- Extended lug nut install help.... PLEASE!!!
- compression problem
- How to EP3 seats in DC
- pr4 ECU chip
- 93 ls Clutch
- Stereo wiring
- Autometer Gray Pillar 2 Gauge Pod Questions
- Header bolt-on?
- car do not cut off
- Engine swap with transmission attached?
- looking for a vtec head
- ITR muffler/exhaust?!..
- ebay !!!!GSR BLADES REPLICA!!!!
- 16" tire size?
- CTR Pistons
- radio block off plate question
- turns over but...
- Front Bumper Screws
- exhaust/muffler look..?!?
- thats that Bullsh&T..
- crank pulley
- Dipstick tube & Dispstick length on B18 vs. B20?
- high rpm=grinding..kinda ?
- Apex'i N1 rusted through
- I've searched, need help with code 74
- spoon axleback bolt right up to stock bpipe?
- please help!
- Golden Eagle VTEC conversion kit quality?
- Will H&R sport springs removed from a civic fit?
- Timing belt wont tighten
- What cams in my GSR?
- car bog/jerk/stuttered then CEL..MAP sensor or TPS???
- 98 GSR wont start
- rpm guage off :( and didnt know lol
- bad TPS and IACV
- ITR/CTR cams?!...
- OBD port
- High idle RPMs and brake pedal
- Skunk2 Camber Kit Nut size, URGENT! Please help! 1999 Acura Integra GSR.
- different sized batbacks?
- quick question
- What are some good suspenesion set ups?
- maintence required
- which ground-control kit?
- fuel pump info?
- syncro for 5th
- crossing parts
- You think I can trust this site?
- trouble setting cam gears to tdc
- Damn WTF this 3rd time i changed my fog light bulb.. any help? JDM front
- Engine Missing
- DC2 radiator in DA
- kaixen plug & play problems, help! JDM headlights with pics
- Password JDM Cf intake work on DA?
- 94 -01 Acura Integra owners please take a look
- Headlights turn themselves on
- 94 gsr Moonroof glass sucked right off at high speed!!!!
- B18c head: exhaust side valve springs
- Civic Type R steering wheel with quick release hub????
- Shift linkage bolt question
- Funny engine chatter
- Fuel rail problems?
- thermal or hks exhaust
- GSR rotor weight?
- Door Panel
- what would u do with this situation?
- where is the B18b stop revving
- How do I remove this window trim?
- Removing the alternator belt.?
- 90-92/93 integra rear bumper conversion
- tach doesn't work
- Looking for a Steering Rack.
- Bosch water pump any good?
- Mugen ITR front bumper
- engine stutter while accelerating
- need LOTS of help..
- NOS question
- What spark plugs for GSR w/JRSC? and wat GAP?
- IACV
- Does anyone know how much the stock wheels weigh?
- brake booster
- A little trouble with the LCA bolt and nut
- Help with fast blinkers
- ARP Head studs placement
- why i HATE working on my car!
- bad Ecu
- Integra to Civic Chasis Similarites?
- lsd
- HID question! please help
- in dying need of shocks
- *****need help on price*****
- headers
- What Tranny is best for a B18B1 LS motor?
- 94 integra ls bolt pattern?
- engine noise....help
- 90 acura integra DA need help with hight.
- Broken Piece on Tranny!
- Best Matching LEDs?
- how to remove ABS ????
- carbon fiber hood
- clean integra kit
- wheel bearing
- A/C retro-fit to R-134
- 4 door rear folding seats?
- HOW DO I convert my P72 from auto to manual?
- Engine overheats in high RPM's
- Looking to buy a '92 integra
- GSR throttle cable Compatibilty
- Dust on Bumper
- how the hell do you clean the gauge cluster lense.
- Camber kits
- How to put a chip in
- removing paint from painted calipers
- 1989 Integra Electrical Problem + 120K maintenance
- problem with fuel maybe?
- J's Racing Color Code ?
- Kenji's ECU/chip
- tan or black interior
- *ProBlem With The beaSt*
- Another "My car won't start" thread
- clutch issues (techs please help)
- Timing on a GSR
- swapping cams?
- Considering B20 Turbo...need help
- '92 RS Teg Climate Control & Steering Wheel Fitment ?'s
- Head work?
- speedo recalibration?
- AC/defrost fan.... not fuse
- AEM Cam gears problem getting TDC
- Clutch Slave Cyl. - What lube to use?
- front strut bar question
- help me please. tranny leak!!!
