View Full Version : Acura Integra
- 94 Ls odometer doesn't work. Everything else does
- 91 Integra wont start after stalling.
- is this a car idle issue?
- 4dr optional lip kit
- i have a 96 GSR turbo question
- Car won't start. Please help?
- Some sort of miss fire issue.
- having vtec problems!
- SS brake lines LS/GS/RS vs Type R?
- '96 'Teg LS/Vtec Pwr/Str Pulley and Nut
- 98 GSR B18C1 - bad LMA's? valve lash loose for 152k.
- REGRET?!?!
- gsr axle problem
- 2000 integra ls auto comparability
- B18c FULL Turbo build help.
- Integra 94-97 fog light switch problem
- steering problem, feels heavy when steering
- Bad fuel pump?
- Search not working? Tail light swap
- My 2.0 turbo build: Taking it Paso a Paso
- DC2 98 INTEGRA NO CLUTCH PRESSURE
- DC2: Tail light question..
- DA brake calipers: has anybody tried centric?
- 96 Ls to a b18c5 swap.
- jdm type r front end anyway to pass brake and lamp inspection?
- 91 ls power window stuck half way
- H2B Db1!
- 95 jdm type r front bumper
- Overheating issues
- oil leaking bad out of my 91 gs
- B18C1 Head Question
- oil dipstick length for a 98 gsr
- turbo a rebuilt engine?
- GSR Vaccum help!
- LS turbo DC vs American Muscle irwindale
- 90-93 integra bushing kit
- wierd Idle jump?
- ls vtec leak!!!! help!!
- Failed smog, helpppp
- 1991 integra rs timing
- Valve lash on 93 Integra
- Cv axle removed, hard shifting. HELP!
- FPR and injector ? OBD1 GSR
- NEED help with B18C1 plz!!!!
- NEED AN ECU FOR A 1990 ACURA INTEGRA(OBD0)
- 93' YS1 Trannsmission pilot bearing
- new here
- Integra not starting need ideas on what to do.
- gsr o2 sensor problem.
- 90 Integra RS what next?
- How to fill antifreeze 1995 GSR
- Is it a b16a or b16b type r ?
- db7 with jdm b20z automatic swap need help...
- Radiator question
- Need help.....have an extra 14mm bolt left over
- Throw out bearing noise?
- DB6 from the UK
- Need Camber/Caster Help for Mini Stock!
- help ?'s about water in head on gsr
- B18 not starting NEED HELP
- b18c1
- Which Way Do LCA's Go?
- NRG Quick Release onto short hub
- Radiator fan doesnt work at all help please
- major hesitation after a drive
- Weird clutch problem
- compression below acceptable levels
- windsheild wipers dont turn off
- Is this ok to remove??
- 5 stud rear wheel hub bearing assy question...
- DA9 pain in the butt issue
- Gsr having problems with hid lights throwing check engine lights
- Im confused i gotta 98gsr
- Confused Gsr oil pan ls block.
- High resistance on gsr injectors
- idle and timing problems help plzz
- GSR VTEC PROBLEM
- Changing spark plugs...found a lot of oil
- Integra torque mounts?
- Hood clearance
- 00 GS-R with Chipped OBD1 ECU No Power.
- Heater Core
- clutch wont disengage after clutch install
- TRmotorsports C1M 15x7.5 30+ offset
- Auto meter???
- GSR back firing and fuel cutting off
- 96 B18B1 Ignition timing
- 96 Gsr possible k20 swap
- Trying to Identify My Pistons
- Quick Brakes-Help
- Need help adjusting the rear tailgate stiker(latch)
- hood stuck closed
- rebuilding a b18c??
- 1990 da build/restoration
- need new engine
- 91teggy pass axle wiggles inside tranny
- Please help need to do this asap!
- What to look out for when buying USED integra?
- Integra LS.. keeps draining my battery
- DC2: lookin to buy a new coilover kit
- car just dies while driving..
- wont start when warm/hot searched
- Craigslist buy help asap
- Teggy sounds like a Subi
- can rather stiff engine and torque mount s cause a crank pulley to come loose
- No start, weak spark WTF
- IACV question
- axle help please!!!
- 94 Integra wont start
- Dash oil lite malfunction?
- LS parts help
- Bad distributor? help please?
- Wrong VTEC solenoid gasket?
- First Teg, '96 LS/VTec, few ?'s
- 88 teg engine harness question
- Between a Rock and A Hard Place...
- [HOW-TO]Spoon Twin Block Caliper Install on 4x100 with 10" Stock Brakes
- Any Supercharged Integras out there?
- dc2 power window switch
- Lights and Radio Turn off whlie driving
- Need help, it's been bugging me
- just got my stuff back from the powdercoater!
- Hood pins question.
