View Full Version : Acura Integra
- what is this port used for?
- integra LS Questions!
- My new integra
- trouble with dc2 gsr
- 2000 integra gsr spurting after like 2500 when accelerating slowly
- WTF clutch cable
- Paint Options
- Help please, driver door problems.
- oil press low on 3k?
- Will P2P ECU work temporarily on 1996 GSR?
- Everything stopped working in 90 db1?
- 92 acura integra doesn't want to go
- 98 Acura Integra LS Smoking
- Tri-Y header on 2001 Integra GSR
- Jdm OBD1 P72
- Fuel tank reserve?
- Head Gasket
- Video: help ID Noise; Trans bearings, clutch, flywheel, input shaft?
- Smoke
- 95 integra LS, cranks but won't start and has no spark
- Exhaust system for DC2
- Greddy Easy Cam vs Skunk2 tuner stage 1 cam
- MIZU rad and fans install
- jdm b20 and ls oil pump ??? help
- can someone post a pic of a sub in a da?
- Do you remember when you first signed up on Honda-Tech? Inquire within..
- Rough Idle & Hesitant Accelaration @ 1500 K
- Weird noise coming from d/s wheel
- oil pan gasket
- Check engine light problem wont go away
- Need Help: RS Prop Valve to 98+ GSR Master & Booster
- 1991 Integra Overheating?
- Help identifying clunking noise
- Too thin oil?
- 1994 integra no power hard idle after head swap
- Hard to shift!!
- GS-R acting weird, low to no oil pressure?
- need help selling car what price
- Bypassing IACV & FITV Coolant Lines
- Bad pressure plate???
- can everyone post a pic of some sick *** da?
- running issues
- Help Tach and Speedo Crazy
- Best part of waking up. Is no wheels on your car
- ITR swap from JDM gsr
- '94 headlight switch doesnt turn on parking lights
- 98-01 front end or jdm itr front end??
- K20 swap into 94-01 integra
- Need Help Doing a JDM Front Conversion on A 94-01
- IGNOR, CI working.
- gearbox issues plezz help!!
- 92 gsr bogs
- Take a look at these pics (*Turbo Guys & Girls*)
- getting new rims soon what offset
- engine swap fitting
- Help me out guys: Rubbing while turning Steering wheel
- 95 teg automatic trans problem*HELP*
- Reliable site to buy a used b18a or b18c?
- 92 Acura Integra starts up but idles crazy than stalls out?? HELPPP
- Fuel Pump not getting Power, Please help
- A/C issue - Freon can held upside down
- Head tapping
- Anyone lowered on 195/55/15's?
- Integra trans swap HELP!
- Seats
- G1 teg rear coilovers
- Engine problem ... Help
- car doesnt crank when clutch is in push starting car works fine
- hi i was wondering what rim size and wheel size looks good on a da?
- Aftermarket ls intake mani
- Cant get cel code !?!?
- Help: Wiring a VTEC Controller to A P72 ECU
- ls/vtec question ??head gasket
- Hydro To Cable Pedal
- timing light says 29 degrees off
- 7000rpm on b20b?
- b20 dc idleing up and down?
- how do you get the one piece jdm da headlights to be yellow?
- wheel pushed back into the fender.
- B18B Turbo charger kit good price? good kit ?
- Help with bad gsr engine
- Alarm works when i connect the battery and doesnt after i start the car
- Does anybody know what this harness is?
- DA LS/VTEC
- valve lash=idle
- Need help car won't go in gear!
- caliper pin boot
- Will 2000 struts fit a 94 ?
- 97 JDM integra
- B18c1 head scarring with hd video
- Alpine Stereo Into a 98 Acura Integra
- 95 gsr high idle 2000rpm+ need assistance
- How Much Would You Pay?
- front and rear bushing issue help!
- Help finding the hood latch cable?
- 95 Integra Key Stuck After 5 Speed Conversion
- 91 teg running issues
- Won't start although Battery is less than 10,000 miles.
- 93 integra key sticks
- More clearance=less press?
- Will AC from a 95 fit in a 2000?
- Four Door Teg, First Honda
- Is this 87 Integra a good deal?
- Which Valve Train is best?
- automatic seatbelt
- looking for ls mesh rims n tires!!
- Bumepr Swaps 94-97 98-01
- Need opinions or advice :)
- What part is this? And can it be removed?
- OEM VS Aftermarket Thermo Fan switch?
- 92 Gsr
- da water pump
- da integra shift light
- removing a pin from an obd0 connector
- Is this 93 Integra a good deal?
- Just purchased my GS-R
- Sidemarker illumination wiring
- Newbie needs help.
- My first Honda
- ls vtec complete.. more upgrade i can do. plz help
- what ecu is better to use.... stock oem p73 itr or a chipped p28 running ls/vtec
- 1993 integra digital clock won't stop?
- SPC experience
- Someone bumped into me and knocked my headlight out of wack. Help!
