View Full Version : Acura Integra
- 95 gsr with skunk 2 stage 2 cams problems
- Integra Doors
- frankenstein???
- right hand drive gear pattern?
- NJ OWNERS...PLEASE READ....IM IN DESPERATE NEED OF HELP!!!!!!
- taking off tags
- '95 Integra RS engine upgrade options?
- P28 chipped...? will it work with my motor..?
- a picture of my gsr.....
- upgrading brake system ...low funds whats the best option....?
- apex wsII universal or rs-r exmag exhast
- 125,000 = safe or not safe for turbo
- POST YOUR DA'S
- Help: Need Part # for Shock Tower Cover.
- how do you clean a cone k&n air filter
- Quick questions: USDM ITR Body Pieces
- OEM radiator cap poundage?
- Buddy Club Spec III Plus Camshafts
- cleaning hks mushroom foam filter?
- Lowering car
- Bags for Integra's??? (bags=slammed)
- Quality, cheap cat-back exhaust for 2G Integra
- HOW TO: Install 98-01 ITR Lip on 94-97 Bumper
- shocks??????? help
- Hey yall im new to HT... :)
- test-only will not accept my check light due to o2 sensor..help!
- B18c cam gear torque spec!!!???? please help
- HELP Blower wont turn on. Checked fuses and resistor and the blower what is the problem?
- wiring up jdm non hid turn signals. got the driver's side, passenger side is wack!
- Will GSR fuel rail fit on LS Manifold?
- Damaged intake manifold?
- Quick fuel pump question
- type r in a DA
- Weird Shift Linkage problem pics for help, searched, this one is weird.
- Mugen Twin loop exhaust?
- Help the dredded timming belt change.
- Integra c.d. player
- LS Exaust not rice!
- cam gears suggested adjustment, for best valve overlap
- Need Help with starting problem
- Integra LCA Bolt Part Number
- 1990 Integra intermittent power loss, shutoff when driving, etc.
- Help My Car Doesnt blow Air HOT OR COLD.
- suspension bolts
- <<Dizzy gurus please help me>> wiring ?
- Sparkplug wire recommendation
- H22 secondary runners
- Camber Kit Install and Price
- Fuel Injector Mechanical Question
- ECU on passenger side?
- installed my exhaust
- Legend horn in integra?
- KYB AGXERS ...stiffness settings
- Differences between 1995 GSR and the 1996 GSR?
- how do u convert obd-0 to obd-2?
- BUYING AN 01 GSR =]..... GO TURBO, N/A, OR SUPERCHARGER
- VORTECH SUPERCHARGER EG HATCH DX!!!!
- are cat's interchangable?
- need an opinion
- Would a faulty Main Relay do this?
- Can i use my comptech swaybar/tiebar combo from my gsr if i put on type r suspension with type r lca
- How to remove front H emblem off of jdm type r hood?
- what to get...
- How to make my 94 GSR look like a Type R ?
- b18c1 in 93 teg wiring...searched
- JDM Front Headlights Yellow (ILLEGAL??)
- Installed new Alpine Type-R interior speakers. Problem though?
- distributor?
- no fuel pump prime or starter, new main relay, few questions
- car club in MN?
- Question about using the clutch while driving.
- rebuilding the engine while it is still in the car
- looking for downpipe adaptor from greddy kit.....
- my new lip. (56k nothx)
- n e body try these radiator hoses?
- question on what parts to keep
- need help installing
- Dying Fuel Injectors
- need color code
- 86 Volvo turbo for my custom integra turbo kit.....?
- Help: Need new Throttle Angle Sensor
- Ok to wax cf hood?
- Which do you prefer? B18c tranny w/lsd to the B16a tranny w/lsd
- need flat aluminun tube for trunk brace
- B18b int mani and head swap
- DA help please
- crazy charging system
- building moter costs..
- Turbo DA's... lets see your setup!
- having trouble finding a part
- Did I sell my Integra for a good price?
- 96 GSR w/ 2000 ITR header..need help
- Blue Tokico Shocks & coilovers
- Weird Gauge Issues (B16 1991 DA)
- Lowered problems
- rear strut tower bar??
- clutch wont work on the ls vtec
- Panel fitment
- integra radiator question
- clutch trouble
- B18 gsr crank pulley bolt?....help
- dropped something into block! am I in trouble?!
- Which lip for 93 DA
- Adjusting Kickdown Cable on Auto Integras
- HELPED!! HELPED!! on my 1990 Integra LS!!!
- rs prop valve - hard lines
- trouble code 74 cylinder 4 misfire
- Buying a '94 Integra
- RADIATORS
- speaker conversion
- Quick tranny ?
- fitting 98 mugne abs lip to my 96 front end...will it work
- k20 swap in 94 integra
- Where can i buy a JDM ITR front end conversion kit?
- I have another coolant leak.... sigh..............
- K24a
- abs sensor wire broken...
- Are GS and LS Steering Racks Teh Same?
- Integra suspension question.
