View Full Version : Acura Integra
- JG ls cams.... 303's....
- checkengine light
- anyone from miami
- loose steering, need help!
- window trim piece - help
- Squeeking noise near the left tire...
- Type R head with CTR piston set-up need help
- Gains with GSR exhaust?
- whats the diference between LS and GSR tranny?
- tune up (comments welcome)
- Indiglos???
- Removing Oil Filter
- J's intake and Neuspeed front strut tower bar?
- Help with obd2 - obd1 conversion harness
- Skunk2 Im and CAI
- Auto tranny will not engage engine
- good place in LA for p&p?
- 98+ conversion....how much?
- Just recieved my suspension!
- EF is a better handling chassis than DC? Comments?
- Dented my oil pan....will a GSR one fit?
- Factory Alarm short?
- yellow/prokit lowering question
- Clutch recommendations
- Quick Q.....What lug nut size on G3?
- ABS light is on?!?
- dyno run...
- Who has 96 Integra LS Automatic?
- will RSX front seats fit a G3 integra?
- ECU confusion help
- need some help
- New Integra problems
- Clutch Questions
- NOS bottle opener work with NX bottle?
- Just bought my 95 LS
- vafc
- Starting Car
- Sparco Sprint seat brackets???????????????
- Stock Integra CD player giving me trouble
- Tried to search, need paintless dent repair in md,dc area
- itr rear sway bar w/ bsq OR comptech rear sway/ tie bar combo
- Air Filter makin sound?
- First Upgrade
- LS with lots of future plans?
- Is the USDM ITR cluster plug and play with a GSR?
- should I get a new b-pipe?
- car stolen, engine striped, how much for a new one?
- Does a 91 Acura Integra GS Gas tank fit in a 90 Honda Civic DX Hatchback?
- Carbon Fiber Hood
- Spring/Strut install: Torquing bolts to a certain level?
- Patching up trunk holes on my Integra?
- bottom end build
- car too slow...must do more
- For those who have sold or bought a car from a personal owner
- ? have 95 ls, want 98-01 front
- Symptons of being off a tooth on cam gear?????
- EP3 5 Lug Conversion
- every1 must see this
- Tien Suspension
- modified exhaust ticket
- blown koni yellow
- How to remove wheel studs?
- 93 GSR shift linkage work on 94+ GSR's w/ hydro tranny????
- ls power results
- bad axle?
- ACT XTSS and ACT flywheel
- ADR GT Sport wheels
- Both Wheels Tires 4 Sale (Konig Monsoon) for only $200.00
- drag gen 3....illegal???
- 2500$ for complete head rebuild??
- Rear washer trick
- Will these be compatible?
- cai installation
- Has anyone seen or used this lower bar?
- No turn signals?
- Help me!
- Pistons for b17 ?
- camber kit?
- RSX TYPE S run time??
- Oxygen sensor pin in LS???
- Modded GSR vs. Stock Rsx Type S
- Head gasket question???
- Tuning a chipped ECU
- pla take the time to read will help me a gr8 deal.. thanks
- size of gsr.........
- B16a swap in 2nd gen integra with bolt ons
- Best ECU to run a GSR motor with Skunk 2 Intake Manifold?
- replaced fuel filter...
- Stupid?
- integra = civic?
- Anyone with comptech camber kit?
- Stuipd Splash Guard
- Oil in three of my spark plug wells!!!!
- Erratic Starting = bad starter?
- exhaust
- DSM Injecters In 00' GSR?
- help removing front bumper!
- Just purchased a clutch and flywheel
- I have no idea what this button does, please help!!
- need comparison of gsr and itr intake mani's bolt pattern quick! pics please!
- y-1 tranny 3rd gear
- GSR pistons into an LS
- Apexi headers, any good and how much should they cost.
- lighten flywheel
- b16a1 into '86 crx si (Turbo'd)
- b18c1 vs. jdm b18c1
- HID'S?? Please help with info...
- Oem foglight + aftermarket lip
- anyone tell me the differences between these two linkages?
- sunroof wont close on the back right side
- Whats the difference between the LS, RS, & GS?
- Car is Totaled what to do now?
- Sorry for this but you guys are my last hope!!!
- Vin number placement on B18A?
- H&R sport springs owners...
- redline only at 7000 rpm?
- headlight clarity
- engine swap
- turbo + vtec
- shifter problem
- Cel Code 22...
- would someone please answer this question
- DSM Injectors???
- Anyone running an RSX oil filter for a long time now?
- Mixed matched rocker arms
- What is everyone's LS 1/4 mile times?????
