95k Service
Old Oct 23, 2002 | 09:47 PM
illi Adik's Avatar
Default 95k Service
My main. reqd light was blinking and now it is staying on. I know service is need on certain mileage intervals. My car is blinking at 95k now and I was wondering what is normally involved in this service if I were to take it to a Honda Service Shop
Old Oct 23, 2002 | 09:52 PM
jclau00's Avatar
Default Re: 95k Service (Jackson4Door)
it should say in your owner manual. you're gettin pretty close to timing belt and water pump. other minor stuff: check valves, rotate tires, check fluids, change oil, blah blah blah.
Old Oct 23, 2002 | 09:59 PM
illi Adik's Avatar
Default Re: 95k Service (jclau00)
timing belt was and should be done around 80k. yea i already took care of both of those.
Old Oct 23, 2002 | 10:25 PM
Volcom's Avatar
The main. light blinks every 7500 miles (oil change) and then stays on until you reset it. After you reset it, it will blink in 7500 miles.
Old Oct 24, 2002 | 11:39 PM
SilverDc2's Avatar
Default Re: 95k Service (Volcom)
the maint reg. light can be easily removed. under your dash theres a button just push it and hold it. the light will go away. but if you haven't changed your oil do so.
98pre1ude
Oct 4, 2015 04:58 PM
MrMilks
Aug 29, 2014 06:00 PM
dennisjai
Honda Civic (2001 - 2005)
Jul 27, 2006 10:58 AM
mavshah
Apr 11, 2005 08:23 AM
Seedc2
Aug 18, 2001 08:01 PM
