View Full Version : Acura Integra
- problem with 91 teg help please
- nd drives91 integra ls for sale cheap must sell fast!!!
- Stock GSR intake differences?
- Will a Aem gsr CAI fit AEBS GSR intake maniofold or do I need a different intake also..
- Apexi V-AFC II VTM Signal on OBDII?
- Info needed on coilover springs. Omnipower and others.
- integra HID
- Battery? Fuse? Relay noise? - Car wont start
- Tires?
- HID-VISION kits for $225.99. Is it a good deal?
- TypeR lip in Canada
- Rebuilt motor small leak at headgasket front, left corner by trans?
- need help deciding on clutch and flywheel
- Bogging and random vtec cross over points PR3
- installing clear side indicator problems
- engine restorer product?
- abs motor clickin...
- Buy an integra?
- my dam cambr kit keeps comming loose!
- your opinion
- replacement hoods?
- what size for my 16's slips?
- Friggen front end bottoming out. Coilovers are the culprit? Where to get custom springs?
- DA Electrical problem help!!!!!!!!
- JDM radiator support, headlights, and paint questions
- Reason For Being Banned? Cant Post in General so posting in here.
- Steering problem
- Blue integra seats??
- just bought areospeed rear camber kit for dc? is it nay good ?
- Can EF Vision CF Mirrors fit on 92 DA??? Need to modify??
- removing oily fingerprints
- hood latch...
- where to buy??
- just installed Skunk2 intake manifold, idle problems
- link for acura interga 91' service manual
- has any ever had problems with striped head bolts?
- Integra Highway Impressions
- ECU code 67?
- *****BRAND NEW TURBO PARTS FOR CHEAP!!*******
- 91' acura integra rocker arms.....fixed or no.......
- remote start
- helpppp me quick. im having alarm problems.
- Integra type-R shift boot question
- b18c with ctr
- What would you do next?? [CAR pics]
- HONDA CENTER CAP ?
- Need help installing a t3/t4 turbo...
- Fuel Pump Question...
- Cranking problems.
- antanna mast delete?
- Anyone know where the FUSES are for power seatbelts for G2's?
- Taillight Swap 94 to 99? Wait!! For a Sedan, not Hatch!!
- HELP ME PLEASE
- broke rear mount! What can i fill it with? Any other sugestions ? 96 LS
- Just purchased usdm integra type r exhaust with a type r cat. Can i use my gsr header?
- Sponsor'd yet?!
- kyb agx on a 92 gsr
- Steering wheel protectant?
- Apex'i RSM being WEIRD!!!!!!!
- need opinions from first hand experience
- AC problem. AC condensor Fuse keeps poping!! WTF SOO HOT NO AC!
- Changing my clutch tommorow, How much MTF do I need? WHat kind is the best? Also clutch fluid?
- Modacar STB
- running to lean setting engine light
- 01 gsr bogging , removed afc hack
- 98 ls brake bleeding
- Weird overheating issue - did a search and didn't find anything on my issue
- Integra Resistor Box With Turbo 92 Integra GSR?
- Does anyone have instructions on how to install a JDM ITR SRS wheel?
- Driveshaft / intermediate shaft problem
- this is a sick website for finding info on some parts.
- G'Damn drug addict sister-in-law stole my amp....
- DA shaking
- Looking for a first car.
- OBD2a and OBD2b difference?
- exhaust
- help please
- camber kit
- wierd noise from engine bay?
- My 'Killer Bee'
- Broken Fpr
- DA Side Marker template
- 92 gsr ys1 question
- Integra header - ITR vs. GSR question
- A/C & Power Steering Opinion
- Catalytic question
- Adjusting valves on 95 Integra LS Engine 1.8L
- B20... what to do.
- Pro's and cons about drilled/slotted rotors...
- My latest additions
- My G1 Teg
- Will this be a big problem or not???
- Passenger air bag help!
- audio and video questions? just ask im an installer
- Cryogenic System
- turbo gsr ?'s
- HASPORT hydro to cable problems
- SUSPENSION TOPIC - looking to buy, and need help!!!!!
- Corner light removal
- Which bolts for LCA replacement?
- New *94-97 Acura Integra Type R style Lips*
- Exhaust
- my brothers gsr got broken into. a few questions.
- 91 ls turbo help!
- RSM intsall on my p75 teg HELP
- How to test a/c compressor?
- sJust sold my 97 LS......now what to get???
- places to find integras
- WTB OBD 1 VTEC HARNESS
- how do i take the head off
- Covering up side moldings on dc body...?
- HELP!!!! #1 cylinder dead
- STRAIGHT PIPE
- good place to buy a short block?
- FS gsr head
- JDM swap
- Socal parts request...
- aebs?
- how much is a tranny swap???
- Front tag relocater
- M3 Mirrors with LED turn signal
- Got a turbo kit, what do I need next?