- Well after much thinking, I decided to keep the integra :)
- ACT XTSS clutch
- Weight reduction questions and help
- Something is wrong with my tranny...
- Finish clutch install.... now what
- Short shifter question?
- Question for automatic integra owners
- RThinking of moving to the Integra camp, have some????
- ecu question
- 1-800-radiators
- lojack contact number? car's been stolen cops don't know who to contact
- Coilovers go thump thump =(
- car just stolen i'm ready to kill someone
- Mugen Center Caps?
- 99 front bumper on 94 teg???
- need code interpreted
- my 9006 bulb is out so i went to ebay...
- battery life
- I have a 98 GSR wanna run 12s with reliability
- How do I reset or turn off my maintenence light in a 97 dc2......
- What headers to get for a APEXi WorldSport
- GM Synchromesh: Anyone have problems after using this?
- quick header question..
- Anyone have a site on howto adjust timing?
- High Beam Problem (wiring)
- header install, can one take old header out as one peice?
- put in a new horn and...
- New Dash?!?!
- New prob with my teg
- installing clutch... a quick newb question *pic*
- loose header bolts, raining out, will it suck in water?
- integ gauge needles in a EG cluster?
- Cheapest place for weather striping/trim pieces?
- 94 Black GSR Stolen In San Francisco on May 29th
- oem sedan spoiler the same as the coupe?
- Where do i check the code?!??
- can someone check alternator fuse on their LS?
- Anyone Installed type R intake manifold on a GSR motor????
- SRS light is on since i bought the car!
- DA teg alternator problem?
- rusted bolts, screwed up thread
- vtec question....please help..
- Valve Nut
- ** TEIN SS GROUP BUY ** Honda, Acura, Mitsubishi, Nissan
- armrest hole, broken. .
- MSD Ignition
- Wanted::Your Reviews on DA Integras
- black rubber piece between bumper and hood, where?
- What tranny to use with a ls turbo?
- Skunk 2 I/M or Apexi VAFC
- car show in connecticut
- Who has axle seal problems/leaks...
- How to put OEM Intake back together?
- Sound Good
- OT: Good Joke
- testing the waters
- Clutch fluid is black
- Lifetime fuel filter???
- Crank pulley missing small chunk?
- Will these pistons do good?
- Cheap
- will these cams work?
- LS engine swap question....
- How much is a new fender liner for a G3 Integra?
- where to find??
- cam sprockets
- Motor Codes?
- Headlights
- For sale
- New brake pads...but still squeaking?????
- Keyless entry options
- come check out my ride!!!!!
- GSR header on LS motor. what will i need to make it bolt up?
- anyone running ls tranny in ls vtec motor?
- Water in hatch (Spare Tire Well) ~ Tail light gasket...solution?
- 2000 Type R Springs in an LS?
- b20=need better fuel injectors?
- type r head
- header ?
- acura vs. honda hardware
- Wings West 94-97 Type-R??
- Clink noise on tranny when shifting - nothing bad though..
- how to rebuild the engine
- Is it true that if you have TEIN SS coilovers on your Integra...
- time to rebuild or swap engine
- Sparco or racing seats in 90-93 integra who has them ?
- Price on a 90-93 GSR
- kyb agx"s - and what springs...
- 2000 ITR side skirts
- Header Selection for LS - DC or Greddy or Other?
- Integra Shell Price
- **90-93 Integra** Tein SS coilovers group buy.
- AARGG! 3" Short Ram - Power Loss - WHY?
- b18b died.....wont start.help
- Keep USDM front after JDM conv.?
- HP stock question
- Stock GSR Power
- can anyone identify this bottle braket?
- what shocks to go with hr sport?
- What are the best BULBS ???? (close to the look of H.I.D's)
- Misshifted NEED HELP!!!!!
- Skunk2 Shift Knob
- HID Install ( a little help would be appreciated )
- The size of the exhaust manifold holes..
- will itr TB fit LS IM?
- civic suspension on integra
- OBD-1???
- b18c torque specs
- FS: ITR in vehicle classifieds section
- meaning of bolt measurements in helms?
- autometer gauges
- What size Slim Pusher Fans can i use
- Stock Spring Rates
- Broken header stud, is it bad?
- My reinstallation of the ITR 22mm Swaybar on my GSR...no BSQ/Beaks kit =).
- weight of stock wheel?
- Rear Brakes....Not workin??????
- Tanabe Exhaust
- Where to buy tires?
- How much is my car worth?
- Highest Compression on 92 Octane?
- good bay area shops to do turbo install..
- Opinions on Toyo FZ4 vs Toyo TS1
- i am looking for a b18b motor swap