- Dash lights stay lit after removing key
- 02 j32a2 swap
- white integra stolen please help recover parts
- 1990 Integra ls swap recommendations
- Did OBD2 B18B's have the PCV "black box"?
- Head gasket burning oil????
- Something is Draining my Battery
- 94 GSR block half shaft stripped
- super camber wear
- B16 head making noise
- pic request: black bezel headlight/chrome accent !specific! read detail
- Type r tranny in gsr
- gsr brakes, are mines abs or not?
- Shaving my badges and emblems
- 95 integra starter fit 98?
- running 2.5in header to stock OE exhaust, flange concern
- 00 teggy ls running rich
- ECU obd0 code 1
- Window Motor
- car died today
- very loud valve train
- Eibach Prosport Adjustable Coilovers..Help!
- 1990 B18A Integra Turbo Idle issue.
- high amp alternator
- 1993 integra 1.8L,manual.2 door
- 94-01 Engine Mount Installation
- Problems after b20b swap
- Acura Integra Insurance Comparisons
- High compressed LS
- gsr bent valve replacement cost?
- integra steering wheels
- GSR 80mph at 3500k RPMS!?
- Carbon Ring at top of Cylinder and oil leaking down
- compression question lsv ctr pistons
- B20b and compressor for A/C
- Could I have a T-stat stuck open?
- 94 Gs-R shut off on highway help?
- B18a1 Problems
- RMF header vs Ebay Dyno numbers
- Should i expect low oil press after rebuild?
- Hose from valve cover to intake
- Removing ABS lines
- looking for 98+ headlights/front end for my 94 coupe
- ok diffrences between pr4 obd/pr4 obd1 and pg7obd0
- To guys with oil pres. gauges
- integra wire tuck First atempt.
- Is it normal to see metal dust in a rebuild motor?
- gsr timing marks locations
- how to get torque out of the b16a???LSVtec maybe????Help Please!!!
- b16a in a Integra GS-R Tranny!!!!
- Which Wire Harness is this?? :)
- 92 integra engine/tranny swap
- Chipped ECU not using my rev limit
- Help broken PWR radiator flush bolt 3gen.
- idle problems
- !!!!!!!!!!!!!!!clutch problem!!!!!!!!!!!
- jdmtigerjapanese.com??? has anyone heard of this
- DA MC fit DC?
- Question with installation of ignition 2000 integra
- What is wrong with my integra?!? (video)
- window doesnt work when door are close.
- b18c head b18b1 block questions
- Waterpipe question
- swap question
- how can i install my s2000 radio on a dc2
- JDM Front: Los Angeles
- 4dr gsr or eg hatch?
- Hot air blowing on my feet
- 92 integra wiring diagram
- Any suggestions on preparing your car for a long road trip?
- clutch identification
- how do you keep your integra safe at night?
- Need help figuring out cost of 93 Integra
- Gas gauge is stuck
- How do I CONVERT AUTOMATIC Integra to MAUNAL?
- Does this sound like it makes ~200 whp?
- Question concerning knuckle/spindle assembly drop
- Pic request
- fuse keeps going out.
- Symptoms of a bad ignition switch?
- Hey! new to the forum, got some questions
- Integra cluster problem, Mileage
- DA integra underdash-harness question:
- how do i know what ecu i have?
- what lip looks good on a 93 da?
- B18A1 Auto Trans work in a B18B1 Car???
- loss in boost pressure and acceleration!
- cooling fan issues after wiretuck need help
- how to make a high reving b20b
- base timing 97 gsr with obd2 ecu in obd0 chassi
- Replacing Alternator
- FAQ: How to Replace Rear Suspension Bushings -- FULL GUIDE
- gears dont go in all!
- 91 integra b20 swap oil presure light
- Replaced main relay, still stalling
- Coolant temp sensor ?
- Car stolen in east bay Cali
- Strange transmission issue.
- Vtec Problems
- Nobody can figure this out.....
- Rear Wheel got very hot
- battery goes dead instantly??
- Check out my DC4 (NEW TO HONDA-TECH)
- 05 OEM s2000 muffler on my integra
- igntion rotor question
- Suspention Bolts
- Question about head stud
- parts please..
- cheap tuning, where to start
- No Break Pressue
- WERE CAN I BUY NEW CCW CLASSICS
- power steering loop
- gsr head bolts?
- Heating issues
- Brake Caliper bleed bolt size?
- items needed for obd0 to obd1 conversion help!!
- Possible vacuum leak
- Stroker and High Compresstion = Blown headgasket?
- 1992 integra with obd0 b18a1 in it ( help )
- Honda Integra Turbo 600 PS / "be Happy!"
- no intake air sensor wire on this harness.
- Compression test numbers + hot spark plug pics
- LS motor loss of torque
- 1st gen integra drop
- Oil light and CEL light went dead, car wont start
- 2001 Integra, rebuilt engine now cuts out
