View Full Version : Acura Integra
- I did a Compression test...
- comp cams in 98 gsr
- radiator leeking
- Wiring a type-r OBD2 into a 90 teg OBDO
- 1989 Integra - bolt to tighten motor
- b18c5 ENGINE SWAP.
- Vison X HID's
- What kind of cams do I have? B18B1
- HELP!!!!!!!
- WHAT DOES GSR MEAN? thanks alot
- exhaust question (knocking)/(rattling)
- DC collector?
- Comptech tie/sway vrs. ITR Sway
- Anyone have MERCURY INSURANCE??
- question about launching and shifting
- Pic Request: JDM ITR Clock Blocker
- valve springs in b18b
- 2001 gsr w/ Skunk 2 mani, Has a whistle???
- Si parts on B18B?
- HELP, EXPERTS!! Transmission bellhouse open, can't get it closed!!
- How do you setup winamp to continuing playing mp3s?
- need some GSR tranny ID help
- 4x114 bolt pattern question?
- nos refill in maryland
- What kind of lubrication...
- JDM HID conversion question (about the lights) what wires are what ?
- 215 40 17 good size or no ?
- Where Can I Purchase a Fake J's Racing Intake For B Series???
- Oem lip kit?
- 9005 question
- 95 rs auto running poorly
- Temperature Gauge on my cluster is acting funny...
- b16 pistons with nitrous in LS
- Which car is a better deal??
- vtec on rs?
- Fuse keep blowing!!!!!
- hey i'm looking for new brakes
- timing belt question?
- Auto Seatbelt problem on my DA
- changing tranny fluid, how to level car?
- gsr turbo?!
- Will a G3 DC 4-2-1 header fit on a G2???
- Need some info on my teg...
- Gas Question
- mugen mr5 silver los angeles
- ecu chip question?
- what swaps into a first gen easily?
- help ! AEM brake rotor kit
- car wont start
- Antenna noise (but its not there)
- are ls parts interchangeable from 90-03 integra to an obd2 ls?
- jdm armrest help *searched*
- need a motor
- Finally, Pictures of my GSR
- Help me fellow hondians
- Where is the PCV valve?
- part number?
- Grill Insert
- cam plug (aka cam seal)
- Cover over spark plugs?
- need a year on an integra
- problem with using claybar
- Changing Thermostat....hard or easy?
- integra stuttering in 1st & 2nd gear?
- GSR cat back on LS
- want to do junkyard turbo on my LS!! need advice
- REPOST: Need help rebuilding tranny (jDM) Can Anyone help me out!
- crank shaft right or left?
- LS cam gear, fpr tuning
- "H" embelms on my 3rd gen teg
- flywheel info needed !!!
- antenna problems.
- GS-R Tranny
- 2ND GEN integra: rear wiper delete? where do i get the plug?? help~!
- O2 sensor location
- tunning and dyno
- Cam gears not in the exact same position on b18a
- loose front end, even after poly bushing install...see pics
- interior differecnes between 94-97 teg and 98+ teg ?
- Vehicle Speed Sensor
- engine stutters and stalls after driving for a while
- CODE 43...A little blunt
- Looking for a 90-93 Integra 4dr full catback.
- tires on 16's what are you running?
- Personal steering- please help
- 98 ITR Lip on 97 GSR
- Integra idle
- Radiator leaking coolant - Please help
- can i/should i bolt on ITR sway bar on 95 integ without other kit?
- can cluster bulbs be painted to match amber ITR cluster?
- Problems with gs-r.. help!
- apex rsm intallation on an ls?
- help with fog lights
- pr3 Slugs!
- 1g Love in new Honda Tuning.
- pirching shocks
- Slid into a curb going 95 in my GSR, need help
- weird sound... ABS
- how to adjust shocks?
- ls/vtec or Gsr build
- clutch help
- odd gearbox issue
- question about my HID bulbs and my high beam bulbs
- favor requested (temp sensor)
- Finally took some pictures of the drop... (56k warning)
- VTEC Oil Leak = Headache
- JDM Distributors...
- Help My damn Engine Mounts are Screwed!
- Clutch Cable Bracket!!
- VTEC CONTROLLER FOR 97 GSR
- Need help! Which setup should I do?
- how smooth are omnipowers?
- what belt for aem ps pully
- hit a curb bad
- d16a1 Piston end gaps?
- is this normal for a ITR rear sway bar??
- e iYs1 tranny question
- ITR LCA and ITR Sway Bar - HELP!
- 15's 16's or 17's
- carbon fiber hood question
- anyone pass smog with NTK o2 sensor?
- 98 gsr motor into 93 integra
- DC Sports exhaust question... 2.25 and 2.5?
- Integra Starts but dies in about 20 seconds
- how do you get this off...
- Good garages for work in SoCal
- Radiator leak
- Does anyone know if our brakes are sequencial?
