View Full Version : Acura Integra
- Am I supposed to have Infinity speakers 94 LS?
- For those who know... is the 98 Integra the same car as the 2000 and 2001 Integra, mechanically?
- need to get rid of her
- H&R Sports + Koni Yellows
- Poly inserts for the lower torque mounts ???
- Skunk2 stge 2 cams on stock compression
- INtegra Ls 1/8 TImes
- Help me distinguish which application this exhaust is for
- 2004 S2000R??
- second try at this muffler..... Should a install or sell?
- ITR expo video...
- Different front ends?
- Whats the odds of this happening...
- Damn horn
- What type of throttle body to get
- Hey
- Possible to use CTR pistons with stock GSR rods?
- headlight/fuse question
- Ride too bouncy? suspension?
- 97 integra Ls turbo
- Tociko Blues/Neuspeed Race
- need help
- Where to get head work done in San Diego area?
- used integra
- How to tell S2 GSR intake manifold bolt pattern from non GSR?
- jrsc ls vs spraying ls
- Relocating the dimmer switch?
- CRV injectors same as Intgera injectors?
- Samco Hoses DC2 (Tried Search)
- Eliminating Sunroof
- aarrgh! window power??
- Making a deal with my local shop....Need help
- 13" hx wheels
- Which SK2 Shifter????
- speed odometer don't work
- Oem Front brake pads for 97 gs
- I NEED A 98+ Integra Front Bumper!
- guys need some help
- big problem, please help!!
- trouble shooting fuel-pump
- type r carbon fiber lip
- Broken axel new transmission
- How much should I sell a 96 gsr for?
- integra ls injector and fuel pump info
- center cap trade
- QUICKIE: H&R sport srpings the same
- Legend/NSX/TypeR/Accord Wagon calipers
- Did I pour in enough tranny fluid?
- HELP Primary o2 Sensor ripped out..
- how can i turn my 92 intgra into ls/vtec?
- dropzone coilover
- Just when you think it's safe...stolen Integra
- 97 Ls vtec ?
- Leaking Clutch Slave Cylinder Replace or Repair?
- Is there something missing here?
- OEM Muffler covered under life time warranty?
- need opinions on carbon hoods
- replacing plastic inner door seals (the moisture barrier sheets).. what adhesive?
- Code 20 - Electronic Load Detector?
- Fuse Panel diagram
- Picture of crack on casing, should I worry? Also pictures of car
- pillow ball mounts or new stock mounts?
- OBD1 conversion question, already searched with no luck
- What Cams to run w/a Supercharger Setup?
- Any body know anything about dunlop tires
- New integra owner, looking for parts.......
- Skunk 2 chip?
- oil relocation kit? any good, how does it work?
- 98+ conversion
- some questions for before the strip...
- another one for my CRAZY ideas...
- BEST place to get a test pipe for integras!
- SRR lca with tein flex possible?
- B series head question
- Looking for connectors!!!!!!!!!
- vtec dowel thing
- DA armrest?
- Part numbers for nose mask fender clips?? Anyone?
- integra ls
- Short shifter Q
- My 4 Door Integra
- 92-95 civics, del sols, 94+ integras front seats fit into 90-93 DAs?
- obd-II motor to non obd in DA
- jdm itr header, 2.5" carsound cat, greddy evo - will these all bolt up?
- Tire Pressure for 195/50/15 Tires
- Caliper slide pin lube?
- spark plug wires
- Buying suspension but need vouching
- Apexi N-1
- 92 gsr question
- Stock Integra Exhaust Piping Size??
- 01 Engine harnes recall?
- New Injectors/ECU Problems?
- I need the part numbers to these tiny tiny light bulbs in the instrument panel
- Sold my GS-R and got me this!!!
- whats the difference between buying a racing cat and clearing my stock cat?
- what size bulb is for the 90-93 jdm one piece headlights?
- Neoprene bushings?
- Where is the OEM Foglight fuse?
- AHHHHHH!!! Another problem with my spring install
- ESPELIR springs!! anyone rolling on this
- high reving ls motor
- Quick Q: Carsound cat owners help
- Greddy SP + no resonator = Happy guy
- how many of u guys are running block guards
- slight rattling noise coming from under my teg???
- Where is a good place to look for an Integra shell?
- Plexi glass
- Some questions :\
- some good swap shops in so cali!
- apexi GT stainless header...comments??
- s2k antenna on a g3
- tranny blew, anyone got an extra?
- camber kits?
- maintnance required light?
- whats the easiest way to trick your ecu into thinking theirs a cat still there??
- LS to Type R wiring harness swap?
- Are all Integra O2 sensors the same?
- ls vtec or b16a1. dont got much cash.
- any risk in using two head gaskets?
- Integra Battery In The Trunk, who has done it?
- Need help, cant put it in first sometimes
- how much can a ls take with nitrous
- what are some good lowering springs?