- Anyone know where i can find this
- ITR Shift Linkage+Stabilizer Bar+Shifter on DA9 Instal/Help plz.
- ecu recommondations
- GSR EM Help
- help please....axle instal?!?
- Looking for these rims. Please help!!!!!!!!!!!!!!!!!!!
- CTR crank pulley?
- integra turn signal wiring problem
- Good shop in Orange County for Engine Rebuild?
- Quick Question...Clicking and Whining Sound (CV Joint and PS?)
- BKR6ES-11 or BKR6EGP ?????
- INTEGRA LS 01....WHAT DO I NEED FOR MY ENGINE TO SPRAY 75 SHOT SAFELY
- Exhaust leak
- Another JDM type R Axel question???
- Question about ITR JDM FRONT headlight adjusting them.
- d2 coil over help
- Rough Idle?
- JDM DA Gauge Cluster
- motor build help
- ys1 tranny question
- Best Short Shifter for Teggy
- 98-01 fogs on 94-97?
- B20 supercharged integra ?
- backpressure
- H.I.D
- HELP TIRES SCRAPE WHEN TURN !!
- Immobilizer question on Integra
- ***I found my PERFECT DA9..........Almost.....need your help please!!!!!***
- battery?
- lsvtec question, no vtec in 4th and 5th
- Would you buy a RHD converted Integra?
- Q: CANT OPEN MY HOOD. HELP. INTEGRA CANT POP OPEN HOOD Plz help
- cam help
- Which headgasket? LS or B20
- anyone have.....
- Do I need to reinforce if upsizing rear sway from 13mm to 14mm?
- header question
- HELP hooking up intake manifold
- Need a new CF hood...
- supercharged DA?
- 93 integra gs stock ecu.. anyone have 1?
- check engine light-canister leak
- Turbo integra problem....(if you have experience) HELP
- side markers
- ABS - replacing my modulator/accumulator today
- Reasons for a head gasket blowing..
- Tranny Code Question
- Q: just fixed my JDM ITR front bumper sag, but now having problem openin hood!
- ITR header or no?
- MY 94 DB8 FOUR DOOR TYPE R
- hid ballast help....
- 14" directional Blades?
- What ECU is better obd1 P72 or p30?
- wheel locks for extended studs?
- How to replace antenna on 1991 RS?
- Whats the difference between a 94-97 integ front bumper and 98-01 front bumper??
- Apex-i WS2
- axle question plz help
- diagnostic port after conversion
- LOL pics of my my cyl 2 has no compression.. funny
- hellllllllppppp
- How does Type R lip Look on STOCK (Unlowered) Integra
- cant decide....
- Clicking Noise.. Oh no.
- Short Shifter
- 92+ trannies STRONGER SYNCROS?
- GSR Cam Caps
- raceinpspired? underbid?
- Which camshaft is better??
- Intake gasket on ebay
- LS/VTEC Setup
- Quesiton...
- act 15k clutch starting to slip All new clutch or just disk? $150 or $500+
- IACV?
- 111K chech engine light came on
- spun a bearing
- Quick questrion about an axle problem
- what sensor is this on the IM?? pics..
- Guage cluster question...
- Phearable ECU
- Questions on my B series Built
- DD build for dc4..
- can i swap ITR second gear into GSR gearbox
- Aight for some DD Wheels?
- Driverside trunk panel removal need help
- Just bought a B18 integra
- CEL HELP yo
- main caps and rocker arm question
- DA9 im buying tomorrow
- need help with smogging
- How do you do headlight adjustment
- chipped ECU?!...
- Moonroof switch
- Intermediate shaft install advice
- early rev limiter??
- Driveshaft/intermediate shaft prob. *V.PICS*
- G-tech Accurancy
- 90 integra
- I am going to repaint my integra but I dont know what color is should do. suggestions?
- is this good for a stock ls
- 91 integra wont start help!!!
- installed some of my last parts on the teg
- CAMS
- PROTHANE motor mount question!!!???
- Thermostat Part #?
- Vehicle Speed Sensor
- .:| Integra Seatbelt Question |:.
- Hello
- Clanking coming from tranny!
- so i bought an LS w/ a b16...
- Been a while since i posted some pics :)
- rattling noise on startup
- LS conversion
- DIY: Citylights on 94-00 USDM Integra Headlight
- DIY: Citylights on 94-00 USDM Integra Headlights
- DIY: Citylights on 94-00 Integra USDM headlights
- questions about lowering.
- nuckle and suspension problems.
