View Full Version : Acura Integra
- ls vacuum lines
- What to look for when buying a teg...
- DA exhaust
- How much does it cost to swap a motor?
- car idle's at 3000k????
- sagging doors on a 90 teg
- Need advice on seat dilemma
- looking for list of tuning shops ''topic''
- How to uninstall/install rear valance??
- Should I get this teg?????
- swap
- help! flywheel!
- Do the 02 sensor affect the idle and gas mileage if it goes bad?
- gsr compression
- hey guys im new with a question!
- Pro Vs Street Clutch?
- b series starter questions LS GSR
- "unmodifying" my da starter question
- idle low after installing cams
- my 99 integra ls
- starter?
- What would you do with...
- VSS code after clutch swap. New VSS did not fix the problem.
- trouble starting
- My new used brake setup.
- stock rims
- db8 insurance?
- I Want To Buy A DA
- What color would you paint it?
- How can you tell when you need to replace your o2 sensor?
- b20 in an integra???
- Ground control
- Integra engine swaps
- problem with b18b help!!
- ABS or Not
- Car died.... cranks but wont run
- FAT 5'S?????
- DA With D15B
- Auto tranny compatibility?
- Anyone ever put a D16 into an integra?
- Rebuilt engine burning oil and very low compression
- Lube Throw Out Bearing
- Dc2 JDM Front Conversion : Rad support question
- vision mc mirrors vs replica spoon mirrors differences?
- VSS cable ??
- EK sides on a DC2?
- rev problem
- What size bulb is for the jdm headlights?
- b18b is the same as b18c
- Clicking Clutch Problem
- new to the honda world
- any experience with Total JDM from Canada
- da pulls to side when braking
- o2 sensor wiring ripped out of connector 95 gsr
- Anyone with a stolen 1990 Acura Integra?
- quick connecting pipe question
- what arp head studs do i need?
- Can timing change by itself??
- Comptech parts...
- Header and test pipe question for B18C1 hatch!
- Should I buy this car?
- TIMNG HELP IN MOUNT JOY
- gsr throttle cable part number?
- Alex's 2000 gsr mini restoration project! Pictures!
- URGENT - Rebuilt motor is having issues
- Need advice on do it yourself clear bra for a 92 integra GSR
- engine swap question
- 90 auto teg GAS!
- WILL THIS HEADER FIT MY CAR?
- c-pillar bar HELP!!!!
- rhd dash question dc2
- mud flap's
- gsr tranny??
- Help!!!
- pic request of volks!!
- jsr type r strut bars
- Can anyone tell me what seats these are?
- Ignition Help
- 90 integra help
- platic sucked in to engine!!!...help
- Intake manifold
- what gauge size wire is on my gsr engine harness??
- alrighty...integra stalling out.
- Opinion On b20 and b20z..
- quick question!
- Exhaust for my db1
- Got a Few Spares I can have/buy?
- Replacing axles
- Looking for.....
- WedSport Tc-05 Center caps
- NON-HID BLACK HOUSING(ITR)?
- question about paypal.
- itr transmission internals into ls casing?
- Coolant housing for a B16A?
- Integra bumper comparison?
- acura integra headlight wiring harness
- on hondata?
- DA9 1 piece headlight
- intake is whistling/sounds different than before. help.
- question for the wire experts
- 2nd Gen DC2 Mugen Wing
- NEED A PIC OF A B18a1
- CEL 45 (running rich) stock integra 96
- p1337?
- Help! Painting my front bumper
- Is it my alrernator? or something else Integra GSR 98
- why would someone do that...?
- do i need to replace the gasket?
- Help -- ABS light coming on randomly...
- engine mounts removal and install question
- Type S wing on integra
- Replacing clutch and flywheel.
- Where to buy si-vtec parking lights?
- >>>PLease Help ME<<<
- Exhaust leak !
- JDM GSR
- What does CAI stand for???
- Grinding!!!
- Is the integra worth it? Project car help
- fast question
- Ticking/Putting noise from new header???
- tow hooks?
- 95 trunk work on 01 gsr?? help..
- replacing altenator belt
- Vibrations at 2600rpm
- cut out at 3500rmp
- INJECTOR QUESTION
- BOGGING OUT/HESITATION PROBLEM
- CF Front Lip????
