View Full Version : Acura Integra
- head, turbo, and stuff..need some advice
- Just go the APEXi S-AFC, Your thoughts...?
- '98 Integra LS w/ ITR Springs & Shocks?
- Suspension Knocking
- Spoon Sports and Type one ??'s
- PERFORMANCE
- Your thoughts :: Integra
- Diff. betwen LS/GS Y-80 transmission and GSR Y-80?
- Sidewalls/Contact patch on Kumho 712's
- finding a 94 integra at a auction
- Albany area guys going to HT meet in CT april 27
- 95 LS...does it have 124 or 127 ft/lb torque? I know I've read both.
- what should i do with theses wheels
- ICE BOX VS AEM CAI
- ITR front lip...
- One Lap of america - co-driver needed
- Where can I find a block for my GSR to send to Golden Eagle?
- Header Rattle?
- Falken Azenis fitment on STOCK GSR, rubbing?
- Need BIG pictures of Spoon strut tower bars for verification
- Stock Wheel Offset
- Suspension
- Another racing question.
- Any suggestions how to my Type-R sooner?
- My quarter mile times
- East Coast Integra Thefts Which States?!
- quick question about the DC2 chassis
- ebay spoon ecu chips...
- shocks
- Got ITR outer valve springs and retainers, now what for inners?
- sleeper exhaust?
- OBD1 or OBD2
- Looking for tires... but NO ONE MAKES a 17" drag radial less than 245 wide!
- Spoke with AEM regarding 3" CAI for GSR's Need H-T Member help!
- Hella Horn, Double or Triple?
- Spring rate question
- abs help
- Changing tweeters
- Who has an ITR exhaust on a GSR sedan?
- What air pressure do you have in your tires????
- problem with brakes
- Grill/mesh
- direct bolt on cat????????
- GSR Top Speed and 0-60 times?
- Are LS and GSR radiators the same?
- Compression Ratio limits to 92 octain gas?
- Running Rich
- Cold Air Intake Vs Short ram intake
- Nitrous questions...
- Positive Camber
- integra body kits
- how to tell if shocks are good.
- how much does the Pressure plate weigh?
- window tint removal
- pic of integra needed
- 2?'s low hum/howl and how to clean apple off my hood
- ecu code 6 help
- test pipe
- What kind of refrigerant do we have?
- momo steering wheel
- Will A 2000 GSR Header Fit On A 95 GSR?
- Questions about Ground Control Coilover Installation
- should I keep my exoust cover on or take it off
- what are the best weather conditions to run your car?
- Tubular LCA's?
- Quick Question: Is there a difference between GS-R stock struts and Type R struts?
- where would i be able to buy model's master's enamel black window tint?
- IDRC team drag racing
- Plugs and wires
- Honest opinion needed : RS or 200sx SE-R
- battery problems? possibly the alternator? help please
- cant find my engine number
- AEM CIA
- How to check gsr ecu?
- Just finished JDM header install
- what should i do?????
- What suspension setup to make a stock 94 GSR a good autoXer?
- Engine Rebuild.....good as new???
- Knock Sensor Question....
- axle back exhaust
- B20 alternator vs B18B alternator
- Subframe Tear-Out - Now What?!?!
- What chips are available and prices
- Will 00' ITR shocks and springs fit on a 94 GSR?
- Reasonable price for calipers?
- just got a California Water Blade
- Question about N/A gen2
- integra door panels
- Oil on my spark plug threads
- Yea I Have question to all the Mechanic's out there!??!?
- NEED HELP ASAP!!! Look!!
- Where is this thing??
- AEROSPEED INtake question...
- Anyone Vouch "TurboInteg95"??
- 225/50/15's fit on 96 GS-R?
- Long block vs short block
- any integra owners in CT want to get together and have a BBQ or something?
- How do I check my comression?
- REV LIMITER???
- Any one make 3" cold air intake for 94-97 GSR?
- Anyone know who's Yellow DC2 this is?
- Racing Hart CP035...who has them in 17"...comments
- Skunk2 Coilovers squeaking in the rear! Help!
- JUN III or SKUNK2 stage II?
- Squeaking at idle? Belts?
- 98+ Front end conversion? Whats needed?
- Synthetic oil and seals?
- Anyone with over 100k miles on their Teg running Synthetic oil?
- LS/VTEC vs Turbo
- final drive
- any one know anything about the edelbrock header?
- New pics of the car :D
- Hypertech Shogun A/F
- Will 17's rub with my Neuspeed Race springs??
- OT: my revell model
- NOS plate system
- Cams!
- HELP! my integ shaking/vibrating
- Koni Yellows Damping Adjustability?
- Anybody in New England area
- should i sell my tranny for a R tranny
- Integra Front Bumper
- how much whp?
- How much is a Type R Tranny worth??
- are the bushings driving me crazy?
- whats the life of an aftermarket flywheel?
- Hot Import Nights Seattle **Pics**
- Question on Tail lights for Integra
- itr muffler
- Boost a 92 ls...
