View Full Version : Acura Integra
- Alignment Question
- a
- Squeek noise from clutch?
- 1st gear hand brake warning light came on..possible 01 integ problem?
- GSR's with ITR cams help me!
- Springs questions...Eibach & H&R
- Spoon Sports parts.
- CF HOOD ON SILVER
- Rocks?
- Autolock Pro.. Good investment?
- Putting back 99 GSR interior - Good shops in Phoenix?
- VAFC install on OBDII GSR -- what Sensor Number Setting?
- Almost Stolen!!!!!!
- Whistle noise at idle (intermidant)
- MY OWN CAI DESIGN "LOOK"!!!!
- JUST WONDERING
- Busted AEM CAI support bushing
- where to order K&N OEM replacement air filter?
- Does anyone know the best place around Richmond,VA to do JDM conversion?
- List Integra Aftermarket Spring Rates
- Camber kit vs. Alignment
- PLEASE HELP CAR KEEPS STALLING!
- Should I Dyno now?
- Need help installing Koni Yellows
- Skunk2 Exhaust
- Need help setting the timing on ITR camshafts
- stock spring rates
- What are a good choice for brake upgrades...going on 98 gsr with 16in wheels
- Cruise control problem, took to dealer and they never saw it happen... :(
- Weird noise coming from front rigth wheel....help.
- ping pong ball sound?
- Dyno feedback
- Whats the best fitting spark plug wires for my 94 gsr?
- will 99 gsr header bolt on to my 94 LS?
- emblems got stolen..how.....
- **** OTHER DRIVERS
- Anyone else think 1st gear sucks bad!!!!??
- gs-r and it-r flywheels
- Black Teg...Rota Circuit 8...silver or gunmetal?
- How safe is a CAI
- 14.2 type-R
- Injector Question
- exhaust question
- next mod, i know this is a repetitious question
- aftermarket steering wheel
- topend tuning of B18C OBDI
- Bad luck....GSR Stolen, Recovered.....Help me out
- parts catalog
- My speedo has changed
- ls/vtec not pulling hard enough
- car bobbles any ideas why
- Easy way to adjust valve clearance with adjustable cam gears?
- what are coilovers?
- Coilovers
- Good & inexpensive exhaust for G2 4dr teg?
- Any place in Houston area that fixes bent wheels?
- switches in console.
- R1 RACING Sports
- For those who want to replace their Greddy SP muffler with an ITR muffler:
- OBX Spec-R Coil Overs
- I need a hell of an ALL motor setup!
- Kinda after the fact..
- Jealous of the ITR Expo....
- will 205/45/16 inch tires effect speedo?
- What to get!!
- How is the Fields vtec-controller?
- 96 Integra LS for sale...
- Yokohama A460?
- need help with Tokico illumina shocks!
- Where is the best place to buy...
- Fuel Injector cleaning?
- Replacing radiator this weekend, and tips?
- Anyone ever deal with Radley Acura?
- How much is an almost brand new ITR throttle body worth?
- ATTENTION: ALL JDM TEGS!!
- turning an LS into a Vtec
- Lightweight flywheel vs stock dyno chart! Wow!
- ABS Unit leaking, help
- Phillips HID Group Buy participants...
- How long does stock battery last on your car ?
- 88 CRX control arm link on Integra?
- Battle Of The Imports@ Bakersfield
- Flex-A-lite Fan's on 2g Integra
- How Much?????
- Where can I get a THIN radiator fan? Also how to hook it up so it's on all the time?
- GSR Injectors....... how many CC??????
- KYB AGX vs. Bilstein
- Head porting/polish
- any good/cheap short shifters out there? what r their downsides?
- Is a metal or plastic radiator better?
- DC Sports question
- Valvoline Max Life anyone?
- Questions about Integra Factory Fog Lamps??
- $300 - What to get?
- Autometer A/F Gauge in 98 GSR
- $1500 for higher compression in LS.. WTF!
- just finished ITR shock/strut/LCA install..... aaaaaaaaaaaaaah
- Busted BOOt under my car
- Running lean.......what to do??
- Unorthodox crank pulley: Question about timing mark
- replacing spark plugs
- VAFC function questions
- got pics of Auto Power roll cage in tegs?
- will a 3 piece integra ls spoiler fit a civic?
- AEM Cold Air Intake
- JDM ITR 4-1 headers for $400 plus shipping...
- need GSR injector flow rate
- Free Horsepower '00 GSR
- My Quarter mile times!
- RS*R Exhaust Systems??????
- turbo on a GSR
- Suspension Question
- WHAT SHOULD I DO? I/H/E OR CLUTCH, FLYWHEEL AND AEM?
- Reactive Coilovers???
- 2nd try Need pics of 16's on an Integra (read before moving)
- Unorthodox Racing vs All
- Radiator Fan Problems
- I Need LsVtec Help!!!!
- Switching to Toda Spec C's, Type R valvesprings and portflow inners good enough?
- Brake Fluid
- Got a problem removing an axle... need suggestions.....
