View Full Version : Acura Integra
- VAFC w/ GSR intake mani
- can I drive without an o2 sensor plugged in? 94 GSR
- GSR stock shifter into an LS ?
- Civic Short Shifters fitting on 94+ gsr's?
- Fields Vtec install on a LS.
- temp gauge ?
- Supercharger question.
- How often to you hit vtec over 6000
- integra water pump
- How to remove a/c compressor on integra?
- AEM Fuel Rail
- Questions about modifications
- What color are H&R sports for integras??
- NEED asap...
- Radiator problem
- TDS Sensor
- OK took me 6.5 hrs to....
- Will this fit?
- How Do I Take Out My Radiator?
- Clutchmaster kit liquidation sale..
- What kind of clutch should I get?
- rpm needle is sticking
- Broken Rear LCA Bolt HELP!!!
- ITR Front Lip Screws
- bypass valve removal
- Need Help with integra cooling problem!!!
- 90 LS rear seats same as 93 GSR seats?
- good cams for NA ls??
- I have a question about different heads?
- Ok... my Motor died on my again today....
- HELP: Hissing sound at low rpm
- Tranny Fluids and Oil
- how bad is it to cut the the stock springs?
- Rev Engine, and then release gas, and loud valve chatter???
- Help with mirrors
- Need help diagnosing my Check Engine light issues...........
- greddy EVO sounding raspy?
- fuel pressure on semi-stock gsr
- what kinda motor is b16a?
- aftermarket integra mirrors
- 16INCH vs. 17INCH
- genuine 4 door jdm type R?!? - !follow link!-
- anybody kno where i can find/buy oem power gsr side mirrors?
- 99 Ls Exhaust on 94 Civic coupe HELP!
- Are the Type R sway bars on backorder?
- Mid-shaft question
- HELP Check Engine Light Is On
- ~~~~~~JDM tailights
- Fender bending
- OT:Auto to Manual Conversion
- Whats the best type of rear lower tie bar (the way it mounts)?
- clutch help quick!!!!
- quick power?
- Proper and >Legal< way to replace WHOLE Gauge Cluster
- AEM Short Ram intake
- Dust boot on Shock
- found this GSR for sale, what do you guys think?
- Brake Help
- Benefits of ITR Rear LCA?
- nice pictures of a JDM 4 Door Type R
- Help, Engine shuts down at ceartan rpms in ceartan gears
- BAAE meet at Dave and Busters on Sept 21st
- vtec controllers good or bad???
- Ingalls 3 deg. Camber Kit install
- Changing the fuel filter
- how to remove shift thing?
- new clutch is grinding in fourth? HELP!
- AC question
- Master Cylinder Question: What the difference btw. these two?
- how do you know when your rotor has gone bad?
- KYB GR2 SHOCKS - how are they?
- What size exhaust Pipe should I use? Is 2 1/4 too big?
- Best shock and spring combo
- OT: nb question regarding avitars
- anyone else get annoyed by the rattles, etc. in their teg?
- fiber images group buy
- jdm itr header for b18b
- anybody using 10w40?
- Are they lying to me???
- Do I need a alignment?
- What else to do?
- Installing ITR springs tomorrow, any tips/hints?
- Hiding Nitrous Tank
- How much HP with Crower Cams
- AC button!!
- Polyurethane bushings installation
- CarFax is a bunch of BS
- anybody know how to to take off the resonator?
- inlinefour/jdmhondaparts.com>>
- extremely ugly 4 door gsr looking for plastic surgery.
- SpeedTrialUSA track day @ GingerMan Raceway
- broken shock?
- What do you look for when buying a modified GSR?
- what should one expect from dropping in ITR cams?
- Help with power steering...
- 2nd gen integra
- o2 sensor wiring diagram
- cams skunk2 or?
- What are my HP and Torque? Gas Mileage Too?
- which header exhaust 01 gsr??
- Just got a new clutch, and have a little problem. Need help....
- allmotor g2 integra 1/4 mile numbers i think a few of you guys will like.....
- Help! High Pitched Whining From Engine
- How to make an Ls Stick with a GSR
- Best Replacement Filter for AEM Cold Air Intake
- can someone tell me a little about obd1 and obd2
- Removing Door Panel??
- Jdm Headlights ????????
- Exhaust and Header Question
- DA jdm Climate Control
- Nos plate system on gs-r
- Apexi Vaf-c
- tightening window track question....
- Manley valve springs and retainers?
- Weight of a 95 4 door gsr.
- For 2nd gen Integra owners, where is the emergency light fuse?
- is anybody running a f-max turbo kit?? please help with mine
- Anyone got a noisy aftermarket clutch??
- How to get rid of yellow headlights???
- Calipers Going Bad???
- wtb: 94+ gsr grey headliner!
- I need help fixing a code 7 and 22....
- my exhaust was stolen! so now should I get the Type One???
