View Full Version : Acura Integra
- Hood question
- turbo suggestions?
- Rear Spolier Caps
- Performer x and exhaust worth 20hp on b18c1?
- Keep Blowing 10A cluster/taillight fuse
- rear wiper delete plug for 94-01 integra
- Cat-back on my GS-R
- Noob Question(s).
- what stock injectors will fit my obd1 ls?
- K20 in 96 Tegy LS
- Reliable PLace?
- What Hondata program is right for me?
- Heater not warming up for a LONG time. *searched*
- whats up with my vents?
- s2k deck in 96 ls ?
- Help,What Do i Need?
- b16's future?
- da squad
- b18b cams into b18a
- Integra Pulls to the right hard.. Just had an alignment and still pulls to the right.. lol
- how much torque of pressure on rear strut bolts?
- exhaust question
- Honda Noob
- cigarette lighter doesn't work
- what size throttle body
- 88 integra b-series swap
- Coolant-radiator questions
- Comptech header too restrictive for new cams??
- weird rattle from ac vent?maybe?
- Suspension..
- Axle removal problem
- I'm Looking for 1994 Acura Integra obd1 wire harness
- da and ef shocks
- Steering wheel jerking to the right when I let off on the gas.
- Where can I go to get my GSR swirlies refinished........
- rack and pinion off EF, on a DA?
- 92 gsr wont start
- ***VIOLENT JERKS IN STEERING***
- New here: Where to search for a DB sedan?
- static in speakers with satellite radio
- how do you convert to power windows and doors?
- LS VTEC Computer problem
- 1991 DA
- Gs-r Intake manifold question, idle and runing problems expert help.
- Easy question I'm sure
- Can someone tell me if this is worth getting and if it will work?!?!
- Sometimes hard to get into 1st gear
- need help with winter tiers!
- clutch pedal clicking...slave/master cylinder gone bad?
- Are 98 jdm and usdm bumpers the same?
- Issues after installing new clutch
- Slave Cylinder Question
- High Flow Cat
- vtec
- fuel trim?
- evap problems
- B20B OIL PRESSURE SENDING UNIT
- Hey...I just need a little help...I did search...not much info
- DC2 Squad?
- Crush washer question
- tail light-instrument light and license plate light keeps going out.help.
- double din?
- P75 ecu
- who has benen products for my eg?
- need benen products
- autometer shift lite
- sawp help
- CALLING ALL KSPORT OWNERS
- Integra Oil Pan question!!
- Got smogged still need my registration tags
- How to tell if CABLE or HYDRO tranny.
- Acura Integra 1993 GS
- pcv valve location
- integra stolen need help figuring out what they took
- Engine swaps?
- hood pins
- bad clutch, bad tranny, or something else????
- What do you think my whp will be?
- car prob.
- Jerking/jolting steering wheel
- Need a favor.
- My first sports car: Integra Ls
- STUIPD IDLE DOESNT ADJUST HELP!!!!
- No Power and delayed Throttle Responce - NO CELs
- charcoal canister?
- SAFC in my DA?
- *** Dash Question ... Where does this plug go?!?!
- Stripped torx screw
- roda and pistons
- Hard to get into gear, and Clutch pedel return fees wierd, PLEASE HELP
- Integra is a curse in Canada...
- stolen integra: irvine, ca
- Rear Floor Bar install????
- throwing a code
- header question
- b17 with p72 ecu obd1, will it pass smog?
- fuel regulator or blox mani-maybe reason for weak b18c1 in da9?
- b18b in 91 integra
- Integra All Motor Quarter Mile Times
- No fuel to the motor
- MY SUPERCHARGED GSR
- Smog ??
- Question About GSR Motor
- Sea Foam
- JDM Foglight wiring
- ls transmission
- Help!!Fast PLEASE!! GSR HEAD
- 94-01 Integra Trunk Shocks
- Resolder rear ABS lines?
- 94 gsr suspension?
- rattle???
- check engine light is resetting by itself
- drivers side back window on da9
- Windows seal problems ?
- exhaust question
- Wire knock sensor to obd2a ecu
- PLZZZZZ HELP integra axel ?