- Need Bay Area help: Can i hear ur Apexi N1 with a testpipe
- Quick Q: need the diameter of apexi n1 exhaust and greddy evo...thanks
- LS AUTOZZZ: list ur modssssss=)
- Will i Benefit changing the timing to 18 degrees on an LS?
- NEED TECH HELP PLEASE!
- Injen CAI probs?
- oil in coolant: need help!
- Eagle Eods
- HX wheels on a teg?
- a 1.5 inch drop
- give me your thoughts on this
- horror story...
- !!just got a 99 GSR..want to get some solid info before modifying...!!
- Steering Wheel hub?
- Dripping water on passenger side
- Type of spark plugs in 2nd Gen Teg???
- Good Deal?
- Gonna Have Extra Money, What to Get????????????help
- cold air
- EBP Integra
- How do you know if the pressure plate is not strong enough? Squealing?
- headers gasket wtf?
- Any help with mods?
- Does a Type-R clutch work in a LS?
- compression good enough for 5 psi turbo?
- Has anyone heard of corroded Honda cyl heads
- how to change ing. timing 18 deg.
- loud Camber Kits
- Car won't shift out of park!!!! Help please!
- Ticking noise
- Exhaust Install Question
- Check this out on eBay! What do you guys think...
- TURN Signal bulbs?
- Heard if i tighten my throttle cable i will get extra kick?? True or False?
- Who's Going to Sears Point on Wednesday
- where can i get a test pipe or straight pipe for a 98 gsr
- bird crap took off my paint
- Stupid clutch question...
- Not kidding..need help!! Throttle Cable/Throttle Rotor on Skunk2/GSR
- First Door Dent!!
- field boxer vtec controller vs apexi vtec controller
- SoCal Meet Pics
- Engine Rebuild
- Zex install help
- Anyway to buy just one brake line?
- WHEEL BEARINGS...OR SOMETHING...
- what motor oil should i use?
- Where can I find an intake manifold gasket for a 97 GSR?
- how to spot good used headers????......(headed to NOPI)
- Need help....uneven ride height....
- B18B1 pressure plate vs B18C5?
- B16A flywheel work on B18B1?
- Your opinion: should I paint this?
- horn contact for momo hubs
- Which tires? Nitto nt450's or Khumos
- AC diagrams please.
- Jdm ITR lip and Usdm 97 ITR lip
- HID LIGHTS!???
- do integras have speed limiters
- Cool It thermal wrap
- have a quesiton about stock intake for 94 gsr?
- How to MAKE clear corners?
- custom cai question
- wheel and tire setup
- Anyone know of a place to get a valve job in San Antonio?
- will 17 in rims slow me down? (performance question, do not move!)
- Phantom Grip LSD
- Greddy SP help.
- What to do with...
- 3G Radiator Question
- Fluidyne in GSR: Problem with fan--Need help
- New Piston Install
- Racingharts...
- Power Window Troubles
- Ground Controls with KYB AGX Question??
- Please help me on header install; please
- 4 piston caliper on 11" rotor update...
- PICs of 4dr GSR w/ exhaust
- HID group buy for a Phillips/Hella kit...
- EVERYBODY MUST READ ABOUT THIS EMAIL VIRUS
- Michelin XGT V4
- misplaced resonator
- How much will this cost me?
- question for tokiko illumina owners
- ITR pistons?
- what are ur opinions on the short ram intake?
- anyone riding on the orginal skunkwork coils?
- Del Sol PR3 Pistons in a B18C rebuild???
- is apex i digital vtec afc worth the money
- all LS owners please read
- Field vtec controller: reliable?
- Motor mount inserts (wow)
- good things come to those who wait
- Ultimate Tire Shoot out : Dry weather Performance
- ECU Pin Layout
- ARE THE 1995 5SPD ACCORD EX FAST
- Does anyone know of any gas stations that still sell 92 octane gas?
- clutch chatter
- link to C5 vs. GSR Turbo..
- how much more power with itr cams in a gsr?
- Comptech Ice box
- b type engines..
- Would this be a reliable good setup?
- knock sensor indicator light
- what type of shocks do most of you guys use...what gives the most bang for the buck
- HELP: How do you remove the fuel injector electrical connector from the injector?
- spark plug wear
- Which has the best balance of the big 3?
- DESPERATE FOR HELP HERE PLEASE ANYONE HELP ME
- Silly ? But which end of ARP stud goes into the block?
- Loose GSR steering
- headers for GSR
- Question about v-tech..also.....?
- Clutch????
- My Brakes
- Question about GSR suspension
- MUGEN JDM RSX TYPE-R!!! LOOK!!!!
- Paint stock side skirts
- DYI Icebox CAI
- what size tires are you running on stock gsr 15" rims?
- I need to transport two 9' surf boards on top of my Integra
- Why do rod bearings go bad at higher RPMs?
- Burnouts on slicks.
- Who has put in a motor+tranny in themselves before?
- I need help with my autometer air/fuel gauge
- problem with ground control coilovers
- buttonwillow
- high hc's. need help
- cleaning rims
