View Full Version : Acura Integra
- running lean
- Integra Walbro Pump Install
- Need helpt installing optional oem rear valance for 98-00 integra!!!
- LS tranny
- what is the difference between rs and ls??
- My 1994 Integra RS.. slow build *updated* 11/2025
- how to tell from stock ls cams and aftermarket ones
- 82MM bore GsR project*skunk2*supertech*.....
- Axle question
- how to test fuses under the hood
- 1992 integra header questions?
- head gasket leaking pressure into coolant system?
- 96 gsr jpec into 98 gsr usdm-----distributor?
- Troubleshoot a heating issue
- b20. what size exhaust piping???
- Rear Lights dimmed significantly over the years... How to make them bright again
- For 90-93 tegs except RS ABS REMOVAL FULL DETAILS
- need way Brighter tail lights
- ASR subframe brace compatibility with smaller swaybars (or just other manufacturers)
- sensor question
- what code is this
- another clutch issue
- 91 Integra question
- Where should i buy my JDM Conversion?
- jdm itr tranny compatibility
- Will it fit?
- After 250K stock miles...
- Is skunk2 intake manifold legal for CA bar test ?
- gsr front suspension fork
- Need help with car idle problem
- where to fine a b18c5 wire harness
- differences between 94-up integra hatch vs. 4 door muffler
- RED integra type r floor mats???
- itr header
- What are the torque specs for the arp rod bolts and head studs?
- jd integra sir-g fog lights
- Harness Bar
- k20 Block/B16 head????
- Block/Head/Sleeves
- Good place to buy stereo installation kit for 91 Integra GS??
- jrsc in da?
- how to determine wether starter or alternator are bad
- need help on frankenstien build
- Steering problem need help asap
- skunk2 manifold throttle response problem. help please!
- 3in exhaust with ASR sway bar
- Spoiler Options
- searched but did not find anwser
- check engine light??
- +5V Wire?
- B20B non vtec integra issues
- b16 no spark not all!!!
- what BASEPLATE FITS BETTER ON DC'S/ MIRROR QUESTION!
- Suggestions?
- Loose timing belt - what can go wrong ???
- 95 ls bogging and backfiring.... HELP!
- shocks/bushins/lines
- turning signals dont work?
- JDM Steering wheel
- threw on springs, rear much lower then front, blown shock?
- B16 swap into 92 teg
- DA side skirts
- spoon sports lsd ????
- Gates timing belt?
- cams not spinning
- Starting problems - Ignition or Fuel?
- function and form installation?
- Anyone reupholster their door panels to leather?
- code 3, map, and now guage cluster doesnt work????
- b17 head studs to b18???
- LOOSE SHIFTER, MAJOR SHIFTER PLAY...
- what is the meaning of a compression ratio?
- if i have a car and im selling for parts what do i do
- b18c1 engine harness
- Building my B20
- Burning OIL
- grinding noise and vibration
- Is this a Integra distributor?
- help 94 ls not starting
- Need to Retard my timing
- Car doesn't have a valve thing in the fuel tube....
- rubber gromet on front bumper bracket
- gaskets for DC header?
- b20 in gsr sedan?
- 90 Integra LS 4 Dr White to Black smoke?
- ? about a clutch setup
- b18b intake manifold~brake vacuum line taken out
- Wiring Harness Diagram for Engine Harness
- Cold air intake?
- 94 integra valve issue low compression in cylinder 2
- Tranny keeps popping axel out!!!?!
- Just bought a 97 4 door LS for cheap
- 93 ls motor
- Quick question on B series oil pan.
- Going for all motor
- Timing belt install problem - belt won't go on
- help with integra
- what is a DC-2?
- what sensor is this?
- Need a oil pan for a b18c1 can i use any b series oil pan?
- What is this white/cream box?
- Stock fuel pump?
- 94-97 Integra SI VTEC Front Lip?
- 98up integra bumper on 95 integra
- Clutch Peadle! Need Help
- larger crank pulley
- 94 ls swap need help
- Replacing the third brake light (high mount break light)
- torque spec
- Need some help here..
- GSR and Type R
- Questions about a 92 DA I found ??
- DIY: jdm fog light wiring
- overheating at stops..replaced thermostat..overheating again!
- Driver side axle help again!
- Need help ASAP!! obd0 motor into obd2 car..
- EXHAUST QUESTIONS!
- Shift knob help!!!
- nut and bolt size for ctr strut bar?
- Need help with odd idle issue after rebuild
- lake in the trunk!
- 98 gsr DB8 fuel problem
- help..
- PLEASE HELP!!! just bought an integra now clicking noise!
- 1991 DA9 gas gauge says i have half tank and i ran out of gas... help please!
- rhd....promble can ya help out....