- going to be raining soon in cali
- window wipers
- Oil leak coming mostly from above oil pan lug....
- sensors
- My slow 4 cylinder integra, past and present.
- Integra Trans Problem
- thinking about jumping on "stanced and flush" bandwagon ?
- Helms lookup - o2 sensor connector diagram
- D4 Light flashing (1994 LS AUTO) NEED HELP, PLEASE READ!!
- My New 1996 Integra LS
- b18a1 won't start and I've tried everything
- k series integra
- 2000 GSR IAB question OBD1 conversion.
- Removing undercoat from wheel wells/underside
- 92 b18 in 94 acura
- WTF is the name of this whole part?
- integra check engine light problems
- CEL code 6 PLEASE HELP!!
- Question about some codes
- Transmission Rear mount bolts not aligning
- rev limit?redlining early?
- 94 gsr motor help!!!
- Train Horn In My Dc2?
- No start, Stumped
- Why no boost?
- sohc db7
- p28 or p75
- Energy suspension master bushing kit for my da?
- 92 acura gsr startup beeping problems
- GSR trans help
- cylinder #3 misfire
- My Civic vs my Integra. (not a race)
- oil pressure prob
- 1995 integra ls trans problems?helpp
- gsr build
- ECU not communicating with scanner
- integra chassis disadvantage..
- Remote start preventing car from starting
- Are all Honda door switch pins the same?
- alarm starter kill problem
- smog fail + rear bumper soot
- Blown clutch???
- usdm obd2b ecu square or rectangle?
- b18b piston ring size???
- Questions regarding a swap
- FPR Installation help
- WTB-DC2 98-UP PARTS
- Slight Idle problem? Integra DB1
- HELP: 98 integra brakes -- > ABS can't bleed
- B18B 93-98 (LS) Long Block ??
- leaking tranny fluid
- 96 GSR Suspesion
- HELP! 96 LS intermediate shaft seal
- 92 db2 integra oil on #1 plug??
- Help me locate this noise
- Gsr question
- 1997 integra ls/ misfire through the gears when cold..
- Weird noise when driving 5-6k rpms?
- A/C not working, want it fixed.
- jdm front end hood lock
- yellow fog lights for my 92 gsr
- b18c rebulid
- 92 integra with thick white smoke:(
- Need some help and guidance, Misfire in all 4 cylinders.
- Hood latch cable loose?
- obd1 integra stalling
- Need Help!!!!!
- No start
- Intake Air Temperature - Interchangeable?
- Been awhile since i've posted. Here's a few new things!(LOTS of PHOTOS *warning*)
- 01 auto integra blown engine - b20 replacement?
- integra look
- 93da b18a with a p75 head ?
- DC4 FI Build Questions (Suggestions)
- Flywheel Bad or good Pics inside
- spark plugs and wires help, LS
- TPS sensor calibrating
- gsr swapped into ek build
- 97 gsr radiator flush?
- got my self a b16 head (pics)
- redone my valve cover
- IDENTIFIED B SERIES ENGINE BLOCKS NON ID
- 92 integra clicking sound...
- Suspension Problems
- JDM ITR Endlinks on Reg LS control Arms Question
- coolant hose diagram
- No sound from my deck
- Possible altenator or ground problem
- VIDEO Turbo LS DC vs Hurst hemi Challenger Irwindale last night
- 00 integra ignition switch. diff between auto and manual
- Coolant pipe question?
- TPS Issues: when set at the suggested. 5 closed and 4.5 WOT, car runs bad/hesitates..
- B-Series Fuel Pressure Regulator All the SAME?Swap QUESTION
- 2000 gsr power window problems
- jdm momo srs conversion help! :(
- Idle, Starting Issues on Cold Start / Car Wont Start
- 99 integra ls with jdm b18c-R swap parts list needed.
- Need HELP!! with ABS Light.
- integra valve covers
- Emissions fail
- 96 GSR Tranny
- new integra
- 92 integra LS will not crank with the key
- My 00 GSR project.
- Car likes a specific transmission fluid?
- Ac not as cold.......
- Brake light acting weird.......
- DB2 integra speed sensor
- Vtec help
- 95 integra w/b16
- 94 build advice
- 1989 Acura Integra Thread!!!!
- GSR Rebuild crank question
- Issues with Clutch
- engine wont start. new plugs still no spark
- my engine wont start i have new plugs but no spark
- 1992 acura integra breather box hoses?
- integra keeps losing battery power
- LS Automatic Transmission 3rd Gear...
- boosted 94 rs Ecu/wiring issues
- SHOULD I ? OR NOT ?
- starting issues ( fuel related )
- Which wire for '90 B18A1 is constant ECU power for OBD0?
- Installing AC in 92 RS
- 96 Acura GSR Oil
- Running rich, smells like burning oil!
