View Full Version : Acura Integra
- tranny-lsd opinions... building a 500whp car
- 94 acura integra ls
- tranny grinding
- WHY can't i find an RSR cat for DC integra GsR?
- mod suggestions
- obd2 alternator on obd1 engine ?
- NOOB QUESTION about Pistons
- i might do a b20 swap the first gen 96-00???
- integra oil pump question
- Catalyst system effieciency-GS-R PLease help
- small GSR idle problem
- no spark?!?!? bad ecu maybe???
- Any Websites
- Green lug nuts
- 99 Integra Value?
- damm raditor fan
- LS Synchros in a GSR Tranny?
- quick question.....
- My GS-R Before Modifications Start!! Look!
- AC Compressor not getting signal to kick on, but works when hardwired
- spiking idle?
- Won't go into reverse??? What?
- da motor mount????????
- what sensor on the back of the gsr block is this?
- 1995 GSR VTEC HARD WIRE HELP PLEASE...
- best for 220 whp NA Integra
- Tein SS or Koni/GC
- Apexi VAFC II - Questions for Owners
- Who has a Valentine One Radar Detector?
- Taillight Fitments? Springs?
- BAR'D B20???
- 94 Front Bumper Bolts
- H22 on a 1989 Teg (D16A1)!!! ELD problem!!! ECU HELP
- obd1 code #1 & 17
- JDM B18C/USDM B18C1 parts compatability
- does anyone know how to hook up a shift light?
- Car stalling above 4k rpms on highway
- how much does my 94 integra gsr weigh???
- OEM Integra Optional Side Skirts
- Approximate weight of catback setup?
- compresswion test trouble
- Removing turn signal lenses from turn signal assembly?
- Integra ECU Pinouts
- ecu codes 16 and 43 ---- integra 91 need help please
- LHD USDM ITR Faux Carbon Fiber Vent
- intake manifold ?
- Rebuild or go lsvtec
- anyone willing to sell there ls or gsr?
- blox manifold on gsr (quick)
- Engine Swap
- wassup
- Need Advice. Help oil starvation.
- can i use a 96 gsr cluster......
- LUG NUT PROBLEM
- flashing your e.c.u.
- Eagle rods machined for GSR bearings to be put on a LS crank?
- 92 integra ECU jumper location pic ( or diagram)
- door conversion
- Mirror Question
- 98 obdII GS-r Misfire - Emergency Please Help!
- Need help car not starting!!
- ram air duct
- new to H-T *pics*
- 91' integra front end problems. need help
- How much can I expect to pay?
- fuel pump
- fog light bulbs
- Headlights
- Anyone have pics of teg with WORK equips? pic inside
- symptons of bad upper ball joint?
- gs-r cluster on se?
- b18c1 - header question
- 94 Integra...need help!
- VAFC II HELP!
- Incorrect purge flow?
- 1/4 mile GSR
- AC problems
- bad gas milage... help?
- LS/Vtec
- 2 choices
- gsr cat
- A tip on oil filters: I lost 8-10 lbs of pressure with.......
- Integra head swap
- trouble in removing engine harness
- How do I remove wire loom clips from body?
- alternator belt size?
- How to make AC work when converting to half size radiator?
- oil pan gasket
- LS V-Tec done...whats next??
- 4 door window weather stripping
- Earthing Kit Installed Tonight
- some weird engine noise on cold start
- My DB1 build progress....Pics.
- Help asap missing problem!!
- HiFlow Cat Question
- JDM FRONT [ hid cutline pictures ]
- First Time Honda owner , Tips Please=]
- Adaptor on top of my manifold. What is it?
- ls motor and gsr tranny
- NEED HELP!!!... car feels wobbley after replacing axles
- in need of head (lol)
- 1992 acura integra motor swap
- help installing skunk2 intake manifold?
- more problems
- New York Mechanic
- jdm 1 piece headlight with hid
- car feels like sh*t
- Headers ring gaskets!!!!!
- I'm new! Need a lot of advices - DA Integra
- 98 integra tring to use 96 gsr cluster i think the shell was an ls
- project: GSR w/B18C5
- Best place to order carpet?
- what else could it be???
- hks hipower exhaust
- gsr trouble
- Hard to get in 3rd and up gears...
- integra gsr for sale
- pics of my 96 gsr (needs work)
- new carpet for a DA
- charcoal can ?
- Video of all motor integra with 190-200 whp??
- ls ecu
- running lean and misfire in cyl1????
- ITR or CTR pistons?
