View Full Version : Acura Integra
- suspension!?!
- axle clicking
- good or no good?
- Clicking sound
- SRS Airbag issues . . .
- Electrical System?
- motor problems :( HELP PLEASE !
- New guy 1990 Integra , a couple quick questions
- HELP! speed meter
- 87 ls and a b16
- Integra ball joints part of steering knuckle! WTF!!!
- 93 integra ls
- Soft brake pedal help!
- new motor in teg starts up and revs to oblivion w/o touching throttle
- HID'S all the sudden died?
- removing black paint from vc
- 98 Integra LS **STOLEN** NJ, keep an eye out please!
- Need help...my gsr is vibrating when i start it up then turns off...
- Clutch fluid flushing valve DB1
- injector question etc.
- Starting Problem -- PLEASE HELP!!!
- cam shaft gear torque specs
- How many foot lbs do i torque my front struts too?
- Vibration from front end
- Strange sound in my tranny
- OBX muffler....
- map sensor code 3 cel on my 95 ls integra
- what part do i need??!>!
- 1987 INTEGRA D16A6 question following to the price of it.
- acura integra forum search problems
- Which coilovers for a '94 DC4?
- Clutch Slipping?? Comp Stage 4
- Need Help Taking Apart B20z Block!! NEED HELP!!
- P0420 code at 160K+ miles
- NEED HELP SRS light ON
- vtec solenoid leaking!!!!!!!
- NEED HELP ASAP!!!!!!gsr
- suspension bolts
- 2000 integra gsr DB8
- moroso oil pan stud question
- How to install hatch?
- shifting feels notchy
- What is my boosted LS worth?
- GSR MANIFOLD!!!!!!!
- 94 LS Couple, NO TPS!
- Ls convert to Ls/vtec
- 90 integra window replace. help..
- HIGH RPM BOGGING NEED HELP!
- Code 54 on 96 Integra
- Fully built integra head for sale
- rubbing compound
- Need help on engine swap info for my 93 GSR
- is a loose timing belt still drivable
- front bumper question.
- Power steering help!
- 1990 da9
- first post- would these struts fit on my car?
- 97 Integra rear disk brake caliper bridge/braket?
- How does the speed sensor come out on a gsr? Or other places to put oil into my trans?
- Good tuning shop in philly?
- ls/vtec hp?
- Looking for suggestions for a new suspension
- Why can't I find a Vtec Solonoid gasket?
- Crower 403 Idle Problems
- idle problem (already searched( need help...)
- HELP!!! Does anyone know of a drl (daytime running light) KIT that will works on a integra? HELP!!!
- obd1 LS block w/ B16 obd0 head..HELP!
- Toda header + Spoon Street Type w/B pipe + JDM ITR cat = direct bolt on DC2?
- Major Problems!
- b18c1 in 1995 ex coupe jdm ecu question?
- starter
- LS-V question
- (Help) Need good price range...
- ls block!!!!!
- door handle
- Where are the major ground points on a DA
- 97 integra type ti
- 97 GSR into 94 LS swap question
- knock link
- can the honda crank pulley tool be used to loosen/tighten the flywheel bolts ?
- OEM JDM 4-1 Header + JDM cat = direct bolt on to USDM exhaust?
- Wiring Harness For Engine Labels
- acura integra 1995 LS cold air intake question?!
- weight and rims
- Radiator Question
- rim/tire question
- 1990 Integra LS idling. Help!
- can someone plz
- Need HELP. I need to know what size bolts go through my motor mount to my block on a LS
- posting pics yes i'm comp ill.
- Steering question
- Mugen rear lip install help
- best place to buy aftermarket "oem" optional sides
- Broken antenna (best option for repair?)
- 94 acura integra for sale
- what engine do i have?
- maximum brake torque
- DA swap help?
- problem with ls header fitment on 01 gsr
- Exedy Clutch
- Would like to know how much the aicv & the fitv on a 90 91 integra go for?
- INTEGRA VSS DIFFERENCE?? VEHICLE SPEED SENSOR DIFFERENCE?
- spring rubbing against sleeve = squeaks
- thinkin' crazy thoughts!
- abs light problem
- The infamous 3rd gear
- bought a 91 integra with a b20b swap, but the car is sluggish
- built B18C1 on 12lbs of boost, have a valvetrain noise
- just installed shocks and coil overs and now rear shocks sound like they are blow, WTF
- ARP Head Stud
- p28 chipped ecu question
- Replacing Seats Need Help wiht brakets
- 94-97 fogs on 98+?
- EGR VALVE??!!
- 05 rsx fog light how to installed
- I CAN'T DECIDE! help me choose what engine set up to go with
- Integra DC2 ?'s Tranny, Flywheel, LSD, etc
- DIY: Civic dual core, half size radiator in a Gen 3 Integra
- quick question about DA AC.
