View Full Version : Acura Integra
- how to get oil out of your spark plug holes????
- b20z swap in 99 integra
- 01 GSR Engine shut down
- fender paint bodywork question
- Still no spark. Any new ideas?
- "whirring" noise in all gears
- Two things I need to figure out !?
- Intake "cough" or "backfire" when shutting off car
- DC2 LS antenna makes short RAPID FIRE noise when turning on/off, How do I fix!??
- running lean
- car goes into limp mode as temp reach's half way
- S2000 Brake Conversion.. How much to mill off Caliper Brackets?
- 1999 GS-R Tri-Y header, Hi Power, what to do
- Motor shuts off at mid high rpm and starts right back up??
- Door lock help Pls 95 integra
- GSR throwing Electric Load Detector (ELD) Circuit High Voltage and Lag Under Low RPMS
- New AEM Air Filters don't fit older CAIs
- DC Integra coupe rear windows removal. Need help.
- ~~My 94 GSR build thread~~
- Spun bearing decisions
- Bumper Fitment??
- front suspension
- Integra Running Super Rich - SEARCHED
- Lowered, think itll rub or have camber issues?
- Were does everyone get there parts from?
- NEED Help on 91 integ fuel pump
- blox itm ideling?
- Transmission Quote
- 4dr 90 Integra Performance Help
- need help on finding a good book on rebuilding tranny
- integra 1994 swap b20 question
- LOOKING FOR A GOOD ACURA/HONDA SHOP
- CEL problem with warm up?
- location of TDC senor in a 1991 acura integra
- GSR idle being high
- help climate control fuse keeps blowing
- Idle drops low after rev and comes back up?
- jdm hid wiring. please help
- oil pump remove on 93 teg b18
- CEL 17 Vehicle Speed Sensor
- IN need of pictures of under dash wiress
- b18b1: how to do a valve adjustment?
- can my 1999 LS tow a 96 miata?
- Itb questions:
- temp (ls)engine in (gsr) integra
- Just Bared my car today!!!!!
- Spacers on rpf1s.
- Spark plug gap on 98 LS?
- b18b1 bouncing idle
- Buy New LS Motor for turbo or GSR Swap in 95 integra LS HELP PLZ
- 94 integra power problem... stumped!!
- suspension questions
- Fel pro gasket, wrong part #?
- Blox intake manifold help??
- REAR DRUM TO DISC BRAKE CONVERSION HELP!!!
- DC2 & DB7/8 Floor Mats the Same?
- Rear coilovers locked?
- skunk2 camber kit squeaking help
- 95 ls- no compression in 3 cylinders
- Regular motor oil TO synthetic...now want to switch back to regular, is this BAD?
- Need Some Collision Help
- Plug underdash harness
- poor mans type R wont rev past vtec
- acura integra timing problem?
- Need 94 gsr motor mounts whats best?
- Sup guys: DA9 Pricing Question
- Another abs delete question. searched.
- oem optional side valence question with pic
- half radiator in a intega
- To the guys that are running HAWK brake pads on they're integras..some questions??
- Where is the idle screw on 89 integra ls??? d16a1
- How often do you guys clean your drop-in K&N filters?
- ABS Delete : Proportioning valve question! HELP!!
- FUEL TRIM PROBLEMS: b18c1 98 GS-R
- Speakers cutting in and out..
- Changing complete distrubitor mess up my timing?
- DC Map light and dome light idea/question.
- 98-01 OEM foglight problem
- integra starting problem..
- Suspension Noise
- B18C1 Turbo Build
- Need help
- Stock Springs Help
- Car only goes into gear when engine is off? Loose clutch pedal
- type-r head
- I really need help, 89 integra ls idling problem
- type-r head
- Wet distributor now no spark
- Greebler's Integra Restoration Thread
- 95 Integra, heater always warm
- Stock 97 Integra GS ready to upgrade
- Start amperage draw
- 2.5" high flow cat
- Stock B17A1...175K...looking to swap
- fuse poppin pantie droppin
- s2000 steering wee-hole
- 92 integra idle problem
- 300whp B18B Turbo Setup NEED HELP On Setup! THANKZ
- Long time Nissan guy. New here, not to Hondas.
- Need Some Help
- Ac compressor question?
- no vtec no speedo after wire tuck. help!
- Ground strap is fine for valve cover ground?
- Good deal 2000 unmolested gsr?
- electric windows on DA 1990
- Issues starting stock car.
- Process of changing complete distrubitor.
- Valve lash specs on LS motors?
- bbs rs or rm
- B18c1 running hotter than normal
- 1995 b18b1 . how to correctly tighten the tension bolt
- gsr b18c1 smoke question
- Front brake problem Some quick help required
- timing belt off 1 tooth !?
- Center vent removal?
- Suspension troubles..
