View Full Version : Acura Integra
- Stolen lights...
- How to change vtec gasket
- overheating problems with my gsr turbo
- Werd oil leak
- How To Replace an Ignition Coil?
- chipping ecu
- ls trubo or ???
- b18 motor ceased up. what could it be?
- estimate
- Skunk2 IM on a B18A fit a B18B?
- Car reving by itself after nitrous spray! HELP!
- GSR misfiring?
- Cluster Light Won't Come on
- Is this the right part?
- Gsr Motor Won't Start Checked everything!
- mounts...?
- Help me please with this integra cluster
- HELP!..scratching/squealing sound coming from front passenger side rotor
- hasport tranny mount??
- ls vtec problems
- Ls-VTec Question
- search button sux!!!! Window visors
- HELP: b18b looking for vtec head
- changing cam seal.
- Stock b18b rpm threshold?
- omg my eacv
- b&m pro edge 45074
- gsr question
- Type R or GSR swap????
- b16 into 90 integra gs help!!
- Reverse to First gear problem
- Is this GSR worth what they're asking for?
- Cat back exhuast installation questions!!
- LCA & endlink question
- Bled Brakes might need readjusting?
- b18 engine questions
- need to replace instrument cluster lights! help is appreciated.
- Iac (eacv)
- Weird distributor problems... need some help
- Idle problems - screw fell down manifold (was: Need help please)
- aftermarket temp gauges
- My Future setup (please comment) good or bad
- 2 CEL's, possible bad ECU?
- LS swap.. Crank Sensor question
- b18b1 - performance questions!
- loose shifter
- rear visor for 93 da
- Car wont start after 3mth hibernation
- Cigarette Socket Illumination
- time for a new/newer transmission?
- GSR high idle 3000 to 4000
- Cluster light & running lights
- super low boost ok?
- Crank sensor question on B18B
- valve cover stud snapped
- intake manifold ?
- help with build
- how do i know if my vtec engages?
- help me please
- b18c1 question
- LS/vtech build
- kinda jerks it self ls
- Iac (eacv)
- Normal burning oil 2qts GSR?
- ecu code
- auto trans questions
- New pads/rotors squeeling???
- Ls Auto to Manual swap
- DA/dc2 traction bar ?
- b18a1 head compared to the b18b1 head
- Stage 2 Clutch
- help for a fellow teg owner?
- 89' LS... starts sometimes..sometimes doesnt..
- maint rego light
- distributor issue
- need help!!..vtec pressure valve?
- SToLen Block*
- Idling So high
- What is the proper procedure on changing my ys1 tranny oil>?
- Changing Quarterpanel glass
- DA interior conversion
- 91 da with startin problems help
- window problem
- Need a little help with my b18a1
- 94 DC2: JDM ITR swap worth it?
- list of stock integra throttle body size plz
- 2000 ek coupe lip??
- Vibration problem on my Da please help!!
- Hood Cable Release
- ECU limp mode (no CELs)
- Need a/c help!
- thinking of trade want to drive something new
- Question about AC not being icy cold...
- Help me pick a muffler for my GSR
- Write up for blown head gasket
- Need help like now Gas gauge.
- Driver side Headlight Out!?!?
- abs pump clicking question
- 95' Integra 4 Door
- Brake Lights on even when car is off.
- Header, test pipe, exhaust Q's for GSR motor into RS chassis(4 door)
- visual difference between gsr and ls
- part number help!
- Horn problem
- 3000 idle!?!?
- LS/Vtec Rebuild
- Cost for new windshield?
- power steering rack?
- How can i tell if a turbo mani is ebay or not?
- 14in HX wheels?
- IAT Code 10 CEL error
- Very Worried! Help! Knocking coming from motor
- profab header on my da
- b16a swap worth it?
- piston ring reccomendation
- mudguard question
- fuel issue...
- HELP: Noisy Transmission
- Would i be stupid to trade for this front end?
- Replaced plugs and found oil on threads of 2 & 3 - awesome.
- injectors for nos
- Stripped shift linkage hole on transmission
- Whining Noise from Belt Area After Timing Belt Replace?
- RC 270cc injectors
- who has the similar setup
- putting a turbo on a B18B1 need help please
- Better to buy new LCA?
- integra ls oil problem
- B18/B18C1/B18C5 question...n00b...