- clutchmaster/clutch slave
- supercharge or turbo
- Removing A/C from a 2000 GS-R
- cat back suggestions for '00 GSR
- More Torque/Top End??
- You can't make this stuff up.
- AC problem
- Clutchmasters flywheel friction surface
- Is this a good deal, 97gsr for 3200bucks
- need help installin a jdm itr climate control in a dc?
- weapon r's new SRI intake
- rear camber ??
- what's a good import magazine?
- ls/gs/rs
- blew oil pan today ls vtec need special oil pan?
- A new "green" addition to my car...
- p72 obd 1
- Anyone have Fidanza Axles?
- any of you guys have the factory installed integra alarm?
- RSR down springs, Should I Buy?
- need help on a 90 ls motor non-vtec
- ITB gains?
- No Vtec and No CEL
- stock idle level
- Tranny Problems
- Motor Help
- clutch/plate combo?
- CTR PISTONS...STREETABLE?
- 90' acura integra 1.8 DOHC non-vtec head questions.......please help!
- paint poll
- OT: shopping for used car in Ny/NJ: help
- GSR tranny with a Sticker that says S40 on it?
- Im an IDIOT! *car totalled?*
- Compression #'s on a B17a1 motor?
- HELP...car wont start and i cant figure out why
- VACUM LINES FOR TURBO
- Accord front end?
- AC Compressor problem.
- radio problems
- 3" del sol exhaust on an 2dr integra?
- Horn fuse blowing???
- warped rotors?
- BAR Certification?
- voltner goes crazy near battery
- type r strut bar
- Where to buy 50a fuse besides Honda?
- Squeaking sound coming from(under?) block at idle. Anyone know?
- integra dash lights....warranty?
- This might be a good deal!!!! No????
- quick question!
- HELP!!!! MY CAR WONT START.....
- Frankenstein- OBD2 head with an OBD1 Block?
- Friend's wife just offered to sell me her Integra, worth it?
- COLD AIR INTAKE
- clutch/shifting issues on a b17
- Draining the Coolant and more...
- Battery dead no clue why
- electrical problem
- Quick Driveterrain Question
- diff in struts?
- A/c
- CEL Code 21, Vtec Solenoid!! How can I fix it?
- AEBS IM Install need help ASAP
- Integra ECU guru's help needed: differences between obdII p72 ecus
- Supercharging my Integra!
- Help with my gsr brakes.....
- WHAT COLOR?
- Does a 89 Integra LS coupe have shocks or struts?
- shifter
- Oil in the spark plug wire hole.....what could that be?
- blower not working
- is 94 integra helms same as 91' when it comes to head service?
- Squeakying noise?
- when to change transmission oil
- JDM front turn signal lights for a DA 90-91
- VTEC TROUBLE
- MOMO Honda Integra Type R steering wheel on a G2
- Helms manual questions........
- any one have a stock throttle body from a acura integra or civic ex or any b16?
- DIY Apexi turbo timer w/o the harness.
- is this all that comes with a rear camberkit?
- honda guru's, what could be the problem w/ my car???
- 91' acura integra head questions.......PLEASE HELP!
- secondary intake runners
- starter help
- Wandering idle...revs up and down, up and down...???
- CV boots replacement (non split)
- Swap Help
- burning oil...
- Quick HELP, where is the teg with the M7's GOLD PLATED???
- Tire Noise
- what kind of valves??
- Transmission Noise
- stage 1 disc in a 4 puck pressure plate ...would there be a problem?????
- need to know the wires for cruise control??
- Runnin suuuuper duper rich
- LS\vtec
- LS dizzy work on GSR Head>>>>>>>>?????????? just cut that tab????
- ITR Springs on LS
- Link to classifieds, DC Integra Hatch F/S, no spoiler
- Getting Some Extra Kick From A b18b1
- a/c oil and freon question
- 99 Integra-> Hatch release doesn't work. Any Suggestions??
- Oil Control Orifice for B18A1
- EG SIDE SKIRTS ON DA??
- ABS light= no vtec???
- help needed
- integra oil change....
- Tempted to put H&R coilover springs on my generic sleeves, is this okay?
- 95 integra GS-R OBD-II what the hell
- Exedy stage 1 racing clutch
- where i can find a intake tube in 3inch for ls gsr?
- Gonna sell complete AC system off my gsr email if interested..
- exhaust gasketgasket
- HELP obd0 ecu code 1 short(pause)7 short DA running bad
- S2000 Antenna??
- Requesting higher spring rates/valving adjustment when buying TEIN SS's?
- Ls head gasket fit gsr?
- FS: OEM Integra sides skirts and rear sides
- Question on Salvaged title Integra...
- oil gone in 2 days?
- does anyone know were i can get a stock rear bumper for a 2dr 90 integra?
- O2 sensor
- A/C Compressor/Pulley/Pressure Plate problem... Searched. Opinions?
- Injectors and tuning!
- Camber Wear on DA
- quick dumb ? b17 dizzy
- can u make this work!?!?!
