View Full Version : Acura Integra
- broke header stud help
- H-T I need your help, getting 3" exhaust but won't be going turbo for a month or so how bad for the
- red or black...energy suspension
- hi im new
- poking a hole thru a cat converter.. good idea?
- Check engine light question
- STRIPPED LCA bolt
- how to ek side skirts on a da??
- Valve cover washers
- tranny won't come off
- help fast
- 4x114 suspension
- GSR knock sensor Question
- I NEED TO SPEAK WITH A MOD!!!!!!!!!!
- quick question
- side marker placement
- NEED HELP BOGGING
- problem since i got itr swap.. input needed!!
- HELP!!!! Axle/Tranny question
- Popping and hesiation..
- ABS Light Disable?
- Tranny fitment
- whats a good car alarm system?
- how can i post my pic
- What are the specs on the GSR cams?
- jdm gsr cluster ????
- smog question
- picture of integra with HX
- Alot of smoke coming out from my valve cover i mean alot....(searched already)
- 13"s On GSR Beakes
- gsr blades clear coat fading.. help PLEASE
- wheel hop problems
- anyone ever used the "help pass smog" fluid at NAPA?
- Gsr hondata
- ITR or skunk2
- Questions about gas mileage
- cams for a gsr
- Spoon (p13) ecu program question(s)
- HP Racing Header-Any Info?
- considering trading my gsr dont know wat to do????
- DA power folding mirror rapair?
- LS VS GS-R
- help with hondata
- Integra DB8 ... Part Help...
- PasswordJDM 3 point strut bar
- EBAY CATALYTIC CONVERTER
- Throttle cable?
- Guage cluster warning lights (what size bulb?)
- da shiftlinkage fit 95 integras ls ?
- Integra not starting
- mounts
- HID
- jdm 1996 SiR integra interior fuse box same as USDM integra?
- help plz p8r head what size vavles
- UR Underdrive Pulley 97gsr
- inaccurate speedo on jdm teg..cleaned +checked vss, removed km-mph converter, reset ecu...help
- intake fell off
- DA auto tranny question
- where to find offset on rota wheel?
- typical price for b18c1 stock header?
- DA seat mounting problem
- ok, shifter feels like i'm stirring a pot....
- my tail lights dont seem to fit right, need HELP. pics.
- Rear seat belts?
- Loud Clacking during high RPM driving
- dc2 mirrors or spoon
- RSX Steering Wheel Fit DC2?
- Headlight problems
- B16 Head on a GSR block?
- dizzy help!!!
- Integra seat bolts... same as civic?
- oil pump replacement
- Finally getting a Honda.
- integra ls 5 speed vs 01 eclipse v6 who would win?
- No spark
- Will these foglights work?
- rims
- F/S or trade LS VTEC!!!
- CEL help!!!! DA b20
- Quick question
- need help with my idle.
- manual to power window conversion in 1990 Integra
- 4door Integra rear seat into 4door Civic
- How to Disable Clutch Saftey Switch??
- Polyurethane motor mount inserts + lumpy cams
- does cruise control lower your mpg?
- friends gsr running like shit!
- trannys
- Fuel pump or something else??? need help
- non vtec to vtech
- del sol seats hmmm...?????
- Mugen Half Bumper Corner lense problem
- What color Fat Fives: Red 1995 Integra GSR
- Sensor Name/Part # Help
- car not running?
- My 98 integ can't hold a charge
- driver side axle b16 tranny
- Low Temp ThermoStat and Thermo Swtich Stant, Napa, Jackson Racing, Spoon, Mugen,
- Steering Creaks
- parting out
- Where to buy a direct fit magnaflo high flow cat???
- My integra, Help!
- want to turbo my ls motor
- fidanza short shifter
- Burnt valve?
- exhaust
- ls/vtec parts..........
- oil filter problem. HELP.
- check engine light blink
- rear brake question
- HELP with AC fan speed and related wiring
- GSR Timing
- Header: Megan vs. OBX
- How to adjust Koni Yellows perches?
- suspension set up
- itr rear sway bar question
- Type r tranny or quaife ls
- GSR radiator?
- AEM COLD AIR
- license plate re locater
- kill off switch help prevent stolen?
- Is Leaded fuel ok to use with a test pipe
- what size tires should i run with my 16s
- LEAKDOWN/COMPRESSION TEST $$
- replacing DA front bumper cover
- I have to pick a B18b motor soon.
