View Full Version : Acura Integra
- Radiator, need a new one.
- how easy/hard is it to change the radiator hoses?
- various questions
- automatic problems
- Wierd noice from trunk area
- need a resistor box
- GSR disscusion!
- Apexi WS2 Or Greddy SP2????
- aebs manifold install
- car flooded-need to remove carpet. please help
- mini-me or D16Y8??
- What kind of turbo should i get? 98 integra ls B18
- will the tsx projectors fit in our tegs?!?!?!?!?!
- Head spacer
- gs-r not pulling like it used to.
- let's try this again...wilwood dynalite calipers onto my teg...
- quick release steering wheel
- ls vtec intake manifold
- I want to stay NA and have a good amount of hp/tq
- RHD gauge piller
- Should I lower it or put on an exhaust
- Power Folding Mirrors
- should i lower my gsr?
- does any body know da Curb weight of an integra 97
- HOW TO TAKE THE BACK SEATS OUT IN 95 INTEGRA
- whats your gsr's gas milege?
- My DA9 Project-on going
- aluminum radiator overflow?
- Couple ?'s
- ECU ?
- B20 IHI RHB5 turbo setup??
- throttle body help please...
- B18C1 won't start. Please help!
- weirdest problem ever... i need help
- Where 2 Buy Hood Molding??
- integra map sensor????
- USDM Seatbelts & JDM ITR Recaro
- Help tsx swap in integra
- Distributor King Problems
- GSR Drive Shifts Fit 5 Lug Conversion Hubs?
- Connecting auto/door dome light to map lights?
- OBD1 vs OBD2 swap into a 90'
- I know what everybody thinks of electric turbos but just read this!
- Lowered car good tow, bad traction in rain.
- Hi, new member from UK
- anyone know if
- leak down compression test
- the world of short throws...
- 2 DA questions - Wheels and Racing Seats
- Motor mount bolts
- no tailight
- need to make 250whp integra any ideas??
- help with oil pan gasket
- improve stock integra
- need to know where i can a itr throttle body
- 250,000 Mark !
- will the railings of an itr seat fit on a da?
- my car got rear ended last week - can i get some goodies?
- Whats A Good Clutch Kit?
- Need a part number
- Car Alarm Place in Dallas????
- replacing intake hose/heater hose (pic)
- best hids
- sunroof drain tubes and taillight gasket
- tranny leak
- GS-R consuming oil
- rack and pinion gearing
- Other Teg Forums
- V2 with a Skunk 2?
- DIY (fender paintjob) anybody ?
- saw blade wheel question
- generic cam seal
- how to fix a small but deep dent on a 95 ls
- HVAC leaking on passenger side floor....
- 96 gsr, put in b18c pistons/rings no have high idle?
- dc header and aem intake don't do anything for my gsr
- Will my wheels fit?
- Integra OEM Optional Sideskirt Weatherstripping (replicating on replica sides)
- my 2nd GS-R
- charged A/C but compressor wont kick on
- NGK G-Power platinum plugs
- Does This Car Have Vtec?
- Brake hard line question?
- Best Spark Plug Wires for 95 Integra LS?
- ALTEZZA"S!!!!!!!!!!
- "Honda" Emblem for Dc2 Integra
- gsr to ls
- auto to manual HELP!
- ABS Question?!?!?!
- Hondapartsdeals.com is to Honda as ____(blank)____ is to Acura.
- name this part: rear brakes
- need help!!! locating the alternator fuse 97 LS
- Heeeeyyy Integra Rear Lower arm
- where to buy oem honda parts in canada.
- ls turbo question
- radiator question
- Motor making high pitch noises??? need help please....
- QUESTION!!! About AEM True Power Pulley Kits.
- Good complete turbo kit for a 97 ls
- benen front lower tie bar and crossmember bar for eg/dc
- Integra LS: Ran for 5 min ran rough, shut off and now no spark?? HELP
- DA suspension question
- do i need a flywheel?
- need advice from tech..please??
- exhaust gasket?
- does anyone have Konig - Britelite (Red with Machined Lip) on a black teg?
- header question
- Integra WONT START!!!! HELP :(
- Possbile B18A1 Build
- Miss Firing!
- H22A in a Teg
- Acura Integra 94 LS, 5 Speed, 170K miles. RPM jumping around. HELP!!!
- 96 integra ebrake help
- Question about noise from engine
- CF Hatch installation question.. (searched)
- Car not running right. PLEASE HELP!!!
- 150K mile maintenance?
- PIC's IF NEEDED BUT BRAKE LIGHTS Q.
- 91 integra no brake lights
- ITR swap into a 94 teg.
