- about tires and sizes...
- obd1-obd2?????
- '01 GSR suspension
- My encounter and final thoughts about kyokugens, please read if you own them.
- Greddy + Thermal Stealth...pro's and cons?
- GSR tranny S80 Y80?
- 4Dr Sedan Exhaust?
- Quick question... Are there holes under the "ACURA" emblem on the left side of hatch?
- Kyokugen Lug Nuts? Question about quality!
- Air bag laws? can someone explain
- Gsr Synthetic
- weird problem???? Please help
- map sensor code 3
- Should i boost?
- What do you have to do to put a B18C JRSC onto a B18B?
- Does anyone know---
- Help! I need to know how big the speakers are in the front and rear of the 94 gs-r
- Question about integra fender
- What is wrong with my Cig.lighter Unit?
- can someone give me an idea about how much hp an ls can push all motor on the street
- who has the fastest non v-tec
- ITR Wing Installation? (Anybody Have A Diagram?)
- should i get an Exhaust now or should i wait?
- distributor???
- 2003 Civic Gauges
- How much power?
- code 91 on LSVTEC
- code 72 and 74 help
- LS cams
- Safe to wash engine?
- stronger trannies????
- looking for a non-honda new map sensor...
- Measured Azenis, their wide....Do you use daily driven Azenis????
- I FINALLY GOT THE MONEY FOR THE LS SWAP BUT........TURBO OR N/A ?
- Time for new clutch already?
- Sparco Torino seats
- any LS guys w/ JG 301's
- CKF sensor
- map sensor plz help!!
- JDM front. . .
- Looking for thread on Civic rack in a Teg..
- B18c1 stock internals boosting --- setup question.
- All Motor Setup
- removing exhaust resonator, loud?
- GS-R and LS gauges compatible???
- AIR BAGS $$$$????
- Check Engine Light?
- My Integras propane tank and tubing has now been replaced!
- How do I time my b18c1?/How much retard for 75 shot?
- WTB: Any stock 4 lug alloys with decent tire tread (DFW area)
- sometimes car idles at 1500??
- What all do I need to install the ITR sway bar???
- Why did they stop making the integras?
- 14.5 in the 1/4 today.
- GSR motor in a LS ... questions about exhaust/intake fitment
- Civic shifter for Teg?
- how to wire fan to stay on all the time?
- vtec problems
- OEM Kit rear valences, template for installation??
- itr rear sway bar & zeal b6s!!!
- Hit And Runners....your dead!
- CARQUEST-o2 Sensor 49.99 94+Teg
- car won't start
- HELP!!
- lamborghini doors
- CRV bottom end guys: you need to read this one!
- Neuspeed tiebar install w/ BSQ kit
- Shock recommendations for Ground Controls
- headunit
- vtec disenganging
- time
- PO6 ecu running dohc vtec program?
- Alignment after changing wheels?
- GC sleeves/h&r race/koni yellow question
- ls build
- hondata
- suspension questions
- Are LS and GS-R exhausts the same?
- Shifter boot question?
- parking brake light!
- need some help people
- Pics after SilverStar vs. Stock! ***56K BEWARE!***
- Vtec Hesitation!!!!
- Headlight seal broken...how to fix?
- rims (again)
- abs light on. need help
- HELP ASAP. i need a Kyokugen Key sold my rims but can' t take them off socali
- pics of autopower race bar plz
- Do Integra's Have Micron Filter's?
- Is the 94 and 97 GSR stock exhaust manifold exactly the same? (tried search)
- difference bet. vtec and non vtec?
- Anyone seen these in person? (Ebay Integra Headlights)
- need info about v-afc hack
- 99 Gs-r looking for good cams
- New clutch makes car idle low
- Tires
- good springs for 98 stock??
- DIY Rocks!
- rs now with 5 lug,how do i install....
- How do I pull out Timing on my 98 LS
- Ls HorsePower
- rsx seats in integra
- need to reset ECU after JDM ITR cluster install?
- What's are the differences between between coupe and sedan exhaust ?
- idles low
- My Intergra has some serious staying power...
- If anyone can help....
- Check Engine Light-Very weird situation..
- req picture/defination of burnt valve
- new honda tech user
- Car has trouble starting up
- H&R OE Sport springs
- silverstars
- anyone purchase ITR lip by Abs Dynamics?
- need help and prayer
- Temp Control center
- Spoiler
- Hmmm decisions.... check my problem
- how much for a 91 92 integra sub frame and what do i need to do to fix it?
- door question
- What is up with my clutch pedal? Please help...
- Rolling Forward your Odometer?
- got this replaced, what is it?
- is the 94-95 gsr faster than the 2000
- turbo or super charge my type r
- act clutches
- Cant get my tranny out... Please help!
