View Full Version : Acura Integra
- DC vs DA Exhaust? Major differences?
- V-tec solenoid is leaking from the top.
- Car died..... Alternator?
- p72 obd1 or obd2 how can u tell
- Winter storage advice needed!
- Tire Selection Question
- what is 00 integra euc?
- performance shops in the chicago area
- car wont start
- HOW about this clutch are these anygood for daily driving?
- anyone have a carbon fiber hatch?
- tires getting worn down fast any suggestions
- GSR sounds like a sick horse!! Cooling fan problems..HELP!!
- My reintroduction to Honda aka build thread
- o2 sensor
- need help
- Radiator problem?
- Why does my car hit bumps so hard?
- HELP.. AUTOMATIC TRANNY ISSUES
- What colour is this?
- b20/vtec owners....need your opinion.....
- 94 ls full swap
- how i remove the ac heater control
- Anybody every bought a swap from JapaneseEnginesInc.com?
- Honda / Import car owners in California....................
- Need help....hurry
- Car stalled and now won't start
- pr3 cam gears?
- motor oil
- replacing ball joints
- Auto to manual engine swap help
- need to buy whole bunch of OEM acura parts where is the best place to get??? help
- engine harness question
- fuel injector OBD1 vs OBD2
- passenger and driver seat rails the same??
- Gas gauge wont go to "F" on a full tank...
- 94 Ls wheel stud question plz
- 1990 integra Gs Clutch or tranny problem
- my DA wont start, please help
- cv joint came appart inside the boot
- Spoon Racing Mirrors
- aem pulley belt #
- cat from 01 gsr on a 95 gsr
- itr head on 2002 b20 block
- Exhaust Rattle
- Need Fenders, Front Bumper and hood to be painted
- BRAKE LIGHT PROBLEM!!! HELP MEEEEE!!!!
- itr piston in gsr
- Pic Request: dc2s
- LS/Vtec Auto Tran
- are all b-series OIL PANS interchangable?
- no vtec
- What are these parts called on the calipers?
- how wide are 02 sensor holes?
- mount problem! dont know if d serise will fit on b block!
- Skunk2 test pipe ?
- leaking master cylinder?
- 5 lug conversion
- Clutch Release Rod, Tanny Removal
- Distributor Question
- Starter Problems
- HID Labor on my 96
- Help with idle problem! Just finished a swap!
- rotor question
- Cam seal plug on a B18B1 torque specs?
- 93 integra
- Is changing the cps (crank position sensor) hard?
- rear wheel bearing question?
- Ls/vtec
- anyone have the diagram to install a vafc
- 98 Integra GS 1st-2nd grinding
- JDM Front end hood?
- Coolant Temp Sensor
- 1991 integra rim size?
- VC Swap?
- Well, this isn't really tech. But its annoying. help?
- Headgasket 0.05mm oversize - ok?
- hello all
- plugs for ls/vtec turbo?
- and yet more electrical problems.....
- oem foglights for 94-96 integra
- GT40 or GT35R ---- B-Series Ls.Vtec - Comparisons?
- 2000 GSR--> Burning Oil --> Idle then rip it --> smokes big cloud
- npr rings
- ::HELP WITH RANDOM SQUEAL::
- HELP! DISTRUBUTOR IS NOT CRANKING
- ** Acura Integra Blank Key ** Butterfly
- What do you think?
- 1998 GSR Stolen in La Palma, CA
- need clutch/pedal bracket
- Stuck in Neutral
- will dc sports 4-2-1 header made for 94-99 integra fit my 2000 gsr?
- Need Swap Help
- Do ek fog lights fit an integra
- quick question
- smog problemsss
- da-dc front arms/knuckle question.
- --98 gsr-- P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
- temperature gauge isn't working
- valves
- how-to? install jdm window visors..da ones
- i just got me my first car 95 ls auto
- Spoon Axleback...or Not?
- 150$ for jun/spoon chip?
- Air Fuel Guage installation
- key help
- Crunch or rattle type noise over bumps in cold temp.
- Anyone online Manual for MT GSR
- welding muffler price range
- another gsr question
- Ignition switch question
- TOkico illumina & Ground COntrol feedbacks!!!!!
- squeak from caarrrrr. sadface.
- Total Loss. What other parts can I sell?
- need help
- GSR launching
- does sy1 have lsd
- SAFC
- i should i pay
- '00 teg turbo kits
- thrust bearings/washers? where do they go??
- i need help with my choice.
- Where would I get one of these??