- b18c1 screech when start up
- ls dizzy on a b16?
- Front lower strut bar or brace
- 95 GSR Weird problem
- Wrong ACL Rod bearings
- 1990 da. car wont start.
- Another "what is my car worth?" thread
- Head Gasket Question
- valve cover bolt/stud
- Will remote start harm my car?
- able to run a A/F gauge if ECU already disabled o2 sensor?
- Need help. grindin noise at certain RPMs
- LCA Bushing Won't Come Out...
- Integra GSR Turbo for sale
- i need a integra dash board
- No spark any ideas?
- Keeping my JDM B18c gsr or ITR swap
- Has it been damaged?
- weird bogging
- ckf bypass not passing smog?
- Interior light plate light and taillights not working need help!!
- Raybrig Integra Fog lights
- Engine revs when car is in motion
- 89 Integra LS, d16a1
- 1994 JDM B18C Throttle Body Gasket
- GSR 94 ABS pump working constantly
- compression test number
- Car wont start? start here..
- GSR Tranny Leak Issue(s) *Pic Enclosed* Please Help!
- 98 b18c recently started
- Which exhaust/headers to buy
- Difference in Integra quarter panels (LS,RS,GSR,Type-R)
- 92 Integra GS Sedan LEAKING n OVERHEATING HELP!
- Bore Size
- PasswordJDM conversion harness
- integra wont freakin start
- b18b1 stripped timing belt tensioner bolt
- 1990 da idle weird
- Automatic To Manual Help
- car will not start and loud whining noise!!
- trying to find jdm front rad supp, t bracket am i screwed or what
- CAR WONT START =,(
- DA turbo Integra wont start Help!!!
- what would cause this leak?
- Bad gas milage 94 ls
- Seat fitment in a 90 DA
- 96 integra ls bruning too much fuel
- DA B18 LS Power steering into a DC2 B18
- wiring in rdx pigtails
- Overheating Problem
- turbo pan questions
- wondering what to do with integra
- Removed spoilerproblem
- Just got a 96 GSR
- How much paint should i buy to respray my integra?
- NEED HELP BADLY!!!***** 98 integra ls!
- best place to tap for 12v ignition source
- car not charging battery enough, dont know what to do!
- how to tell difference between b20's?
- Crank sensory bad?
- 1990 da/ 95 ls swap. wont start wont crank. cant hear the fuel pump.
- Turbo charging gsr
- Hydrualic Ls Transmission Help
- passenger side parking light/blinker not working
- my 94 integra
- Emissions Question: 89 B18A1 + PR4
- How much longer can my integra go?
- exhaust for xsi da6
- tough choice
- 1995 Integra Main Relay Clicking no fuel pump prime
- ac questio
- Ac repair
- Screech when turning
- Broken Camshaft End Cap Fixed !!!!!! Pics inside.
- 1990 da w/ 95 ls swap (how to do timing)
- my fuel economy suckss!
- PO 1457
- Transmission swap
- is this too much slack for timing belt?
- Hard to start when motor is cold
- Best fully built head set up project
- !!STOLEN BLUE INTEGRA GSR TURBO in Belvidere,IL HeLp!!!
- 93 Integra - d16a1 swap
- Question regarding conversion
- crank sensor bad????????
- 94 gsr just picked up help!!!
- Vtec installing help
- ac question
- shaking under acceleration..
- RHD wiring issues
- vtec conversion question
- What's this piece in '01 GSR? PIC INCLUDED
- E-brake not clicking when i lift
- dc2 front suspension on da
- JDM DC 4-1 header
- need help installing ac on 99 integra gsr
- integra clock spring question!
- compression test planning to add supercharger
- b16 mysterious oil pool/leak
- JDM B16A ECT Sensors..
- 92 DA potential build
- b18c1 ECU
- Head Bolts B18
- Help! hit deer and car no longer runs
- Can anyone ID these injectors?
- Spoolin Performance experience
- SRS ITR steering wheel
- B18
- ilde really low on cold start. HELP!!!
- what are the best tiers for an 94 acura integra?
- 1990 teg w/ b16a3
- How to remove glue from body kit
- lowering 92 DA
- ALL MOTOR
- question about ls tranny
- need some honda heads to pick** DA problems
- da turbo b18a1 help
- New to honda
- Will any sidemarker light work for a DA?
- Fog light fuse location in DA
- B17A1 question
- power steering pump bracket issue
- Waterneck question : WHAT is this?
- foggy windows, no heater!
- Leaking
- trans help please.
- what should be my first upgrade?
- reliable parts dealer
- Question about stock gauges on 99 LS
- easiest way to replace studs (really need help)
- b18c1 head gasket ?'s
- ENGINE REBUILDING - WORRIED
- Tuning DA Integra for Gas Mileage
- need help deciding what axles/halfshaft i need.