- CURIOUS?????
- Skunk2 IM: stick with GSR TB or upgrade to ITR TB
- CAR IS SLUGGISH ON HIGH END.
- what to do with my block
- auto ls
- Have a Problem need some advice PLEASE!!!!!
- car starting problem
- Had A Problem With Davis Acura!
- Quality in gauges
- safe boost on gsr??
- race harnesses
- Turbo help
- Anyone running this setup?
- wtf!! ACG-IG fuse keeps blowin out!!
- O2 Sensor Wiring Help!!!!
- my car wont start... fuse keeps blowing out!!
- Ignition Switch
- LS SHIFT LINKAGE w/ b16 tranny?
- Lowering ?'s
- DIY intake question...
- Bad luck for my car.
- rear bumper same on 2/4dr??
- can two shortram intakes be made into a cold air intake?
- OOOPS!!
- can integra RS with GSR pass smog?
- 95 Integra
- Best tranny swap
- B20/VTEC 92 DA WHICH HEADER TO USE?
- High Milage Teg?
- DIY Trunk Brace 98% Completed!!
- Mushy Brakes 91 integra
- 90-93 projection headlight question *website included*
- Front lip question: What's the different between the US / JDM front lip?
- This might sound dumb but where the f**k is the ecu @?
- So, I take it OBD1 is my ECu type. Now, should I get this?
- which throttle body to buy
- Screw my integra gsr idle prob
- tranny rebuild
- which act clutch? gsr/typer or other bseries
- Changing Intake, suggestions?
- Which car does the b22 come from
- engine bogging...help! ecu code 16?
- smoke under the battery???
- idle problems
- Mileage Maintnece/ Check ups?
- CARBON FIBER PLEASE!!!!!!!!!!!!!!
- need help: swapping 2000 LS motor to to 1992 integra - intake manifold and injectors
- changing transmission
- Gsr Header On LS
- makign a 13mm es bushing into a 14mm
- good place to buy rota
- help integra please??
- Factory fog lights
- 92 Integra Header question
- Valve adjustment on a b18a
- rough transition from idle
- ls/vtec
- Headlight bulbs (size or number)
- My 91 integra 1/4 Mile Time
- stock quarter mile time gsr
- GSR(B18C1) stock intake fit on GS (B18B1)?
- ls/vtec obd
- ls\vtec water pump? (yes i searched)
- your car
- Engine making a wierd noise
- Lug nuts help
- Left headlight went out?
- Newbie here.... My car (56k???)
- Crazy Sh*t Happened
- Neuspeed??
- noob tranny question
- 00 Si DC 4-1 Headers on 00 Integra LS?
- Help picking shocks for my Pro Kit
- oil cooler set up - quick question
- header and cat Gaskets
- N/A 2.1 L Stroker makes 280 LBS at 9500 RPM?
- Spring Compatibility
- Just put my engine back together, I look at the timing belt and its loose in between the cam gears??
- Replacing my stock shocks, anything else....
- Rear ABS plug fell out?
- Rear rotors, what to get?
- installing a front bumper
- Metal type of RH wheels?
- Switching Auto tranny with Manual.
- Anyone weigh a gsr tranny?
- my 2nd car (better then 1st)
- question about when to get wheel alignment
- JDM tranny
- can i put different cam in same engine?
- header exhaust question
- ahhh %&$^ ... grinding sound ..help !!!
- Will 24's fit on my integra?
- Car Trouble , Need Help
- Tranny Time: What setup is best?
- WHat is V tec
- 2nd gen of course
- its a clutch question?
- ABS light stays on as i drive... is that normal?
- Short SHifters
- has anyone actually ran faster times with a lightweight flywheel???????
- speedometer
- NEED ADVISE PLEASE!!!!!!!!!!!!!!!!!!!!!!!
- GSR drivers with ITR/CTR cams, which header is a good match? HELP!
- Replaceing 1992 integra LS motor 220k miles w/2000 integra motor 50k
- axleback exhaust
- hid question
- LS-vtec b18 vs CVR-vtec b20
- 92 Integra CV Boot
- Selling a car with mods scare people away?
- What are some basic bolt ons to increase power
- Would a Stock 95 muffler fit onto a 95 Ls?
- 97 Civic EK exhaust Mid-pipe on a 92 Gsr Will it fit?
- Speedo/Tach/Temp/Dash Clock Not Working
- clutch problems...PLEASE HELP!!!
- How many had their teg stolen?
- Will a Honda EG Steering Wheel Non-SRS fit on a DA?
- Would the S2000 antenna fit on a GS-R sedan?
- shifter was stuck in neutral
- SUMMER IN TX IS KICKING MY @SS BOUGHT AFTERMARKET PULLEY NEED THE SIZE FOR THE RIGHT BELT HELP!
- my $1000 GSR
- Fan relay problems
- ITR TB & Intake Manifold