- fields sfc or the apex vafc. need help
- OUCH! Got a damn "yielding" at a stop sign ticket......while on probation
- Cam Timing
- steering problems
- control arm?????
- Looking for front-end for 92 teg LS. Anyone?
- Need Help From a GSR Owner w/ Hemls Manual
- ive got cash what should i buy
- *Updated pics of my ride.........finally did some work over the weekend!*
- ctr tranny bolt on to gsr?
- Thinking of installing Springs without shocks...advice!
- Anyone here have any of the fastbrakes.com brake kits?
- Kumho Ecsta, worth the price (seach is haywire)
- helP!! which hood pins aren't rice?
- 55 shot on stock internals?
- distributor problems. anyone selling a dist?? Or know if this will work?
- Almost got my GSR wheels stolen last night :(
- 96 Acura Integra
- where do i find these wires?
- Need 94 and up Type-r or GSR tranny
- how to tell apart jun stage 3 cams???
- JDM DC Headlites HELP!!!
- JDM ITR header and catalytic convertor
- Does anyone know any tricks for this.....?
- APEXi S-AFC tuning
- New shocks vs new tires?
- **16in ROTA C8s? or LS MESH?**
- Writing an essay for class...Give me some info on JDM, etc...
- Does it really help?!!
- Hey ppl with GSRs what rpm are doing at 60 and 80 mph?
- Oem Body Kit, did a search already.
- Suspension Upgrade Help -- ITR or H&R OE Sports
- KYB AGX installed
- jdm ITR 4-1 header impressions
- Best Spark Plugs
- anyone use a cable tranny on hydro car
- Is OBD1 GSR faster than a OBD2 GSR if it is why is it?
- Pulled too much on inboard CV joint.. how can I repair it?
- Where can i get a HARNESS and buttons for vtec controller
- Question about 3rd Gen Integra LS
- C-speed gets published (caution bandwidth intensive)
- Knock Sensor Help
- FALKEN AZENIS GROUP BUY
- Exhaust for 4-door?
- Any GSR out there with ZEX Kit...I have a couple of questions?
- 90-93yr which is best to buy and what model
- 95 G3 projector lamp replacement
- Dask Kits
- Insurance for GSR
- Anybodys Green GSR Stolen in Phoenix???
- My New GSR - Need Opinions Please?
- How much should it cost me?
- TEIN S-Tech Medium springs
- Are ITR shocks and springs w/ 20,000 miles still good?
- 16" Gunmetal K-1's on a Milano Red Integra.
- Where is the oil pump in a b18a?
- Are kaaz lsd's any good?
- tanabe exhuast
- Will a gs-r ac compressor work on a b18a block???
- JG vtec cams -- quality?
- VTEC didnt engage?????wtf
- bad idle when engine hot. ok when cold
- Greddy FMU Flashing QUESTION
- car shakes like crazy when goiong 70 mph
- debate on my timing.
- This looks like the right place,,,,,,,,,,,,,,
- LS/vtec
- Removing back seats
- San Diego Euginuity Dyno is it mess up??
- need springs what kind?
- Engine Mis-fireing Check engine light codes (71-74)
- what is the sensor on the back of the ls block....
- How to get this sand out? (pic)
- Is my timing retarded? (pic)
- Weight differences between Honda/Acura shells in stripped form; And what causes these differences?
- How many times have you mis-shifted?
- Where can I find a good aftermarket head gasket for LS/vtec
- Post pics Teg with SSR Competition
- are progressive rate rear springs bad for autocross?
- Anyone willing to trade For 84 Buick GN?
- Post pics of volks gram lights wheels on a teg
- Free H&R springs
- 93 ls racing chip?
- Fuel/Detonation question
- Roaring VTEC
- Mass Air Flow Sensor
- fuel pressure regulators
- whistler radar/laser detector
- turned rotors=new pads????
- NJ/NYC peeps-- Where to do a clutch install?
- Will b18b head fit on b18a block?
- 91 teg motor swap
- Spark Plugs
- Brake warping...
- GSR tranny for SI tranny
- Stock 94 GSR rims...
- Looking for advice
- Need info/help on installing Koni yellows & Pro-kit myself......
- Need some numbers from gsr owners
- Problem with Skunk2 Stage2 cams. Anyone else????
- Drivers side window switch?
- damage from towing?
- Acura Steering wheel interchangeable?
- Question for people who removed/replaced the Rear bumper in a 2 door coupe!
- alright how much for auto to manual swap?
- question about timing???
- 9005 conversion quesiton
- help me decide what clutch is best for me.
- See what i traded to get some volk te37!
- hoses question.
- how do u tighten the tensioner on timing belt? help help
- What cams is everybody using?w/turbo?
- Goina race my teg... Gotta question!
- looking for a integra with these kinda rims
- Compression Restorer....anyone try these?
- RAZO Shift lite installed on my 95 GSR...How do I tune it?
- identity crisis
- Difference between GS and LS
- Philips 4300k pics
- Ack! Another brake question..
