View Full Version : Acura Integra
- B18 a1 for sell or trade
- MANIFOLD QUESTION
- integra dc2 koni yellows?
- torque specs on gsr bottom end ?
- What parts?
- rear defogger question
- honda tech....parting out
- Timing belt and Water pump
- difference between rs and gs?
- high pitch squeek noise near dizzy
- custom exhaust?
- A1 Tranny?
- which is faster? a stock integra rs or a stock eclipse gs?
- timing belt stretch issue
- Compression numbers, tell me what you guys think
- GSR Question.
- How Much HP??
- gsr mtx question.
- will 90-93 sways fit w/ EG civic rear LCA's???
- need help identifying price and info about this aftermarket steering wheel
- Springs or coil-over kits?
- integra Exhaust question
- Who can tell?Where can I order NGK plugs (ZFR5FIX-11 IX iridium) in providence RI?
- Minimum reqirements for the 5 lug conversion.
- gsr owners... need your help
- Probably the wrong forum, but...
- will 98 corners fit on 97's ?
- back to the teg
- **rebuild or not**
- Valve Adjustment Gone Wrong (vent)
- Home made poly mounts - HUGE dissappointment.
- si blue g2
- Decreasing Cabin noise-- Any thoughts?
- GSR Cam Specs
- AZ emissions Stations
- rattling noise coming from drivers front on 87 ls
- Where can i get these canards?
- ITR CAMS?
- h22 teg
- DA rear sway bar question
- will H22 injectors work on obd1 gsr motor
- Handling: (H&R Race/Koni Yellow) vS. (Omnipower Full Coilovers)
- third break light
- Will 225/45-16 have any rubbing problems with neuspeed sport springs?
- LS Greddy turbo kit ?
- ticking noise from engine B18A1
- Alot of negativity in here
- FINALLY...started porting my spare head! Take a look...opinions welcomed!
- what to set fuel regulator at or in between?
- 1989 Integra LS Suddenly dies
- Which integra springs are the fronts and which are the rears?
- B20 block/b16 head
- 92 gsr injectors and 01 R injectors
- PLEASE HELP Looking for REAR MAIN SEAL PLATE for ZC BLOCK/NONVTECH/1.6DOHC
- i m buying salvage 2000 integra gs
- has anyone thought of this??????
- my old g2
- front tire cliking
- rear clicking in the GSR when going over driveways
- ls/vtech conversion
- question about gsr intake manifold butterfly
- Right handed drive teg
- vacume hose
- Hondata s100 or s200 on my 99 gsr?
- need help on 3rd light
- WHAT HEADER TO GET???????????
- Ported Intake Manifold/TB
- Does using the AC use a lot of gas?
- Thinking about getting a GSR.
- What # does a USDM GSR Tach go up to?
- Suspension ?'s
- GSR Coil??
- Modding 2001 GS Integra to the best, need advice.
- For those of you that went with Type-R suspension components..
- a/c Air conditioner compressor cycling fast?
- Clicking noise in rear passanger side
- Cut and splice turn signals to high beam lights?
- 96 ls coolant hose connections
- 98-01 integ cf hatch....
- GSR-Type R
- DA b16 swap help.
- im going to vent... then im going to build the hell out of it!!!
- Newbie here
- First mods to a '98 GSR?
- ecu question for ls
- stats for the b17a
- What is the best turbo?
- ac squeek
- GSR won't shift to reverse...
- GSR oil level and dipstick
- 269 too much for a tune up?????????????
- squeeking brakes need help asap
- JDM itr ecu vs. USDM itr ecu - 2nd O2 sensor
- clutch prob. searched. no problems quite like this one:
- Install your own parts or Take it to a shop
- Strut/sway bar
- $120 to install exhaust?! more problems..
- gsr brake system question
- swap or turbo?
- short shifter help
- somthing for the old skoool peeps
- New 92's Cruise Control not working, and gas milage question
- need help please!!!
- what type of ecu for a obd1 b18b1???????????????????????
- body Work
- WOULD A BAD PCV VALVE CAUSE A MOTOR TO SMOKE
- whats wrong with my teg
- New Teg Owner with a couple questions
- Which exhaust manifold would best suit my car? (searched)
- Integra Trouble Start
- Accident
- Do Integras have a cabin air filter?
- who owns this first gen?
- Clutch chatters at idle. whats causing this?
- HELP ! installing rear sway bar...!!!pls!
- New gsr IM?
- maintenance required?
- Tach Flutter
- stupid ? whats the gear ratios and fd of a usdm s1 tranny
- Spun a bearing
- quick question
- Correct wiring diagram for 01 GSR
- New to the import scene, need advice....
- problem with a gsr motor.
- boost adaptor missing?
- Nitto Tires
- clutch pedal adjuster: WTF is THIS thing???
- Here's my suspension set up. What do you think?
- Type r interior pieces
- Springs/Shocks/Struts
- OIL PROBLEMS!
