View Full Version : Acura Integra
- my old DA
- 96 LS engine noise...
- fender braces
- Car won't start
- Tires...
- whats the compression on a usdm gsr motor?
- Megan 'drift spec' exhaust
- Car Starting???
- LS Automatic to Complete GSR swap
- Gsr Down...Help
- How do i hook up the vtec solenoid? :(
- fans turn on when car is cold?
- How to hand crank my motor??
- GSR Swap For Sale
- K20 into a dc2
- question about cleaning headlights
- WHAT IS THE IDEA BEHIND CODES?
- 2001 integra gsr
- 96 gsr intake manifold question
- are automatics good to supercharge
- Distributor leak!!
- k&n air filter producing water?
- Distributor leak help help
- engine sputter
- engine compression question
- fog lights on JDM ITR front end
- b18b intake mani on b18a head with obd0 possible? help plz...i need stock mani for cheap
- Overheating problem.
- integra dash question
- Ignition/starting issues
- how do you post a dyno graph?
- Main Relay Compatibility
- soon to be integra owner.couple of q's
- whats the difference?
- shiftlinkage hole stripped out
- Steelies
- Integra body side moldings?????
- h22a mounts for da6 1990
- Whats the Best Motor or Motor Set up for 500+ WHP for my DC....!
- any DB2's or DA's on GC and koni yellows?
- 02 Sensors question.
- OBD0 LS-VTEC VAFC wiring Question- NEED HELP ASAP!
- Running 2000 Gsr on 95 Gsr ecu...
- USDM bumper (steel on rad support) w/ JDM front
- e.s. mount inserts
- 4dr to 2dr exaust will it fit (DB8-DC2)
- airbag problem
- H22 into a 'teg..
- My 96 LS won't start
- Lowering coilovers
- Orange County Junkyard for Acura/Honda
- NEW GIRL
- will an ITR lsd fit in a 94+ ls tranny
- JDM ITR 4-1 header, hmotorsonline
- little wiring problem...
- Does a B16A2 head have a PCV valve?
- Exhaust pipe welding cost
- distributor question
- oem jdm h.i.d bulb blown. need help!!!
- bolts from cat to exhuast piping
- transmission swap
- QUESTION PLEASE HELP!! Jdm ITR Steering Wheel
- Codes: P0301, P0302, P0303, P300, P1399 help
- Anyone Remeber the HIDZ from CATZ?
- cat-back exhaust?? or just muffler?? for 91 integra...what to get.
- GSR cat same size as LS?
- both front turn signals not working
- Driver side axle on Integra!!!!
- Timing belt broke...
- Shifting Isnt Smooth!!!
- Short Shifter too long!!!
- header clearance
- Stainless Steel Clutch Line for 95 Integra GSR
- People that Know about swaps Please Look !!!
- Valve adjustment??
- OEM hood problem
- What Headers should i go with?
- aggravating as hell charging system issue in DA.
- Greddy SP2 OR EVO2 for ls
- Driver side Axle Problems/Apexi N-1 Suspension Please help!
- 98 integra cluster problem
- How can I find out the model # for clear corner bulbs?
- shock and stuts
- jdm integra type r hid headlights wiring
- testing vehicle speed sensor 94 integra ls
- OBX high flow cat
- Integra Starter 94-95 vs 96-00
- wierd oil readings
- cracked bolt and stripped lug nut
- Where to get screws/bolts/(brackets) for OEM ITR lip??
- rhd/type r conversion with real carbon fiber dashboard
- Car won't start...HELP!!!
- Sum1 wana make sum money finishing a swap!!!
- itr headlights......parking lights do not come on
- gsr with type r lsd tranny?
- 97 type r cluster on 00 gsr????
- Good tuner in Central OH area
- b20b swap
- Car Pulls.HELP!!!!
- problem w/ car .....please help
- Thieves of san jose UPDATED!!!
- clutch change
- CONS ON TURBO???
- can someone tell me what their idle is on a b series engine with the iacv unplugged?
- COMPTECH
- MANIFOLD PROBLEMS
- B16A on DA?
- ls/vtec bottom end build
- is it easy to install a dash?
- 2000 gsr repair manual ...any1 have a link
- Can I take heats shields off?
- replica jdm itr 4-1 header problem.
- jb weld substitute for headlight glue?
- eagles rods
- LS VTECH HELP
- JDM ITR
- oil temp sensor
- BAD bogging issues
- Picked up the b16a2 head today, but got some questions.
- Head gasket install.
- anyone ran there LS with some N20?
- How do you know if u need new spark plugs and or wires?
