View Full Version : Acura Integra
- cant decide!!!!!
- My Tranny took a shit !
- clutch?
- headlights
- need help with my acura integra ls its an 89 model with a b16
- FUEL PUMP PROBLEM???
- need pics of your stock 94-01 gsr purge evap system please
- External Coil on a LS
- I need some interior parts for a 95 LS
- dash fuse index/diagram
- Smoke comming out of the exhaust every now and again.
- PS assembly
- Headlights... not HIDS
- 92 integra vss
- gsr obd1 or obd2?
- Cam Seals (leaking)
- Rims and Tires
- help with holes in trunk lid
- My 94 rs will crank but will not start...
- NEW INTEGRA!
- NEED SOME HELP
- Wiring help - gen 2 integra gauge dimmer
- FRONT HEADLIGHTS?? IM NEW CAN N E ONE HELP
- Vtec
- taking off inside panel
- short shifter install issue
- CEL Problem ... o2 sensor?
- car in limp mode/.... o2 sensor maybe??????
- LS/VTEC problems HELP
- KYB GR-2 for my DA
- Oil Question
- searched and can't find
- MY LS/VTEC BUILD! (56k please beware)
- timing belt and water pump
- electrical any one know how
- Pics, difference between ITR LCA's and GSR - HELP!
- carfax
- My Integra (Insanity)
- @@@1998 Acura Integra LS Sedan - White - Price Check @@@
- B18C Breather location
- Motormount ?
- need help putting a msd 6a box on my jdm b16a obd0
- head swap on 90 ls integra
- Need Radio Code.
- anyone knows? please help!
- on my B17
- Valve cover swap. Will the newer cleaner looking cover fit an OBD 1 head?
- question about .......
- exhaust manifold question
- black or red rota gt3 drag on a dc2 BLACK TEG
- I just bought a B16A3 to put in a DB1, need some advice.
- ITR Catback exhaust, yay/nay?
- Parking Brake Cable or Adjuster?
- WHAT IS THE DEALERSHIPS ANTENNA PLUGS PART NUMBER????????????????????????
- Integra cranks but won't start
- Need help wit da B18
- ball joint problem......
- Engine noise upon start up?
- HID'S???
- Correct ECU for a B16
- Problem with door pin switch
- Best Exhaust System
- valve adjustment
- what do u guys do?
- what 93 teg parts fit 95 ls
- jdm da headlights/foglight ?
- Rims size
- 93 teg parts swap
- what kind of ecu for a 92 civic ex
- alarm for my car
- Fuel filter nut from firewall...Clockwise, counter clockwise, wtf?
- DeckLid Spoiler?
- LS/Vtec milage?
- spring question
- FAILED REF...HELP!!!!
- help plz i need to know if this tb will work for my car
- h4 bulbs?
- Need Radio Code
- cheap integras
- in need of gsr tranny
- DA passenger side molding?..
- normal life of and integra
- help, tranny issue?
- intake air temp sensor
- gsr wire jumble
- need po5 or p06 chipped to run my b16 who can do it
- HELP:NEED MY WAR WET SANDED....
- clicking sound when depressing clutch pedal..
- WHERE TO BUY INTEGRA REPLACEMENT BUMPER BESIDES DEALER....
- 92 TEG WITH B16 HELP need to have computer question answered
- p75 in ls vtec??
- Smoke screen at higher RPM
- Engine shutoff while driving
- calling all DA guys
- aem dry flow or K&N?
- What is this this screw for??? OEM optional rear valences...
- ECU
- Replacing Rear Quarter Panel on G3 Integra
- Is 95 GS-R rad. fan motor same as Civic
- 94-01 Integra Steering Columns: Any difference between automatics and manuals?
- injector resistor box
- power folding mirror?
- Oil gushing out from somewhere near the head?
- type r spoiler?
- D16A1 stock head gasket thickness?
- tons of questions regarding my 94 ls engine. and ls/vtec conv. in WASHINGTON STATE
- coil sleeves/shock or springs/shock combo
- titanium valvesping retainers
- type R motor
- need help my tranny is actin weird can u help
- paint quality
- Mudgaurds.
- Exhaust question
- H22 Swap?
- WHERE CAN I BUY NEW NOKYA HEADLIGHTS AND HARNESS FOR CHEAP????????????
- WHAT CAMBER KIT IS GOOD? 93 INTEGRA....
- What shocks for a DA?
- WTB RSX-Type S muffler...
- need to find a good head shop in socal
- engine build, from exospeed ??
- GSR HEADER what Cat should I get
- RHD Conversion
- ABS Wiring removal...anyone?