- 93 integra alignment
- wierd vibration (lol)
- Shifter Problem
- California Turbo (ers)
- how much boost??
- brake pedal feedback and feel
- B20 oil pan question!
- help with YS1 tranny
- 94 integra wont start
- anti freeze level dropping
- gases automatically
- window issue.
- It's Cold N' i have no heat! please help
- car sounding like a Subie Idle Rumble
- I'm having problems with smog. I'm running too lean.
- water temp sensor
- vin on cluster?
- Bouncing? Idle, help :(
- chips
- question about greddy headers for 2000 LS
- Disable ABS??
- Ign Coil Fuse Keeps blowing!!--HELP!
- LSD tranny installed.....Question???
- Truely Bizarre No Start 98 In#4120tegra
- O2 Sensors
- !!!LS vtec???
- Oil Problem in my 98 teg
- Emergency Timing Belt Help: Tune in 2 days!
- Car fogging up
- ls vtec or gsr motor for turbo?
- DOES ANYBODY KNOW
- motor noise in my 92 gs-r integra
- --Power Window Problem--
- seized bolt in lca bushing
- Heat Problem
- wiring problem
- mugen twin loop and some other parts
- N/A builds vs. Forced induction...which is better?
- 90 integra Idle Air Control Valve Question
- Install CD player
- pics drop H&R sport springs
- Bogging issue...
- car wont start?
- 92/93 gs-r
- valve ticking
- is it my tranny???
- knock from front wheel
- B18 valve cover
- noob question
- new pics of my gs not an r
- were to find a cylinder head
- Ls tranny bolt size??
- rear type r sway bar best prices
- Help: 94 ls wont start!
- bad news
- good ass deal!!!! 95 GSR for 1750 OBO!!!! waaahhh
- Integra back from paint :D
- camshaft question...
- Need Some Advice
- Quick Q on Header.
- CTR wheel on integra....how?
- VIN LOCATION ON A 1995 INTEGRA
- my car
- where to go from here
- Sparks comming from battery
- 93 power steering removal
- Lookin to buy integra
- quick question about rear window brake lights.
- should i sell my car?
- my jdm front integra project....
- intake manifold
- some help with nitrous
- dc2 dash in da?
- need help with my future setup
- kill switch for 96 integ ls ?
- Whats the average mileage you guys have seen for 99 cars??
- what cams to get
- new to integras
- DA seat belt question
- supercharger from gsr to ls
- My trunk wont lock
- Ignition Switch
- MSD ignition in usefullness ?
- 1990 Integra ABS Nightmare!
- Cluster not working.
- B18b integra failed smog test please help
- 2ND GEAR NOISE...
- will need your advices about 95 LS
- are jdm and usdm trannies the same??
- dind me a LS for cheap!!!please
- MEASUREMENTS!!!
- 2000 integra question
- 4 Door 94-01 Integra vs. 4 Door 96-00 Civic <-- Which has more space?
- go 98 front end or keep the 95 front end
- abs fittings to MC...
- CEL 22, JDM B18C in ek
- civic to teggy exhaust
- Need to figure out what each wire on the moonroof switch are and do.help.
- Car shaking, what is the problem??
- first car
- Car wants to die out on cold starts
- 93 teg sensor question
- Drain tubes question?
- transmission problem.....help.!!
- Heater smells funny.
- inner tierod
- need a little help here.
- New to H-T. My 1997 LS/SE.
- two questions....please help
- Starter issue.
- Timing Belt Question
- da integra
- Need help ASAP!!!. Broke a Motor Mount Bolt
- 94+ service manual
- Whats the difference between USDM & JDM door panels?
- Hey yall, new here on HT. Some pix
- GREEN LUG NUTS/wheel locks for 99 integ
- Right Hand Drive Brake Lines
- catback exhaust
- B17 rebuild
- What Would Kill My MPG Drastically?
- Colder Spark Plug in a Bone Stock Teg
- Muffler question
- alternator??vid
- manifold question
- obd0 injector wire colors and order? ( color firing injectors wiring wireing wires obd 0 )
- baking the headlights
- DA Problem
- what yall think?
- Nothing to see here...
- integra 95 gsr abs questions need help ASAP
- White Smoke! HELP!
