View Full Version : Acura Integra
- what size rims does everyone run?
- Tanabe Hyper Medallion vs. Apexi WS
- Need help?!?!>....problem has somethin to do around 3500 to 5000 rpm..please help!!!!
- Why does gas mileage vary so much in Integras?
- Ground Control Coil Overs
- I need to buy rotors and pads..... **BRAKES!** (help!)
- Cannon Floormats
- Light bulbs dilemna...
- I have a serious question....
- JUN engines
- How much should a valve job cost?
- DC Sports TCS
- Code 10?
- Goin to tha track tomorrow, got a couple questions.
- Dyno tuning procedure
- B&M synthetic tranny fluid
- How to remove and keep water out of corner bumper lights?
- Help!! Wheel stud spins with the lug nut!!
- Help with hesitation problems please
- Dumb question about Si(R) muffler on GSR
- weight savings with CF hood
- Starting to get fed up with everything
- Center caps for GS-R wheels...
- when getting cams.........
- Broke damn bolts under spark plug cover arghhh
- Nitto 555R...60ft times in your GSR?
- Fuel Pressure
- A'PEXi power intake, anyone?
- wow or waste: high flow cat, denso iridium
- DC or Comptech headers for 2001 GSR?
- JG/Edel header: what's the real deal
- skunk2 intake manifold install
- may need pistons, head gasket
- someone said i dont post on honda-tech much anymore(updates..join in)
- Clearance on Integra stuff -->>
- Electrical problems...
- Imperio M-05 in 16"
- Raspy Noise on my 2.5" str8 pipe...
- clutch pedal vibrating
- Anyone have the CROWER 63403s?
- How Can i get extra HP?
- SSB owners...
- Help with greddy headers...did search...
- Indiglo help, please
- How does altitude affect timing?
- Turbo Ls w/ stock internals
- Engine Swap Step by Step Process
- opinion on an all-motor setup.....
- Black Gs-r blades on a dark green teg?
- nj autox this weekend: 7/21-22 !!!!!
- remove the center piece, can someone please help me
- Thanks guys!! (Related to my valve adjusting questions)
- Will a 95 Civic Exhaust fit on a 98 Integra?
- OT: WRX or Honda /Acura Model Turbo
- Weight of 15" 2000 GSR wheel?
- LOL .. the Toda Racing babies, an early start in life !!!
- my dip stick is bent???why?
- short throw shifters
- air intake for GSR
- Comptech ice box with JRSC
- .05 over ferra valves
- I need this answered quick
- Rubber suspension spring cushioners?
- How long does it take for the engine to cool down...
- What techniques do u guys use?
- question bout best exhaust for 94 gsr.....
- bay area: where to get clutch installed?
- Flat tire beotching
- Enkei RS6's
- what should my settings be?
- 95 GSR what type of induction?
- More exhaust questions.
- Grinding gears on tranny
- Exhaust Sound Poll...
- Anyone Selling Type R front end conversion?
- My car sounds Ricey....
- Which muffler looks the most stock?
- Where to get Clutch checked out?
- ATTN all B18A/B!!!
- gutting the cat...
- VTEC knock (Loud!)
- HELP HELP: My nitto 450 205/40/16, has CRACKS on sidewall.
- OT - Importing cars from japan
- will my apexi n1 exhaust type r 01 fit your 00/01 gsr. if so, im selling it
- Need a reliable mechanic ASAP in Pittsburgh
- How much would this cost?
- fields vtec controller??
- Which throttle body gaskey for Skunk2 intake manifold w/ 64mm TB?
- skunk manifold any good????
- Apexi V-AFC vs. Fields SFC-VTEC controller
- Should I Purchase A Used Exhaust?
- Touring
- To buy or not to buy.....
- 75,000 miles service
- transmission case oil
- Discrepency with Apex WS exhuast on GS-R?
- How do i get into the upper 14s w/ my GSR?
- damn rotor screw...
- obd 2 gs-r's stealable???
- carfax report...
- Buying CTR cams locally....need a few tips..
- Integra LS/vtec vs Prelude vtec
- chekcin valve lash..
- How many bolts hold on a teg's side moldings?
- Stripping interior question
- Just wanted to say hey :)
- ls/vtec which head is better
- DC Sports Headers. CC vs. SS
- Has anyone heard off....
- Attention!!!! B18A/B owners.....
- Which valve spring for Skunk2 cams revving to 9k?
- New RSX Forum.....Use It!!!!
- Are all Type-R axle-back exhausts the same?
- Maint Req Light -- I'm Worried....
- shocks & struts
- OT: but need some help
- GSR cluster?!?!
- Timing belt change -> Screeching belt sound while accelerating
- KONI cellular polyurethane bumpstop
- H&R Sport Vs. Eibach Sportline
- Detonation!?!?!
- Kamikaze Ceramic Headers??????????
- lowering springs by Eibach
- Tips on modifying a GSR
- valve cover ?
- ITR Muffler on 96 LS Teg
- How do you know?