- Stolen GS-R - Las Vegas/LVMS
- LS Project car parts for sale
- Oil Pickup nut almost took the life of my B18c5
- Replacing coolant hose from TB to upper rad. hose?
- how do i remove this piece on my 90' integra??
- 205/45/16 Problem
- ECU questions
- Carbon fiber hood? or trunk?
- how much is shipping on a front clip, no motor???
- Another Rattling Problem, plz help.
- will a DC shiftboot fit in my DA?
- USDM Headlights and DRL running lights...
- Integra GSR only goes up to 6500 RMP on 3rd gear why?
- What tire sizes are you guys running?
- Where can i find an OEM "INTEGRA" DA emblem?
- requesting pics, DA with GSR swap
- My 91 honDA!
- Which car magazine?
- Rim choice for 92 integra gsr
- Upper control arm?
- Battery on a '90 LS
- Need a diagram For Acura Integra 99/00
- Fuel guage issues...
- SeatBelt Smeetbelt
- Will 96-00 civic greddy evo2 bpipe fit 95 ls teg?
- LS VTEC
- Lift points
- Car not running right after header install...
- Anyone ever try the AutoCool?
- What size are my front speakers and tweeters in my 97 gsr?
- my headlights say japan on them
- b18a bogging
- royal purple sycro fluid
- Door wont shut
- pro 1 exhaust
- skunk2 catback on 99 ls?
- msd 395 cc on na car ok or not???
- big hopes?
- B18B1 Using lots of oil
- ebay racing seats?
- how can you tell if itr lip is oem, and not a replica?
- Need Some Help here for my car acura integra
- question on type r block?
- Need help!!!
- i need to sell my 1992 integra
- rear sway bar
- ITR SRS AIRBAG LIGHT is ON
- type r body with gsr seats?
- Car wont start, Wierd gas smell. Ecu code 43. Searched :/
- gsr cat question....help!!
- short ram installation - 01 gsr
- e55 retrofit Help- Can't get bulb to stay in socket
- b18b..obd1 to obd2
- burnt rod bearing, what to do?
- WIPERS!!!!!
- Where to buy 13 14 brackets?
- O2 sensor wireing
- GSR Swap in my DA
- ? about valve adjustment
- 4.4 or 4.7 final drive?
- Timing belt went out?
- b17 spec question
- tranny noise
- B18b engine question..
- shift linkage
- spark plug, leaking is this a problem? - see pic
- Turbo setup?
- dash and tail lights not working
- In depth pics of 95 integra engine bay
- finishing up GSR into DA swap, 3 things i dont know where they go (pics)
- signal light prob
- So who knows there paint codes?
- How much will an intake help performance?
- Quick Question?
- valve adjustment problem
- pistons or cams?
- b18a1: how much oil to put in?
- 91 Acura Intergra wont start on the first 3 tries. Looking for answers.
- H22 into a 2nd GEN??
- weird noise coming from newly installed shocks
- ProStreet Control Arms
- master cylinder question
- Idle drops below 1000rpm then sometimes the car will make this screeching sound.
- how to do a integra rhd conversion
- camshafts
- instruction on how to put head on block?
- turn signal light is weird
- Come get these parts
- need help 1 piece headlights !
- Integra Colours?
- hi
- Question about Integra Front Lip with Pics...
- GSR Swap In Civic Throwing Codes????
- Coolant Leak
- 94integ gear scraping while shifting at high revs into 3fd
- I broke my vtec
- rs length vs. gsr length
- Main relay
- Would anyone recommend doing this??
- ~HELP~93 LS has problem starting
- Sunroof cover or something similar? searched
- anyone do got a diagram ?
- Need rod bearings
- need a quick fix already searched
- question about radiator
- torque specs
- How much HP is Too Much for Stock Trans?
- help need pr8 head spces
- Aftermarket Muffler
- popping noise coming from driver side wheel suspension area
- blowin shocks!
- GSR engine swap help
- Stock block power
- need help from 2nd gen experts
- Help!! I'm overheating!!!
- auto to manual
- type R body kit
- rear wiper removal on DA
- Air Conditioning a standard feature on a '91 RS?
- Effective bolt ons
- Headers Pro's/ Con's
- picked up a swapped teg, 93 with a b16a, need info
- help me with swap-Galveston, tx
- DA speedometer CABLE*****