- Spring install?
- quick response needed!!! LS and knock sensor
- b18b head installation help!! ASAP!
- Where to get traction bars?
- What type of front camber kit?
- RS-R header review
- Just bought a 93 LS with these horrible blue glow gauges
- Seems like my luck just keeps getting worse, CRASHED my GSR, story inside :(
- can you weld an AEM CAI?
- built and JRSC engine on long trips...
- b20/vtec in DA
- possible?
- Moaning or Grinding sound in '94 Integra
- 94-01 instrument cluster pinout
- Would This Motor Setup Be Better
- hoses sizes
- Results of 9005 Conversion
- How do I install my HKS Circle Earth earthing kit on my LHD car?
- TurboProblem/ IHI RHB5
- how do you check engine mounts?
- Fuel line/hose question
- i have not noticed this till today. . but my tail lights are sagging :(
- Running Rich And Studdering
- how can i convert my 92ls to vtec?
- Short Shifter Questions
- any links or articles and how-to do drop in an engine???
- Serious ABT This..
- Timing belt and Crank bolt
- type r center caps
- suspension setup, please help
- where do these miscl. pieces belong?
- Where to order bsq kit?
- Which drill bit to use on c/f?
- What kind of clutch setup do you guys: want, prefer, like, or use?
- how strong...
- skunk2 short shifter
- 14mm rear shock bolt
- valvoline syntec brake fluid
- HELP: Replacing LCA/shock bushing
- Integra Cluster Question!
- 94-95 gsr injectors..
- Hondata IM gasket intstall , GRRRRRRRRRRRRRRRRRR
- Does a JDM non-ITR steering wheel bolt on to my usdm car
- Quick Q: about valve adjustment
- What should I buy
- picked up cusco complete coilovers.anyone know how it performs?
- QUICK question, best catalytic converter is......???????
- problem during valve adjustment
- headers
- DA STEERING hub adapter fit DC??
- Vtec crossover!
- Fast ITR rear sway bar question. what tie bars will it not fit with
- Shifter feels weird, is this normal?
- trunk trim + rear quarter panel
- Ingalls, Ingalls STYLE, or skunk2 camber kit
- Resetting ECU on GSR
- weight of parts
- Carbon Fiber Hood + or -
- DA integra question...
- Teg meets tree...glad to be here...
- how fast will this be
- 90k maintenance prices?
- Sea Form?
- Airbag light ON???
- Integra Control Arms
- Damages of a blown head gasket
- Engine mount inserts
- Where to buy 5mm wheel spacer? Help me out
- Any of you guys headed to Import Wars next sat?
- What type of oil to put in my 97' GSR?
- greddy evo exhaust rattle - rear hanger rubbing (pics)
- what is the name of our interiour color?
- Timming Belt replacement, a DIY proyect?
- Hondata IM gasket,worth it?
- How Do You people remove this?
- FS: MOMO, JDM, Mugen, APEX, Recaro, 5zigen, Personal STUFFs FOR DC2, DC5, EK, EG
- need help guys
- cusco full damper/coilovers
- Most Integra members here have LS????
- Integra GS-R Owners!! I need help inside!!
- tranny question, third gear gone, rebuild or buy a new one??
- 4DR integra owners... do your windows whistle on the highway?
- apex vtec controller for a mod with $500???
- signs of a bad fuel pump?
- need alittle help on ls vtec conversion?
- DA6 Power
- Squeek in the GSR :(
- Toyo Proxes T1-S
- JDM Honda? On Ebay. Right Hand Drive
- Florida Import Racing Motors Reputable?
- sunroof wont close all the way after i greased it
- helm
- OT: So who's going to LimeRock May 23 - 26 2003?
- CM clutch and flywheel are in!
- Door gap adjustment?
- Ok!
- brake setup
- Open Header at the Track
- how to post pic
- Wings West Side Skirts
- Skunk2 IM ?????
- Type R sway bar question
- Should I get an alignment NOW?
- Interior vent removal???
- I am getting the car dynoed!!
- i have a b16A2, B18 vtec hybrid...and i need a header
- gasket question
- TURN SIGNAL RELAY 40 dollars!!!!!!!!!!!!!! WTF!
- Good Roll Cage Fabricator/Installer in or around Central Valley, CA????????
- crank angle sensor?
- help with removing lower dash
- help with brake lights
- what's a NICE drop for a 4dr teg??
- GSR interior colors
- Does anyone know how or where i can get this done??
- need help on setup please...
- squeeeel ugh! help
- hr race springs
- What's wrong with this picture??
- help me oil on spark plug problem
- b16 swap in teg problems
- aem cai question?
- lord save me ive had the worst night of my life...[tech question]
- My 2001 GS-R Build-up. Questions/Comments/Suggestions?
- b18a runs good idles at 3500 RPM :(
- Should i buy this car??? integra
