View Full Version : Acura Integra
- Rolling back miles on speedometer
- Integra Info Please
- I NeeD TO decide what swap i should THrow into my 92 teg
- mechanic dispute. Heeelp!
- Parting Out 90 Integra
- TDC mark on 87 integra crank pully gear
- B18 or Turbo?
- Questions about Performance Chips
- gay engines <-- pro's
- Lowering my integra
- OBD2a to OBD1 ECU Conversion Harness 1998 GSR and more Problems
- I need complete xsi swap!!!!!!!
- Weird Vibrations under Acceleration. HELP!!!
- What suspension should I go with? Spoon? Benen?
- boosted ls's what gas MPG are you getting?
- What's Wrong
- hey guys, i need help with a carfax.
- bsr tranny in a 99 ls, 14's possible?
- Stalling in Neutral.
- oil pan seal
- planning on buying racing seats for my gsr
- water blowing out of the muffler
- ecu engine subharness
- how?
- Console switch installation
- turbo kit any good??
- Ready to get a new header, input needed
- wiring screwed up
- O2 sensor
- jg edelbrock freebie
- OBD 1 or OBD 2
- B18 swap specialist
- Insurance already fixed my car, additional damage underneath.
- 98+ JDM foglights
- deck brackets
- obd2 engin in obd1 car.
- what should i do with my gsr?
- WHATS A GOOD OIL FILTER
- police radar detectors/jammers
- ANYONE SELLING AN INTEGRA!! PICS HELP!
- Which cam has two rings?
- skunk2 exhaust dyno sheet
- B20 swap
- integra transmission requirements
- integra part name
- sport clutches
- Tein Type RA on daily driver?
- 98+ fogs on a 94-7 front ?
- b18b1 dyno chart..please
- HELP!! car isnt idling right
- New here
- GSR head?
- Ls help needed
- No start! fresh out of ideas
- how much should i pay?
- Windsheild wiper problem?
- PLEASE Help Those Who Have Tucked + Relocated Wiring!!! 93 LS
- Mild Build on GSR, Power #'s?
- jdm ls
- where to buy a oem ITR cat back?
- Integra axle back help!!
- lambada sensor
- newbie
- question about obd 1 conversion
- coilover installation help!!
- quick question...
- Will exaust from 92-95 civic coupe fit on a 94' Gsr....
- Speedo is twitchy and not working at its best! =(
- What would you do with a 92 Integra RS and $3-4K
- Blue extended lug nuts
- What the hell?
- Type R Trans
- pic request of integ g3 2 inch drop
- Engine will not start -Fresh out of ideas-
- foglights in front bumper?
- un-filtered intakes/ im's
- How much could I make off of this car?
- Intake Manifold Swap for GSR, Ls Vtech
- DC Seats... 2dr vs. 4dr? Whats the difference? Interchangable?
- WTB 16'' rota slipstreams..
- distributor question?
- question regarding alignment and camber
- Guys, i need help with an oil change gone bad...
- URGENT PLEASE READ AND RESPOND
- Who has bought this? *Any Opinions?*
- getting JDM conversion...need advice
- Do they make this for DC tegs?
- special or home depot will do?
- bracket for stock deck...
- getting a new exhaust system...suggestions?
- Head on 87 integra
- B18C1 Head gasket
- <<<another MY IAB DONT WORK thread>>>
- need help
- brake pad question
- i go the consule to work!!!
- Squeaking Problem
- rs and ls integra
- Engine swap, Injector problems
- lug nuts
- Dyno Results
- 90 Teg Tranny.. :-(
- looking for a part number please help
- Curb Weight?
- DC and EG exhausts interchangeable?
- nasty gas milage - 11.5 MPG in my 97 gs-r!!!!
- diameter of gsr rotors?
- Blown timing belt
- will it fit?
- Tranny or clutch problem????
- integra wont start
- Tranny question..
- LS/VTEC turbo cams?
- Windshield wipers only work when on the highest setting ????
- 14 second dreams (yea i know its sad)
- Glimpse of my GSR Swap to come
- Rear upper control arms
- oxygen sensor for emission
- how many k are my stock itr hids?
- LS stroke and rod length in metric
- Squeaky Clutch Pedal
- what clutch to use? Exedy OE?
- GSR motor with GSR tranny and LSD or b16 tranny
- B18c1 What Turbo??? What Parts??? Rubuild Motor Where??
- Half Antenna Switch???
- Power Door Locks
- tire balance
- Can you guys give me some input on what car to keep?
- so much better
- Recommendations for a ECU?
