View Full Version : Acura Integra
- How much?
- MAP Sensor (code 3), VAFC? Help, por favor.
- how do I know if I have a bad o2 sensor?
- Compression Test Numbers....
- skunk2 stage1
- Car is okay
- need some help. researching on suspension setup of DA.
- compression test questions
- 99 Ls into a 95 Ls....?????????
- ABS code
- my rediator fan stayed on after the car was turned off
- OBD0 B16A into DC4...whats needed?
- leaking boot on tranny
- SGT tuning
- To solder or not to solder that is my question?
- bypass valve worth it?
- getting an alignment
- ACT 6 puck?
- Need Carfax....
- need help with my situation. EVERYONE i need your input
- Cat-back exhaust help
- Best way to remove AC/PS
- anyone use Tanabe springs yet??
- ACT XTSS and prolite flywheel
- 75 Shot on LS?
- Kinda dumb ?....Horn bolt size???
- Reading Air/Fuel with Apexi timer
- bumper bolts?
- a few questions about ITR stuff
- size of crush washer for tranny drain bolt?
- header question
- Clutch is stuck from 3-4 gear
- DC2 98 integra Type R usdm cluster?
- will an ek9 lsd fit my 96 gsr?
- what tranny?
- what head is this pr42?
- comptech brembo kit?
- Order confirmed...
- Tech ?s on ITR brake upgrade
- Quick suspension question..koni yellow
- Turbo that biatch.
- E-brake question???
- just got my ground controls.. i have a question about the spring rate
- anyone run the hks hi-power exh for the DA?
- brake rotors...
- neee help w/ something
- just did some calculations
- How should I go about lowering my car?
- anone hear of Ultima Performace????????
- rant: my tranny fluid change story
- where to get head rebuilt in New York?????????
- Weight diff. between G2 & G3 Tegs
- DA's with Del Sol VTEC or Civic radiators, question......?
- Short Shifter bushings
- Does AEM bypass valve affect performance??
- idle valve ??
- what should my 1/4 be?
- Emission test failure...
- Timing Hole
- new mobil 1 high mileage oil
- gauge pod for 4dr teg?
- Pics of me abusing my 95 GSR.
- Help me make some power
- Shouldnt stock cam gears work with 62403's?
- ABS light comes on when i go over hard bumps!
- Just wanted to introduce myself
- Very nice clutch for your street/drag car
- Is my clutch gone?
- How do I tell if a gsr block is 96 or newer?
- My 97 Integra GS "Maintenance light" is coming on...? WTF?
- I give up.
- "AEM V2"
- FIve lug conversions for the dc-2 integra questions!
- Everyone In So.cal Please Read!!!!!!!!!!!CAR JUST STOLEN!!!!!!
- check engine light on
- No wang, some lil' wang, lots of wang
- regarding radiators
- How much is my teg worth???
- Underdash Fusebox Diagram... Please......HELP....
- hyper ground system?
- bosch wipers
- 2.0 liter engine
- Should I Buy an Integra with over 100K
- help with exhaust purchasing
- how many quarts of oil does your integra take??
- What wires to get for built ALL MOTOR non-vtec..?
- Cooling problems-To Cold? Please help.
- Need help with s-afc
- STOLEN CAR VICTIMS! What theft prevention did you use but they still stole your car?
- anyone take their turbo integra on the circuit?
- Exedy clutch + flywheel
- southern CA, if you worked on your own tranny before, please help
- ** The Project.......... Explained... b4 and after. 56k beware **
- Those with HID's. Where to mount the..
- Bump stop questions??
- Ummm yeah type rwarrr
- For all u 94+ integra owners!
- Check engine light help needed ASAP!!!
- Will a 215/50/15 go on the oem 15x6 teg wheel?
- igniter for my 88 integra
- where is the igniter
- CAI install, no filter!
- 90-01 TEG brakes all the same??
- Junk yard site?
- Paint Rims or sell and get new rims
- Bad Axles??? Help! My car handles like SH*T!
- Dunlop SP sport 8000 or Falken azenis
- CatBack for 90-93 integra ?
- Tokico Blues and springs, no instructions need help
- Flywheel installation?
- will a jdm type r dc sports 2.5 inch header and 2.5 carsound cat bolt up to my apexi WS exhaust?
- is this wheel, crank, or flywheel HP???
- How do I take a bad heat shield off when it's too rusted to put a wrench on it.
- oil
- integra spoiler swap
- Nor Cal Dyno Day June 7th, cheap!
- Will stock OEM 98 Integra shocks and spring fit on a 89 Integra?
- Need best online store for clutch/flywheel
- Wiring B18C
- AC Compressor how much and
- Clean your Comptech Icebox
- problem with axel
- my mileage
- AEM Pulleys - UNorthodox - What type of gains can you really expect?
