View Full Version : Acura Integra
- Viper Alarm Sensitivity
- Clutch won't bleed
- JDM itr headlights?
- NEW ROTORS AND PADS INSTALLED, BUT STILL SQUEEKIN'?
- How do you get your intake manifold gasket off?
- WS 2 exhaust. Real or not?
- quick question??????
- White integra with Rota GT3's
- "honda" emblem on integra ricey?
- ::NEED HELP::WITH ALTERNATOR/BATTERY::ASAP
- Super Yellow light bulbs
- WTB: ONE 16" ROTA Circuit 8 Bronze rim
- Can someone please tell me if this is obd1 or obd2 please? (PICTURE)
- which coil overs offer a "decent" ride?
- whats a good price
- si shocks and springs on 94gsr
- odd wheel stud problem... ideas??? to get it off.
- Dc sports front upper strut bar-bent brackets???
- blox I.M. opening
- Another Stolen DA Watchout pics!!
- "RrRrRr" sound when turning, normal?
- GsR Emblem Need help with exact location
- Please need help ASAP. PLEASE ANYONE
- angle on your Apexi N1
- Mugen Gen 1 Spoiler
- noob question, how to tell what engine type
- Side Marker Install Help. *searched*
- Master cylinder?
- help doing a b18 ls head swap ????
- CEL and bucking while driving
- Another R.I.P Integra
- OEM honda parts websites???...
- e management system
- cain i put a b18b in my 93 teg?
- much diffrence in stage 1 or stage 2 cams
- JDM headlight Signals Help!
- type-r manifold fit b16a head?????
- Post Apexi WS II exhaust on DC2's
- You'll never beleve the week I've had. Lots of questions
- How do I install my LED tail lights correctly?
- jdm b18b swap into 94 ls
- Vaccum Diagram for B18a?
- fit itr intake manny on a gsr?
- OT: ways to battle the summer heat?
- factory radio is loose.
- from obd2 to obd1
- Adjusting the e-brake on a dc2
- CLUTCH PROBLEM
- ls turbo or h22a
- tranny case?!...
- Help me pick an exhaust setup
- DA Cluster swap
- dont know what to do with my ecu....
- Any trouble with leaky exhaust gasket?
- Acura MTF & Honda MTF the same oil?
- vafc 2 sensor number???? help
- LS taillight.
- Brake Line Size and fittings.
- NRG quick release stuck!
- wtb 4dr teg exhaust
- Good Engines To Boost on?
- b18b head
- smog check with an catback exhaust?
- good body shop in the bay area?
- obd2 dizzy with obd0 plugs
- cam gear timing marks
- SCORE momo wheel
- throttle body
- What springs for the lowest drop on a 90-93 integra?
- Jdm front end wiring question LOCAL bodyshop miami FL
- Squeaky Clutch
- looking for a b16
- code #22 >>> vtec system malfunction?
- Is there another dizzy that will work on a 94 gsr?
- 99 GSR --> Compression Test Results
- integra being funny after headgasket job
- to all cali people that live in the valley !!
- clutch woes
- How to check for spark?
- Im in the market for an integra GSR, what do you think of my options
- JDM: weaksos weaksauce?
- charcoal canister for 96+ LS
- pic request DA polished Rota Slipstreams SEARCHED
- What rims for a 90 integra
- Which header is better
- When i turn left my suspension makes a wierd noise?? help please
- water hose replacement
- k20a2 type s swap $2000
- ignition lock help!!
- Porting/Polishing GSR IM
- Jdm front end question...oem jdm radiator support or top/t-bar radiator conversion
- What Motor To Chose?
- 90-91 and 92-93 clutches
- clutch acting very weird
- Review on Kumho ecsta asx's after 3500 miles.
- How do you remove the pinkish part of the tail light off?
- about gsr blade rims
- b16 tranny vs gsr tranny
- Question about 94-01 teg oem spring/shocks
- VSS
- Prim. O2 sensor problem?
- Need info on the metal panel in the glove box door!!!
- car losing traction at 45-50mph turns
- HID bulb question...
- question about a/c lines.
- LS throttle pully
- ALL MOTOR ls project
- New Ls Turbo project
- OEM Foglight lens DIY repair
- KYB AGX's....allow you to adjust ride height like koni yellows?
- Aem fuel rail too big for minor mods??
- how do adjustable shocks work?
- replacing battery terminals?
- whats the little round hole on b18b valve over
- USDM DC '98+ BLACK HEADLIGHTS
- clutch seems stiff compared to other cars
- Need Help on B17a1 =[
- !!!WHO CAN DRIFT????
- How easy to remove quarter panel dent?
- Shakey front end
- Will these work
- oil question
- JDM power folding mirrors, type R wing
- New to Ht
- light weight flywheel
- Defeative clutch?