- ITB's for GSR
- messed up my rockers
- NSX calipers
- need help
- WHERE CAN I GET THIS SPOILER/TRUNKLIP
- WET SANDING HELP
- header question
- No turn signals...help
- Valve cover ground question.
- DA Question, sportmax 002 please help
- screws from motor mount to motor missing
- Lugs Help
- Replacing tie rod dust boots ?
- need new distributor. what works?
- EcTune problems... help
- starting problem
- WHATS THIS PART CALLED?
- 1997 Acura Integra.. What engine?
- car sometimes starts other times it just cranks 90 with swap think its a relay
- clutch problem
- car drops to 0 rpms?
- best, most effective REAR strut bar
- DIY: Quick/easy/cheap fix for dull, cloudy and yellow headlights.
- Speed Sensitive steering problems?
- B18B swap not warming up?
- time to change the timing belt.
- What the %$# is wrong with my GSR?
- quick question about ac compressor and fans
- p72 vtec engagement
- Suspension Setup for DC4
- Help me fix my Integra
- Stainless steel or ceramic???
- a lil help with bearing cap
- lets hear it, worst thing that ever happen to your teg.
- OEM Acura bolts and washers
- trouble opening door
- ls vtec ecu and distributor....
- camber kit install?
- stock stereo
- how do you clean
- I got locked out of my 1993 integra. How do i use a slim jim for it?
- B16 Head look good?
- LS/ Vtec
- Vtec question...
- I want to lower on my integra!
- DA Steering rack
- gsr swap idle problem
- i hate my life!
- My teg is overheating...
- gsr swap took a turn for the worse
- Apexi N1 on 98 rear bumper!!! question help?
- DA with H22A swap..
- Looking for 94-96 Acura integra
- Water leaking out of pass. dash
- Transmission slips out of gear?!!!
- Turbo? Vtec? Both?
- those of you with JDM front ends i need ur help!!!
- 93 gs need help??
- Throw out bearing?¿
- rota c8's
- Ignition Switch, Where to get one at
- NEED HELP,FAULT CODE 20(ELECTRICAL LOAD DETECTOR)
- need help!!
- need help on DOHC POWER
- QUESTIONS ABOUT Ls VTECs
- how do u reset the abs light
- Question about Integra Type R Intake on a Civic Si ???
- New user looking for some help WTB front DC5 Recaros black with red stitching
- B16 into a 95 DC Integra???
- 92 integra lsvtec overheating problem!!
- GSR SKUNK2 Pro Series Manifold
- GSR sputtering & won't idle, cuts out, crazy tach BAD Distributor/Dizzy?
- need suggestion on RHD setup
- Anyone with a DA gone K-series yet? I know there has been, but I have a ?.
- Radio code retrival problems
- Rims Question: 5Zigen vs Fat Fives
- JDM 94-97 Integra SiR-G Front Bumper (USDM)????
- ned racin help
- backfire
- NEED HELP! 95 integ radio help!
- searched prob with no luck, help!
- Can I safely run over 12 psi on my fully built engine......
- Radio would not turn on
- CEL 22 and 45
- VAFC mounting...need ideas!
- How hard is it to get a title?
- silly idle need ideas?
- obd 1 car and ecu, obd 2 motor and harness need help????
- is it possible to clean.....?
- 1996 Gsr runnin like shit
- Running Rich?
- Compression test results, what else could it be?
- Start help
- Acura integra problems please look
- Squeaky windows
- What 14inch steel wheels fit GSR's?
- 91 ls running way rich! any ideas????
- check engine light in rain
- where did you get yours?
- 37 offset on a dc...am i screwed?
- Corbeau driver side bracket on a 90-93 teggy fitment issue.
- idle issue
- napa parts bad?
- Long block?
- interior question on 2nd gen
- ebay axles?
- throttle body. obd0 or 1?
- Is This Normal? 6in+ Lift 1 Tire :(
- n switch 2 questions ignition/battery
- B16 problems help!!
- hood wont close
- water and oil coolant lines for 2871r on LS
- need help... anyone know about 96 integra auto tranny problems?
- cold air induction....any ideas.....
- GSR OEM Header
- competition clutch disc into exedy plate...
- Coolant reservoir? Can it be removed totally?
- Idling
- questions about civic integra conversion
- radiator hoses pic wanted