- Quick Yae OR Nae -
- how to change spark plugs?
- Line sealant?
- Rallying a GS-R.
- Anyone got the jg/edelbrock intake manifold???
- Wanted: A Good Speed Shop
- I want my 95 to be a 2001, how do I do it?
- Super Sonic Blue Geeser?
- Falken Azenis 205/50/15
- 9005 conversion?????
- What's wrong with this picture
- turbo!
- how much hp diff between 98 vs 00-01 itr cams
- rear strut bar civic/integra same?
- why do i keep on breaking wheel studs?!
- Anyone have pics of a 2000 GSR with powder coated white stock rims?
- Working on a Honda....
- hey guys, i need help installing headers..
- Need Paint Code
- camshaft swap
- turn signals not working URGENT!!!!
- Who has aftermarket seats in there g3 integra?
- itr TB/throttle cable install
- Rear Lower Control Arm Bushings
- hey everyone!
- cams model?
- boost upgrade
- Exhaust Pipe: GSR vs Type R
- Turbo kit info and website...?
- when is it time to change ur timming belt and water pump?
- GSR's anyone port their stock intake manifold?
- DC 4-2-1s worth it?
- Is this a clutch cable problem or something else
- is this price good for a gsr
- WTB: oem integra parts
- wtb skunk2 intake manifold for integra ls
- any suggestions?
- help...fuse keeps blowing
- NEED Answer for autometer A/F gauge
- Pics request>DC Max Air Filter System
- Gunmetal GSR wheels....PICS!!
- what kind of pedals do you guys use?
- no idea what's wrong
- need opinions on a possible purchase
- Going from B18b1 to LS/Vtec or Turbo. Can I keep my mods?
- diff between gsr and itr blocks
- ???'s About GSR Head on An LS
- Someone help me decide....
- Need help QUICK...installing used Gground Control right now! thanks...
- skunk2 intake manifold or a ported intake manifold
- Grounding Wire....
- 1999 gsr b18c1 motor. whats the best tranny fluid to use?
- Idles low after valve adjustment?
- Gauge Warning Lights???
- Thirsty engine?
- v-afc owners >> need your help.
- Short block question...
- When u push brakes in the integra, does all 4 brakes sqeeze or just the front 2?
- What else besides springs and shocks do i need to lower my gsr?
- how in the world can you push the rear brake piston when installing the rear brake pads ?
- Will the 14" snowflake wheels fit on a gsr?
- ITR vs. CTR pistons
- Idle problem with 90 integra
- 2000 SI cylinder head ...
- Sknun 2
- Best on-line prices for shocks
- Removing Brake Dust??????????
- ls/vtec ?'s
- Ticking after valve adjustment...too tight or loose?
- Where do I look to see if i'm OBD1 or OBD2?
- gsr calipers
- Turboing An Integra LS
- MainT ReqD????
- help me with gearbox problem
- Stock Shock Question
- better camber kit?
- New Valve Cover for LS Options?
- LS Turbo or LS Vtec?
- Turbo kit
- Charge for Carsound cat
- Rocket LS cams, who has them?
- just installed skunk manifold and problems
- What is stock fuel pressure for a obd1 b18b?
- Why is my b18b sticking at 1,500 rpm when sitting still?
- Quietest Catback Exhaust?
- FS: Apexi N1 with Custom Pipe
- WTB: i want a gsr shift knob and boot, please sell me one
- JDM dc2 steering wheel??
- "poor mans type r"
- b20/b18b LS vtec
- Clutch Problem
- anyone know where one can find team dynamic rims??
- bored at work = RAM AIR!!!
- ECU Codes?? for Gen2
- Jun head package
- racing on konis..... ?
- what kind of shocks?
- Need help! coolent leaking on my teg......
- Greddy blue box on 2000 Gsr?
- car died while at the light
- Problem! Please read.
- skunk 2 intake manifold troubles
- Turbo Gs-R
- potential of those tegs..
- Bar between CV HalfShaft and transmission box? Name?
- Really weird electrical problem...????
- Can someone enlighten me about why the B18B is so good for turbo?
- GReddy SS 4-2-1 (1 Piece) Header Question.
- Neuspeed Race vs. H&R Race?
- Who has an inline fuel filter? (Setup ?'s)
- Clutch: ITR or ACT?
- Round 2 in the 98 GSR at the track
- Where to buy suspension arms??
- prelude seats for teg
- LS Intake Manifold install
- Type R Spoiler install
- 95 Gsr Bottom end with a 00 Head where does this hook up too??
- Bay Area Dent Removal?
- field sfc wiring
- Urgent Question. VTEC perhaps Broken.. AHHHHHHHH HELP! :(
- 01 LS ecu swap
- My Resanator is rattling......
- retarding timing
- Newb Prepping for Solo2
- question about hondata for b18a
- ~~List Mods regret getting~~or~~sastify mods~~
- 5 lug conversion