- She's missing in Ontario 909 Area.....fuking thieves,//......
- ??No Windshield Wipers- Not Working-Need Help??
- My Clock keeps turning off - Help
- ls to itr or F20c
- Pic Request: 98+ halo projectors black housing
- NEEDED: 5th gear set from LS Integra
- 1996 Integra SE Starting issues
- Hi im new to HONDA-TECH... =]
- Help with radio code plz
- 00 gsr obd2- obd1 conversion
- LS to GSR Cluster problem????
- WTB: 94-97 headlights...
- porting my vtec solenoid
- where is the fuel pressure regulator on a DA?
- s2000 antenna help what wire is this
- Painting mirrors on DA
- OEM paint
- cable to hydro mount/bracket?
- 91 Integra
- Will Hi-Flow cat bolt right up to stock existing piping?
- does anyone have a picture of where and how the cruise control wire connects to the gas petal on a 9
- inline pro mani
- Sticky Valves
- REAL SKUNK2 INTAKE MANIFOLD OR IS THIS A FAKE???!?!?
- Broken Door Lock
- What comes with an OEM Optional Kit?
- Help with Eibach Springs
- what is a safe amount of boost on a b18c1 rebuild?
- help! inline pro manifold
- JDM Headers ?
- idle problem in my integra, please help!!
- newb question, how do i rotate my tires?
- crank question
- fuel rails
- ECU fuse keeps blowing
- NTK ASAP - Head bolts Blown motor?
- adjustable upper control arms?????
- Integra Foglights
- Unlocking Stock Headunit
- How wide of a tire will a DC2 take without rubbing or other problems?
- how to test computer
- PIC REQUEST & Opinions on Tanabe Super Medallion Exhaust for a DC4?
- LSD INSTALL QUESTION
- Aftermarket camseal install
- websites please ? ? ?
- Should I buy a 1998 Integra?
- First Gen Interior parts compatibility between 2 and 4 door models
- ecu codes
- B18A1 Head Bolt Length's
- AEM or SKUNK2???????
- Throttle Body Spacer
- jdm gsr lsd swap in to 94 ls questions
- anybody have the diagram of how the wires connect to the back of the headlight?
- GSR Gaugle Cluster Question
- Will DC Rotors work on a DA?
- WTF would cause the corners of the oil pan to leak so much?
- anybody remove their working SRS system from their car 96-97 integra? help me out
- metallic grinding sound
- eg stock lip on 94-97 front end
- smoke coming out from exhaust help!!!
- quick intake question
- help help help
- WTB: LS TB Pulley
- Good place to pick up STOCK motor mounts?
- Check Engine Light --> Need Help
- how would i make about 190whps on my JDM GSR using stock block?
- DB7 JDM Front End?
- door poppers??
- Turbo B16a??
- how to replace pulyurethane motor mount inserts on 94 gsr tegg?
- 98 b18b1, valve seals, rings? how to find out why my engine smokes.
- anyone in new york or tri state
- pistons?
- Opinion on headers
- LS turbo questions
- That DAMN Antenna
- vtec malfunction
- Sagging spring or Messed Shock?
- Strange throttle issue.
- Rebuilding, need some suggestions
- broken vavle
- Number 3 piston
- Annoying Buzzing Sound
- MY coilovers suck
- **Black Housing CL lights??**
- i was wondering if these are smog legal
- what is the chance i installed my rear oil seal incorrectly?
- SHIFT knobs
- WTB front GSR/ ITR sway bar
- how much for a complete b17a1 motor and tranny for 93 integ?????????
- Water in my motor
- icm results
- HID conversion....is it worth it???????
- im new to! woOT!
- O2 sensor heater problem
- Will DC2 coilovers fit on an EK?
- Flat tire Question
- Converting a OBD1 B18B1, to OBD2 is it possible?
- any one use reactive muffler?
- Wrong Part #?
- up for sell 93 acura ls vtec
- HID's in 92 teg wat projector to use?
- Where can I get a VADER HOOD in SJ??
- Some quick questions on bodywork.
- Pic Request DA w/ H&R sports or race
- tunning question
- suspension bump stops
- Need some advice.
- 205/45-16 tire options/opinions
- Transmission wont shift into 3rd? bushing problem?
- Distributor
- starter or battery? rebuild!
- Advice help Rear motor Mount
- b17 compression?
- Anyone Have Instructions for OEM Fog Lights?
- car cuts off out of nowhere...??
- replaced vtec solenoid--oil leaking?
- Need b16 OBD1 wireing diagram .
- Bad compression! please read.
- Taking off bumper