- flowmasters of mac's??
- E-Brake Question
- what pistons are better for a ls
- integra ls tuning
- Greddy exsaust system
- ALOT of oil on spark plug
- going wingless
- Stolen Black 95 Integra GSR In Northeast TN
- gsr suspension
- Motor mounts not alighning up wen trying to put motor in....
- just some pics of my sspb Gs-R nothing special
- Mugen Brake Upgrade for Integras in 4x100 12" rotors is complete!
- which radiator
- 94 GSR Sedan inconsistent starting "fixed" but still nervous
- CALLING ALL GSR GURUS NEED HELP
- Need a set of axles
- Junkyards around san jose?
- What is the compression ratio?
- just put in new head
- rear springs question..
- carbon fiber lip
- Question on DC2 ground effects?
- where can i buy...
- Is thier any interchangable master cylinders for the integra?
- Exhaust
- Resonators! i know......please help!
- ***ABS LIGHT ON***96 GSR***Code 1
- wtb: 94+ GSR
- How do you get a firm brake pedal? Gravity brake bleed?
- Heat rising from floorboard?
- clicking noise
- gsr sk2 trouble
- Drop, camber, alligment oh my
- retard timing?
- anyone have a pic of gsr cams?
- Fog Lights
- GS-R problem
- ECU HELP FAST!!!!! <<<<<<<<<<<
- skunk 2 IM on 94 GSR question
- Oil Filter Plate
- NEED HELP I AM NEW 2 THIS
- HELP!!! I KEEP BLOWING A FUSE.....CAR WONT STAY ON
- Is it Ricer to paint your hood black?
- Crazy Noise, sounds like a machine gun, axel issue possible?
- gsr IABs, where is this plug?
- Carbon Fiber Interior Pieces.
- LCA bolt won't come off
- leather care product ?????
- how to tune cam gears for stage 1 shaft
- Skunk2 springs install problem..
- How to tell if my clutch is going bad?
- how do I??
- quick spray paint question
- help please i only have until 4:30 or 5:00!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- how can i tell from LS plug wires and GSR
- wheel size and offset for 1990 4dr
- Replaced Tie-rod ends w/ Mevotech.. Question about a feature
- getting a GSR
- blown suspension?
- NRG horn problem
- accord seats in a DA?
- Port and Polis???
- My DA won't start! HELP!
- prelude springs on DA??
- i need a recommended clutch
- Building A B18C1...help
- Overheating question?
- Many questions on B20z swap
- timmin issue please help?
- 96-00 rear shocks on a DA
- Please Help!!! Engine making noise........
- halo question
- Throttle Cable annoyances!!
- YO DUDES! i gots new shoes
- h23 GSR
- is it worth this?
- timeing belt tensioner help
- Can't hear vtec, opinion/advice needed
- Took off head and now...
- Brembo Brakes
- car wont go into gear
- oil light blinking
- need help ek to dc
- rusted bolts...help?
- sway bars, GS vs. Type R
- Was there a Blue GSR in 96?
- so what should i do with my teg?
- automatic integra question
- CEL flashes 10 times
- compression test results 1990 integra gs, whats up?
- A/C problem! NEED HELP.
- 92 gsr cable tranny internals into 95 hydro tranny case
- B17 Vtec head Dual cam WHAAAT>?
- 94+ gsr
- Timing Belt Keeps Hitting T-Belt Cover
- hi-flow cat ?
- ANY ONE SELLING
- Need help!! which rims to get for integra gramlights 57s-pros, 57pro, or 57maxpro?
- hello
- need some help, oil pan
- hi
- Need Help???? B20b into DA integra
- '95 Integra GSR - No mods, planning on NA or Greddy Turbo
- GSr
- switching from synthetic to regular oil
- vtec ls...dont worry not what you think...
- sun/moon roof
- 94 ls restore or retire? Long post.
- Stolen lug nuts + Not knowing = Disaster
- Four door itr seats???
- ITB's? Are they worth it?
- h23a in a ls dc???
- how to check spark/fuel?
- ls question
- where to buy 93 tegra manual tranny?
- SAW THIS TEG ON CARDOMAIN ITS SOO NICCCCEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 98 GSR with 167k oil question???
- 98 gsr clutch squeak?
- clicking noise on h2b swap in da
- 89-93 non U.S DA paint colors?
- Integra steering is Off...
- jdm itr headlights
- What to BUY?? NEw used integra
- 2 quick questions
- gsr feling REALLY sluggish. help me out
- help with my 97 dc...