- whats the difference?
- Main relay replaced car still not starting?
- cam timing for ls vtec
- INTEGRA OR CIVIC?!
- What do I need to rebuild my gsr block? HELP
- wtt: hydro b16 for hydro ls plus some cash
- Need some help blue smoke =O
- tire question
- TOKICO SHOCKS
- Kamekazi Header DA?
- gsr skunk2 intake manifold
- Vtec not engaging
- Timing for ls vtec help
- how to read obd1 trouble codes?
- side moldings
- NEED ASAP---98-01 Integra front bumper!!!
- 93 inetgra radiator
- who does good head work in the socal
- Good shops in San Diego to have motor swaps performed...
- 1990-1993 Integra Seat Rails...
- ???? ls-vtec obd2 setup with ls crank, rods, pistons....Next??????
- compatible cable trannies for b20b
- >>> What do I do to get my car running... Please HELP??? <<<
- all b18b's OBDII?
- B20 Swap Complete......now what?
- DA powerband
- DA owners please help!
- Rebuild Engine?
- Washing the engine bay
- what is this piece????
- Type R muffler
- 92-95 Civic AC fit in a 2000 LS?
- 1990 DA caliper is beginning to become stuck in rear.... any remedies?
- CAr REF????
- motor mount ?
- GSR compression
- cat back exsaust
- Starting Problem
- Slim Fan fitments and size?
- Can i use a 5lug prelude,accord, rsx, on my 2000 dc2
- How do you remove an altenator without removing the half shaft?
- Think ill pass ref??
- Integra Paint Color Questions: Pearl vs. Metallic
- Ek coupe axleback
- MAP sensor issue
- car has slight rough idle
- 5 lug install?? ABS?
- clutch
- td68u
- twisted steering colum...
- how can i fix this dent
- Stuck axle. NEED HELP!
- manual swap at a shop?
- HT i rele need ur help!
- difference in installing 205/50/15 on 15x6 vs 15x6.5 or 15x7 rims
- obd2 dizzy
- a/c recharge
- a/c question......
- Leather interior
- GS/RS/LS differences from other trims
- My finished dc2 was just wrecked!! Pics coming and partout coming
- GSR Dyno sheets N/A ONLY
- k20 inetgra
- Problem with my GSR
- question about 98 gsr interior swap into a 95 ls?
- cam cap edge
- Motor question
- help with gsr swap into 00 teg
- LSD..LS tranny
- Integra RHD conversion brake ***PROBLEM***
- How many dowel pins?
- do i have a bad master cylinder?
- obd2 gsr distributor plug pinout
- Crimestopper CS-2900 DP alarm!?
- a/c belt and alternator belt tension
- Good or Bad
- driver window not working
- transmission problems
- air intakes
- can a install a b20z head on my b18a1 block
- 94 integra rs help!
- how do i tighten my alternator belt
- Anyone running a turbo jdm B18c1?
- What is this? v. Coolant cap
- ??????help???????
- what part number for civic radiator for integra?
- 2000 front bumper and headlights on a 95 integra how too!
- HAS ANYONE TRIED TO USE THIS KIND OF ANTENNA FOR THEIR INTEGRA?????????????????????
- iac / fit ?
- anybody know where I can find oem style side skirt and rear, also need help on wiring jdm headlights
- DC2 foglights?
- sir-g fog lights
- Skunk 2 Intake Manifold, or Edlebrock?
- Tokico Shocks
- burning oil and its not the rings need some help
- DC2 Suspension revamp.
- struts
- Noob here with some basic questions related to tires
- Should i buy it?
- integra suspension
- need help...buying a tranny w/ vin
- changing jdm front fog lights
- adjusting valves?
- My Integra was stolen, have an insurance question… Plz help if you can...
- Gsr Head w/ B16 Block?
- JG 301 LS
- 94 RS, keeps shutting down.
- leaking oil!! help!!
- 95 LS ?
- factory fog light templates?
- How to find the part # on my Greddy exhaust?
- DA Electrical Issues - Lots of troubleshooting already done.
- Clutch/tranny HELP!
- thing between fender and front bumper on teggy?
- Bogging problem.
- Clutch Slipping possibly?
- Stock GS-R to CRVtec or invest in the engine I have?
- My 93 Integra B16A VTEC issue
- 1990 DA bumper on a 1992?
- pls Help!!!! distributor question need help asap
- cold idle starts
- B-18A1 motor
- 1990 integra only has spark when it feels like it, can someone help me out
- b18a block b18b head
- 96 gsr car wont turn off
- valve adjustment questions
- battery relocate
