Battery: Honda OEM or Die Hard?
Old Oct 23, 2002 | 09:20 AM
RedGSR's Avatar
Default Battery: Honda OEM or Die Hard?
I'm leaning toward Die Hard, since the battery from factory only lasted 3 1/2 years.
Old Oct 23, 2002 | 09:27 AM
p nut's Avatar
Default Re: Battery: Honda OEM or Die Hard? (RedGSR)
OEM
Old Oct 23, 2002 | 09:28 AM
b18bvtec4drteg's Avatar
I have duralast gold. No pobblems for 5 years. Some OEM batteries are made by GM so
Old Oct 23, 2002 | 09:29 AM
RedGSR's Avatar
Default Re: Battery: Honda OEM or Die Hard? (con)
Do you know if Civic and Integra use the same battery? Honda dealer sells for cheaper.
Old Oct 23, 2002 | 09:30 AM
RedGSR's Avatar
Default Re: Battery: Honda OEM or Die Hard? (b18bvtec4drteg)
who makes Duralast Gold? where can I get them?
Old Oct 23, 2002 | 09:44 AM
96IntegraLS4DR's Avatar
I don't think Die Hard makes that small of a battery for our cars (G3).
At least not for 96 LS.
[Modified by 96IntegraLS4DR, 10:45 AM 10/23/2002]
Old Oct 23, 2002 | 09:46 AM
allmotorls95's Avatar
Default Re: Battery: Honda OEM or Die Hard? (96IntegraLS4DR)
lol..just go to kragen..a battery is a freakin battery..
Old Oct 23, 2002 | 09:53 AM
RedGSR's Avatar
Default Re: Battery: Honda OEM or Die Hard? (allmotorls95)
You can say that in CA.. In cold climate, a battery isn't just a freakin battery.
Old Oct 23, 2002 | 10:28 AM
justagsr's Avatar
optima - red or yellow top...well worth the money.
Old Oct 23, 2002 | 11:24 AM
obd2gsr's Avatar
Default Re: Battery: Honda OEM or Die Hard? (justagsr)
what part # optima fits in an g3 integra? i couldn't find one that fit properly. my friend had one, but he had to put the battery in the rear...
Old Oct 23, 2002 | 11:38 AM
PnX-R's Avatar
Hmm.. Your Teg seems to be a 98 and up model. I don't know about your car but my car needs at least a 410 Cold Cranking Amp battery. And if you go to the dealer, you'll probably get 410 CCA battery.
My advice to you would be to go and get yourself a Die Hard battery. You can get a 490 CCA battery. It's the 52 model/series battery I believe.
But this really depends on what kind of climate you your car in. If it's a 4 season climate like Minnesota, you'll want the 490 CCA battery. Because the starter draw on a Teg, I believe is 120amps. Well at least mine was. So that means at 0 degrees farenheit, the starter will draw about 200%.. That means it'll draw about 240amps just to start it. And if you've got a sulfating battery and it can only put out 220 amps.. At 0 degrees farenheit, you're screwed.. Unless you can warm the starter up and make it easier for it to turn..
Anyways, have fun finding the RIGHT battery..
Old Oct 23, 2002 | 12:02 PM
GSRaCeRbOI's Avatar
Default Re: Battery: Honda OEM or Die Hard? (obd2gsr)
yeah I don't think theres an optima that fits in the regular engine bay position .. at least not the last time i checked..
Old Oct 23, 2002 | 02:24 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Battery: Honda OEM or Die Hard? (GSRaCeRbOI)
Honda's been known for bad batteries...
Old Oct 23, 2002 | 02:36 PM
RedGSR's Avatar
well... I don't have time to research for a better battery, so I just went to Acura and get a OEM one. I have no idea what spec it is, but the part guy told me the newer Honda OEM battery are made by Interstate. I don't see anything on the battery saying interstate, just 2 big Acura sticker.
As for the old battery out of my 99 GSR, it is made by Panasonic. I'm suprised that the Panasonic battery last only 3 1/2 years.
[Modified by RedGSR, 11:37 PM 10/23/2002]
Old Oct 23, 2002 | 02:39 PM
Web_Head's Avatar
New User
WALMART has batteries.
Old Oct 23, 2002 | 02:42 PM
Web_Head's Avatar
New User
Default Re: Battery: Honda OEM or Die Hard? (95VTECGSR)
95VTECGSR - Man you are mean. Your poor nephew.
Old Oct 23, 2002 | 05:36 PM
Autozone has them. Not sure if you have autozonr in ur area tho.
Old Oct 23, 2002 | 05:57 PM
95 Gizzer
Guest
Posts: n/a
Default Re: Battery: Honda OEM or Die Hard? (Trench)
oh i get it now
[Modified by 95VTECGSR, 6:57 PM 10/23/2002]
Accord1234
Feb 20, 2015 07:09 AM
machgo5go
Dec 11, 2006 01:37 AM
acchaser
Sep 21, 2006 11:59 PM
tonystarks
Jul 9, 2004 10:45 PM
EminemGSR
Nov 21, 2001 02:48 PM