- Tire rubbing at right turns
- b18c1 starting problems
- smoke from exaust when down shifting?
- Need help with 95 LS wiring...doing auto to manual swap
- Need help with TDC on obd1 ls motor
- vtec smoke?
- ARC Intake quest.
- Integra Tsudo exhaust system
- Driverside window won't go up...
- K20 cost
- anyone have a pic of there 4-1 header on a DA?
- Bseries upper starter bolt question.
- headers
- tps sensor
- dyno???
- Vtec checklist.
- rip axel boots?
- cam seal leak
- NEED HELP: SPARK PLUG EXPOLSION
- GSR shaking!
- h22 integra db8 problems
- axel lenght issues...
- i'm a Noob
- Crank Angel Sensor HELPP!
- installing cams
- injen IS Vs Password jdm whale penis?
- What will it take to put on the dc5 brembo calipers?
- 4-1 header subframe clearence G2 Teg?
- 98-01 integra cloth seats Are there different colors???!!
- LS VTEC or GSR
- 5 lug conversion question
- Brake pedal hard after service
- stock flywheel weight?
- Replacing Coolant System Question
- New clutch
- cusco b pillar bars will fit in a dc2???
- Apexi N1 axle-back Part# 162kh11
- weird smell???
- 00 teg GSR Steering wheel issues
- squeak from driver side
- ITR Cluster install
- Electrical Problem
- ls block with type r pistons!!!
- ls block
- check engine light help
- password JDM power chamber intake?
- Just for some reinsurance.....
- Strange Issue, Charging and Battery Drain Issue.
- Need Help
- Installed dsm injectors.. stock LS
- 96 itr cluster in a 1996 ls integra. Maybe broke?
- DA9's stripped trunk?
- 92 Teg
- ABS wiring removal
- How do I know what year tranny I have without opening it?
- Wheel bearing? Need help ASAP
- DA seat belt problem
- Vtec questions please help
- High Mileage with turbo?
- lens for 94-97 fog light
- 92integra shuts off wile driving? help!!
- 01 Civic & DC2 Seat Rail Mounting Points...
- 2.5" collector to 60mm test pipe?
- Integra radio code issue.
- Integra S80 Transmission
- clutch pedal issue
- 2.25 collector header?
- 90 Integra LS Automatic Shift Flare
- Wierd Blackout in my GSR
- Gsr trouble. dont know whats wrong?
- a/c problem and others
- will a b18C5 head go on a b18a1 block?? and is it better then a b16/gsr head??
- I bought a GSR block and saw this?!?! Can i bring it back to life?
- Advice 93 DA? :scared:
- Clutch Job - Spindle Nut Question
- acura integra 91 ls engine feels weak
- older steering wheel on newer car. Can it be wired in to function with srs?
- Car sounds like it struggles
- INJECTORS AND FPR ISSUE HELP !!! =/
- IAB solenoid question
- new project..
- Cluster Problem
- Check Engine Light when it is warm only.
- Looking for person or shop that does JDM conversion!
- 94 dc integra engine ??
- Help... Horrible Vibration on Accel/Decel?
- Stolen White 1995 Integra Ls special Edition!!!!! License Number 6DHG587 Chula Vista, Ca
- Samco Radiator Hoses for GSR fit on an ITR block?
- 94 integra gsr just installed jdm b18c wont idle properly
- Engine Check Light ON Code
- NEED HELP SRS light 1997 ITR!!
- Looking to tune up my 98 Integra, some advice needed.
- 95 LS turning over, but no start.
- cant shift
- 2000 civic hatchback with B18C motor ?'s about the ECU
- lighting problem someone please help me!!!!!
- 97 LS Coolant Smell
- door hinge noise?
- need help.. gas pedal shakes when i reach high rpms
- gforce display
- can a s2000 oem air intake in a civic gsr pass smog and referee?
- another GSR build up...
- axle seals
- help on build
- Wierd idle problem 91 DA Integra RS, won't hold idle.
- ever saw these optional 94 integra rims?
- buyers beware type r conversions
- skunk2 or tokico hp, shocks/struts
- help needed with some chp issues and vehicle history records
- gsr exhaust on an ls?
- DOES A B20 BLOCK GO BETTER WITH A B16 HEAD OR B18 HEAD?
- TB question for ITR cable change over.
- No FITV No Problem?
- I need ur help with my 90 teg 4 dr ls power steering
- I need ur help for an idling problem.
- white smoke, oil on top of pistons
- Power steering removal question
- Machine Work on GSR block
- a winding noise coming from belt
- ► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc
- will a 1993 integra's starter work on my 1991 integra???? i need to know ASAP
- integra with b16 wont start after installing headgasket, need help fast
- alt isnt charging batt
- Misfire? Help!
