View Full Version : Acura Integra
- Preventing Theft
- Whats the difference between type f or type d?
- VAFC 2 set. in gsr
- Window Visors Installation
- flex pipe issue
- best oem TB on an ls Intake man?
- Low compression numbers on b18c??
- Need help with front Benen tow hook installment.....
- tps issues!!!
- Another car wont start thread
- Suspension Question
- new o2 and now A/F gauge freaks out
- timing off?
- Violent car shaking!
- color coating on rod bearings??
- gsr
- Need help removing shift knob
- ITR sway bar bracket?
- Difference in automatic and 5spd cams in a JDM LS,please help???
- 94 integra to 01 cluster wiring diagram needed
- fuel rail
- JDM Headlight Adjustment
- all you skunk2 catback owenrs
- Gettting headlamp out
- kteller exhaust question
- CAr wont start....
- fog lights wiring trouble....
- crank pulley
- What the easiest way to clean inside of lense w/o taking apart?????
- What motor came in 92 - 93 gsr?
- 1996 integra rear brake installation...
- Battery for DA
- b20 in an 92 teg?
- auto to manual on a DA????
- Ls Head Swap
- GSR block and LS head
- Wiring schematics
- lightened flywheel
- New look for the DC4 come spring, need ideas
- Feedback on ITR black/red stitching replica seats
- Heavy rain causing loss of power, then car wont start and will not compression start or popping clut
- hi new to ht
- JDMsh!t Replicas and JDM ITR back seats
- take apart the foglight housing
- Cheap and effective way to quiet down the interior cabin of my Integra?
- My Integra
- pics of drop on H&R
- cluster?
- cant shift using clutch
- Quick question....REAR FOG LIGHT
- Integra's heater core / AC evaporator / ducts, what cars have the same parts?
- '90-93 Acura Integra Blk Corner Lens
- ls piston and p30 q's
- integra pics
- question on b16 help needed please
- WTB: CDM Seatbelt set for 90-93 DA
- ls/ vtec head conversion
- LSD tranny with 4.266 FD?
- *help* Engine knocks when i gas it!!
- cheap upgrades?
- What should I get for $120?
- DA Integra...92 ls...Need new Motor Mounts / New or Used in good cond. Where can I get them?
- teg on rotas
- putting 92-93 integra front calipers on a 94+
- Engine problems(burning water?)
- Tenzo R Steering Wheel - Searched and nothing - Advice
- b16a2 in a obd2 integra
- imobilizer
- pilot bearing doesnt slide in flywheel
- Water Leakage
- con rod lengths
- OIL PRESSURE HELP
- what type of bulbs for DA One peice headlights
- threads on valve cover?
- merry christmas!
- one break wore super quick???
- Is my head gasket going bad????
- help!!!!
- just got a type r for my db8
- Help with Butterfly Valve
- Anyone use this?
- HELP!!! O2' Integra Cd Player!
- clutch problem... i think... HELP!!!
- f20b in 91 da9
- CTR cams in my gsr= whats needed?
- Integra DA Question
- Power Door Locks
- Looking for a Book
- Clear out SRS cel code and get new steering wheel
- Next Modification
- DA neutral safty switch, broken car doesnt shift into drive untill warm?
- air breather.... Help
- Check eng. code after adjusting valve lash.
- failing TPS
- Spray painted my JDM DC2
- Anyone know the cating code of a 2000 GSR head?
- sir-g lip???
- Something har har happened to me MUST READ
- Tranny removal / installation
- NEED A LIL HELP ON CHANGING RINGS
- Will comptech sri work with stock airbox?
- car wont pass 3k
- car dies but doesn't?
- Will an EF Civic/CRX exhaust fit a DA?
- anyone selling ground control coilovers?
- Motor swap?? LS to B16A. 95 Teg.
- is ls/vtec reliable???
- how much gas in tank, car is sitting
- hole in brake line
- Apexi WS2 noises, searched no results
- noob oil change
- Suspension on 94 integra
- Engine Trouble
- Integra Color Names....
- usdm itr gauge problem....
- CF Sunroof plug
- Intake Manifold Swap Question
- valves
- my hood
- Carbon fiber mirrors for DA?
- b20 swap, got questions
- *** Q and A
- Just bought a old(honda crx) for 300 bucks... what should I do....
- I NEED ALL OBD 1 SENSORS FOR A 94 INTEGRA RS ENGINE.
- taking out back seat
- No Vtec in my gsr
- Car Dying!!!!
- ECU fuse keeps popping!!
- XSi DA
- Cheap Right Side Bubble Headlight (94-01) Replacement?
- Holiday Special on JDM integra front end
- thinking about to get full body kit.
- itr headlights help
- will the lsd differential from a b16 tranny work in an ls tranny?