- will a crx lambo door bolt on kit fit my 90 integra
- weird
- Exhaust Heating Short Shifter
- improving ride sound quality in gutteg teg
- K20 vs Type-R
- Difference in B18a and b maincaps?
- aem short ram vs j's racing cf whale penis
- will a 94-97 front bumper lip fit a 98-01 bumper
- PLEASE HELP ME TRANSFORM MY 94 LS?
- New to ht
- overheat
- pleaseeeee help!!!!!!!
- are these gsr cams
- Crome bin file for a B20B need asap
- SERVICE MANUAL PLEASE??????
- VIPER 791XV TROUBLRSHOOTING HELP
- **Request** All Avalible DC2 Info/Specs!!
- removing back emblems and wing
- accelerator delay
- Chrome .bin file for JRSC GSR application
- Main Dash harness diffrences?
- DC4 & DC2 (GSR) Chassis Differences?
- Just Bought rollydc69's GSR....pics!
- Thieves Found in SanFransisco apparently?
- VTEC HEAD? on LS
- Integra no start
- car start problem
- car wont start - not a newbie Question either
- Post Up Pix of A'PEXi N1 Exhaust
- AHELP!!!!!!!!
- do rsx seats fit integra
- 98-01 foglights
- question on ls or gsr
- check engine light???
- leaky tranny
- Is Anyone running a garrett 60-1 if so what whp are you putting down and setup
- is this ecu manual or auto?
- 95 Teg GS-R w/Toda 4-1 Header Lose Bolt/Nut
- will eg seat brackets comw off and go on sparco seats
- c.e.l.
- rpm problems
- ls tranny b16 gears ls final drive
- p 72 oil pan capacity. i already searched
- can't decide...1990 integra DA coupe-eibach pro-kit/sportlines/H&R OE'S...
- idleing to low
- How to tell difference between ARP and OEM headstuds
- OBD0 TO OBD1 conversion sources
- 98+ conversion
- Clutchmaster clutch w/ alum flywheel. Hear squeaking
- b16/gsr
- DA 2 dr exhaust vs DA 4 dr exhaust, whats the difference if any?
- gsr pistons
- not getting battery voltage for o2 heater at ecu
- Best Non-VTEC b18b cams for low end power?
- DAVIS, CA meet 9.16.06 CALLING OUT ALL INTEGRAS!
- Sunroof
- help on brakes!
- leaky hatch
- heres mine after wash and wax
- sputtering from the front?
- heres my ride.....
- ecu questions ?
- HELP ALL DA OWNERS!!!! Intake Manifold Probs!!!
- Integra Coilover - Swapping spings Question. Need opinions
- need help injector ??????? please help
- Troubles removing tranny
- Hot soak?
- ((((((((((((SAN DIEGO))))))))))))) NEED NEW CLUTCH/TIMINGBELT/WATERPUMP PUT IN
- Driveshaft shop axles Vibration in mid range???
- Car slanted?
- Weight of GSR motor and tranny?
- Dropping Motor..
- Ecu problem...?
- ok just got a 89 integra.......
- cam ?
- Intake Manifold HELP
- Lowered + speed bumps + front sway bar = OUCH
- What are the symptoms of a bad lower ball joint?????
- battery alternator starter,..... wtf?
- Help, starter will not spin
- wires needed
- wiring harness???
- passwordjdm sirg foglights
- fuel pump??
- Which Distributor?!
- need help
- which turbo kit?
- new diagram for DA Integra Ls Intake Manifold
- windshield washer reservoir removal
- WUT DO YOU GUYS THINK SHOULD I, OR NOT???
- Honda injector Questions
- Need some wiring color help
- Distributor Whining... help?
- which side is this axle?
- gsr/dc cluster in das
- shops in southern ontario canada?
- overheating no fans
- 3500rpm resonance
- Right side 2 fingers higher than left?
- Engine hesitation
- Ezclutch on ebay
- Integra trunk door shocks/dampeners
- Changed Axles : car shakes = /
- Anti-freeze leak!!! Help
- Needed: CHICAGO area shop for install
- Bay area shop for waterpump
- P72 ecu obd1 chipped w/ Uberdata ((((acts up in different cars))))
- auto tranny swap
- crower 404 cams
- clutch question
- Jacked up my car....
- gsr vtec wiring diagram...
- what fogs?
- b18b1 To Vtec
- starter question
- Stolen :: Light green 1994 Integra in 619 San Diego
- Fuel System maintenance questions...
- Need help!
- changing rear speakers on a 4 door integra...write up anywhere??
- Has anyone seen this car?
- Stumbling Idle, Running Rich, OH NO
- Need help in determining how many degres of camber i should fix my car to.
- turbo ?'s - ruff idle, fuel pressure
- My integra...pics, mods, dyno