- part number for ITR throttle cable bracket (one that attaches to the intake manifold itself)
- Coil/Strut Spring Compression
- how much for my '99 gsr?
- can't get integra because of insurance
- WTF.. lol..call me stupid but! Why does my car feel faster sometimes?
- Seat interchangeability ?
- GSR throttle body thingy(actuator???)
- EK seats
- Fuel Filter
- Help me.... my shifter is EVERYWHERE....
- Need help ASAP! caliper sticking?
- Other than extra o2 bung is 94GSR and 97 GSR stock downpipe same?
- will integra rs rims fit on a old school jetta? (4x100)
- Cracked my GSR header. Anyone have Stock '96 GSR header for sale? Or Fix it?
- GSR Owners
- b18a distributor
- ls transmission parts help!
- ITR rear seats in 95 GSR
- cranks
- 1991 Integra GS Parts?
- Sound / Video of Spoon N1
- Air Conditioner question
- GSR water pump leaking, fix or replace?
- Part of a 90 - 93 integra
- 205/50/15 psi?
- Help! Ground Control coilover won't adjust.
- just got a 91 ls...
- ****very quick questions..how much does dohc cams weight?
- aem v2
- Another OBD Question, OBD2 Engine in OBD1 Integra ....
- b18c1 turbo or b18a1 turbo?
- JDM Integra SiR-G
- A few Q's about Toda A's
- clock question 13:00
- need: instruction to install skunk2 manifold on gsr obd2
- ebay spring coilover Q
- supercharger
- Cable to hydro kit in Gen2 integra
- head bolts
- Satin Silver Integra owners....
- 1990-1993 integra exhaust question
- integra 2000 taillight
- Clutch noise
- where can i get hondadata for a decent price?
- right hand drive conversion worth it.
- check engine light after rebuild?
- I need help!
- OBD2 ITR into OBD1 Teg... couple of questions
- can you use a 90-93 clutch on 96 tranny.....
- Skunks IM or VAFC?
- how to put on my rear hatch...
- Anyone dyno a bored throttle body on their GSR?
- Clutch Install
- integra interior
- GSR drivers: whats your gear to speed ratio + tire size?
- question about an automatic integra
- Is a camber Kit necessary?
- Maintenance light
- I need to find these parts in Acura Carland, but can't locate it. can u provide me a link there?
- Apexi ws exhaust and 4-2-1 dc sports header
- *** Help : No light in temperature controls module and gauge cluster ***
- Fuel Tank Question
- ctr pistons in my gsr???
- Which wheels will fit a 99 integra??????????????????
- motor mounts
- I Miss the GS-R
- is this normal for the frt bumper????
- 96-2000 integras
- Aftermarket Pulley Gains
- how much would you pay for the Optional Acura OEM Sideskirts?
- Oil Pan Gasket's Suck
- How to remove power steering?
- good place to get tim. belt/w.p. done in MN??
- integra interior
- Flywheel and PP torque specs for 94 GSR?
- ATTN: Seattle area Integra owners....
- Steering/suspension problem
- accelaeration hesitation on LS
- Best Bang Buck B17
- Camber Kit for an 01 GSR
- anybody got pics of a B18C1 in their 90-93 integra?
- Which teggy should i get?
- Tranny Swap in G2
- got 2 questions on ls motor
- need your opinion ITR or Greddy SP
- tranny additive?
- Spend MY money!! Help with my motor build!! need info/advice.
- tanabe exhaust just broke in half!!!!!!
- Best setup for drag racing?
- so i dropped my car...
- opinions on upgrading suspension
- GSR gearing w/ 195/45/15. opnions please
- skunk2+itr sway bar+beaks= :(
- lookin for Installation guide for APEXI AFC v-tec controller?
- NYC Performance Shops: HT please name the shop and your dealings with them!!
- seatbelt/harness
- clutch question...
- Need Help With Vtec Contoller On JDM B18c
- Anybody have 396 miles on one tank beat?
- Where to buy ITR Floor mats
- New track times.
- Is o2 bad to have in a/c freon lines when refilling?
- intakeeeeee
- Integra 4-door interior pieces
- A/C compressor need
- h&r face springs on my daily driven teg?
- I need help....
- i need shocks
- clutch dies @67800 miles.
- wat is the tranny code for 94+ USDM GSR B18C1
- HELP! Can barely get into gear! Urgent!
- good aftermrkt axles for integra w/ 350 whp??
- b18c1 rev limiter problem
- quick Q on OBD1 and OBD2
- What tire would i need on a 16" to keep the factory wheel specs....
- Auto LS w/ Rev Hard Turbo
- What are factory swirleys selling for now a days...
- HOnda Hp and Trq stats
- Injectors?
- What to use to plug 02 bung when not in use.
- Passenger side wet
- Plz Help... Wheel Bearing questions