- balance the rotating assembly
- camshaft type?
- Starting problems
- Fuel Injection and ECU Help!!
- will i pass inspection
- Wire tuck
- Wiring Harness Removal
- shouldi buy ????
- CTR piston questions.. milling
- Compression test results in non-running car
- help please, stolen car in SD
- anyone see integras in movies?
- short shifter rattle
- da springs on a dc?
- B18C valve clearance
- HELP!! Car is dead and parked illegally + Cant get a code
- How often do you get your car's valves adjusted..?
- the hell do i do now?!!?!
- Ideling Problems
- ls VTEC
- rethreading crankshaft
- how much for b18c1/with gsr tranny and ecu. intake manifold, TB, and stock header 100k
- ITR head on LS block
- evo 2 muffler
- OBD2 to 1 conversion TDC Code???!! need answeres ASAP!
- need tuner in philly
- Roll Cage!!
- Oil light problem
- i need help with my integra
- 1990 da6 2dr integra b16a lag,sputtering,etc
- Speedo / odometer accuracy for 92-00 Civic / 94-01 Integra owners...........
- tie rods
- Carpet
- Daily Driver Project
- need advice on a shop for integra
- how many miles will car run after oil/fuel lamp turns on?
- where can i get a 0bd1 to 0bd2 harness jumper?? cant find any on ebay anymore help!!! please
- steps to pulling out a motor
- looking for a perfect paint job...........
- OEM cassette player 98-01
- light bulb
- DA Owners READ!
- Wiring Remote start W/keyless/alarm...
- need help finding oxygen sensor thread?
- Aftermarket 98 Bumper
- converted to non abs and now having a problem...
- da tranny swap
- **********Sway Bar, Control arm Fitment problem.***********
- engine swap dilemma in CA
- !!CONVERSION HARNESS QUESTION!!
- question about OBDs
- It all started with the oil light
- how strong should my car be running
- ingalls camber kit
- what will i need to install my k24a4 into my dc2 integra?
- ls transmission issues.....
- new ECU or just a chip?
- expletive U Dogginator
- gsr pistons on ls rods?
- help need conversion wiring on obdo-obd1
- car engine check
- speed needle & mileage counter
- Apexi neo install on 93 gsr teg. Ive searched and cant find it. Colors different
- exhaust question
- e brake light goes off and on
- Evo2 exhaust with stock header.
- LS Honeing ?
- Coilover ? Apexi Exv N1 or Skunk2 Pro-C
- Ignition issue? please help
- Anybody running 4-1 header on their LS engine?
- Cam Help
- i know these arent too common with tuners but...
- Carbon fiber hood painted.....
- whats a headgasket again?
- How to remove outer CV joint from driveshaft??
- Value of my gsr swap
- header installation
- Window issue.....please help...
- when to change gears for optimal acceleration
- type r swap ls
- which airbags will work in my car?
- Original motor, 2000 GSR.
- when/where can i post?
- hytech replica header
- Did I get ripped off?
- Honda Emblems on Integra DC2
- b16 tranny
- Acura VIN Number explaination
- '94 LS Timing Belt Tension.....
- WHAT cat are you running ?
- Quick question!!
- What kind of fuel do you guys use in yur gsrs?
- Noisy Struts?
- Suggestions on a decided b20 swap
- ac in DC2
- intake manafold gasket for g2 b16?
- skunk2 throttle body = cruise control?????
- Battery or Starter Problem please help??
- pic request. white integras
- 205 on a 7" wheel?????? will it work? pixs?
- Offset for DB8?
- 1994 gsr head work?
- 94 gsr jackson racing sc 11lb pulley
- Shaved.SameColor.Black
- Squeeking belt how to fix please
- help need advise on cams
- 94-97 seats please help
- Crusie control and ABS removal
- need help identifying a transmission.. thanks
- oil leak into spark plug. will other b-series o-ring work?
- B16 YS1 Lsd Cable Transmission - Which Clutch Disk?
- weird idle ?
- can't redline any help
- how do you make your high beam lens yellow?
- Sensor on knee bolster?
- energy suspension motor mount kit
- EXHAUST QUESTION!!!
- help with tranny code and which one i got lol..
- Rear Caliper Rebuild Kit for 90-93 DA
- Comptech Icebox Vs Aem Cai
- vtec wiring?
- Shaking brakes on 94' Integra RS?
- Winter Maintenance in the Midwest
- greddy evott??
- Gsr header
- salvage /rebuilt title
- Power Antenna removal