- DC Part Number Question
- Brembo replacement rotors (Blanks)
- Exhaust help: 95 gsr sedan, ITR header, stock gsr cat, which exhaust fits?
- i wrecked my 95 gs-r what do i need to put it in a 92-95?
- gsr harness question.need help
- Anybody want a HONDA emblem?
- 1994 Acura Integra LS - New Paint, Painted Sides, Painted Lip, Painted Mouldings ( PICS ) REQUESTED
- would a 2000 GSR Comptech Catback fit a 94 LS??
- Greddy Exaust Fit.
- "Must Do's" at 60,000 mile service (GS-R)
- Apexi N1 Vs Apexi N1?
- WHAT DIS CAP TO USE WITH EXTERNAL COIL ???
- Hesitating Start
- Need your opinions
- rear hatch window plug for the Dc2
- Shops in Miami, Florida
- saying good my to the gsr and getting a taco
- NSX power in a Teg!
- GodSpeed testpipe
- ive got a 94 gs
- what seats are compatible?
- Maxspeed Coilovers
- opinion on how much to sell my gsr
- DENSO IK16 and NGK ZFR5FIX-11, which is better for my GS non VTEC 1997?
- window problem..
- k20 in a 90 ls DA
- 93 Accord Harness with B16a???
- JDM 4-1 header on an LS? pointless or not?
- Skunk 2 IM, crap inside?
- Integra Trouble StartIng
- Overheat at idle, goes back to normal when engine reved..
- turbo high mileage GSR?
- new brakes
- problem with new tires on 97 gs-r mesh wheels
- Do I need a clutch kit when......
- o2 sensor removal from stock 99 ls cat?
- OT: Gatta love the UPS man.
- Signs of bad rotor?
- Not getting as many miles on a full tank
- header and cat choices
- '92 teg GS-R stalling @ 1/2 tank
- Vtec Silinoid!!!
- TPS problem with swap
- Turbo...do you need VTEC???
- Bushings question
- AC guru's : 90 teg ac suction line in a 94 teg ? POSSILBLE ??
- itr lip install
- Valve Cover Question
- Acura Ignition goes Down Hill
- Skunk2 or thermal exhaust?
- headers== 4 - 2 - 1 vs 4 - 1
- Ebay products
- Synchros TOAST, just need to vent....Teg Finally took a S*it on me.
- changing to synthetic causes clicking noise from head?
- CARBON FIBER TRUNK..... FOR DC
- help wiring my amp
- Antenna motor
- Can't Drive until........
- Advice on where to get timing belt changed in Atlanta?
- exhaust for gsr
- newbie...questions about GSR's
- aerospeed header?
- ignitor question
- buzzing sound when AC is turned on
- need answer quick
- see if you can fix this problem???
- Will a b16a1 drop into a second gen DB as easily as it will a DA?
- squeeking clutch slave cylinder
- AEM Short RAM Intake
- Going to look at a 96 teg, I HAVE A FEW QUESTIONS!!! help me please....
- jdm integra cluster question
- need help finding header for my gsr
- Needed: Instruction for 94-97 oem fog lights installation
- oil pressure, oil temp sender
- which exhaust is good for my 4 dr.
- JIC coilover install: Can stock collar for brake lines fit into fork? G3 DC2
- header difference
- Broken into. . . 94Integ
- About to WED a 4dr 1993 1.8 Import, HELP needed
- just bought Skunk 2 intake manifold....
- HONDA MTF
- Type R brake discs
- 94 teg w/ 96 jdm teg R. cluster?
- eBay SS header testimonials?
- Type R cams
- what is the diference between of skunk2 stage 1 cams and skunk2 stage 2 ??
- best struts?
- Catalyst System Efficiency Below Threshold
- How to remove slight bumps and scratches from plastic bumper?
- anyone have some hard proof of a flywheel upgrade?
- What is the difference in the different levels of Integras?
- 99 INTEGRA LS
- Some f***ed up stuff
- i bought an aftermarket crack pulley looks the same as the aem is silver aluminum with belt goes on
- Difference between Auto or manual ECU
- B16 WIRING HELP! people who know obd0>obd1 by heart
- Price of a GS-R motor? Only head, block and tranny.
- HELP: Overheating problem... what do you think it is...
- Clutch problem or ... what?
- Help in changing out clutch
- OBD1 or 2
- To complete my Tan to Black conversion i need some help
- clanking noise in rear after lowering
- How thick is a GSR DC2 front sway bar?
- battery keeps in dieing out
- new to the forum
- Help - Exhaust header fit for ITR motor swap into GSR with stock gsr cat and exhaust
- GSR's on liability or full?
- gsr rod bearing
- H&R Race Springs for my DA?
- ticking noise.......
- Cluth or Tranny or BOTH????
- Nosiy Heat Shield on 96 gsr
- My first buy for the TEG. Yeah.
- Fuel Pump
- Injen or AEM?
- SI shifter in LS integra...
- What rim sizes are good and too big for the teg?? 94+
- Water leaking out of Air vents...