- Help car runs like sh*t
- Help vtec!!
- Best proven bolt ons for B18C1
- ls/vtec question/input
- Jdm b16a sir2 into 91 integra rs
- seat brackets
- p73 ecu question
- Turn signal moisture
- what would cause the code..
- Clutch is done for... pics...
- My ignition wiring all messed up Help
- Questions about LSD in a GSR trans
- AHHH metal scratching noise = BAD
- Good jack for lowered car?
- 92 DA RS swapped in a b17, bogs as temp goes up, jdm one piece fog light question too
- oversizing TB worth it?
- db8 and dc2 lip
- questions about a swap
- just installed coilover and then i lost steering
- Oil problem Oil blow by?
- Sway bar buying
- Alternator help!!!
- Block Noise help plz
- ITR lip screws?
- Removing Door panels help!
- confirm tps
- Do I need to RETUNE??!?! HELP!
- ABS Makes Noises
- Transmission help!
- 98 GSR swap in 91 DA
- B18b1 header oil leak
- Vacuum Question
- Exhaust Manifold Leak
- stock b-series pistons and rods
- Vacuum diagram
- Bad Vibration
- A Hole in the Cylinder Head Exhaust Port?
- shifting problem!
- speedometer actual speed?
- Head Gasket
- Check this out__ this dealership stole pictures of my GS-R, posted it on AUTOTRADER
- What size bolts??
- What the hell is that whistling sound?
- Need opinnions from those who have HID retroffited headlight using Ebay's headlights
- 91 integra CEL code
- Header emissions test
- Greddy or 5zigen headers
- 97 integra
- Need help finding a front lip...
- Anyone take out IAB system on GSR mani?
- whats wrong with my defroster?
- whats the best short shifter?
- Differences between B-series axles??
- got some nippon 6.5 wheels 195/50 or 205/50?
- How to repair subframe bolt hole threads?
- how much could i sell my gsr shell?
- slow when hit vtec?
- What kinda ECU chip???
- HELP gsr throtle cable harness on aebs throtle body
- 3rd Gen Interior Question
- Oil leak from Head Gasket
- striped valve cover bolts on b18b1
- Low Idle, Lil sluggish, and does a lil sputtering...
- gsr lag on high rpm
- bouncey idle, engine stalls
- Compression Problem
- gsr smoke when rev high
- Rear Engine/Trany Mount GSR and ITR same or different?
- LS swap questions
- 97 integra wont start
- High/Bouncey idle?
- Ls tranny question
- us type cluter in 94 teg
- car wont start, fuel pump works, help
- Smog pass in orange county???
- Skunk2 Pro Series Plus Camber Kit installed, still cambering?!
- chip or tune
- tranny help
- Would EP3 seats from an Ek fit a DB8?
- Distributor ignitors the same?
- crower 403 question
- I used 10w30 oil on my da b18a1,bad?or not so bad?
- Great site !!
- quick question about a 98+ conversion
- Need a DA Integra shell!
- 94 gsr sedan.. need advice..
- Odd Question but it is integra related...lol
- having some abs problems
- Gsr swap?
- Interior Lighting Problems
- 1994 INTEGRA RS ? yes or no
- help stall, no start
- Evap solenoid questions for GSR swap in a DA
- whats the diffrence between this short shifter??
- Can a type r oil pump fit into a b18b1
- Exterior Mods Beside OEM
- JDM B18B Valve Lash Adjustment the Same As USDM?
- what is a good exhaust
- CEL Inoperable (not working)
- camber issues
- type r console to ls
- No VTEC: cel trouble code 22
- How much is this trans worth??
- Integra short throw shifter questions plz help.
- DA wearing inner cv joints out.
- Where can I buy a wheel bearing?
- New clutch. Ez shifting when moving, doesn't like shifting when cold/sitting still.
- My 97 integra
- Parking lights fuse keep poping!!!!
- RSX TypeS Front Brake Upgrade on my DC2
- Fuel System
- need help identifying ITR cams
- gsr head question
- charcoal canister vacuum line question??
- HELP!!! DB1 owner's................................
- help with drivetrain knowledge
- Can't figure out why integra won't start, not the main relay
- Name That part Web site
- How to Do a Cam Seal Replacement On 2nd&3rd gen integs
- Help with drivetrain...
- clutch Problem (help before i set my car on fire...)
