi ws sounds like?
- OBDII Distributor with OBDI ECU - is it possible?
- 92-93 integra oem bumper in S. Cali?
- found a header that looks identical to DC
- axle shaftttttttt
- Just brought a stock GSR from 1-owner for $7500 with 85. Its a 98. Good deal?
- Question regarding amber interior lights & OEM head unit
- Best auto tranny fluid?
- my car keeps on over heating so
- act clutch problem
- ls- DC header
- HELP...Need help with pcv...
- Is it just me or does the 94-97 Accord front similar to the JDM Integra front?
- are non abs axles smaller than abs axles on a b series
- Will 98+ rear bumper fit 95 SE?
- tranny.
- Swap GSR 5th gear into an LS tranny ???????
- Carbon Kevlar lip for DC2 integra?
- htInterior parts for 90-93 Integra
- cranking but won't start
- Windshield help.
- Exhaust question
- help. timmings off
- I'm looking at a new car, how to validate authenticity of a swap?
- Need Help on wiring OEM Fog Light Switch
- Screeching noise
- clutch and flywheel.
- Problem with axles
- cam gears?
- erratic idle issues- again
- black smoke coming out of exhaust
- are camber kits necessary?
- LS's GSR's with ITR calipers....did you change your brake booster and propvalve?
- Pics of my integra....AFTER wrecking into a semi on the highway
- IS this a good dyno number for a 99% stock GS-R?
- Front turn signal light-up, 98+ Integras
- fuel pressure regulator
- LS vs GS-R?
- 00-01gsr header on 95 gsr......... how do i make it fit?
- silencer in exhaust
- 91 LS suspention? daily driven but frequently at 1/4 mile
- What i need for Ls Vtec
- HELP!! PCV valve location
- Wheel lugs...HELP!!
- Should I buy a shell for my first car?
- Newbie
- speedo, tach, and temp needles dont move.
- just a new headlight idea for integra projector i though of
- Looking for GSR engine...
- 1 revolution of crank = 1/2 rev of cams???
- need carfax report!
- Quick question
- Bypass Valve
- Off topic, but need help
- problems with the camber kit
- NOOB HERE
- integra wiring problems
- wondering y water gets in my integra??
- Skunk 2 Manifold Question........
- ZEX TPS help
- electrical q's
- need uberdata LS basemap
- resonator help get rid of the "rice" sound?
- for those with 8lb flywheel, how much do u have to slip the clutch for driveability?
- accidentally pulled off oil pressure unit wire
- leaking oil pan
- Low comp in Cyl1...venting...
- oil plug crush washer?
- JDM 1-peice headlights?
- camber kit?
- Removing Rear Quarter Panel
- Can't Find Wire For Speed Sensor!
- gs r sturt bar question..
- can anybody runs me a carfax
- Is B18C and B16C distributor interchangeable?
- cold air intake in automatic
- ecu's?
- how hot (on temp gauge) does your turbo'd integra run?
- electrical problems PLEASE HELP!
- 1990 Integra catalytic converter question
- JDM Type R Header In A Ls
- Longest swap ... drop it in or take it out from the top?
- how to remove abs wire?
- New Member
- 87 integra external coil...
- JDM ITR suspension install
- 3 MAP - manifold absolute pressure sensor
- looking for pics of cars on H&R OE springs and experiences with them
- Blown Headgasket?????
- *Went back to the track to claim my 12 second timeslip, Woot woot*
- 2.5 piping too big?
- Flywheel
- What does the left side windshiled weather stripping cost...
- wich ecu for gsr ...
- lightening a itr flywheel to 10lb?
- Anyone have a CARFAX account ??
- wearing out rod bearings
- URGENT...TRYING TO INSTALL VAFC.
- Need help with wing install
- ITR HID wiring how to
- clutches?!?
- i need a switch for sunroof
- ABS removal?
- integra harness
- 90-93 service manual?
- peak & hold / saturated question
- Can someone carfax this VIN for me?
- Whats a good company to buy a front clip from
- Gapping spark plugs..
- Another VAFC problem...(yes I searched) Repost from tech
- clutch and flywheel?
