- difference? gsr crank type r crank?
- JDM headlight adjustable?
- code 43 fuel supply
- High idle and smoking distributor!!!???
- 90 integra b18a1 problem's bog
- snapped a belt... which one?
- main relay assey/ ecu fuse question
- Intake manifold
- window wiper switch question
- what bulbs in center console? and how many?
- Cooling fan and air vents stays on after car is off
- Cel 43 trouble shooting flow chart???
- jdm dc2 itr front end on da?
- Fuel Filter for 92 teg
- ls timeing belt on b16???
- Been a long while... which wires do i need to extend?obd1 rs harness/gsr swap
- LS Vtec/B20 Vtec OR GSR w/ all Type R Guts ??
- help asap!!!!!! :(
- hey its time to change bushings
- clutch engaging very early
- Overheat at idle but normal while driving?
- My brakes dont Work Anymore.
- water leak inside the car
- Need help with my1st gen B16 passing bar.
- REAR ENDED SOMEONE IN MY DA!
- ATTN: GSR owners w/ ABS!!
- ITR Cams on a GSR question
- fuel tank pressure sensor (ftp) sensor.. anybody know about this?????
- type r 01 w/CEL start sometimes, runs rough
- Help needed with JDM 98 spec motor vtec install
- bogging 92 gsr help!!
- Valve adjustment then Stalling/low idle
- Integra 2000 SRS Steering On 94-97 Integra
- exhaust gasket help!
- Am I missing some oil seals?
- Honda dealership can't get parts for Acura??
- Shift linkage rubber boot part number
- ECU Problem! Help Me! Help Me!
- about to get an exhaust
- HELP*****what cables will work for the jdm front conversion******HELP
- diy help...
- 4x114.3 conversion on my DC [QUESTION]
- Help... Exhaust System...!
- fan not coming on...
- problems with b18b
- 6mm pin punch to set timing on GSR?
- Broken ball joint
- this is a hard decision to make
- Engine Problems with my REX
- price fixing? need help!
- Acura INtegra Roof Spoiler? anyone have pix
- ALarm baics site i found, Team-integra memebers click***
- car wont start
- JDM front end
- Tranny question
- ecu question
- Windshields
- Camshaft dilemma
- pic request!
- CTR Shift BOOT ON DC2
- mishimoto radiator?
- B18c engine torque
- removing stock spoiler?
- no hazards or turns...
- Exhaust
- wtb valve cover
- HELP!!! car has issues and the Acura dealership gave up!!!!
- 1992 integra died on the street
- best performing and sounding exaughst for 01 gsr
- Starter/Battery short
- prevent theives from towing
- Need help...93 integra b18...auto to manual advise
- 94-97 foglight question
- this is for the retrofit club
- ls/vtec integra header?
- Help ITR lip install??
- 98spec jdm itr cluster into gsr
- HID Questions
- which is a better idea?
- Problems with passenger seat.
- need help using right head gasket
- Succesful ls/vtec conversion .....
- FS: GSR tranny
- exhaust
- DA integra Camber kits 90-93
- Rear Lip options?
- heat blower question
- the build questions
- da teg fuel pump problem NEED HELP!
- where can i find?
- Crankshaft pully install / torque
- Valve cover cut....
- B20 redline question.
- Painting itr front lip and sideskirts
- !!!I cant Roll Dumped Headers drag!!!
- s80 tranny question..
- where to buy OEM Optional Sides???
- lookin 4 gsr head
- Greddy SP2 Muffler
- Wierd car starting problem. Help asap.
- iacv wire question!!! HELP
- Type R rear calipers
- Where is the ABS computer? 92 GSR??
- 99 integra ls egr?
- Rhd wiring question
- da6 clutch
- To boost or not to boost?
- wiring and window issues.
- pistons ( all motor gsr )
- Whats it worth?
- What's unique about your 'TEG?
- transmission oil question?
- New Evap test for older cars, need help.
- Cable Clutch in 91 LS- Having problems - could be tranny. I need help!!
- help
- what is idle (noob at manual)
- Gauge Lights don't always come on.
- Engine Harness Question?
- 1992 Integra GSR not starting
- HELP!
- Idle Issues with my 98 gsr
- 4 lug itr rims where can i buy them!!!
- i dont understand
- added Sta-Bil now my teg wont start.