- quick motor help guys :D
- integra smoking.....need help....
- Having problems with my engine... help please......
- just like everyone else in need of a b18
- i was wondering if any1 knew the honda part number for the oem c/f integra type r drivers vent?
- i need some help fellas, when i start up my car it idles at 6K
- USDM p72 OBD1
- Rolling Fender
- Integra Part Questions
- Chassis Code
- 94 integra gsr?
- b18b cam question????
- looking for a SIR-G front lip. anybody know???
- Fuel Rail Question
- www.integraman.com
- built b16 on a DC2 Integra
- Cold Idle fine, warm cycles from 1k to 2k like clockwork
- AEBS Head Studs P/N?
- does anyone sell Azect side skirts for a 4door '94 teg?
- top hats....oval and circle
- DA valve cover bolts
- min/max compression numbers for an LS
- Black smoke when i rev my car :(
- 98-01 Bumper Cover Conversion ?
- Greddy Evo
- 94-97 OEM JDM SIR-G INTEGRA Foglights Fogs ?? Where to get them ??
- Is this a good price?
- Check Eng. vs. Maintenance Req. Light
- quick exhaust fitment question
- Cat delete
- Will the DC sports header 94-99 work on a 2001 Integra GSR
- Quick transmission question
- bigger fuel injectors
- NOOB pedal assembly ???
- Broken wheel studs!!!!!
- wat do ya think of her
- GSR with YS1 Tranny
- 2000 GSR w/97k Miles - Compression Result's
- tires???
- overbore ???
- what's stock horses to a B17 gs-r on a DA?
- Motor mounts inserts in a 96 integra install question
- Should I sell my 2000 GSR or should I keep it???
- Brand New OEM side skirts on ebay
- need help with connections
- ls special edition
- ABS Buzzing noise gotten alot worse then normal
- stock piping w/ magnaflow exhaust
- How Many Turns Lock to Lock?
- Trunk Sensor
- Exhaust fitment woes
- Honda's engines (high rev-ones) vs other low-reving engines
- New Honda Integra user
- Windows dont roll down or up, but I can hear the motor going
- New shoes for this slowmobile....
- Anyone have any horror stories from raising their stock rev limit on stock cams and valvetrain?
- quick question about h&r springs....which is which?
- 94 Integra GSR wont start - No Spark but fuel
- shaky speedo on 92 DA
- lightweight flywheel on freeway/5th gear
- Replica Rear Valences Fitment
- Do you guys know where I can get these?
- Installed H&R Standard Coilovers - is this correct? (pic)
- moderator pls help me out.
- new
- Need help! Please! Car is bogging!
- auto ls
- Is the JDM ITR front end conversion kit street legal in California?
- clutch choices
- vtec help
- I have an Idea I'm gonna run with, I need a parts list
- Anyone remember the booted wheel issue? this is my version... only it involves an axle and a hub
- ITB's
- bullshit or a good deal?
- Ls vtec is it worth it?
- I got a brake question
- site with all dynos
- question about recaro sliders
- intake manifold and idle???
- Pics and Info bouts a teg I might buy tomorrow...
- What kind of wheels are these??
- i need help with an automatic trans 90 integra
- Another thief bites the dust...in Vegas
- Get keys made?
- tokico illuminas or koni yellows for DA ?
- qRattling under the intake manifold.
- anybody with a dc2 2000 integra with edfc
- engine over-heating
- 95 teg WONT START! electrical.. please help!!
- Any one have a picture or can describe what the alternator bolt/nut or whatevver it is looks like???
- non vtec dc 4-1 header - need help
- LS Trany price + install
- I think my alternator is dead. Can you confirm with these symptoms?? HELP! Thanks!
- Differences with a GSR longblock and a regular GSR?
- password jdm drain plugs and other products????
- Best Cams for my Boosted Built B18A1? Crower, Crane...???
- Need suggestions!
- 94 gsr where do I fill up tranny fluid?
- Transmission mount cracked
- The Greater Bay Area...
- Caught GSR Theif
- Questions about conversions
- Keeping cruise control with an aftermarket steering wheel
- New guy. hello to anyone
- Recently replaced valve seals leaking again
- what to look out for on a DC2?
- What is wrong with my tranny...??
- I'm Building and Boosting a B18A1 Please Help
- What Size Slipstreams?
- ac tension pulley question
- Smog and reg. in 2 weeks need opinions!!!
- Questions About PassWordJDM CarbonFiber Intake System
- LS Tranny
- black leather integra seats, front and back for sale. pics inside
- Question about code on head and axle question
- kyb gr2 + neuspeed race
- adding power locking
- IS bumper on integra?
- looking for uberdata tuners
- k20a swap
- to turbo or not to turbo..
- B18B Turbo Problem for you Techs...
- question about OEM lugs...
- 2g motor question
- loud annoying noise
- horn not working
- S-AFC II knock settings
- Gauges?
- UKDM ITR Cluster - ABS Light Stays On
- gsr.. itr water pump, timing belt
- GSR tranny on LS motor
