View Full Version : Acura Integra
- cams or port and polish
- Can I go ahead and install shocks/springs and then camber kit later?
- need ecu pinouts obd2
- Help Integra dizzy
- 97 GSR cams... 3 stage vtec?
- What valves you use?
- shift light question
- VAF-C question on 98 teggy? Pls help...
- Grindingg
- my integ makes a squeaking nose...pls help
- need serious help with my 96 gsr emission.
- car jacking at riverside, ca
- Sounds like valves hitting pistons.....
- HELMS MANUAL!!!!
- CAM cap torque spec's
- strait newb turbo question
- Carbon fiber side skirts,rear lip?And a few other questions please take a look....
- Rear hatch hinge sealer... what is it?
- Easier?!
- Wheels?
- Damn Ebay Seller!
- A little help
- just got a new gsr, need some help with it.
- Integra ign lock ?
- b and m shifter
- Trade integras
- Ok Really Novice wit Integras, need your help!
- Need help with my DB1 Integra
- Looking for paint names..
- engine coolant reservoir
- Help with tires quick!!!
- Need someone to help me to..
- These rims on a teg?
- ABS removal????
- Y1 Tranny
- broken axle and dented fender need to fix
- fuel system problem
- Idle problem...
- JRSC with SI tranny---hondata
- timing belt tensioner
- Why should I buy an integra?
- have CEL says ECT problem, is this why my VTEC dont work?
- got a quick brake question?
- wing conversion
- 96 gsr airbag interchangeable with 96 LS?
- OEM Exhaust Header Gasket??
- Flywheel choice for Turbo build?
- LS Vtec? GSR? or LS turbo for 93 integra ls
- Turbos on an LS?
- 95 rs auto b18b swap to b16a1 manual
- SRS air bag problem
- can someone help me
- oil
- How much do you guys pay for insurance
- Just got Hondata!!
- static radio problems
- resister box
- built LS bottom end
- side markers tamplets?
- Is my fuel pump going bad? Questions about the fuel systems on 3rd gens.
- filter directly in the manifold?
- LS/Vtec VS TURBO
- **** Another Teg Broken Into ****
- Reference Materials | Popular Wheel Weights
- Right Hand Drive
- Any San Diegans want to help me replace my radiator? (don't know where else to post)
- I fixed my ABS leak for $1.57 SOOOO EASY
- LS rod strength?
- too much overlap cause lower compression test results?
- IC piping
- Selling a B18A...how much????
- What are the appearence differences in the Integra LS and the Type-R?????
- tranny 2 short?
- Block Question
- QUESTION ABOUT HEADLIGHT ADJUSTMENTS ON LOWERED CARS
- I want a v-tec head for my non
- Maintence light
- dose a b16a1 head run the same vaccum hose as a 90 ls
- Help!!!my teg isn't running right
- jdm headlights
- anyone with a frontmount air intake?
- What head is this??
- problem gettin head off
- stock gsr QM time?
- lip?
- Throwout Bearing same for cable/hydro?
- anyone using omnipower coilovers?
- searched Is there a site where i can buy a 98-01 stock bumper
- How low are you on omni-power coilovers?...is there something wrong with mine?
- Would off timing cause low idle?
- Wiring Issue
- Honda ITR momo steering wheel install
- Si Cluster in a integra?
- For Those Running OEM HIDs.. HELP!!
- Huge problem...any advice will help
- Integra running problems
- beaks kit with ITR sway on Gsr...need instructions!
- Best Intercooler for '95 GSR Greddy Turbo
- valve train question
- shyistock exhaust question
- ctr or skunk2 cams?
- Racing cams
- Removing motor AND trans?
- Blowing fuses!!!!!!!
- b18c1 interference engine?
- OT but funny
- vafc need help
- HELP!! POLARG H3 YELLOW BULBS? fit on jdm one piece for DA????
- Weird noise
- > how often does one need to clean the vtec solenoid?
- Best brand for a strut bar?
- question about O2 sensor.
- gas mileage
- Clicking noise, cant find where its coming from
- OBDII CODE 22
- HELP!!!.... oil pressure sending unit
- Skunk2 Mani Injector Question
- HID owners..i need help.
- G2 HP question (not what you think)
- obd1 b18b auto intake manifold Q. (egr valve)
- Face plate stolen!!! Where can I get a replacement deck?
- HELP PLEASE! Installing GC coilovers.. which sleeve goes to the fronts? Short or long ones?
- Ok, so I bought a 94Integra (LS)...