- how to get after market water gauge to work in dc4
- whining noise upon start up?
- CAR BOGGS NEED HELP
- A problem I can not fix! Help Please.
- where can i get license caps
- how do u post pictures
- Gsr Head oil dowl question
- no power???
- 90 integra problems
- b18a1 burning 4 qts of oil at a time!!
- compression test?
- switch in 450's for turbo and car runs like shit
- yellow stains from floormats?
- circuit testing plz help
- severe battery drain HELP!
- 97 gsr wont start!!
- Running on warped cylinders??
- PROBLEMS WITH MY INTEGRA!
- What should be a great header for about 200-300 $
- 6x9 in da 4door possible?
- OEM headlamps with HID
- power windows not getting power?
- Can't get transmission out!!! HELP!!!!
- building 2 tegs at the same time
- knock sensor question?
- Need help with GSR conversion for VTEC wire up.....
- Windshield swap.... 90 to 93DA
- oil pan gasket just came off wtf
- USDM TO JDM B18A, just some questions
- Just got my first integra!!!
- Dying Problem
- Automatic transmission acting odd
- bottom radiator cushion the same as civics???
- Wheel choice
- Tryna my run my DA this thursday...tech inspection???MIR
- poor mans type r need a lil help
- Please Help need to replace a sensor.. dont know what it is!
- shop manual
- So i put in Shell and I hear knocking
- Removing the transmission
- INTEGRA DA side skirt QUESTION?
- Misfires in all 4 cylinders! 2000 Integra LS Non-vtec. Advice needed!
- Need Quick Help-Removing Alternator Pulley Bolt
- ls head gasket or mls cosmetic gasket?
- Help picking motor for my integra
- 93 integra auto to 5 speed swap need help
- cools off at idle
- Performance axles
- LS to GSR swap vtec HELP!!!!!!!!!
- How to remove front speakers from 91 Gs?
- Clutch Slave Cylinder leaking oil onto clutch disk
- Will it fit?!?!?!
- Improving suspension
- good online stores for rims
- 02 sensor bung hole location
- NEED HELP.....2000 B18C1 FOR TURBO
- '94-'01 Integra Closer to which Model Civic '92 or '96?
- strange problem/miss after new plugs
- 90 DA GSR Swap help needed!!!!!
- 97 GRS - help me find a thief please
- DRIVESHAFT SHOP AXLE POPPING OUT
- Bought an Integra
- SRS?
- need headers
- Block Guard
- DC2 LS questions -- Wheel offset and GSR Axle back question
- Suggestions
- squeaky squeak from front right wheel area
- ??? RODS QUESTION ????
- How to check your TPS sensor on an OBD2 'teg
- oil pan
- issue with brake lights!!
- skunk2 writeup
- help car over heating
- teg height question
- check engine light comes on while cruising on the street.!! HELP!
- ticking when heavy acceleration!
- DA6 manual crank window options?
- Wheel bearing help!
- JDM Integra Axle Questions Please Help Thanks
- fuel regulator
- Could a leak in the clutch master cylinder cause gears to grind?
- oil filter question
- Car wont turn over :( !! NEED HELP
- i need some input!
- bad rattle?
- trans/reverse
- Please Help anyone :Idling problems with my DA
- SRS bypass?
- speed meter help..asap
- Corbeau bracket / Recaro rails fit Sparco Torino?
- Question about brights
- integra windows help
- lookin for ls/vtec oil line kit
- 1994 Acura integra 98-01 front and rear swap
- da9 turbo
- *****STOLEN*****CHARLOTTE NORTH CAROLINA 92 Acura Integra LS Graphite Black
- ebay header downpipe and cat problem
- Battery Tie Down Question
- obd0 b18a w/ b20z cams?
- motor mounts question
- Does OEM ITR Lip fit on a GSR 00 front?
- DC2 MANUAL TRANSMISSION IN MY DC4???
- gsr intake mani with no butterflys
- b18b1 idle problem
- Need help on radiator plz!!
- why's there black soot on my back bumper???
- momo steering wheel hub
- head gasket?
- where to get 3rd brake light connector
- Oil
- RPMs
- question about rackn and pinion
- leaking weird green fluid???help!!! overheated
- JDM housing bulbs 94+
- spoon monoblocks on integra ls?
- What to look for when buying an 94-01 integra?
- 94 gsr won't start
- headlight adjustment
- 94 RS Project
- Close to buying this LS Turbo swap DC2 tell me what you all think?
- my tranny has some weird issues when shifting up or down past 4k rpm
- car sounds like a tea kettle (most noticeable reving 3k+)
- 2000 civic CTR lip on 99 teg
- quick question about STB.
- defected stage 2 axle
- STOLEN ORLANDO FLORIDIA, SOUTHCHASE
- need swap advise
- need to know what this connector is called?
- where can I get a launch control
- my car is tilting.