- so stoked
- jdm hid help please (pics inside)
- B17A1/B18A1....safe?
- gsr dizzy problems
- Carfax
- bad camber wear on a non lower integra.
- 1997 Acura Integra and 17" honda wheels
- ?? ebay ITR replica urethane lip fitment
- skunk2 IM making me lagg
- short shifter question
- 98-01 integra front bumper AFTERMARKET FITMENT
- anybody heard of this?
- rear tie bar
- noob
- ls vtec problem! 95 gsr
- honda gurus and electricians please help
- heater blower motor uninstall and instal
- clutch going soft
- JDM Wiring Question
- skunk2 4 u the best of the best out there
- Looking for OEM 89 integra front lip
- turn signal not working but the hazard is working just fine need help plz !!!
- --- front tie bar installation
- which tranny to get...
- How long do I have?
- b18c1
- lca, ball joint
- Down pipe/Exhaust to close to oil pan?
- wtf? car died on me
- "FLIP'S" 94 2 DR LS BUILD THREAD
- exhaust question
- SOLD!!!
- Vtec needed
- 15k to spend on 94 gsr
- axle nut???
- VAFC question prs? reading right
- New Greddy Header
- gsr shifter in da
- were can i get carbon lip, and are fender braces any good.
- Fender rub=tire shread
- helm manual
- Kill Switch?
- a question for those of you with shrrt shifters
- where can i find replacement gsr emblems?
- gsr b18c1 swap to a b18b1?
- First thing you did with car
- gas problem..
- tranny and clutch
- beginner with driving manual
- what else to buy with new clutch
- EK SIDE SKIRT ON DA INTEGRA????
- Greddy SP2 vs HKS Hi-Power Catback?
- Daily Driven Clutch Opinions
- I BROKE MY WINDOW!
- Twin loop on DA?
- Bleh, gauge cluster light....
- Good find?
- Unlock Steering Wheel?
- Heater Core ... HELP!
- Type R 98+ Lip Owners Chime In
- Head Bolt size search didn't find.
- Nardi steering wheel question??
- how to put dc2 integra dash gauges in a da9
- need opinions about internals
- my idle is messing up
- Blox Exhaust system??
- Tire pressure?!?
- all motor gsr
- 1994 GSR Master Cylinder Rebuild Kit
- well EF civic springs work on my DA?
- Help; Fuel Pump
- lower motor mounts
- A few questions... Wiring & Codes
- Strange Liquid Dripping from the bottom of my car
- thermal exhaust
- motor pwned or no?
- 3" intake piping
- LS Tranny on GSR, axles dont turn
- Gas Spilled everywhere!!
- pic request: stock gsr muffler :searched:
- first time / suspension mod
- DA integras MUDGUARDS/FLAPS
- How to install 94-97 OEM fogs? and how to remove front and rear bumper and tail lights?
- skunk2 IM idle problem
- Speedometer Cable?
- Tires//online purchases
- 1994 thunder gray tegs??
- clutch/flywheel bolt torque...
- brake light will not turn off
- SPP muffler LOSS of HP ???
- Catalytic Converter messed up took out o2 sensor how to fix it?
- Fan installation
- Rsx Oil Filter On GSR?
- hey
- OBDI B18b swap in a DA?? what all do i need for swap
- Is it a good idea for a f20b
- BEWARE
- show me your turbo setup
- p29/pm7 in 91 integra?
- d'z rimz
- Pulley Q's
- rack and pinion gurgaling (where to put fluid in?)
- Type R Intake Manifold
- How do i identify a type r head help
- Need advice on purchasing an Integra
- thank u.
- Tsudo N1 Catback
- Integra Catalytic Converter
- o2 sensor
- i need the underdash fuse box diagram
- Clutch Cable Problems!!!please help!
- 91 Integra DA with B16a. Speedo cable into guage cluster needed for vtec to work?????????
- DOHC VTEC
- HELP! obd1 to obd2?
- 91 DA horsepower question
- Take 2 minutes to help- What clutch?
- car down head hurt????
- JDM front couple questions on lighting.....
- noise when driving
- b18a1 torque specs
- 4-1 header opinions?
- ***JDM Front GSR STOLEN Hercules Area - BAY AREA
- i ju s purchased hondata s300
- 98-01 integra fog light install directions (anyone have a link?)
- DA SQUAD
- JDM Front end alignment