- Headlight modification
- ** Help me! I am installing my USDM ITR rear sway and a bolt wont go in!
- Jdm 1 pieces for 91 teg
- took my head off (would this be the cause of low compression?)
- What do i use to stick on my "H" emblems?
- is there a difference between a four door and a two door
- diagram for vacuum lines anyone???
- 1/8 mile... 1st time
- How rare is a 98 Integra RS?
- Does anyone know ALL the body color codes for a 97 ls?
- b18b
- LS/VTEC worth it in an auto?
- 99-00 Front conv.
- studdering/hesitation
- 98-up integra on eibach sportlines??
- will obd1 IAC work on an OBD2 car?
- What to do...
- gettin HEADERS
- Question on upper control arm...same part (pic) as 88-91 Civic?
- Unusually high oil consumption, and black color
- STOLEN S/C INTEGRA - NOVA ~!
- Dash BRAKE idiot light
- OEM Part Number Need It.
- what is this plug? pic inside
- Rear End Slid out on me-- concerning.
- Gauge lighting problem...
- Gauge Cluster Inverted LED Install
- Front axles shake
- plz i need help before i buy it ESPELIR EXHAUST
- valve Lash important???
- LSD set up!
- b18a and b18b timing belt
- Timeslip/Setup Assesment: How am I doing?
- oil
- any one know any sites with pda shit for the ecu's?
- Integra ...OVERHEATING?
- Tire Question
- 94 front, 98 front question?
- distributor question
- Check out my new battery...
- No gas in town..help...
- Camshafts
- Wring diagram
- fuel pressure ?
- Race Alternator Pulley
- Taking of stock spoiler
- Where the hell is the dipstick
- will this fit on my car?
- Coil Over installation instructions
- is friends vtec solenoid dirty?
- Clutch issue?
- I just changed my outer tie rods... quick question
- 99-00 si exhaust on 94+ teg?
- 98 to 94 parts
- clutch question...
- axle help!
- reinstalled my oem airbox and fuel econemy dropped
- My new car
- JDM LOVERS AND HATERS
- Which one is better ?
- which fuse for coompression test???
- taking off my stock ls spoiler.....
- Type R ECU in GS-R...possible?
- msd blaster
- Breaking in CAMS
- AC Condensor Fan
- Gotta love them dealer oil changes!
- Non bling-bling pedals with a bit of extension?
- Stock GSR intake fit onto a RS??
- Need some advice....
- GSR motor with LS tranny? v-tec?
- ls/vtec limited to 7000 rpm
- Ground Controls not lowering...
- need help with grs.. and need help with lsd
- DriveSHaft stage 2 axles for a Integra, will they fit a civic with a B series swap??
- ok, here goes....
- Integra RPM signal?
- Cam differences...How can i tell?
- god help!!!!!!!!!!!!!!!!!!!!!!!!
- found out why my clutch wont engage. dont know how to fix it.
- Type R front end conversion on a GSR
- camber squeek?
- aem ems..
- Clutch Master Stg 2 vs. Stock GSR Clutch
- My engine bogs... can you tell me why?
- CROWER CAMS install, car shuts off.
- JKlowering
- 98 teg going jdm
- Weapon-R coil-overs on an Integra
- New to HT - sorta
- GSR and Type R rods the same size and specs?
- largest tire on a gsr fat five?
- biggest width tire on a 95 gsr fat five?
- heating
- 1991 Integra GS Starter Specs? Help Needed!
- abs, pw removal 92 gsr
- Single cam integra
- b18c swap question?
- local meet
- Need Help
- USDM Black Housing Headlights
- ** HELP me! my ITR guage cluster isnt workinn in my 00 Canadian GSR!!
- question about interior...
- What parts do I need?
- Turbo or supercharge automatic
- problem runnin p28 on GSR ls/vtec?
- Jic exhaust?
- DC4?
- Any of you guys using OMNI slip on Coilovers?
- bleeding brakes on tegs with ABS
- should i go with skunk 2 stage 1 cams or itr cams for my 00g sr???
- Would you pay $170 for this?
- LSD help!!!
- new integra owner!!!!
- dc2 springs
- Tire questions and poll.
- Is it hard to swap front end from 96 integra to 93 integra?
- apexi integra pic????
- How do mags test the braking distance for a car???
- Doing the exhaust right the first time...
- Pics of my new Integra...finally
- DIY Rear Lower Tie Bar
- lifting teg
- How much hp will A aftermarket pulleys push out to the wheels?
- bent valves?
- springs - coilovers?
- Idle Problem, HELP!