- finally!!
- thinking about the track
- loss of brake pressure?
- stock muffler form other cars
- Are there any SRS steering wheels that can be used with a quick release hub
- 95 INTEGRA, SPUN OUT, ANY ADVICE HERE?
- help! overheating
- Problems with Cluster (Spedometer) doesnt work/jumps @ high speeds
- Integra with no throttle responce- Any advice appreciated
- "Clicks" when turning on 94' GSR
- anyone put DC2 seats in a DA.
- pics or vids of thermal r&d exhuast
- Im freshly new!!
- What dipstick do I have? Pic included!
- help with trunk!
- 3rd gear pops out in a left?
- Best lowering springs?
- Good Parts Sites?
- *HELP* Throttle Lag | Low Response Time | Estimated 1-3k Rpms
- B16A1 Overheating Problems
- Integra true short shifters
- putting gsr head on a 98 gs questions???
- How Does This Price Look?
- 4-1 header on b18a?
- New to Honda-tech. Suggestions.
- my fender got hit !!! (jdm dc2) HELP !!
- Another Integra Newb!
- no keys
- 90 Integra, Electrical Gremlins.....
- 1994 integra clutch problem? or worse?
- I need some reccomendations!!!
- wierd noise after repair
- Spoiler help
- questions on turbo for a ls??
- Steering wheel doesn't straighten up after turning
- Rear disc brakes acting up
- ****Stolen Teg, SoCal!!!!!!
- Cell code #8 TDC - top dead centre sensor
- will it fit?
- cant get my air fuel hooked up right!!
- was it worth it?
- 95 Gsr Ecu Pin outs
- h2b or stay turbo
- HEADGASKET CHOICE ON SLEEVED BLOCK
- Idle Air Control Valve?
- ls/vtec
- Quick M/C hard line question?
- obd2a alternater on obd1 engine
- FITV gasket or not
- GSR vs LS vs B16 ignition plug wires.
- camber kits?
- integra lights
- Struts question
- Help with Swapping Doors
- ls head vs vtec head?
- header
- Whats the problem here ?
- Was this a good deal?
- fuel pressure regulator
- Trouble shifting gears while driving..HELP!
- Camshaft
- Suspension techniques sway bars!?!??!?!
- Skunk 2 Composite Intake Manifold
- HeLp!! 97 to 99-00 integra frontend
- obd1. how to get cel codes?
- JDM Front End Conversion Installation
- CTR cams uprgrade?? A few questions
- Help with Pivot Tachometer Install
- need help on 91 integra idle when A/C is on??????
- clutch squeak?
- urgent help please! tegras stranded at walmart
- difference between b20b b20b4 b20b7
- anyone have pics of integra with tinted windows over the dots?
- ICU Questions
- question about my integra
- EVAP/charcoal canister Question
- weird ignition problems on 01 gsr
- gsr swap into ls integra dc2
- Need Help AC Problem
- whats this on a gsr intake manifold?
- Car doesn't feel as fast anymore
- Weird noise when braking
- Electrical problems with GSR swap
- Im new looking swap info
- Beaks SRK DC kit. ????????
- Head installation
- Will rear seats exchange between coupe and sedan?
- Can I fit this battery in my Talon???
- 1997 integra jdm swap!!
- B18C1
- battery problem
- 5 lug swap ?????
- engine light on.
- inseat rail same ? (eg/dc)
- coolant line on gsr
- Added fuel additive to 88' integra LS and now wont start
- HORN RELAY?
- SiR-G
- Center Console Question !!!!!
- 95 Jdm Clipped integra gsr stolen!!!!!!!!!!!!!!!!!!!!!!!!!!! From South Florida! Miami Area
- gsr header?
- where to get radiator?
- Torque Specs for Gsr head
- MY DA IDLING TO HIGH HELP HELP
- need help with wiring harness
- pics of the 96 teg i just got for $1500
- will a vtec solenoid from a D16 work for a B17 GSR
- torque specs? help please...
- Battery Dies after sitting over night, opinions?
- Integra Gsr Procharger Supercharger
- 92 DA with only 18-20MPG WHY?
- IM NEW
- the back Turn Signal on my 1990 integra is dim
- CAR WONT START
- fender question?
- Removing Spoiler
- name of this exhuast?
- cant get proper tps voltage
- help!!! no power door locks and power window problem.
- Rattle
- civic shocks on integra
- IApexi world sporth for 94 LS sedan
- how do install
- Stripped screw for rotor
- code 1 and 4 i need help fast
- My reivew of Tsudo Exhaust for DA...
- NEED HELP BADLY!
- iacv question