- whats the diff between a 92 integra motor and a 95 integra motor?
- what to look for in a car at a used car dealership?
- 93 integra fuel pump problem, NEED HELP!
- will a 99 civic si brake master cylinder fit a 94 gsr?
- flywheel how to?
- What fuel pressure should i be running? My second problem is fuel pressure regulator doesn't want to
- vaccum diagram gsr
- K&N filter at Amazon
- Shaking question
- Small grind in clutch pedal near bottom of travel?
- gsr exhaust ports
- Change Bulbs in Gauge Cluster ???
- No headlight, turnsignals, gauges, dash clock
- Dynamat in integra question
- should him trade for this GSR?
- DC , GC and tokico blues , question.
- Is an EK clutch master cylinder recommended for a 96 GSR?
- Transmission:PILOT BEARING
- picking up my teg tomorrow
- tranny question ??
- itr valve springs in gsr
- 1992 Integra ls or 1991 civic
- gsr with skunk2 IM outcomes
- save up for EMS, block rebuild, pistons and rods or throw in FMU?
- polished valvecover
- humming sound when turning right...
- hydro tranny in 93 ls with a b16 obd1 swap?
- need quick answer to easy question PLEASE
- Let me know what you think
- difference between P72,P28,P30,P61,P72J,P30J,P08J ecu's ???
- next mod
- ? any mods to swap a b16 in a 92' teg?
- Engine swap?
- Defroster sucks!!!
- SRT-4 or H22 Integra
- question about camber parts (pic inside) 97 gsr
- 96 gsr suspension
- skunk 2 throttle help!!!!
- Did the test, IGN coil/Ignitor. B16 and what to use?
- Civic camber kit...fit 95 GSR?
- GSR problem, idle surging, new redlines, funky noises...help!
- Question about No Check Engine Light? Possible oil burning?
- Beck/ Arnley products?
- Carsound Cat size
- revving
- Cruise Control problems...acting weirdly
- Random loss of clutch fluid
- ABS on an 97 gsr
- A/C Torque mount is broken, fill it with silicon/window sealant?
- H22 Integra
- Question on Tranny issue 2nd gen RS...Pls take a gander.
- how to put back gsr head?
- i need help asap crank position sensor
- 90 Integra LS - B18B - Would a B18A1 work?
- american cars vs teg
- Worth The Money?
- gsr colors
- bottleneck question
- Post Pictures of DA turbo setups
- Weird vibrating steering wheel need help !
- b16a is in what car stock
- quick transmission question..
- Need help diagnosing an acceleration problem
- request pic of an-r header in dc2 bay
- Tach not working, Help!
- Test pipe?
- Synthetic Or Non Synthetic
- So Cal....Oil Change Location Question....So Cal
- H22 fully built 4 sale /95 Ls motor 4 sale or trade 4 a sohc turbo-kit
- 95 Ls motor 4 sale or trade 4 sohc turbo-kit
- Idle Jumping?
- Piston/Rod fitments?
- heat gets turned on, temp. falls?? HELP!
- HELP I DONT KNOW WHAT ECU IT IS
- Any nice and clean lip kits out there for 94-01 integras???
- this weeks dilemma: car wouldnt start after getting gas..later shuts off while driving
- where to get DA CF eyelids?
- Removing Axel?
- What is the best K to set your Vtec controller???
- WHP estimate?
- idle problems....help!!!
- map sensor cel and can't find the problem
- Question for motor techs..
- Question about clutch master cylinder for a GSR
- Whats a strong head gasket for my set up?!
- Identifying the problem.
- Selling my DC2, Flamers Welcome :)
- need help wth a serious transmission issue
- GS-R or 97+ prelude. Which one should I get?
- junkyard parts
- Strange...very strange.
- 99 Integra Ls front end for sale, wcarbon fiber ITR lip....and new pics of the JDM front
- **1991 Integra B16 Swap***
- New teg.
- backfire
- injectors
- ls/vtec to b20/vtec
- tranny problem
- JDM FRONT END FROM HMOTORSONLINE
- Changing Timing Belt and water pump/ should I change anything else?
- synthetic or non synthetic?
- Integra dash/sterio install on a 97rs, quick easy q?
- exhaust question "sorry, and i did search"
- Finding an integra..
- gas mileage????
- check this setup out!!
- what is the best oil for a gsr
- any body knows where i can find amber signal lights for a 92 teg bumper???
- CEL with no code...
- Installing oil pump on GSR
- so now im startin to get just a little bit pissed off...
- how much should I Charge to do a headgasket and timing belt?
- !!!IMPORTANT!!! Bad Piston Rings
- ts98-01 looks
- DA Emblem
- tranny... type r or gsr with lsd ???