- lift and duration of GSR cams?
- how can you create a all motor ls/vtec?
- dealership prices for parts online?? where to find
- guide for installing cams.
- low level torque wrench
- Koni install question - HELP!
- whining sound coming from timing belt area
- second gen pic
- I just got my SMSP 2.5 catalytic converter!! Need some advice!!
- Blitz Air Filter..
- toda set up
- Strut tower question!
- ITR Axelback exhaust on an LS
- debating...money to spend but on what
- Mirror question for 2 and 4 door G3 Integras
- GSR Intake Piping...?
- starting issues?
- What does wot mean?
- Dunlop Tires?
- JDM ITR Pistons and JDM GSR RODS (noob question)
- What wires for ALL MOTOR non-vtec?
- OEM Fog lights
- minor problem with the teg.
- anyone know where to get the carbon fiber hatch covers for a dc2 integra????
- Need a good response to prove my dad wrong...
- Does this sound like a good deal?
- Where should I set the Vtec point w/ Skunk2 mani???
- BA! Quick...where to get ACT XDSS and Fidanza combo?!
- air filter
- Next Honda-tech meet in NC
- need help adjusting headlights
- Carpet dilemma...
- chipped Ls ecu
- Where can i purchase a tranny to fit in a ls?
- ls tranny
- turbo kits
- Transmission Mount
- skunk2 stage2 cams on gsr
- Price of clutch change...
- Oil change, crush washer.
- does anyone know grounding points
- Integra in Florence SC
- hondata?
- CEL Code 90, how do I troubleshoot it?
- south florida track
- my baby is coming home in a little over a week
- What does you integra weigh?
- would it be worth it?
- Is this a good deal for leather???
- Can It Work?
- Help on AEM CAI install - searched...
- aem short ram intake replacement filters?
- TEG LS AUTO OWNERS... plzz share ur 1/4 mile times..
- will a CEL code 41 disable vtec?
- best street tires for the money
- What header for my GSR
- Is this a good trade
- code 65, need help
- Black cloth seats weight????????
- ls/vtec
- water lines through throttle body
- booooost help!! car wont go past 6 grand
- Would a short ram intake like this be more effective?
- B18C Motor mounts in for 91 ls
- Anyone have modified some ITR calipers and rotors into the 4x100 pattern
- custom sheet metal 8 injector turbo intake manifold for LS motor
- Portflow ti retainers :thumbdown:
- seats
- will a B16a head handle 9K
- how much $$ for dealer to change tranny fluid?
- b20 Si Vtec piston question
- Boost
- shitty short throw?
- need two new tires help please
- Anyone change Their Front Swaybar Bushings?
- 2000 b16a2 into a 91 integra
- CA Ref and Nitrous Q
- oem air bag replacement trays...
- suspension bushing "Q"
- did compression test, seem high???
- AC line is interfering with wastegate placement
- OBD 1 P72?
- Problem installing front upper Neuspeed 4-point bar on Integra
- timing belt tensioner
- throwing a CEL 41!?
- JG edelbrock header are they good?
- Remote start install help
- green plug, back of b17 block, what is it?
- Why wont my non airbag ITR wheel fit in my 99 LS???
- GSR tranny
- sealing headlights
- LS GReddy EVO on GSR?
- Goin -Jun- Parts all the way? $expensive$
- amperage on stock 95 gsr?
- would a gsr exhaust fit a ls body?
- My B18c1 is rattling, and burning oil is it SHot?
- ??¿¿Arkansas¿¿??
- A/C doesnt seem to be working well... help, its getting warmer out
- Attention NY Integra Owners!!
- Cat Back Exhaust
- diy grounding kit
- V2 vs reg AEM vs Injen intakes
- JDM B18c (gs-r) in a 89 Integra .....legal ..and fitment Questions??
- Squeaky Clutch Pedal
- Ques for those NJ drivers with full tint?
- where is the ignition coil
- My teg is now stuck in the driveway...
- the math doesn't add up. Magic horespower!!
- New to Integra forum, question about IACV
- update: header rattle...(at least i thought so)
- B18C1 Daily Driven Compression Ratio.
- Anybody familiar with S-K SureGrip hex design Sockets?
- Why is this happening to my Integra!!!!!!!!!!!!!
- quick Skunk2 camber kit question
- Who has the Greddy EVO papers?!?
- Single Runner ECU
- H&R spring from ITR fit a GSR
- Quick question: what's the size of crantshaft pulley bolt?
- Help idle issues and yes I DID SEARCH!!
- just put on apexi exhaust =now smoke
- check engine light problems
- Changing from AEM CAI to Comptech Ice Box...
- help me solve these 2 problems!!!
- 95 ls chipped
- specs for '98 Integra LS
- camshaft difference