- black smoke .... i changed my o2 sensor and nothing ... HELP PLZZ
- Cost of Rebuilt engine? *general, i know i just want ppls prices*
- rich or lean?
- Wierd sound
- Friend needs a motor rebuild for gsr motor
- how can i clean my fuel injectors?
- no thermostat=car runs cooler????
- "Squealing" from engine bay, clutch.
- JDM B18C in EG swap not starting...help needed!!!
- Has anyone heard this knocking sound? .wav inside
- parts from gsr head into ls head
- Shuddering / Can't get into gear?
- Ported and Polished LS head
- Side Skirt
- rhd wont start.................
- GSR Questions
- springs help
- Difference between obd1 ls and gsr wiring harness?
- Jdm Teg front light problems!
- Best motor-swap for the money?
- HELP..brake and fuel lines
- NEED help asap please help..automatic shift seems locked...............
- 100001? Its not binary...
- Type R Oil Pump
- ---coil over suggestions---
- Phoniex Yellow on wheels....
- Where to buy a B16 lsd tranny?
- Quick strut bar question?
- For those who might have had the same problem with what i'm having. *2nd gear grind*
- JDM or USDM DA Armrest?
- Cable B16 Clutch?
- Blinking CEL while driving ?
- avic-z1 in 2000 gsr?
- K20 DA Mounts
- Where to get mouldings?
- HID ????????? wtf
- itr headlight conversion
- I need help withan engine complete rebuild.
- K20 into DB1?
- what should i do now?
- what type of clutch should i put on a gsr
- WTB GSR Leather rear seats - black
- Well it finally happened....
- Integra not running right. Not a noob problem
- hood latch
- Engine code....again
- Question for the old school ricers?
- I need help with exhaust systems?
- FMU vs eManage
- Turbo vs NOTHING
- Where can i get this
- wont go in gear at 8000
- website to pick up silencer for spoon n1
- Has any one used the comptech Ice box?
- GSR safe revving abilities?
- Motor Swap
- ebay clutches
- need help with fuel filter
- ~searched~ turn back mileage thread ?
- noob fly wheel question
- Swtich the frot bumper!
- Nuespeed coilovers help.
- Can't fight the ITCH! new to the scene again.
- OT: MY old gsr
- Neutral wont start, 1st will???????
- 96 iNTEGRA WON'T START
- 97 GS-R value? Opinions/Comments welcome
- ls gsr head swap questions
- automatic tranny help
- quick question fat fives
- Super low IAT (Intake Air Temp) sensor reading.
- partingout my DA /have LS motor DC2 trust bar
- Differential install what shim did you use??? B series hydraulic
- cam gears?
- tore down to block- piston to same cylinder?
- What do I need to swap a GSR motor into an LS chassis?
- someone have carfax???
- LS camshaft torque specs
- Thanks for the help!!!!!!
- Valve Cover help!! Cant take off!
- NOW I HAVE THE ENGINE GOIN... WHERE DO I GET A SHELL?
- odb0 vafc wiring diagram
- More problems after turbo'd DA CEL
- 92 integra lights problem ... please i cant drive at night .......
- 2nd vtec problem at 5700 in GSR
- 97 RS problem .. need help pls
- Is a 75hp shot to much?
- Anyone have the DIY for S2K cluster with all wiring ????
- GSR Tranny Flush
- testing waters...how much for my gsr
- goodridge ss brake lines
- tranny noise..?
- Steering wheel jerking...cv axle???
- intake question?
- stock LS turbo w/stock boost
- LS rods with GSR Pistons
- GSR Idle Problem Different From Other Idle Problems
- Found my stolen car. Looks what left!
- p72 obd1
- Driving Last Night - Lost All Coolant.
- im scared
- IABV REMOVAL
- engine code.
- Moving my car around in the garage... preparing for it to be towed... Help, please
- new interior bulbs
- 2000 GSR Integra ECU question
- Need a distributor....any experiences w/ these??
- - - - Meeyatch1 - - - What is your email???
- Harness wont fit my B20??
- OBD2B
- Show off that exhuast
- Spoon N1 Loudness - Mixed Reviews
- 91 da new wire harness
- B16 Tranny or Gsr Tranny
- help
- k20 DA mounts
- Transmission Differential NEED HELP PLS !!! 94 LS Automatic
- hey well i have a question on ls tranny a GSR block
- help on taillights
- HELP! My girlfrined put DIESEL gas into her 05 Toyota Camary!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- b18b with b16a tranny, how bad will highway gas mileage be?
- A really strange small water leak in my dc2 trunk area...
- H23 in a DA
- 95 LS E-brake line Removal??
- blown head gasket!
- Exedy Stage 1
- Is there a date on the timing belt??