- car breaks up sparatically....
- rear suspension/shocks
- Can I put 90-93 rear shock into a 94+ integra?
- ls/vtec
- Rolling out fenders
- ACURA's factory CD changer question
- question about GSR cams
- Comp cams specs & info
- GSR with I/H/E
- tire weight is often overlooked... new Azenis... heavy?
- Question about JG engine dynamics
- Question for people with iceman intake
- web address to buy valve adjustment tool?
- How to distinguish GSR OBDI ECU from OBDII ECU?
- headers??
- Skunk2 Intake Manifold Will 98 Gsr Intake Pipe Fit?
- throttle cable?
- Shaving side molding
- C.R. and Piston/Valve clearance Q's
- question about CAI
- Any way to change VTEC engagement without V-afc?
- Anyone got......
- This car...RS or LS???
- Which wire off the ECU is for VTEC?
- Where can I find a RSR exhaust?
- Be sure to check your tire pressures...
- Brake shim needed..
- I JUST WANT MY CAR!!!
- JDM/US Front Clip (and yes I did a search)
- Oil Pressure
- SUNROOF RATTLE/CHATTER! HELP.
- Intake mainfold
- Sunday, Sunday, Sunday!! Bring the Tegs out for some fun!!
- i hate it when my car gets hit!!!
- whats goin on with ma engine..???????????
- APEXi WS Coilovers: Applications for a 3rd gen Integra
- Anyone got an ls running lows 13's
- Question about ECU'S
- How much to paint side moldings??
- Shaved side moldings
- Need your opinions on a product
- Haha, green brake fluid
- Canadian RSX
- Reccomended performance shops in Pheonix
- Valve adjusting question
- Insurance Prices?
- Overheating?
- Stolen Tegs Survey.....
- Suspension install help.
- Basic Steel Rims Vs. GSR Rims
- I have an obx rear upper strut bar from a 92 ls...
- How much to torque LCA bolts...need help quick
- start the car, heard clicking, power winding down....= Bad alternator ??? help !!
- Source for Parts - The Dealer?
- AC-Sputtering-PowerLoss
- Finally happened to me...
- Specs?
- KYB or other aftermarket shocks ?
- need help with tuning ITR cams..help!!!!1
- 5 Zigen Fireball Muffler for an 1996 LS Integra
- Wheel Rotational Play
- Worn Springs?
- Odd tire wear?
- Dyno tuning for 94 GSR
- Just installed clutch...have some problems
- anyone got obd1 94-96 teg ls ecu 4sale?
- camber adjustionn needed for eibach springs?
- CV boot installation!! need assistant
- Difference between a Integra non-vtech and Integra GSR exhaust?
- Is this a good deal on a '94 gsr?? long..
- Apex N1 muffler = Hearing loss?
- Anyone have pics of spoon wheels on a white G3 integra?
- Battery Recommendation
- Side moldings on LS's
- What will this run?
- Where is my oil going??
- HELP: Piece of rubber got sucked into throttle body!
- rear camber washer trick..... got 1 quick question
- My rear shocks wont come out...
- How much do 96 GSR ECU go for?
- dunlop sp 8000 for dirt cheap
- recall on 1998 itr???????
- Fuel upgrade necessary for Skunk2 cams?
- ZEX kit for $375 or ITR cams for $325?
- Kamikaze header OR DC sports jdm 4-1
- How much horse's from this set up
- Hit somebody, Need a new Hood!!!
- IS this a good setup for a gs-r?
- Nail in Tire...
- Battery ??
- rebuilding block ?'s
- ITR O.E. exhaust on a GS-R
- What are the best cams to put in a 99 GSR...i already bought cam gears
- N1 sound???
- Catco cat converter....sucks ass
- 1 more thing... leaks!
- Powdercoathing 2001 GSR rims Glossy black?? kool?
- "sputtering" with AC on
- 20 x 6 x 14 slicks too small?
- Wow!! Check this out!!
- Anyone want to sponsor a RSX Type S?
- Wheel Offsets
- any pics of thermal stealth or classic on a 3g teg?
- 12" brake mock up done...
- Any problems with a 215/50/15 on an Integra?
- Chattering sound from clutch
- fyi, there's a DC "JDM" 4-1 on eBay for cheap
- Bay Area Mini-Meet?
- Gapping spark plugs
- JDM ITR Recaro or Sparco Torinos?
- Help. Air conditioner & fan, and Radiator on 24/7
- Any downsides to always having your Check engine light on, besides being annoying
- Which Camera and How to mount one on the front lip?
- Check Engine light reset button!!!
- Calculating Tire Size
- Who has Apex N1 Suspension? Need a little help.
- are bigger injectors, ie 310cc, beneficial for my TODA B's in my B18c1
- Since when did 76 change their octane grade?
- What exactly does getting an alignment do?
- Measured my car with G-Tech Pro, how accurate is this?!?!
- HID lights?
- So does anyone have an RSX yet?
